Results 1 to 7 of 7
Thread: Can't dowload ASAM using mobile application
    Verified VCDS User Vasco Ferraz's Avatar
    Jan 2017
    Portugal
    Hi
    While trying to scan the following car using the mobile application, for the engine module, the ASAM download goes looping over and over.
    Is there something that I am doing wrong?
    Thursday,23,January,2020,21:28:39:51935
    VCDS Version: 19.6.2.0 (x64)  HEX-NET CB: 0.4513.4
    VIN: WVWZZZ7NZBV036446   License Plate: ZORBA
    Mileage: 194080km-120595mi   Repair Order:
    Chassis Type: 7N-VW36 (7N0)
    Scan: 01 03 08 09 10 15 16 17 18 19 25 42 44 46 4F 52 53 56 61 62
              72 77
    VIN: WVWZZZ7NZBV036446   Mileage: 194080km-120595miles
    18-Aux. Heat -- Status: Malfunction 1010
       Part No SW: 03L 906 018 HH    HW: 03L 907 309 Q
       Component: R4 2.0l TDI   H24 9980
       Revision: 44H24---    Serial number:
       Coding: 0019003A042401080000
       Shop #: WSC 00077 261 00000
       ASAM Dataset: EV_ECM20TDI01103L906018HH 003015
       ROD: EV_ECM20TDI01103L906018F_VW36.rod
       VCID: 77BE380ECE079BF796-8022
    4807 - EGR System
              P0401 00 [096] - Insufficient Flow
    15733 - SCR NOx Catalyst Bank 1
              P20EE 00 [236] - Efficiency too Low
                        Mileage: 193839 km
                        Date: 2020.01.18
                        Time: 15:41:53
                        Engine speed: 2557.00 /min
                        Normed load value: 66.3 %
                        Vehicle speed: 117 km/h
                        Coolant temperature: 78 °C
                        Intake air temperature: 22 °C
                        Voltage terminal 30: 13.100 V
                        Long-term adaptation of reduction agent dosage: 1.00
                        Measured NOx conversion: 0.122
                        Calculated efficiency of NOx conversion: 0.854
                        Efficiency threshold of NOx conversion: 0.300
                        Current temperature in NOx reducing catalytic converter: 274.3 °C
    Readiness: 1 1 0 0 0
    Address 03: ABS Brakes        Labels: 7N0-614-109.clb
       Part No SW: 7N0 614 109 M    HW: 7N0 614 109 M
       Component: J104   C3 450M VD4F 0009
       Revision: --H07---    Serial number: 00000003999905
       Coding: 0019223
       Shop #: WSC 00020 790 00000
       VCID: 373EF80E46875BF756-8062
    02214 - Tire Pressure Warning
                        Reset counter: 94
                        Mileage: 192744 km
                        Date: 2014.05.25
                        Time: 18:53:48
                        Speed: 136.0 km/h
                        Hex Value: 0x0001
                        Bin. Bits: 00000000 00000000
                        Voltage: 13.25 V
                        Bin. Bits: 00011111
                        Count: 185
                        Hex Value: 0x0000
       Part No SW: 5K0 907 044 F    HW: 5K0 907 044 F
       Component: Clima-Sharan  H11 0104
       Coding: 0000000109
       Shop #: WSC 00020 999 00000
       VCID: 2E10DD6A71DD9A3F05-807A
       Slave 1:
       Subsystem 1 - Part No SW: 7N0 907 049 B    HW: 7N0 907 049 B
       Component: KBT-H  004 0102
       Serial number: 20110330000000020558
       Part No SW: 5K0 937 086 J    HW: 5K0 937 086 J
       Component: BCM PQ35 M    011 0048
       Revision: BC011001
       Coding: 40180A3B8925F3C0400800C0100081E443011308424D29626480C72000C1
       VCID: 3B36E43EBAAF7F97B2-806E
       Subsystem 1 - Part No SW: 7N1 955 119 A    HW: 7N1 955 119   Labels: 1KX-955-119.CLB
       Component: WWS    110402  31  0032
       Serial number:         110405042010
       Coding: 004DBD
       Subsystem 2 - Part No SW: 7N0 955 559     HW: 7N0 955 559   Labels: 7N0-955-559.CLB
       Component: RLFS  021 0022
