Can't dowload ASAM using mobile application
Vasco Ferraz
Portugal
C?ID=288561
Hi :)
While trying to scan the following car using the mobile application, for the engine module, the ASAM download goes looping over and over.
Is there something that I am doing wrong?
Thursday,23,January,2020,21:28:39:51935
VCDS Version: 19.6.2.0 (x64)  HEX-NET CB: 0.4513.4
VIN: WVWZZZ7NZBV036446   License Plate: ZORBA
Mileage: 194080km-120595mi   Repair Order:
Chassis Type: 7N-VW36 (7N0)
Scan: 01 03 08 09 10 15 16 17 18 19 25 42 44 46 4F 52 53 56 61 62
          72 77
VIN: WVWZZZ7NZBV036446   Mileage: 194080km-120595miles
18-Aux. Heat -- Status: Malfunction 1010
   Part No SW: 03L 906 018 HH    HW: 03L 907 309 Q
   Component: R4 2.0l TDI   H24 9980
   Revision: 44H24---    Serial number:
   Coding: 0019003A042401080000
   Shop #: WSC 00077 261 00000
   ASAM Dataset: EV_ECM20TDI01103L906018HH 003015
   ROD: EV_ECM20TDI01103L906018F_VW36.rod
   VCID: 77BE380ECE079BF796-8022
4807 - EGR System
          P0401 00 [096] - Insufficient Flow
15733 - SCR NOx Catalyst Bank 1
          P20EE 00 [236] - Efficiency too Low
                    Mileage: 193839 km
                    Date: 2020.01.18
                    Time: 15:41:53
                    Engine speed: 2557.00 /min
                    Normed load value: 66.3 %
                    Vehicle speed: 117 km/h
                    Coolant temperature: 78 °C
                    Intake air temperature: 22 °C
                    Voltage terminal 30: 13.100 V
                    Long-term adaptation of reduction agent dosage: 1.00
                    Measured NOx conversion: 0.122
                    Calculated efficiency of NOx conversion: 0.854
                    Efficiency threshold of NOx conversion: 0.300
                    Current temperature in NOx reducing catalytic converter: 274.3 °C
Readiness: 1 1 0 0 0
Address 03: ABS Brakes        Labels: 7N0-614-109.clb
   Part No SW: 7N0 614 109 M    HW: 7N0 614 109 M
   Component: J104   C3 450M VD4F 0009
   Revision: --H07---    Serial number: 00000003999905
   Coding: 0019223
   Shop #: WSC 00020 790 00000
   VCID: 373EF80E46875BF756-8062
02214 - Tire Pressure Warning
                    Reset counter: 94
                    Mileage: 192744 km
                    Date: 2014.05.25
                    Time: 18:53:48
                    Speed: 136.0 km/h
                    Hex Value: 0x0001
                    Bin. Bits: 00000000 00000000
                    Voltage: 13.25 V
                    Bin. Bits: 00011111
                    Count: 185
                    Hex Value: 0x0000
   Part No SW: 5K0 907 044 F    HW: 5K0 907 044 F
   Component: Clima-Sharan  H11 0104
   Coding: 0000000109
   Shop #: WSC 00020 999 00000
   VCID: 2E10DD6A71DD9A3F05-807A
   Slave 1:
   Subsystem 1 - Part No SW: 7N0 907 049 B    HW: 7N0 907 049 B
   Component: KBT-H  004 0102
   Serial number: 20110330000000020558
   Part No SW: 5K0 937 086 J    HW: 5K0 937 086 J
   Component: BCM PQ35 M    011 0048
   Revision: BC011001
   Coding: 40180A3B8925F3C0400800C0100081E443011308424D29626480C72000C1
   VCID: 3B36E43EBAAF7F97B2-806E
   Subsystem 1 - Part No SW: 7N1 955 119 A    HW: 7N1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS    110402  31  0032
   Serial number:         110405042010
   Coding: 004DBD
   Subsystem 2 - Part No SW: 7N0 955 559     HW: 7N0 955 559   Labels: 7N0-955-559.CLB
