Results 1 to 6 of 6
Thread: 2007 jetta 2.5 mk5- car runs fine but fault codes on dash
    Nov 2019
    Canada
    initial problem 500ma parasitic drain.
    ran scan and had 5 fault codes but car ran fine. no lights on dash
    checked all fuses. 500ma draw on lower engine fuse block. wire headiing to firewall and dash
    decided to disconnect radio and instrument panel lit up with faults. epc abs, brake lining low, check engine
    changed the gateway model and programmed ( used part) and parasitic draw fixed. still have faults and codes
    old gatwey 1ko907530k new gateway 1ko 907 530 k
    check can bus voltages and resistance=60ohms i dont have a scope. i suspect that might be the next logical step?
    Friday,24,January,2020,14:12:10:43666
    VIN: 3VWRF31K67M191614   License Plate:
    Chassis Type: 1K (1K0)
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 62 72
    VIN: 3VWRF31K67M191614   Mileage: 62540km-38860miles
    03-ABS Brakes -- Status: Cannot be reached 1100
    Address 01: Engine        Labels: 06A-906-032-BGP.lbl
       Part No SW: 07K 906 032 S    HW: 07K 906 032 Q
       Component: 2.5l R5/4V      G   9652
       Revision: --H01---    Serial number: VWZ7Z0G9087339
       Coding: 0000003
       VCID: 392F2A62A5533BEFCE9-806C
    049441 - No Communication with ABS Brake Control Module
                   U0121 - 008 -
                        Mileage: 62547 km
                        Time: 00:26:07
                        Temperature: 93.0°C
                        Temperature: 46.0°C
                        Absolute Pres.: 1010.0 mbar
                        Voltage: 11.938 V
                   U0121 - 008 -
                        Mileage: 62547 km
                        Time: 00:26:07
                        Temperature: 93.0°C
                        Temperature: 46.0°C
                        Voltage: 11.938 V
                   U0121 - 008 -
                        Mileage: 62547 km
                        Time: 00:26:07
                        Temperature: 93.0°C
                        Temperature: 46.0°C
                        Voltage: 11.938 V
    000264 - Manifold / Barometric Pressure Sensor (G71) / (F96)
                   P0108 - 001 - Signal too High - Intermittent
                        Fault Status: 00100001
                        Mileage: 62547 km
                        Time: 00:26:07
                        Temperature: 93.0°C
                        Temperature: 46.0°C
                        Voltage: 11.811 V
    008825 - Leak in Air Intake System
                   P2279 - 008 -
                        Mileage: 62547 km
                        Time: 00:27:39
                        RPM: 694 /min
                        Load: 21.2 %
                        Temperature: 86.0°C
                        Temperature: 49.0°C
                        Voltage: 13.716 V
    Readiness: 0110 1101
       Part No SW: 09G 927 750 FL    HW: 09G 927 750 FL
       Component: AQ 250 6F           0920
       Revision: 00H69000    Serial number:
       Coding: 0000072
       VCID: 005987868609AA27C97-8054
    Address 03: ABS Brakes
       Part No SW: 1K0 820 047 FT    HW: 1K0 820 047 FT
       Component: Climatic PQ35   141 0909
       Revision: 00141027    Serial number: 00000000000000
       VCID: 7BA3F06AEFEFC9FF9C5-802E
    Address 09: Cent. Elect.        Labels:. 3C0-937-049-23-M.lbl
       Part No SW: 3C0 937 049 AD    HW: 3C0 937 049 AD
       Component: Bordnetz-SG     H52 2002
       Revision: 00H52000    Serial number: 00000000635216
       Coding: 10050E234004150007140000001400000008730B5C0000
       VCID: 6B83C02A9F8F597F0C5-803E
       Component: Wischer 050607 020  0501
       Coding: 00038805
       Component: 6E AIRBAG VW8R  034 8000
       Revision: 05034000    Serial number: 003B6M020SRD
       Coding: 0013893
       VCID: 6C81C3369A815E4705F-8038
       Subsystem 1 - Serial number: 6332MSME13070664+
       Subsystem 2 - Serial number: 6342MSME187A4216B
       Subsystem 3 - Serial number: 6351HSME0D38737DL
       Subsystem 4 - Serial number: 6361HSME0D2C0D6DR
       Subsystem 5 - Serial number: 63727SME0D0D625A9
       Subsystem 6 - Serial number: 63827SME0C744123.
