Hello i got some codes, i want to know what i can do about them:
Friday,24,January,2020,08:28:34:64666
VIN: VSSZZZ6JZGR100225   License Plate:
Mileage: 156994km-97551mi   Repair Order:
Chassis Type: 6J-SE26 (6C0)
Scan: 01 03 08 09 10 15 17 19 44 55 5F
VIN: VSSZZZ6JZGR100225   Mileage: 156994km-97551miles
Address 01: Engine (J000-CUTA)       Labels:. 04B-907-445-V1.clb
   Part No SW: 04B 906 027 AM    HW: 04B 907 445
   Component: R3 1.4l TDI   H08 2763
   Revision: 21006001
   Coding: 01114032422401080000
   Shop #: WSC 00049 770 00189
   ASAM Dataset: EV_ECM14TDI03004B906027AM 003001
   ROD: EV_ECM14TDI03004B906027_003_VW26.rod
   VCID: 6C8034F7B6043EC705F-8038
Readiness: N/A
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP90.clb
   Part No SW: 6C0 907 379 K    HW: 6R0 907 379 BA
   Component: ESP9.0i       H03 0004
   Serial number: 08504737160219
   Coding: 11DD487D892333C00916106B0056881291CC90080013C9098F00
   ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
   VCID: 372ADB9BBFC24D1F38D-8062
Address 08: Auto HVAC (J255)       Labels:| 6C0-907-044.clb
   Part No SW: 6P0 907 044 B    HW: 6P0 907 044 B
   Component: Climatronic   H02 0202
   Serial number:  1602061A-0491
   Coding: 001000001001210001
   ASAM Dataset: EV_ACClimaValeoPQ26 003001
   ROD: EV_ACClimaValeoPQ26.rod
   VCID: 3038E0875AAC9A27797-8064
329987 - Motor for Defroster Flap
          B1090 13 [008] - Open Circuit
                    Reset counter: 130
                    Mileage: 154723 km
                    Date: 2019.12.30
                    Time: 17:07:49
                    Voltage terminal 30: 11.7 V
                    Interior temperature: 12.20 °C
                    Outside air temperature: 8.0 °C
                    Defroster flap: specified value: 951
                    Defroster flap: actual value: 182
                    Defroster flap: actual value: 127.50 %
1179905 - Cooling Fan for Housing
          B126B 01 [008] - Electrical Failure
                    Reset counter: 137
                    Mileage: 154376 km
                    Date: 2019.12.28
                    Time: 20:55:36
                    Voltage terminal 30: 13.9 V
Address 09: Cent. Elect. (J519)       Labels:| 6C0-937-089-V1.clb
   Part No SW: 6C0 937 089 C    HW: 6C0 937 089
   Component: BCM PQ26 Hi4R H08 0087
   Serial number: 006098026113
   Coding: 08000A5042532AFB43804000402F07480001690253010000000000000000
   ASAM Dataset: EV_BCMA0 005005
   ROD: EV_BCMA0_005.rod
   Subsystem 1 - Part No SW: 5Q0 955 547 A    HW: 5Q0 955 547 A  Labels: 5Q0-955-547.CLB
   Component: RLHS  037 0059
   Serial number: S5Y16M02D13H16M19S58
   Coding: 00984D
   Drivers Door Control Module:
   Subsystem 2 - Part No SW: 6R0 959 801 DT    HW: 6R0 959 801 DT  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 0630
   Serial number: KU0KU012021660436714
   Coding: 1400A5
   Subsystem 3 - Part No SW: 6R0 959 802 EE    HW: 6R0 959 802 EE  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 0630
   Serial number: KU0KU012021660432700
   Coding: 0400A5
   Subsystem 5 - Part No SW: 6R0 959 811 R    HW: 6R0 959 811 R
   Component: J388__TSG_HL  022 1122
   Serial number: 13102719160222210103
   Subsystem 6 - Part No SW: 6R0 959 812 R    HW: 6R0 959 812 R
   Component: J389__TSG_HR  022 1122
   Serial number: 13102718160222163141
   Revision: --------    Serial number: 39391603901669
   Coding: 0031051001
   ROD: EV_EPHVA18AU3700000_SE26.rod
   VCID: 43D2BF4BFB1A11BF945-8016
Address 15: Airbags (J234)       Labels:| 6C0-959-655.clb
   Part No SW: 6C0 959 655 J    HW: 6C0 959 655 J
   Component: VW20Airbag002 002 0380
   Revision: --------    Serial number: 003TH0032J6-
   Coding: 88C0C000000000005C0000CA000800000000
