Results 1 to 3 of 3
Thread: 2005 4F A6 Electrical issues
    Jan 2020
    Australia
    Hi guys, first time poster.
    So our workshop loan car is an 05 Audi A6 2.4 it has a load of dtcs in it which don't seem to effect the way the car drives,
    it just has a heap of warning lights appear at random whist driving, usually bulb warning messages.
    we are thinking it may be a faulty module, but being in Australia it's difficult to get factory information.
    wondering if anyone could steer me in the right direction.
    Cheers,
    Brad.
    Tuesday,28,January,2020,08:16:16:24635
    VCDS Version: 19.6.2.0 (x64)
    VIN: WAUZZZ4F96N025813   License Plate: S384ASG
    Mileage: 171400km-106503mi   Repair Order:
    Chassis Type: 4F (4F0)
    Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 42 46 47 4F 52 53 56 61
              62 72 76
    VIN: WAUZZZ4F96N025813   Mileage: 171400km-106503miles
    62-Door, Rear Left -- Status: Malfunction 1010
    72-Door, Rear Right -- Status: Malfunction 1010
    Address 01: Engine (BDW)       Labels:. 06E-910-552-BDW.clb
       Part No SW: 4F0 910 552 R    HW: 4F0 907 552 D
       Component: 2.4l V6 MPI         0010
       Revision: --H17---    Serial number:
       Coding: 0105000302070120
       Shop #: WSC 02325 785 00200
       VCID: 3261F0F2AD4F5ADF61-8066
    005137 - Secondary Air Injection System; Bank 2
                   P1411 - 007 - Insufficient Flow - Intermittent
                        Fault Status: 00000010
                        Reset counter: 35
                        Mileage: 171229 km
                        Date: 2019.10.18
                        Time: 09:17:48
                        Mass Air / Rev.: 0.0 mg/str
                        Temperature: 33.0°C
                            Engine Off
                        Load: 0.0 %
    005686 - Powertrain Data Bus
                   P1636 - 009 - Missing Message from Airbag Controller - Intermittent
                        Fault Status: 00000100
                        Reset counter: 11
                        Mileage: 171259 km
                        Date: 2019.10.21
                        Time: 08:22:00
                        Temperature: 91.5°C
                            Engine Off
                        Voltage: 12.04 V
                   P1653 - 008 -  - Intermittent
                        Fault Frequency: 6
                        Reset counter: 14
                        Mileage: 171263 km
                        Date: 2005.02.01
                        Time: 12:00:31
                        RPM: 1024 /min
                        Mass Air / Rev.: 174.4 mg/str
                        Temperature: 25.5°C
                            Idle
                        Load: 32.5 %
    Readiness: 0010 0001
    Address 02: Auto Trans        Labels: 01J-927-156.lbl
       Part No SW: 4F1 910 155 F    HW: 01J 927 156 JG
       Component: V30 01J 2.4l 4V RdW 0030
       Revision: --H01---    Serial number: 00000000000041
       Coding: 0000001
       Shop #: WSC 02327 785 00200
       VCID: 26491CA29187367FFD-8072
    17111 - RPM Signal from ECU
                P0727 - 000 - No Signal - Intermittent
                        Fault Frequency: 109
                        Reset counter: 29
                        Mileage: 171224 km
                        Date: 2019.10.17
                        Time: 21:04:38
                        RPM: 96 /min
                        (no units): 13.0
                        Torque: -16.0 Nm
                        Temperature: 41.0°C
                        T.B. Angle: 0.0°
                        Bin. Bits: 0101 0 0
    Address 03: ABS Brakes        Labels: 4F0-910-517.clb
       Part No SW: 4F0 910 517 K    HW: 4F0 614 517 K
       Component: ESP 8.0 front   H03 0090
       Coding: 0021330
       VCID: 2C5DEE8A8F6B0C2F2B-8078
                        Fault Frequency: 6
                        Reset counter: 201
                        Mileage: 171263 km
                        Date: 2005.02.01
                        Time: 12:01:29
                        Hex Value: 0x0000
                        Hex Value: 0x4282
                        Hex Value: 0x0024
                        Hex Value: 0x018D
                        Hex Value: 0x00FF
       Part No SW: 4F0 910 852     HW: 4F0 905 852 B
       Component: FBSAUDIC6 ELV   H30 0160
       Revision: 27100401    Serial number: 10600300178535
       Coding: 0000019
       Shop #: WSC 02323 785 00200
       VCID: 63CF45B6A2358357DA-8036
       Subsystem 1 - Part No: 4F0 910 131 A
       Component: FBSAUDIC6 EZS   H44 0070
       Subsystem 2 - Part No: 4F0 910 220
       Component: FBSAUDIC6 IDG   H39 0040
                        Fault Frequency: 50