       Part No SW: 1K0 953 549 AP    HW: 1K0 953 549 AP
       Component: Lenksäulenmodul 036 0070
       Coding: 0010021
       Part No SW: 1K0 920 853 T    HW: 1K0 920 853 T
       Component: KOMBIINSTRUMENT 3HL 1610
       Revision: V0003000    Serial number: VWZ7Z0G9087339
       Coding: 0023307
       Shop #: WSC 00066 067 57207
       VCID: 3B23306AAF6F09FFDC5-806E
                        Reset counter: 89
                        Mileage: 62547 km
                        Time: 00:27:54
       Component: J533  Gateway   H07 0052
       Revision:   H07 01    Serial number: 171007F1001182
       Coding: ED807F060000021002
       Shop #: WSC 00066 123 12345
       VCID: 303917467629FAA7797-8064
                        Reset counter: 89
                        Mileage: 62547 km
                        Time: 00:27:55
       Component: IMMO            3HL 1610
       Component: J386  TUER-SG FT    1133
       Revision: 32008001    Serial number: 00000005478512
       Coding: 0001205
       Part No: 1K1 909 144 L
       Component: EPS_ZFLS Kl.069 H07 1806
       VCID: 34311B568231C6871DF-8060
    00625 - Vehicle Speed Signal
                        Mileage: 62540 km
                        Temperature: 31.0°C
                        Voltage: 13.90 V
                        Voltage: 13.70 V
       Part No SW: 1K0 959 433 CA    HW: 1K0 959 433 CA
       Coding: 13900F880106281B0904058FB0880F0488FCA0
       VCID: 71BFD242BDA3B3AF369-8024
                        Reset counter: 89
                        Mileage: 62547 km
                        Time: 00:27:54
       Part No SW: 1K0 959 702 P    HW: 1K0 959 792 L
       Component: J387  TUER-SG BT    1133
       Revision: 32008001    Serial number: 00000114778518
       Coding: 0001204
       VCID: 3C213376AA610EC7D5F-8068
       Part No SW: 1K0 959 703 Q    HW: 1K0 959 795 J
       Component: J388   TUER-SG HL   1120
       Revision: 12006001    Serial number: 00000001592277
       Coding: 0001168
       VCID: 3E25397EBC7D1CD7FBB-806A
       Part No SW: 1K0 959 704 Q    HW: 1K0 959 794 J
       Component: J389   TUER-SG HR   1120
       Revision: 12006001    Serial number: 00000001626972
       Coding: 0001168
       VCID: 3FDB447ABB7715DFF0D-806A
    End----------(Elapsed Time: 01:10, VBatt start/end: 13.9V/13.9V)-----------
    Clearly the ABS module is off-line in that scan. That's likely the source of your various warning lights.
    Nov 2019
    Canada
    thanks for pointing that out Ewe
    I see that now that I look at the scan
    will report results later
  4. Likes PetrolDave liked this post
    Quote Originally Posted by dand View Post
    -Uwe- <- Starts with a 'U' as in "Uniform".
    Nov 2019
    Canada
    sorry UWE for the mispell
    I connected a pico scope to can-hi and can-lo. turned key to on. noticed both channels at 2.5 volts flat lining with a little noise spikes. can see any data being transmitted
    I placed channel a on auto v/div and saw some square wave packets being transmitted. I think the voltage is being attenuated. really confused
    I sourced a used abs module complete with pump and valve assembly . exact same part no. 1ko 907 379ac c0ding on old module 0021122
    I was thinking just to connect it electrically and see if I can establish communication without hooking up brake lines. is this a good logical step ?
    Nov 2019
    Canada
    I installed a used abs module but only electrically
    still no communication with module
    checked for powers and grounds . missing 12v reference on one of the pins. Traced it back to a misplaced fuse
    hadn't realized there are three 12v powers to module. 2 from fused and 1 controlled from ecm
    thanks for your help
  8. Likes Uwe, Jack@European_Parts liked this post
