Results 1 to 3 of 3
Thread: 4Motion codes and fuse keeps blowing
    Jan 2020
    Hey guys, looking for some help with the 4Motion on my wife's new to her 2014 Tiguan. This is a bit of a saga so bear with me! I posted this over on VW Vortex too to see if anybody there could help.
    We purchased the Tiguan from my father in December and at the time of purchase there was a dash light on for the 4Motion system. I pulled the codes and found that there was no communication to the Haldex controller. I started with the Haldex ECU, pulled it off the car and found that there had been minor water ingress into the Haldex ECU (a minimal amount of road salt had crystallized on the rear of the controller). There didn't appear to be any permanent damage so i cleaned it up very carefully with rubbing alcohol and resealed everything. Still no communication to the controller. I then found a burnt fuse under the hood (a 15A fuse), replaced it, cleared the codes and let my wife start driving it again. I can't say for sure that it was working at this point.
    Fast forward a few weeks to this past weekend and the same fuse has burnt out. I had already planned to do the 40k fluid service on the front and rear diffs, transmission, and Haldex diff this past weekend. I got all of the fluids changed, but somebody needs to beat a VW engineer with a dipstick for not putting a fill port and dipstick on the transmission. Anyhow, while I had the Haldex draining, I pulled the pump to clean the mesh filter. I was expecting the fluid to be a black mess. Incredibly, the fluid looked pretty clean and there was minimal build up on the pump screen. So, after cleaning, I wired the pump direct to the battery for a quick function test. It ran immediately (I only ran it for a few seconds). At this point I know the pump is functional to some extent. Next, I reassembled and refilled the Haldex, started the car, and performed the pump learn function in the VagCOM software. I could hear the pump running at this point. Put the car in gear (all 4 corners off the ground) and verified that all wheels were turning (they were). So I took it for a quick drive in the gravel roads around our farm and discovered that the AWD is still not functioning. I had a pile of front wheel spin and next to no, if any, rear wheel engagement when starting aggressively on uphill gravel roads. So I pulled the codes again. The scan is below. I am absolutely stumped as to what the issue is. I don't know if I should replace the pump or the controller or both? Or are there further diagnostic tests I can perform to isolate the problem component? Any insight you guys can provide would be much appreciated!
    Sunday,26,January,2020,19:00:13:28897
    VCDS Version: 19.6.2.0 (x64) HEX-V2 CB: 0.4508.4
    VIN: WVGBV3AX3EW****** License Plate:
    Mileage: 59510km-36977mi Repair Order:
    Chassis Type: AX-VW36 (7N0)
    Scan: 01 02 03 05 08 09 15 16 17 19 1C 22 25 2B 2E 42 44 46 4C 52
    53 56 62 69 72 75 77
    VIN: WVGBV3AX3EW****** Mileage: 59510km-36977miles
    Address 01: Engine (CCT) Labels:. 06J-906-026-CCT.clb
    Part No SW: 06J 997 027 S HW: 06J 907 309 A
    Component: MED17.5.2 TFSI 2 06 0402
    Revision: P3H07--- Serial number:
    Coding: 0423010A190F0160
    Shop #: WSC 47317 001 1048576
    VCID: 45D756F0A9A6E83FBA1-8010
