Results 1 to 4 of 4
Thread: Audi A7 headlight issue
    Mar 2016
    Hungary
    Hello fellows,
    I have a problem with this A7. The dashboard shows the yellow message about but I do not understand why? The camera 85 does not shows any fault code. I took the car to the dealer and they said do not know the problem, all the control unit coded correctly. On-line connect said everything is fine about the ECU's.
    Maybe I have to do a basic settings on the camera? Is it possible?
    Thank you very much for any advices.
    Monday,27,January,2020,16:06:22:34036
    VIN: WAUZZZ4G3BN033733   License Plate:
    Chassis Type: 4G-AU57 (4G0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 28 34 36 3B 3C 42 44 46 47
              52 53 55 56 5F 62 6C 6D 72 85 8F 90
    VIN: WAUZZZ4G3BN033733   Mileage: 277504km-172432miles
    Address 01: Engine (J623-CDUC)       Labels:. 059-907-401-V2.clb
       Part No SW: 4G0 907 401 F    HW: 4G0 907 401
       Component: 3.0TDI EDC17  H37 0007
       Revision: 53H37---
       Coding: 1A254012052601020000
       Shop #: WSC 78387 152 452326
       ASAM Dataset: EV_ECM30TDI0114G0907401F 001007
       ROD: EV_ECM30TDI0114G0907401F.rod
       VCID: 2616FE05386F427793B-8072
       Part No SW: 4G0 927 156 K    HW: 0B5 927 156 F
       Component: 0B5 30 TDIRdW H10 0015
       Revision: --H10---    Serial number: 0000000076
       Coding: 000001
       Shop #: WSC 02311 785 00200
       ASAM Dataset: EV_TCMDL501 A02203
       ROD: EV_TCMDL501.rod
       VCID: 3432144DFEB320E71DF-8060
       Part No SW: 4G0 907 379     HW: 4G0 907 379
       Component: ESP PREMIUM   H08 0190
       Coding: 27A6C702E465E340DB00
       ASAM Dataset: EV_ESPPremiAU57X 003013
       ROD: EV_ESPPremiAU57X_003.rod
       VCID: 6E86C625D01F4A372BB-803A
       Part No SW: 4H0 907 064 AP    HW: 4H0 907 064 AP
       Component: BCM2 2.0      H24 0217
       Coding: 05AA2F00000000000000
       VCID: 77A8E341AFC50BFFF8D-8022
       Serial number: 2311000103881013
       Part No SW: 4G0 820 043 K    HW: 4G0 820 043 K
       Component: KLIMA 4 ZONEN H11 0056
       Serial number: 17051100040073
       Coding: 360300B80C
       ASAM Dataset: EV_AirCondiComfoUDS 002029
       VCID: 2708F3013F655B7FA8D-8072
       Part No SW: 4H0 907 063 BN    HW: 4H0 907 063 F
       Component: BCM1 2.0      H12 0111
       Revision: 20012002    Serial number: 00000001048680
       Coding: 0200201050B49FE0C981008380001908CF9CC3082E080101000008402100
       Shop #: WSC 00046 000 00000
       VCID: 75B4E949B5C979EFEA1-8020
       Component: WWS57X 110505  H35 0051
       Serial number:         110506131522
       Coding: 0045F7
       Component: RLS  H04 0003
       Serial number: 11434775
       Coding: 02562B
       Subsystem 3 - Part No SW: 4G0 941 531 E    HW: 4G0 941 531 E
       Component: E1 - LDS  H07 0044
       Serial number: 06 05 2011  00000155
       Serial number: 4F6807A5000000000001
    01771 - Control Module for Headlight Range (J431)
                013 - Check DTC Memory
                        Fault Status: 01101101
                        Reset counter: 74
                        Mileage: 277504 km
                        Date: 2020.01.23
                        Time: 14:42:00
       Part No SW: 4H0 919 475 H    HW: 4H0 919 475 C
       Component: PARKHILFE ACC H07 0030
       Revision: 11001001    Serial number: 55901111702079
       Coding: 300303
       Shop #: WSC 22195 142 181936
       ASAM Dataset: EV_EPHVA18AU57X0000 001002
       ROD: EV_EPHVA18AU57X0000_001.rod
       VCID: 37282341EFC5CBFF38D-8062
       Component: Airbag10.43   H40 0040
       Revision: --------    Serial number: 003JG002FH3W
       Coding: 30314530323130303037554A304C34473853
       VCID: 36362E45E8CF32F723B-8062
       Serial number: 3575HRB40590HM766PCG
       Serial number: 3585HRB405B0IDFS8H4R
       Serial number: 3515JRB40550GQ8QLOKB
       Serial number: 3525JRB404T0I70GH03+