                        Reset counter: 212
                        Mileage: 171293 km
                        Date: 2005.02.15
                        Time: 10:36:48
                        Reset counter: 212
                        Mileage: 171317 km
                        Date: 2005.03.03
                        Time: 16:38:42
    Address 07: Control Head        Labels: 4F0-910-7xx-07-H.clb
       Part No SW: 4F0 910 731     HW: 4E0 035 729
       Component: Interfacebox    H43 1200
       Revision: 00000000    Serial number: 350EN057565163
       Shop #: WSC 02335 785 00200
       VCID: 5FC749468E5DA7B7FE-800A
       Component: Bedienteil MMIC6H04 0060
       Subsystem 2 - Serial number: 00000000723195
       Subsystem 3 - Serial number: 0105.04.070000000100010169ÿ
       Subsystem 4 - Serial number: 010169ÿ
    Address 08: Auto HVAC        Labels: 4F0-910-043.clb
       Part No SW: 4F0 910 043     HW: 4F2 820 043
       Component: KLIMABETAETIGUNGH04 0150
       Revision: 00000025    Serial number: 00000030019146
       Coding: 0001094
       VCID: 5BBF7D569A45BB9792-800E
                        Reset counter: 211
                        Mileage: 171315 km
                        Date: 2005.03.03
                        Time: 16:00:04
       Part No SW: 4F0 910 279 B    HW: 4F0 907 279 B
       Component: ILM Fahrer      H14 0080
       Coding: 0000101
       VCID: 2855129A9B93200FCF-807C
       Subsystem 1 - Part No: 4F2 910 113   Labels: 1KX-955-119.CLB
       Component: Wischer AudiC6  H04 0150
       Coding: 00062736
       Shop #: WSC 02335
       Subsystem 2 - Part No: 4E0 910 557   Labels: 8K0-955-559.CLB
       Coding: 00141886
       Shop #: WSC 02335
       Part No SW: 4E0 910 111 E    HW: 4E0 035 111 A
       Component: CD-Changer      H44 0430
       Revision: 00000000    Serial number: AUZ5ZBE7191663
       VCID: 1B3F3D56DAC5FB9752-804E
    Address 15: Airbags        Labels: 4F0-910-655-8R.clb
       Part No SW: 4F0 910 655 E    HW: 4F0 959 655 B
       Component: 4F AIRBAG AUDI8RH29 0260
       Revision: 07H29000    Serial number: 0037LD085GYL
       Coding: 0013382
       VCID: 2953179E80991907D0-807C
       Subsystem 1 - Serial number: 6332CSME090A270C1
       Subsystem 2 - Serial number: 6342CSME0A0C5E53B
       Subsystem 3 - Serial number: 6352QSME02021903.
       Subsystem 4 - Serial number: 6362QSME02022E7BG
       Subsystem 5 - Serial number: 63734SME021C1473V
       Subsystem 6 - Serial number: 63834SME021C4951-
       Part No SW: 4F0 910 549     HW: 4F0 953 549 A
       Component: Lenksäulenmodul H07 0230
       Revision: 00H07000    Serial number: 90025051340252
       Coding: 0102041
       VCID: 66C95CA25107F67F3D-8032
       Component: Lenkradmodul    H07 0080
    Address 17: Instruments        Labels: 4F0-910-xxx-17.lbl
       Part No SW: 4F0 910 900 A    HW: 4F0 920 900 M
       Component: KOMBIINSTR. M73 H10 0630
       Revision: 01000000    Serial number: 4R417VD55
       Coding: 2304763
       Shop #: WSC 00999 444 64523
       VCID: 1E393442C9D7EEBFB5-804A
    Address 19: CAN Gateway        Labels:. 4F0-910-468.clb
       Part No SW: 4F0 910 468 A    HW: 4F0 907 468 D
       Component: Gateway         H10 0060
       Revision: 10          Serial number: 120080551480EB
       Coding: ECFE53C41B0104
       VCID: 275711A6968D2F77C6-8072
                        Fault Status: 00101011
                        Fault Frequency: 30
                        Reset counter: 227
                        Mileage: 171259 km
                        Date: 2019.10.21
                        Time: 08:28:18
                        Fault Frequency: 119
                        Reset counter: 212
                        Mileage: 171293 km
                        Date: 2005.02.15
                        Time: 10:36:49
                        Reset counter: 212
                        Mileage: 171317 km
                        Date: 2005.03.03
                        Time: 16:38:42
    Address 42: Door Elect, Driver        Labels: 4F0-910-793-42.lbl
       Part No SW: 4F0 910 793 C    HW: 4F0 959 793 C
       Component: TSG FA          H11 0040
       Coding: 0000538
       VCID: 2A51E892859F121FD9-807E
                        Fault Frequency: 18
                        Reset counter: 212
                        Mileage: 171293 km
                        Date: 2005.02.15
                        Time: 10:42:17
    Address 46: Central Conv.        Labels:. 4F0-910-289.lbl
       Part No SW: 4F0 910 289 G    HW: 4F0 907 289 G
       Component: Komfortgeraet   H18 0120
       Revision: 01200018    Serial number: 01004416990000
       Coding: 0262157
       VCID: 2E59E482B9777E3F05-807A
    01565 - Luggage Compartment Light (W3)