   Shop #: WSC 00049 770 00115
   ROD: EV_AirbaVW20BPAVW26X.rod
   VCID: 3A2CC2AF8CD05077C73-806E
   Subsystem 1 - Part No SW: -----------    HW: 410 271 902 16
   Component: SideSensor_Df  15B 0148
   Serial number: 3495R0024294FA53741S
   Subsystem 2 - Part No SW: -----------    HW: 410 271 902 16
   Component: SideSensor_Pf  15B 0148
   Serial number: 3505R001829544A5226C
   Part No SW: 6P0 920 741 A    HW: 6P0 920 741 A
   Component: KOMBI         208 1424
   Coding: 072D1100298000080D087E001000000000000000
   ROD: EV_DashBoardVDDMQBAB_SE26.rod
   VCID: 2E04FEFF40988CD76BB-807A
Address 19: CAN Gateway (J533)       Labels:| 6C0-909-901-V1.clb
   Part No SW: 6C0 909 901     HW: 6C0 937 089
   Component: GW MQB A0     H08 0087
   Revision: --------    Serial number: 006098026113
   Coding: 030100044F08590070000000000000010001000000000000000000000000
   ASAM Dataset: EV_GatewA0Lear 013020
   ROD: EV_GatewA0Lear_013_VW26.rod
   VCID: 659641D355EE0F8F5A1-8030
   Subsystem 1 - Part No SW: 5F0 959 537 B    HW: 5F0 959 537 B  Labels: 3C8-959-537.CLB
   Component: E221__MFL-PR6  H04 0130
   Serial number: 000000000B0575030216
   Coding: 002000
   Subsystem 2 - Part No SW: 6C0 915 181 A    HW: 6C0 915 181 A
   Component: J367-BDM  H08 0223
   Serial number: 63059340412821631208
131654 - No Communications with HVAC Control Module (J301)
          U0164 00 [008] - -
          [Timeout Knoten 0x46 / 08 - Steuergerät für Klima]
                    Reset counter: 118
                    Mileage: 154918 km
                    Date: 2020.01.02
                    Time: 02:48:43
                    Supply voltage: Terminal 30: 12.4 V
                    Terminal 15: OFF
197149 - Generator
          U1052 00 [009] - No Communication
          [Generator (LIN#1) Timeout]
                    Fault Frequency: 124
                    Reset counter: 115
                    Mileage: 153616 km
                    Date: 2019.12.19
                    Time: 16:57:04
                    Supply voltage: Terminal 30: 11.7 V
                    Terminal 15: On
Address 44: Steering Assist (J792)       Labels:| 6Rx-909-144-V2.clb
   Part No SW: 6C1 909 144 AG    HW: 6C1 909 144 D
   Component: EPS_TRW_ALow  312 3232
   Serial number: CG2M0206
   Coding: 000731
   ASAM Dataset: EV_SteerAssisUDSTRW 016026
   ROD: EV_SteerAssisUDSTRW.rod
   VCID: 6D8639F38D1E37CF121-8038
   Coding: 058A000003000000
   Shop #: WSC 00049 770 00137
   VCID: 40D8B047EA0C0AA7897-8014
   Subsystem 1 - Part No SW: 7L6 941 329 C    HW: 7L6 941 329 C  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0004
   Coding: 290000
   Subsystem 2 - Part No SW: 7L6 941 329 C    HW: 7L6 941 329 C  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0004
   Coding: 290000
Address 5F: Information Electr. (J794)       Labels:| 5F0-035-MIB-STD2.clb
   Part No SW: 5QA 035 858     HW: 5QA 035 858
   Component: MU-S-ND-ER    H24 0245
   Serial number: SEZAZ2S0016862
   Coding: 04520301960A000011111101008808002F0201C40120010046
   ASAM Dataset: EV_MUStd6C1TSAT 001015
   ROD: EV_MUStd6C1TSAT_SE26.rod
   VCID: 04507C57BE94D687EDF-8050
   Subsystem 1 - Part No SW: 5F0 919 604 A    HW: 5F0 919 604 A
   Component: ABTm_Std2_Nav  H44 1031
   Serial number: SEZ8Z9SLM00J8M
   Subsystem 2 - Part No SW: 6P0 919 866 BK    HW: -----------
   Component: ECE AS 20/21  --- 1430
2571 - Navigation system
          B126C F2 [008] - Navigation database not enabled
                    Fault Frequency: 178
                    Reset counter: 155
                    Mileage: 155413 km
                    Date: 2020.01.06
                    Time: 22:54:15
                    Voltage terminal 30: 12.1 V
End----(Elapsed Time: 00:52, VBatt start/end: 11.7V/11.8V. VIgn 11.7V)-----