       Serial number: 3554VRB40650GR36C924
       Serial number: 3564VRB40650GR36KGAS
       Revision: 00000000    Serial number: 20110513000726
       Coding: 000034
       VCID: 303A185D0A2B1CC7797-8064
       Component: E221 - MFL  H07 0009
       Part No SW: 4G8 920 930 P    HW: 4G8 920 930 P
       Component: TDieRdw       H34 0312
       Revision: 19100074    Serial number: 658180511593037
       Coding: 13A601021B030008000100
       ASAM Dataset: EV_RBD4K 004033
       ROD: EV_RBD4K_AU57.rod
       VCID: 3A2E3A75DCD7D697C73-806E
       Part No SW: 4G0 907 468 C    HW: 4G0 907 468 A
       Component: J533--Gateway H08 0204
       Revision: --------    Serial number: 00000000151687
       Coding: 00CD077D00
       ROD: EV_GatewUDS_AU57.rod
       VCID: 303A185D0AAB1CC7797-8064
       Component: J367-BDM  H07 0140
       Serial number: 00000000005650480902
       Voltage stabilizer:
       Serial number: 11137001004021200410
       Part No SW: 4G0 919 158 D    HW: 4G0 919 158 D
       Component: KLIMA FOND    H07 0056
       Serial number: 11051100040629
       Coding: 00
       ASAM Dataset: EV_ClimaContrUnitRearUDS 002012
       Part No SW: 4G0 907 553 B    HW: 4G0 907 553
       Component: LUFE-DAEMPFER H17 0778
       Coding: 008000
       ASAM Dataset: EV_AirSuspe 003022
       ROD: EV_AirSuspe_VW51.rod
       VCID: 2A0E0A352C776617B73-807E
       Component: MEM-FS        H03 0153
       Revision: AA000000    Serial number: 00000006129276
       Part No SW: 4G0 907 637 B    HW: 4G0 907 637 B
       Component: SARA 6D       H02 0004
       Revision: --------    Serial number: EJ1BPA4200WC120
       ASAM Dataset: EV_SARA 006014
       ROD: EV_SARA_006.rod
       VCID: 2D0401291D99712F521-8078
       Part No SW: 4G0 907 566 H    HW: 4G0 907 566
       Component: J769  SWA MasterH04 0040
       Revision: 00H04000    Serial number: 6PZ 010 287-02
       Coding: 0000103
       VCID: 3432144DF23320E71DF-8060
       Subsystem 1 - Part No: 4G0 907 568 H
       Component: J770  SWA Slave H01 0040
       Subsystem 2 - Serial number: 6PZ 010 287-22
       Subsystem 3 - Serial number: 5F29.04.1100H010003C720284˙
       Subsystem 4 - Serial number: 720284˙
       Part No SW: 4G8 959 793 C    HW: 4G8 959 793 A
       Component: TSG FA        H04 0210
       Coding: 011F56225E00628002080002
       Shop #: WSC 02312 785 00200
       VCID: 40DA489DBA8B8C47897-8014
       Component: RCEPS         H33 0010
       Revision: 00001000    Serial number: 0014075626
       Coding: 101000010000
       ASAM Dataset: EV_RCEPS 009008
       ROD: EV_RCEPS_009.rod
       VCID: 323E125504A72ED70F3-8066
       Revision: 00002001    Serial number: 0149843404
       Coding: 01000E2020B9B48583200A040A0100000000000000000000000000000000
       Subsystem 1 - Part No SW: 7P5 959 591     HW: 4H0 959 591
       Component: J245 PS40.033  H07 0006
       Serial number:     WOO1208106Z
       Coding: 001F00
       Subsystem 2 - Part No SW: 4G8 959 252     HW: 4G8 959 252
       Component: HSP-SG  H09 0027
       Serial number: WA101432000000272996
       Part No SW: 4G0 035 223 A    HW: 4G0 035 223 A
       Component: BOSE G3 C7    H07 0160
       Revision: CJ007000    Serial number: 00000000035282
       VCID: 1B60DFF173AD8F9F3C5-804E
       Part No SW: 4G8 959 792 C    HW: 4G8 959 792 A
       Component: TSG BF        H04 0210
       VCID: 3FD84B61C775F3BFF0D-806A
       Revision: --------    Serial number: 00000000074192
       ROD: EV_ParkiBrake_VW51.rod
    Address 55: Headlight Range (J431)       Labels:| 4H4-907-357-V1.clb
       Part No SW: 4H4 907 357 A    HW: 4H4 907 357 A
       Component: ....AFS13.... H01 0012
       Serial number: 000000-0000-000
       Coding: 11236F33F91AEB00
       ASAM Dataset: EV_AdvanFrontSyste 005001
       ROD: EV_AdvanFrontSyste_AU21.rod
    H01 0010
       Coding: 3A0000
    H01 0010
       Coding: 3A0000
