Results 1 to 6 of 6
Thread: Flashing coil, scan shows a handful of fault codes
    Oct 2018
    Hi all
    I drive a 2014 A3 2.0 184 (with DTUK)
    I had the flashing coil the other day after pulling out of a junction. Car drove fine no limp mode. When I went out later the coil light had gone out and still driving fine. Done >100 miles and no problems.
    Did a scan today and found a few fault codes in the engine module and one in the CAN module for steering that all popped up last week.
    Any "best approach" here or just start cleaning sensors and checking wires?
    Thanks, Kristian
    Monday,27,January,2020,16:19:25:42375
    Mileage: 201915km-125464mi   Repair Order:
    Chassis Type: 8V-AU37 (5Q0)
    Scan: 01 03 08 09 10 15 16 17 19 42 44 52 55 5F BB BC
    VIN: WAUZZZ8V   Mileage: 201915km-125464miles
    Address 01: Engine (J623-CUNA)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 021 EP    HW: 04L 907 309 A
       Component: R4 2,0L EDC   H22 7539
       Revision: 81H22---
       Coding: 02190012032501082000
       Shop #: WSC 29392 003 1048576
       ASAM Dataset: EV_ECM20TDI01104L906021EP 002008
       ROD: EV_ECM20TDI01104L906021AE.rod
       VCID: 77ABE8D7FF471CCFF8D-8022
    11901 - Manifold Pressure / Boost Sensor (G31)
              P0236 00 [032] - Implausible Signal
                        Time: 00:00:00
                        Coolant temperature: 8 °C
                        Intake air temperature: 8 °C
                        Voltage terminal 30: 12.360 V
                        Charge air cooler inlet: pressure sensor 1 bank 1: raw value: 2440.2 hPa
                        Engine status: COENG_STANDBY
                        Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 0
    19210 - EGR System
              P0402 00 [096] - Excessive Flow
                        Mileage: 201859 km
                        Date: 2020.01.24
                        Time: 16:50:58
                        Engine speed: 1576.00 /min
                        Normed load value: 40.8 %
                        Vehicle speed: 14 km/h
                        Coolant temperature: 10 °C
                        Intake air temperature: 15 °C
                        Voltage terminal 30: 14.620 V
                        Exhaust recirculation valve 1 bank 1: mass flow - nominal value: 67.2 kg/h
                        Exhaust recirc.valve 1 bank 1: posit.feedback - Act.value: 0.00 %
                        Exhaust recirculation valve 2 bank 1: mass flow - nominal value: 0.0 kg/h
                        Exhaust recirc.valve 2 bank 1: posit.feedback - Act.value: 0.00 %
                        Exh.recircul.valve 1 bank 1: pos.feedback - Act.value: 0.18 %
                        Air mass at air mass meter 1: 105.0 kg/h
                        O2 sens. 1 bank 1 upstrm oxi cat: raw value: 3.2979
    5169 - Manifold Pressure / Boost Sensor (G31)
              P0238 00 [032] - Signal too High
    17448 - ROD - Unknown Error Code
              - 00 [032]
    4113 - Camshaft Position Sensor (G40)
              P0341 00 [096] - Implausible Signal
       Revision: 00000000    Serial number: 62004000002468
       Coding: 12F18AA234230A74017E060241CB2948512C5080608294F4026100788608
       VCID: 45D7521FF52BBE5FBA1-8010
       Revision: 20026000    Serial number: 00000000387850
       Coding: 03100104002000011000000000001100
       Shop #: WSC 06314 790 00021
       VCID: 33331CC7ABBF30EF045-8066
       Serial number: 0319CD37000000000001
       Component: BCM MQBAB H   H18 0134
       Serial number: 01011419804312
       Coding: 07040A46C24322FD03844004B31C07A80000000000000000000000000000
       ROD: EV_BCMBOSCH_013.rod
       VCID: 0059830BAA895B77C97-8054
       Subsystem 1 - Part No SW: 8V2 955 119 A    HW: 8V2 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS370 140713  041 0580
       Serial number:         140716220904
       Coding: 0A47F7
       Serial number: 63282863
       Coding: 02006C
       Light switch:
       Subsystem 3 - Part No SW: 8V0 941 531 AE    HW: 8V0 941 531 AE
       Serial number: 26 01 2016  00001031
       Serial number: 000000000ZY141681KG4
       Serial number: 00000000000030264090
       Part No SW: 5Q0 919 283 E    HW: 5Q0 919 283
       Component: PARKHILFE 4K  H10 0051
       Revision: --------    Serial number: 39231420400990
       Coding: 0000050001
       VCID: 3B2334E783EFF8AFDC5-806E
       Serial number: 003M2R07T4KS
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 4BC36427D34F482F6C5-801E
       Subsystem 1 - Part No SW: -----------    HW: 480 001 607 14
       Serial number: 357670000003EAD0001Q
       Subsystem 2 - Part No SW: -----------    HW: 480 001 607 14
       Serial number: 35867000000DDAD0001-
       Subsystem 3 - Part No SW: -----------    HW: 480 402 107 14
       Serial number: 3516502C515F3C34B23C
       Subsystem 4 - Part No SW: -----------    HW: 480 402 107 14
       Serial number: 3526502C515F3C324166
       Subsystem 5 - Part No SW: -----------    HW: 480 401 706 14
       Serial number: 35565029D1697520A136
       Pedestrian Protection Driver:
       Subsystem 6 - Part No SW: -----------    HW: 480 400 807 14