    Part No SW: 09G 927 750 NK HW: 09G 927 750 NK
    Component: AQ 250 6F 2253
    Revision: 00H97000 Serial number:
    Coding: 0000840
    VCID: 074B9CF8D32A3A2F88D-8052
    Address 03: ABS Brakes Labels: 5N0-614-109-C6.clb
    Part No SW: 5N0 614 109 BK HW: 5N0 614 109 BK
    Component: J104 C6 450M VDFE 0014
    Revision: --H07--- Serial number: 00000007838629
    Coding: 0005161
    VCID: 75B7E630B9C638BFEA1-8020
    Address 05: Acc/Start Auth. (J518) Labels:| 5K0-959-434.clb
    Part No SW: 5K0 959 434 B HW: 5K0 959 434
    Component: VWKESSYPQ35GP 086 1101
    Revision: 00086000 Serial number: 0326044417
    Coding: 030C0C
    VCID: 34311B34FEBC61B71DF-8060
    Part No SW: 561 907 426 E HW: 561 907 426 E
    Component: AC Manuell H02 0303
    Revision: 00001K02
    Coding: 0010001002
    ASAM Dataset: EV_ACManu****ctGen2BHTC 001002
    ROD: EV_ACManu****ctGen2BHTC_VW36.rod
    VCID: 1D67DE906D36C0FFC21-8048
    Part No SW: 5K0 937 086 R HW: 5K0 937 086 R
    Component: BCM PQ35 M 122 0173
    Revision: BJ122001
    Coding: EF180A1B80232EC4018800C1110081644B21008E565D8DF064 804000A040
    VCID: 43D348E8AB92D60F945-8016
    Subsystem 1 - Part No: 5N1 955 119 A Labels: 1KX-955-119.CLB
    Component: WWS 060214 03 32 0010
    Coding: 009795
    Part No SW: 5N0 959 655 AD HW: 5N0 959 655 AD
    Component: J234__207 VW10 HI 2418
    Revision: 28019000 Serial number: 003N4P1RJRJJ
    Coding: 0012343
    VCID: 7F5B04188BFA72EFB0D-802A
    Subsystem 1 - Part No: 5N0 959 339 B
    Subsystem 2 - Serial number: 0000000000G6RB
    Subsystem 3 - Serial number: 0004.11.130000300000630002˙† 63
    Subsystem 4 - Serial number: 630002˙† 6332MTS654700274%˙† 63
    Subsystem 5 - Serial number: 00274%˙† 6342MTS6451602740˙† 63
    Subsystem 6 - Serial number: 602740˙† 6351HTS6KURQFCKJ8˙† 63
    Subsystem 7 - Serial number: QFCKJ8˙† 6361HTS6PP58JCKRM˙† 63
    Subsystem 8 - Serial number: 8JCKRM˙† 63727TS6OFGCHCKJ8˙† 63
    Subsystem 9 - Serial number: CHCKJ8˙† 63827TS6106CHCKJ4˙
    Subsystem 10 - Serial number: CHCKJ4˙
    Part No SW: 5K0 953 501 DM HW: 5K0 953 569 AP
    Component: LENKS.MODUL 016 0140
    Revision: FF010042 Serial number: 20140207100156
    Coding: 110A140000
    VCID: 78A9EF04A25445D7F17-802C
    Subsystem 1 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C Labels: 3C8-959-537.CLB
    Component: E221__MFL-TAS H31 0037
    Coding: 820000
    Part No SW: 5N0 920 973 E HW: 5N0 920 973 E
    Component: KOMBI H04 0811
    Coding: 211D01
    VCID: 3635213CE8C073A723B-8062
    Part No SW: 7N0 907 530 AK HW: 7N0 907 530 AK
    Component: J533 Gateway H57 1642
    Revision: H57 Serial number: 170114F1001847
    Coding: 356002
    VCID: 79AFEA0099DE5CDF8E9-802C
    Address 1C: Position Sensing
    Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
    Part No SW: 0AY 907 554 F HW: 0AY 907 554 F
    Component: Haldex4Motion H52 7521
    Serial number: HA1-00029.01.14
    Coding: 0001
    VCID: 4EC569DC70502B670BB-801A
    16671 - Pump for Haldex Clutch
    C1112 04 [009] - Internal System Fault
    [Pump Motor - mechanisch defekt (mechanisch festgefahren)]
    Reset counter: 253
    Mileage: 59518 km
    Date: 2020.01.26
    Time: 18:46:44
    Component: IMMO H04 0811
    Coding: 000007
    VCID: 6A8DC54CECF8E747773-803E