       Serial number: Y11M03D29h05m23s03S1
       Coding: 4380BB
       Subsystem 3 - Part No: 7N0 951 171
       Component: DWA-Sensor 00  002 0205
       Subsystem 4 - Part No: 1K8 951 605 B
       Component: LIN BACKUP HO  H11 9005
    Address 10: Park/Steer Assist (J791)       Labels:| 3AA-919-475.clb
       Part No SW: 3AA 919 475 D    HW: 3AA 919 475 A
       Component: PARKHILFE PLA H04 0007
       Revision: --------    Serial number: 20401107400104
       Coding: 10820D
       ASAM Dataset: EV_EPHVA2C000000000 001006
       ROD: EV_EPHVA2C000000000_001_VW36.rod
       VCID: 3C34E722B7A178AFBB-8068
       Part No SW: 7N0 959 655 B    HW: 7N0 959 655 B
       Component: VW10Airbag015 H07 0013
       Serial number: 003GFP6CHW2%
       Coding: 003135
       ASAM Dataset: EV_AirbaVW10TS6VW428 A01002
       ROD: EV_AirbaVW10TS6VW428.rod
       VCID: 3E30ED2AA1BD6ABF95-806A
       Subsystem 1 - Part No SW: ---            HW: ---
       Component: S.Sens.Fahr.V  --- ---
       Serial number: 3493ETS60F089E3139D%
       Subsystem 2 - Part No SW: ---            HW: ---
       Component: S.Sens.Beif.V  --- ---
       Serial number: 3503ETS60E7CFC113DD7
       Subsystem 3 - Part No SW: ---            HW: ---
       Component: S.Sens.Fahr.H  --- ---
       Serial number: 3513ETS609D3EE4139D0
       Subsystem 4 - Part No SW: ---            HW: ---
       Component: S.Sens.Beif.H  --- ---
       Serial number: 3523ETS60CEB9C0139D2
       Subsystem 5 - Part No SW: ---            HW: ---
       Component: F.Sens.Fahr  --- ---
       Serial number: 35540TS60B35FB113DDR
       Part No SW: 5K0 953 501 BA    HW: 5K0 953 569 H
       Revision: FF010040    Serial number: 20110408201259
       Coding: 118A240000
       VCID: 6A98117A8DB5361F19-803E
       Coding: E20000
       Part No SW: 7N0 920 870 A    HW: 7N0 920 870 A
       Coding: 140F00
       VCID: 302CC3126BE98CCF17-8064
    Address 18: Aux. Heat        Labels: 1K0-815-071.clb
       Part No: 7N0 963 271 C
       Component: Zuheizer        051 2730
       Revision: 00051000    Serial number: 09022126000000
       Coding: 0000041
       Shop #: WSC 11649 002 1048576
       VCID: 3424CF0257F1B0EF73-8060
    01407 - Flame Extinguished
                        Fault Frequency: 6
                        Reset counter: 147
                        Mileage: 97821 km
                        Date: 2011.05.22
                        Time: 07:38:12
                            Start
                        Temperature: 79.0°C
                        Temperature: 81.0°C
                        Voltage: 14.74 V
    02251 - Heater Unit Locked
                        Reset counter: 107
       Part No SW: 7N0 907 530 D    HW: 1K0 907 951
       Component: J533  Gateway H35 0614
       Revision:   H35       Serial number: 060411F6000720
       Coding: 468002
       VCID: 312AC61668E385C718-8064
                        Fault Status: 00110100
                        Reset counter: 92
                        Mileage: 192617 km
                        Date: 2014.05.25
                        Time: 08:04:23
       Part No SW: 7N0 959 793 E    HW: 7N0 959 793 A
       Component: TSG FA        H04 0400
       Revision:             Serial number: 0000114322182
       Coding: 01110620D000411011
       VCID: 44C49FC2C751006FC3-8010
       Part No SW: 5N1 909 144 L    HW: 5N1 909 148 G
       Component: J500__APA-BS KL.323 0802
       Revision: 1AH03729    Serial number: 00110770618001
       Coding: 0000258
       VCID: 3B36E43E7AAF7F97B2-806E
       Component: EZE_2         H35 0614
       Coding: 050B0500
       VCID: 6FAE006EBE57D3374E-803A
       Subsystem 1 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
       Component: J245EE20SKB13  H02 0220
       Component: J394EE20SKB13  H02 0220
       Part No SW: 7N0 959 792 E    HW: 7N0 959 792 A