       Serial number: 2286502C11656B83C307
       Subsystem 7 - Part No SW: -----------    HW: 480 400 807 14
       Serial number: 2296502C11656B8393CH
       Pedestrian Protection Center:
       Subsystem 8 - Part No SW: -----------    HW: 480 400 807 14
       Serial number: 23065029B1656B853287
       Part No SW: 8V0 953 521 BM    HW: 5Q0 953 549 C
       Revision: --------    Serial number: 17071408490481
       Coding: A408
       ROD: EV_SMLSKLOMQB_010_AU37.rod
       VCID: 0655951388AD7547F3B-8052
       Part No SW: 8V0 920 971 E    HW: 8V0 920 971 E
       Component: KOMBI         H02 4291
       Coding: 27A509002B8026000100EA001000000000000000
       VCID: 3FDB40F797F7E48FF0D-806A
    1048578 - No Basic Setting
              B2010 00 [009] - -
              [Steuergerät keine oder falsche Grundeinstellung]
                        Reset counter: 192
                        Mileage: 189435 km
                        Date: 2018.11.16
                        Time: 11:51:48
       Part No SW: 5Q0 907 530 T    HW: 5Q0 907 530 F
       Component: GW MQB High   128 1188
       Revision: --------    Serial number: 0002290549
       Coding: 030100040F0876005B000248080B00000001010000000000000000000000
       ASAM Dataset: EV_GatewLear 011016
       ROD: EV_GatewLear_011.rod
       VCID: 42DD4903E40589679F3-8016
       Serial number: 12 07 2014  D0038904
       Serial number: 3110563903
    131602 - Power Steering Control Module
              U101D 00 [008] - No Communication
              [Timeout Knoten 0x12 / 44 - Steuergerät für Lenkhilfe]
                        Reset counter: 124
                        Mileage: 201680 km
                        Date: 2020.01.22
                        Time: 10:03:23
                        Supply voltage: Terminal 30: 12.2 V
                        Terminal 15: OFF
       Serial number: 14071403110089
       Coding: 00108E204001040000001002
       VCID: 40D9430BEA099B77897-8014
       Coding: 8103
       ROD: EV_SteerAssisMQB_010.rod
       VCID: 41DF460FE103927F869-8014
       Serial number: 12071404080092
       Coding: 001086204001040000001002
       Coding: 019C000001000000
       VCID: 75B7E2DFE54B6EDFEA1-8020
       Part No SW: 8V0 035 874 B    HW: 8V0 035 874 B
       Component: MU-S-ND-ER    041 0420
       Serial number: A7F01907140514
       Coding: 01730301FF0A000021111101000A00002F0004460100010006
       ASAM Dataset: EV_MUStd4CPASE 002018
       ROD: EV_MUStd4CPASE_VW37.rod
       Subsystem 1 - Part No SW: 8V0 919 866 B    HW: -----------
       Component:  ECE 2014  --- 0036
       Subsystem 2 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
       Component: DU Std  H49 0013
       Serial number: AUZ8Z9EY304V8J
       Multimedia Operating Unit:
       Subsystem 3 - Part No SW: 8V0 919 614 P    HW: 8V0 919 614 P
       Serial number: C1000007061400020173
       Part No SW: 5Q0 959 595 B    HW: 5Q0 959 595 B
       Component: TSG HFS       020 0025
       Serial number: 11071401100167
       Coding: 000086204001040000001002
       Component: TSG HBFS      020 0025
       Serial number: 11071402090166
    Nov 2014
    New Zealand
    DTUK? As in a tuning box?
    Remove that before you start engine diagnostics - it's made to make sensors read wrong*
    (*well, actually alter the signal sent from them, so the ECU sees different values to what is really happening)
    Allan
    The R32ran Thread
    How to post a full Auto-Scan
    Oct 2018
    Thanks, it took me far too long to consider that as a culprit given that I changed the settings about a week ago. I’ve set them back, will monitor.
    Oct 2018
    I removed the box a few days and cleared the codes. Car has fault code again but just the boost sensor.
    edit: i'll check the wiring and i think i saw a vacuum pipe going to it as well. can i assume there is no red herring here and i need to replace the boost sensor.
    acceleration is less nimble and the throttle feels heavier, car feels a bit slower, but it does drive with no limp mode. if i clear the code car is back to normal until i can feel the heavy throttle again after a number of miles.
    Friday,07,February,2020,12:04:11:42375
    VCDS Version: Release 19.6.2 (x64) Running on Windows 10 x64
                    Address 01: Engine       Labels: 04L-907-309-V1.clb
    Control Module Part Number: 04L 906 021 EP    HW: 04L 907 309 A
      Component and/or Version: R4 2,0L EDC   H22 7539
               Software Coding: 02190012032501082000
                Work Shop Code: WSC 29392 003 1048576
                  ASAM Dataset: EV_ECM20TDI01104L906021EP 002008 (VW37)
                        Mileage: 202160 km
                        Time: 00:00:00
                        Intake air temperature: 10 °C
                        Voltage terminal 30: 12.320 V
                        Charge air cooler inlet: pressure sensor 1 bank 1: raw value: 4131.2 hPa
    Sep 2016
    Riga, Latvia
    This is unreal value. Bad sensor or damage in wiring to it.
  6. Likes Jack@European_Parts, Uwe liked this post
    Oct 2018
    thanks for that, that sort of thing was over my head. I replaced the sensor took it out and fault cleared on its own. Fingers crossed all sorted