    0061 - Function Restriction due to Implausible Message(s)
              U1112 00 [137] - -
              [Fehlerhafter DLC der CAN-Messages Kamera_Status  (0x318)]
                        Reset counter: 74
                        Mileage: 277504 km
                        Date: 2020.01.27
                        Time: 15:59:46
       Part No SW: 4G0 035 053 E    HW: 4G0 035 053
       Component: Radio U Basic H52 0093
       Revision: AB001007    Serial number: 050ET0B7557008
       Coding: 010003010000000001
       VCID: 201AE81D5ACBAC47E97-8074
       Part No SW: 4G0 035 670 G    HW: 4G0 035 670
       Component: H-BNT-EU      H46 0484
       Revision: --------    Serial number: 428EZ0B7514724
       Coding: 090100040003F1EF55108B3E00000003000001000000000000
       VCID: 2708F3013FE55B7FA8D-8072
       Subsystem 1 - Part No: 8R0 060 884 N
       Component: EUR 2011  1205
       Subsystem 2 - Part No SW: 4G0 919 605 A    HW: 4G0 919 605 A
       Serial number: AUZ8ZDB1300RSB/
       Subsystem 3 - Part No SW: 4G1 919 610 C    HW: 4G1 919 612 L
       Component: E380 BDT C7  H08 0204
       Serial number: 90349KEE0001W
       Component: CD-Database  2712
       Part No SW: 4G8 959 795 C    HW: 4G8 959 795 A
       Component: TSG HL        H03 0210
       Coding: 010F14224000628002080002
       VCID: 42DE4295B4879E579F3-8016
       Part No SW: 4G0 907 441 A    HW: 4H0 907 441
       Component: SG Rueckfahrkamera  0050
       Revision: --H04---    Serial number: 525 PA8J14F17D
       Coding: 1020013
       VCID: 2514F90949E9496F9A1-8070
       Part No SW: 4G8 959 107 D    HW: 4G8 959 107
       Component: HDSG-Modul    H12 0036
       Revision: 11012001    Serial number: 114100415
       Coding: 0A3205C000
       ASAM Dataset: EV_HDSGAu573 001014
       ROD: EV_HDSGAu571.rod
       Component: TSG HR        H03 0210
       Part No SW: 4G0 907 217 A    HW: 4H0 907 217 A
       Component: DPC-SG        H24 0038
       Coding: E4060000
       Shop #: WSC 04653 141 00001
       ROD: EV_OnBoardCamerDPC.rod
    0500 - Control Module For Camera
              C110A 54 [009] - Missing Calibration / Basic Setting
              [Camera_not_or_erroneously_calibrated]
                        Reset counter: 74
                        Mileage: 277504 km
                        Date: 2020.01.24
                        Time: 08:50:16
                        Outside air temperature: -43.0 °C
                        Voltage terminal 15: 12.2 V
                        Control Module temperature: 15.0 °C
       Part No SW: 4H0 980 945     HW: 4H0 980 945
       Component: RGS-VL        H05 0070
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
       VCID: 6FB8DB21D715433F20D-803A
       Part No SW: 4H0 980 946     HW: 4H0 980 946
       Component: RGS-VR        H05 0070
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R.rod
       VCID: 70BAD85DCA2B5CC7397-8024
    End----(Elapsed Time: 02:18, VBatt start/end: 12.7V/12.2V. VIgn 0.0V)------
    Yep, looks like the camera needs to be calibrated. That requires special target equipment. If your dealer does not know how to do this (or have the equipment to do so), you'll have to find a better dealer.
    HQ
    I've poked around here a little bit and notice the following:
    The soft coding of Address 55: Headlight Range (J431), you have the this value:
    11236F33F91AEB00
    Byte 6, bit 6 is enabled for "Camera (PR-8N2) installed".
    As per PL24, 8N2 is a rain/light sensor, which this car has, it is subsystem 2 of the Central Electronics.
    So.... do the headlights come on automatically? Do the wipers come on automatically?
    Jef
    Jul 2019
    Malaysia
    11236F33F91AEB00
    Hi, I have the same problem on my A6 C7 2011. Same fault codes. In my case the headlights and wipers do come on automatically. I have not resolve the issue until now. Thinking of changing the J431 module. I hope I can find the solution in this thread.