    Address 2B: Steer. Col. Lock (J764) Labels:* 5K0-905-861.clb
    Part No SW: 5K0 905 861 C HW: 5K0 905 861 C
    Component: ELV-PQ35 H21 0240
    Revision: 00000000 Serial number: 14000027431003
    Coding: 4900000000000000
    ROD: EV_ELVMarquMPVW36X.rod
    VCID: 303917240AA45D97797-8064
    Address 2E: Media Player 3
    Part No SW: 5N0 959 701 F HW: 3C0 959 793 B
    Component: TUER-SG FT 002 0503
    Revision: 13110009 Serial number: 0007986820
    Coding: 0004B4
    VCID: 38292F04E2D485D7317-806C
    Slave Driver:
    Subsystem 1 - Part No SW: 5N0 959 703 G HW: 3C0 959 794 D Labels: 1K0-959-70X-GEN4.CLB
    Component: J388__TSG-HL 009 1504
    Serial number: 00000008178929
    Coding: 000490
    Part No SW: 5N1 909 144 R HW: 5N1 909 148 J
    Component: J500__APA-BS KL.286 1401
    Revision: 1BH04841 Serial number: 00140320049701
    Coding: 0000258
    VCID: 41DF42E0BD8EC41F869-8014
    Part No SW: 5N0 959 702 F HW: 3C0 959 792 B
    Component: TUER-SG BT 002 0503
    Revision: 15110009 Serial number: 0007989073
    Coding: 0004B4
    VCID: 392F2A00D9DE9CDFCE9-806C
    Slave Passenger:
    Subsystem 1 - Part No SW: 5N0 959 704 G HW: 3C0 959 795 D Labels: 1K0-959-70X-GEN4.CLB
    Component: J389__TSG-HR 009 1504
    Serial number: 00000008430870
    Coding: 000490
    Part No SW: 3AA 907 801 H HW: 3AA 907 801 H
    Component: J540 EPB4 VW-86594 0010
    Revision: H19 Serial number: 00000001894458
    Coding: 0026156
    VCID: 3635213CE44073A723B-8062
    Part No SW: 1K0 035 188 F HW: 1K0 035 188 F
    Component: Radio Prem-8 H05 0008
    Revision: -----09S Serial number: VWZ4Z7P3525659
    Coding: 0100044004000C
    VCID: 2B03004823023E4F4C5-807E
    Reset counter: 224
    Mileage: 58235 km
    Date: 2014.06.03
    Time: 00:05:24
    Reset counter: 38
    Mileage: 59518 km
    Date: 2014.06.17
    Time: 14:23:50
    Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb
    Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
    Component: Anhaenger H09 0100
    Revision: 3A001001 Serial number: 00008030473524
    Coding: 0200000100000000
    Shop #: WSC 01999 444 183813
    VCID: 303917240A245D97797-8064
    Address 75: Telematics (J949) Labels:| 12E-035-284.clb
    Part No SW: 561 035 285 HW: 561 035 285
    Component: OCULowUSA 014 0102
    Serial number: 000003554140515
    Coding: 02130602C2161A107F1606C20000
    ROD: EV_OCULow_001.rod
    VCID: 53F378A85B72468F245-8006
    2103041 - Control Module
    Fault Priority: 8
    Reset counter: 254
    Mileage: 59519 km
    Date: 2020.01.26
    Time: 18:59:05
    Address 77: Telephone (J412) Labels:| 5N0-035-729.clb
    Part No SW: 5N0 035 729 A HW: 5N0 035 729 A
    Component: TELEFON H05 0592
    Revision: 1B001001 Serial number: 00007665709780
    Coding: 0A10030080010110
    ROD: EV_UHVUMI.rod
    VCID: 2E05095C10904B676BB-807A
    9457664 - Function limitation due to excessive temperature
    B1050 00 [008] - -
    Reset counter: 28
    Mileage: 59060 km
    Date: 2020.01.21
    Time: 08:15:02
    End----------(Elapsed Time: 01:23, VBatt start/end: 14.1V/14.2V)-----------
    Tartu, Estonia
    There is a page for this in my wiki.
    The world is my oyster...
  3. Likes Uwe, MartinsX liked this post
    Jan 2020
    So from what I'm seeing, the C111204 code indicates that I need to replace the Haldex pump, is this correct?
