Hello i got some codes, i want to know what i can do about them:
Friday,24,January,2020,08:28:34:64666
VCDS Version: 19.6.2.0 (x64) HEX-V2 CB: 0.4508.4
VIN: VSSZZZ6JZGR100225 License Plate:
Mileage: 156994km-97551mi Repair Order:
Chassis Type: 6J-SE26 (6C0)
Scan: 01 03 08 09 10 15 17 19 44 55 5F
VIN: VSSZZZ6JZGR100225 Mileage: 156994km-97551miles
Address 01: Engine (J000-CUTA) Labels:. 04B-907-445-V1.clb
Part No SW: 04B 906 027 AM HW: 04B 907 445
Component: R3 1.4l TDI H08 2763
Revision: 21006001
Coding: 01114032422401080000
Shop #: WSC 00049 770 00189
ASAM Dataset: EV_ECM14TDI03004B906027AM 003001
ROD: EV_ECM14TDI03004B906027_003_VW26.rod
VCID: 6C8034F7B6043EC705F-8038
Readiness: N/A
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP90.clb
Part No SW: 6C0 907 379 K HW: 6R0 907 379 BA
Component: ESP9.0i H03 0004
Serial number: 08504737160219
Coding: 11DD487D892333C00916106B0056881291CC90080013C9098F00
ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
VCID: 372ADB9BBFC24D1F38D-8062
Address 08: Auto HVAC (J255) Labels:| 6C0-907-044.clb
Part No SW: 6P0 907 044 B HW: 6P0 907 044 B
Component: Climatronic H02 0202
Serial number: 1602061A-0491
Coding: 001000001001210001
ASAM Dataset: EV_ACClimaValeoPQ26 003001
ROD: EV_ACClimaValeoPQ26.rod
VCID: 3038E0875AAC9A27797-8064
329987 - Motor for Defroster Flap
B1090 13 [008] - Open Circuit
Reset counter: 130
Mileage: 154723 km
Date: 2019.12.30
Time: 17:07:49
Voltage terminal 30: 11.7 V
Interior temperature: 12.20 °C
Outside air temperature: 8.0 °C
Defroster flap: specified value: 951
Defroster flap: actual value: 182
Defroster flap: actual value: 127.50 %
1179905 - Cooling Fan for Housing
B126B 01 [008] - Electrical Failure
Reset counter: 137
Mileage: 154376 km
Date: 2019.12.28
Time: 20:55:36
Voltage terminal 30: 13.9 V
Address 09: Cent. Elect. (J519) Labels:| 6C0-937-089-V1.clb
Part No SW: 6C0 937 089 C HW: 6C0 937 089
Component: BCM PQ26 Hi4R H08 0087
Serial number: 006098026113
Coding: 08000A5042532AFB43804000402F07480001690253010000000000000000
ASAM Dataset: EV_BCMA0 005005
ROD: EV_BCMA0_005.rod
Subsystem 1 - Part No SW: 5Q0 955 547 A HW: 5Q0 955 547 A Labels: 5Q0-955-547.CLB
Component: RLHS 037 0059
Serial number: S5Y16M02D13H16M19S58
Coding: 00984D
Drivers Door Control Module:
Subsystem 2 - Part No SW: 6R0 959 801 DT HW: 6R0 959 801 DT Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 003 0630
Serial number: KU0KU012021660436714
Coding: 1400A5
Subsystem 3 - Part No SW: 6R0 959 802 EE HW: 6R0 959 802 EE Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 003 0630
Serial number: KU0KU012021660432700
Coding: 0400A5
Subsystem 5 - Part No SW: 6R0 959 811 R HW: 6R0 959 811 R
Component: J388__TSG_HL 022 1122
Serial number: 13102719160222210103
Subsystem 6 - Part No SW: 6R0 959 812 R HW: 6R0 959 812 R
Component: J389__TSG_HR 022 1122
Serial number: 13102718160222163141
Part No SW: 5Q0 919 294 K HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0054
Revision: -------- Serial number: 39391603901669
Coding: 0031051001
ROD: EV_EPHVA18AU3700000_SE26.rod
VCID: 43D2BF4BFB1A11BF945-8016
Address 15: Airbags (J234) Labels:| 6C0-959-655.clb
Part No SW: 6C0 959 655 J HW: 6C0 959 655 J
Component: VW20Airbag002 002 0380