   Component: RLFS  021 0022
   Serial number: Y11M03D29h05m23s03S1
   Coding: 4380BB
   Subsystem 3 - Part No: 7N0 951 171
   Component: DWA-Sensor 00  002 0205
   Component: LIN BACKUP HO  H11 9005
Address 10: Park/Steer Assist (J791)       Labels:| 3AA-919-475.clb
   Part No SW: 3AA 919 475 D    HW: 3AA 919 475 A
   Component: PARKHILFE PLA H04 0007
   Revision: --------    Serial number: 20401107400104
   Coding: 10820D
   ASAM Dataset: EV_EPHVA2C000000000 001006
   ROD: EV_EPHVA2C000000000_001_VW36.rod
   VCID: 3C34E722B7A178AFBB-8068
   Part No SW: 7N0 959 655 B    HW: 7N0 959 655 B
   Component: VW10Airbag015 H07 0013
   Serial number: 003GFP6CHW2%
   Coding: 003135
   ASAM Dataset: EV_AirbaVW10TS6VW428 A01002
   ROD: EV_AirbaVW10TS6VW428.rod
   VCID: 3E30ED2AA1BD6ABF95-806A
   Subsystem 1 - Part No SW: ---            HW: ---
   Component: S.Sens.Fahr.V  --- ---
   Serial number: 3493ETS60F089E3139D%
   Subsystem 2 - Part No SW: ---            HW: ---
   Component: S.Sens.Beif.V  --- ---
   Serial number: 3503ETS60E7CFC113DD7
   Subsystem 3 - Part No SW: ---            HW: ---
   Component: S.Sens.Fahr.H  --- ---
   Serial number: 3513ETS609D3EE4139D0
   Subsystem 4 - Part No SW: ---            HW: ---
   Component: S.Sens.Beif.H  --- ---
   Serial number: 3523ETS60CEB9C0139D2
   Subsystem 5 - Part No SW: ---            HW: ---
   Component: F.Sens.Fahr  --- ---
   Serial number: 35540TS60B35FB113DDR
   Part No SW: 5K0 953 501 BA    HW: 5K0 953 569 H
   Revision: FF010040    Serial number: 20110408201259
   Coding: 118A240000
   VCID: 6A98117A8DB5361F19-803E
   Coding: E20000
   Part No SW: 7N0 920 870 A    HW: 7N0 920 870 A
   Component: KOMBI         H20 0420
   Coding: 140F00
   VCID: 302CC3126BE98CCF17-8064
Address 18: Aux. Heat        Labels: 1K0-815-071.clb
   Part No: 7N0 963 271 C
   Component: Zuheizer        051 2730
   Revision: 00051000    Serial number: 09022126000000
   Coding: 0000041
   Shop #: WSC 11649 002 1048576
   VCID: 3424CF0257F1B0EF73-8060
01407 - Flame Extinguished
                    Reset counter: 147
                    Mileage: 97821 km
                    Date: 2011.05.22
                    Time: 07:38:12
                        Start
                    Temperature: 79.0°C
                    Temperature: 81.0°C
                    Voltage: 14.74 V
02251 - Heater Unit Locked
                    Reset counter: 107
   Part No SW: 7N0 907 530 D    HW: 1K0 907 951
   Component: J533  Gateway H35 0614
   Revision:   H35       Serial number: 060411F6000720
   Coding: 468002
   VCID: 312AC61668E385C718-8064
01207 - Control Module for Auxiliary Heater (J364)
                    Fault Status: 00110100
                    Reset counter: 92
                    Mileage: 192617 km
                    Date: 2014.05.25
                    Time: 08:04:23
   Component: IMMO          H20 0420
Address 42: Door Elect, Driver (J386)       Labels:. 7N0-959-793.clb
   Part No SW: 7N0 959 793 E    HW: 7N0 959 793 A
   Component: TSG FA        H04 0400
   Revision:             Serial number: 0000114322182
   Coding: 01110620D000411011
   VCID: 44C49FC2C751006FC3-8010
   Part No SW: 5N1 909 144 L    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.323 0802
   Revision: 1AH03729    Serial number: 00110770618001
   Coding: 0000258
   VCID: 3B36E43E7AAF7F97B2-806E