                        Fault Status: 00101001
                        Fault Frequency: 29
                        Reset counter: 222
                        Mileage: 171260 km
                        Fault Frequency: 11
                        Reset counter: 226
                        Mileage: 171271 km
                        Date: 2005.02.07
                        Time: 16:58:42
                        Reset counter: 212
                        Mileage: 171315 km
                        Date: 2005.03.03
                        Time: 16:03:51
    01505 - Bulb for Blinkers; Rear Right (M8)
                        Fault Frequency: 14
                        Reset counter: 226
                        Mileage: 171315 km
                        Date: 2005.03.03
                        Time: 16:13:59
    02739 - Bulb for Tail/Brake Light; Right
                        Fault Frequency: 8
                        Reset counter: 226
                        Mileage: 171324 km
                        Date: 2005.03.17
                        Time: 11:13:51
    02741 - Bulb for Tail Light 2; Right
                        Fault Frequency: 8
                        Reset counter: 226
                        Mileage: 171340 km
                        Date: 2005.03.19
                        Time: 12:18:31
    Address 47: Sound System        Labels: 4F0-910-223-AS.lbl
       Part No SW: 4F0 910 223 B    HW: 4F0 035 223
       Component: Amp.-ASK        H09 0270
       Revision: 20S00001    Serial number: 01905050098849
       Coding: 0000007
       VCID: 1D3B334EC4D1F5A7AC-8048
       Part No SW: 4F0 910 280     HW: 4F0 907 280 A
       Component: ILM Beifahrer   H10 0080
       Revision:             Serial number: 00000000095245
       Coding: 0001014
       VCID: 5EB974428957AEBFF5-800A
    Address 52: Door Elect, Pass.        Labels: 4F0-910-793-52.lbl
       Part No SW: 4F0 910 792 C    HW: 4F0 959 792 C
       Component: TSG BF          H11 0040
       Coding: 0000538
       Part No SW: 4F0 910 801     HW: 4F0 907 801
       Component: EPB  C63C0030   H03 0030
       Revision: C63C0030
       Coding: 0002031
       Shop #: WSC 02334 785 00200
       VCID: 5DBB734E8451B5A7EC-8008
       Part No SW: 4E0 910 541 F    HW: 4F0 035 541 B
       Component: TUNER EU/US/RDW H42 0480
       Revision: 00000000    Serial number: 394E-057550786
       Coding: 0000001
       VCID: 234F05B6E2B5C3579A-8076
    Address 61: Battery Regul.        Labels: 4F0-910-181.lbl
       Part No SW: 4F0 910 181 E    HW: 4F0 915 181 A
       Component: ENERGIEMANAGER  H12 0490
       Revision: 00000000    Serial number: 00000000045264
       Shop #: WSC 00000 384 00290
       Subsystem 1 - Part No: 4F0 915 105 B
       Component: von MLA  0505170307
       Coding: 34463039313531303542204D4C4130353035313730333037
    02256 - Quiescent Current
                        Fault Status: 00100001
                        Reset counter: 220
                        Mileage: 171351 km
                        Date: 2005.03.20
                        Time: 14:39:51
    Address 62: Door, Rear Left        Labels: 4F0-910-795.lbl
       Part No SW: 4F0 910 795 A    HW: 4F0 959 795 A
       Component: TSG HL          H11 0030
                        Fault Status: 00101110
                        Reset counter: 212
                        Mileage: 171317 km
                        Date: 2005.03.03
                        Time: 16:38:38
    Address 72: Door, Rear Right        Labels: 4F0-910-795.lbl
       Part No SW: 4F0 910 795 A    HW: 4F0 959 794 A
       Component: TSG HR          H11 0030
                        Fault Frequency: 85
                        Reset counter: 212
                        Mileage: 171293 km
                        Date: 2005.02.15
                        Time: 10:36:48
                        Fault Frequency: 85
                        Reset counter: 212
                        Mileage: 171293 km
                        Date: 2005.02.15
                        Time: 10:36:48
       Part No SW: 4F0 910 283 B    HW: 4F0 919 283 B
       Component: Parkhilfe 4-Kan H09 0020
       Revision: 00H09000    Serial number: 11720514001314
       Coding: 0001006
    End-------------------------(Elapsed Time: 02:18)--------------------------
    Address 01: DTCs cleared
    Sep 2016
    Riga, Latvia
    Hi and welcome!
    I would start with checking wiring/splices/connectors to rear right light and rear right door.
    P.S. I don't think Australia has some limitations to use internet. You can get access to factory WD and other repair information using ERVIN subscription.
    Did you check combi SAI exhaust port circuit for carbon enema needed as per TSB's?