Revision: -------- Serial number: 003TH0032J6-
Coding: 88C0C000000000005C0000CA000800000000
Shop #: WSC 00049 770 00115
ROD: EV_AirbaVW20BPAVW26X.rod
VCID: 3A2CC2AF8CD05077C73-806E
Subsystem 1 - Part No SW: ----------- HW: 410 271 902 16
Component: SideSensor_Df 15B 0148
Serial number: 3495R0024294FA53741S
Subsystem 2 - Part No SW: ----------- HW: 410 271 902 16
Component: SideSensor_Pf 15B 0148
Serial number: 3505R001829544A5226C
Part No SW: 6P0 920 741 A HW: 6P0 920 741 A
Component: KOMBI 208 1424
Coding: 072D1100298000080D087E001000000000000000
ROD: EV_DashBoardVDDMQBAB_SE26.rod
VCID: 2E04FEFF40988CD76BB-807A
Address 19: CAN Gateway (J533) Labels:| 6C0-909-901-V1.clb
Part No SW: 6C0 909 901 HW: 6C0 937 089
Component: GW MQB A0 H08 0087
Revision: -------- Serial number: 006098026113
Coding: 030100044F08590070000000000000010001000000000000000000000000
ASAM Dataset: EV_GatewA0Lear 013020
ROD: EV_GatewA0Lear_013_VW26.rod
VCID: 659641D355EE0F8F5A1-8030
Subsystem 1 - Part No SW: 5F0 959 537 B HW: 5F0 959 537 B Labels: 3C8-959-537.CLB
Component: E221__MFL-PR6 H04 0130
Serial number: 000000000B0575030216
Coding: 002000
Subsystem 2 - Part No SW: 6C0 915 181 A HW: 6C0 915 181 A
Component: J367-BDM H08 0223
Serial number: 63059340412821631208
131654 - No Communications with HVAC Control Module (J301)
U0164 00 [008] - -
[Timeout Knoten 0x46 / 08 - Steuergerät für Klima]
Reset counter: 118
Mileage: 154918 km
Date: 2020.01.02
Time: 02:48:43
Supply voltage: Terminal 30: 12.4 V
Terminal 15: OFF
197149 - Generator
U1052 00 [009] - No Communication
[Generator (LIN#1) Timeout]
Fault Frequency: 124
Reset counter: 115
Mileage: 153616 km
Date: 2019.12.19
Time: 16:57:04
Supply voltage: Terminal 30: 11.7 V
Terminal 15: On
Address 44: Steering Assist (J792) Labels:| 6Rx-909-144-V2.clb
Part No SW: 6C1 909 144 AG HW: 6C1 909 144 D
Component: EPS_TRW_ALow 312 3232
Serial number: CG2M0206
Coding: 000731
ASAM Dataset: EV_SteerAssisUDSTRW 016026
ROD: EV_SteerAssisUDSTRW.rod
VCID: 6D8639F38D1E37CF121-8038
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Coding: 058A000003000000
Shop #: WSC 00049 770 00137
VCID: 40D8B047EA0C0AA7897-8014
Subsystem 1 - Part No SW: 7L6 941 329 C HW: 7L6 941 329 C Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0004
Coding: 290000
Subsystem 2 - Part No SW: 7L6 941 329 C HW: 7L6 941 329 C Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0004
Coding: 290000
Address 5F: Information Electr. (J794) Labels:| 5F0-035-MIB-STD2.clb
Part No SW: 5QA 035 858 HW: 5QA 035 858
Component: MU-S-ND-ER H24 0245
Serial number: SEZAZ2S0016862
Coding: 04520301960A000011111101008808002F0201C40120010046
ASAM Dataset: EV_MUStd6C1TSAT 001015
ROD: EV_MUStd6C1TSAT_SE26.rod
VCID: 04507C57BE94D687EDF-8050
Subsystem 1 - Part No SW: 5F0 919 604 A HW: 5F0 919 604 A
Component: ABTm_Std2_Nav H44 1031
Serial number: SEZ8Z9SLM00J8M
Subsystem 2 - Part No SW: 6P0 919 866 BK HW: -----------
Component: ECE AS 20/21 --- 1430
2571 - Navigation system
B126C F2 [008] - Navigation database not enabled
Fault Frequency: 178
Reset counter: 155
Mileage: 155413 km
Date: 2020.01.06
Time: 22:54:15
Voltage terminal 30: 12.1 V
End----(Elapsed Time: 00:52, VBatt start/end: 11.7V/11.8V. VIgn 11.7V)-----