   Component: EZE_2         H35 0614
   Coding: 050B0500
   VCID: 6FAE006EBE57D3374E-803A
Address 52: Door Elect, Pass. (J387)       Labels:. 7N0-959-792.clb
   Part No SW: 7N0 959 792 E    HW: 7N0 959 792 A
   Component: TSG BF        H04 0400
   Revision:             Serial number: 0000114406021
   Coding: 01110620DE00411011
   VCID: 43C69CDEC25F0757FA-8016
   Part No SW: 3AA 907 801 E    HW: 3AA 907 801 E
   Component: J540 EPB4  VW-55183 0007
   Revision:   H18       Serial number: 00000000273769
   Coding: 0024066
   VCID: 3326CC1E52FFB7D76A-8066
                    Fault Status: 00101101
                    Reset counter: 115
                    Mileage: 189801 km
                    Date: 2014.04.26
                    Time: 18:16:55
                    Voltage: 9.60 V
                    Count: 69
                    Hex Value: 0x1263
                    Hex Value: 0x0001
                    Hex Value: 0x1010
   Part No SW: 3C8 035 195     HW: 3C8 035 195
   Component: RCD510        H16 5026
   Revision: -----13S    Serial number: VWZ4Z3L1128287
   Coding: 0500040004
   VCID: 658262466CAB196734-8030
03138 - Input AUX IN
                    Reset counter: 134
                    Mileage: 113604 km
                    Date: 2011.10.30
                    Time: 16:15:40
   Component: Batt.regelung H35 0614
   Coding: 030B185A
   VCID: 71AA0616A863C5C758-8024
   Subsystem 1 - Part No SW: 1K0 915 181 F    HW: 1K0 915 181 A
   Component: J367-BDM  H07 0150
   Serial number: 00000000009370192536
Address 62: Door, Rear Left (J388)       Labels:. 7N0-959-794.clb
   Part No SW: 7N0 959 794 E    HW: 7N0 959 795 A
   Component: TSG HL        H03 0400
   Revision:             Serial number: 0000114530655
   Coding: 010004200000411001
   VCID: 45C282C6CC6B3967D4-8010
Address 72: Door, Rear Right (J389)       Labels:. 7N0-959-794.clb
   Component: TSG HR        H03 0400
   Revision:             Serial number: 0000113407667
   Part No SW: 5N0 035 730 D    HW: 5N0 035 730 D
   Component: Telefon       009 0511
   Revision: --------    Serial number: 35909603136987
   Coding: 020000000100100000010000
   ASAM Dataset: EV_UHVPremi A01005
   ROD: EV_UHVPremi_A01.rod
   VCID: 291A2E764833FD07D0-807C
13893888 - Function Restricted due to Excessive Voltage
          U1401 00 [008] - -
                    Fault Frequency: 10
                    Reset counter: 109
                    Mileage: 192924 km
                    Date: 2020.01.06
                    Time: 08:16:29
End----(Elapsed Time: 01:53, VBatt start/end: 12.1V/11.9V. VIgn 11.9V)-----
Address 01: DTCs cleared
What happens when you use VCIConfig to try to update your HEX-NET?
Vasco Ferraz
Portugal
C?ID=288561
Hi Uwe,
Says it is updated.
Hawkeye9723
C?ID=389466
I had a similar issue with my HEX-NET using the web based client. I had to switch it to get the BETA updates and then update it through the Windows client. Hope this helps.
Vasco Ferraz
Portugal
C?ID=288561
OK, but are you still missing ROD files?
VCIConfig says that RODs are up to date.
Should I change the channel to beta?
Thanks.
So what happens when you do a scan with VCDS-Mobile?
I think you are already on Beta. If you continue to have problems with this, I would be more inclined to [Clear Dataset Cache] and [Clear ROD Files] (in VCDS-Mobile, [Options] and start over with a fresh/clean set of files.