       Component: TSG BF        H04 0400
       Revision:             Serial number: 0000114406021
       Coding: 01110620DE00411011
       VCID: 43C69CDEC25F0757FA-8016
       Part No SW: 3AA 907 801 E    HW: 3AA 907 801 E
       Component: J540 EPB4  VW-55183 0007
       Revision:   H18       Serial number: 00000000273769
       Coding: 0024066
       VCID: 3326CC1E52FFB7D76A-8066
    01316 - ABS Control Module
                        Fault Status: 00101101
                        Fault Frequency: 8
                        Reset counter: 115
                        Mileage: 189801 km
                        Date: 2014.04.26
                        Time: 18:16:55
                        Voltage: 9.60 V
                        Count: 69
                        Hex Value: 0x1263
                        Hex Value: 0x0001
                        Hex Value: 0x1010
       Part No SW: 3C8 035 195     HW: 3C8 035 195
       Component: RCD510        H16 5026
       Revision: -----13S    Serial number: VWZ4Z3L1128287
       Coding: 0500040004
       VCID: 658262466CAB196734-8030
    03138 - Input AUX IN
                        Fault Status: 01101011
                        Reset counter: 134
                        Mileage: 113604 km
                        Date: 2011.10.30
                        Time: 16:15:40
       Component: Batt.regelung H35 0614
       Coding: 030B185A
       VCID: 71AA0616A863C5C758-8024
       Subsystem 1 - Part No SW: 1K0 915 181 F    HW: 1K0 915 181 A
       Component: J367-BDM  H07 0150
       Serial number: 00000000009370192536
    Address 62: Door, Rear Left (J388)       Labels:. 7N0-959-794.clb
       Part No SW: 7N0 959 794 E    HW: 7N0 959 795 A
       Component: TSG HL        H03 0400
       Revision:             Serial number: 0000114530655
       Coding: 010004200000411001
       VCID: 45C282C6CC6B3967D4-8010
    Address 72: Door, Rear Right (J389)       Labels:. 7N0-959-794.clb
       Component: TSG HR        H03 0400
       Revision:             Serial number: 0000113407667
    Address 77: Telephone (J412)       Labels:| 3C8-035-730-A.clb
       Part No SW: 5N0 035 730 D    HW: 5N0 035 730 D
       Component: Telefon       009 0511
       Revision: --------    Serial number: 35909603136987
       Coding: 020000000100100000010000
       ASAM Dataset: EV_UHVPremi A01005
       ROD: EV_UHVPremi_A01.rod
       VCID: 291A2E764833FD07D0-807C
    13893888 - Function Restricted due to Excessive Voltage
              U1401 00 [008] - -
                        Fault Frequency: 10
                        Reset counter: 109
                        Mileage: 192924 km
                        Date: 2020.01.06
                        Time: 08:16:29
    End----(Elapsed Time: 01:53, VBatt start/end: 12.1V/11.9V. VIgn 11.9V)-----
    Address 01: DTCs cleared
    Thanks
    Vasco Ferraz
    What happens when you use VCIConfig to try to update your HEX-NET?
    Jan 2017
    Portugal
    Hi Uwe,
    Says it is updated.
    Vasco Ferraz
    Dec 2019
    I had a similar issue with my HEX-NET using the web based client. I had to switch it to get the BETA updates and then update it through the Windows client. Hope this helps.
    Quote Originally Posted by Vasco Ferraz View Post
    Says it is updated.
    OK, but are you still missing ROD files?
  6. #6
    Jan 2017
    Portugal
    VCIConfig says that RODs are up to date.
    Should I change the channel to beta?
    Thanks.
    Vasco Ferraz
  7. #7
    So what happens when you do a scan with VCDS-Mobile?
    I think you are already on Beta. If you continue to have problems with this, I would be more inclined to [Clear Dataset Cache] and [Clear ROD Files] (in VCDS-Mobile, [Options] and start over with a fresh/clean set of files.
  8. Likes Boki Ar liked this post
