Results 1 to 7 of 7
Thread: Cluster Coding Values
    Feb 2018
    Nigeria
    I've just installed a used cluster on my 2006 Golf (1K) for Europe. The coding value on it is 0019103. The original cluster had 0007103. The difference is in the options reference of 19 and 07. What do these two signify as neither is represented on the Ross-Tech code chart?
    Got a VCDS Auto-Scan you can share with us?
    Feb 2018
    Nigeria
    Sorry, I didn't save the copy in the VCDS. But I have it on my PC
    Saturday,18,January,2020,09:46:34:52522
    VIN: WVWZZZ1KZ6W085668   License Plate:
    Mileage: 220760km-137173mi   Repair Order:
    Chassis Type: 1K (1K0)
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 55 56 76 77
    VIN: WVWZZZ1KZ6W085668   Mileage: 220760km-137173miles
    Address 01: Engine        Labels: 06A-906-033-BGU.lbl
       Part No: 06A 906 033 EN
       Component: SIMOS71 1.6l 2VG    7004
       Revision: --H01---    Serial number: VWZ7Z0E2910569
       Coding: 0000075
       Shop #: WSC 06402 785 00200
       VCID: 6FBB2E3B7B91DEDF20D-803A
    Readiness: 0010 1001
       Part No: 09G 927 750 DK
       Component: AQ 250 6F           0646
       Coding: 0000008
       Shop #: WSC 01279 785 00200
       VCID: 7DA7047321FDBC4FA21-8028
    Address 03: ABS Brakes        Labels:. 1K0-614-517-MK60AT.clb
       Part No SW: 1K0 614 517 AC    HW: 1K0 614 517 AC
       Component: ESP FRONT MK60-AT   0102
       Revision: 00H13001
       Coding: 0021121
       VCID: 688945275E7F09E7617-803C
       Part No: 1K0 907 044 BE
       Component: ClimatronicPQ35 090 0808
       VCID: 6B833A2B4F8922FF0C5-803E
    00797 - Sunlight Photo Sensor (G107)
    00709 - Sunlight Photosensor 2 (G134)
       Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
       Component: Bordnetz-SG     H37 1002
       Revision: 00H37000    Serial number: 00000005090850
       Coding: E78F8F2700041800001400001400000000097F075C
       Shop #: WSC 00000 785 00200
       VCID: 2B03FA2B8F09E2FF4C5-807E
       Subsystem 1 - Part No: 1K1 955 119 C  Labels: 1KX-955-119.CLB
       Component: Wischer VW350  013  0402
       Coding: 00065493
       Subsystem 2 - Part No: 1K0 955 559 T  Labels: 1K0-955-559-AF.CLB
       Component: RegenLichtSens 011  1110
       Coding: 00208933
    02498 - Left Low Beam Reflector Motor (V294)
                        Fault Status: 01111100
                        Reset counter: 169
                        Mileage: 220574 km
                        Voltage: 13.65 V
       Part No SW: 1K0 909 605 N    HW: 1K0 909 605 N
       Component: 2E AIRBAG VW8   015 2100
       Revision: 03015000    Serial number: 0038ED0P1NNO
       Coding: 0012869
       Shop #: WSC 01269 785 00200
       VCID: 372BD65B4341561F38D-8062
       Subsystem 1 - Serial number: 6332MSME0C641D73H
       Subsystem 2 - Serial number: 6342MSME0C5F0226E
       Subsystem 3 - Serial number: 6352QSME0603405B6
       Subsystem 4 - Serial number: 6362QSME05511F29G
       Part No SW: 1K0 953 549 AF    HW: 1K0 953 549 AF
       Component: Lenksäulenmodul 634 0070
       Coding: 0010042
       VCID: 76B51B5F04CBEF17E3B-8022
       Part No: 1K0 920 872 J
       Component: KOMBIINSTRUMENT VDD 4312
       Coding: 0007103
       Shop #: WSC 00999 444 64523
       VCID: 323DE74FA823B3370F3-8066
    00771 - Fuel Level Sensor (G)
       Part No SW: 1K0 907 530 F    HW: 1K0 907 951
       Component: Gateway         H10 0120
       Revision:   H10       Serial number: 2800105A2709BF
       Coding: 7F0F07C0070002
       VCID: 2A0DFF2F80F3FBF7B73-807E
                        Reset counter: 169
                        Mileage: 220436 km
                        Time: 11:03:10
                        Fault Frequency: 9
                        Reset counter: 182
                        Time Indication: 15
                        Reset counter: 169
                        Mileage: 220587 km
                        Time: 18:46:08
    01304 - Radio
                        Reset counter: 169
                        Mileage: 220587 km
                        Time: 18:46:11
                        Reset counter: 169
                        Mileage: 220587 km
                        Time: 18:46:08
       Component: IMMO            VDD 4312
       Shop #: WSC 00137 211 56823
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX2.lbl
       Part No: 1K0 959 701 L
       Component: Tuer-SG         024 2481
       Coding: 0000182
    01706 - Switch for Mirror-Adjust (E43)
    00096 - Drivers Door Central Locking (Safe) Motor (V161)
       Part No: 1K1 909 144 K
       VCID: 3333E24B5739BA3F045-8066
       Part No SW: 1K0 959 433 AR    HW: 1K0 959 433 AR
       Component: 01 KSG PQ35 G2  010 0101
       Revision: 00010000    Serial number: 00000000000000
       Coding: 809002085103087F2D04840570084B06F0A040
       VCID: 00597D87560FD1A7C97-8054
                        Reset counter: 157
                        Mileage: 220587 km
                        Time: 21:49:34
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX2.lbl
       Part No: 1K0 959 702 L
       Coding: 0000182
       VCID: 3829D5674E5F5967317-806C
       Part No: 1T0 907 357
       Coding: 0000003
       VCID: 74B1215712B7FD07DDF-8020
    Address 56: Radio
    Address 76: Park Assist        Labels: 1K0-919-283.lbl
       Part No: 1K0 919 283 A
       Component: 22 Einparkhilfe     0101
       VCID: 2D07F433B11DECCF521-8078
    01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
                009 - Open or Short to Ground
    Address 77: Telephone
    End----------(Elapsed Time: 01:07, VBatt start/end: 14.2V/14.1V)-----------
    Address 08: DTCs clearedFriday,24,January,2020,14:40:29:52522
    Address 01: Engine
       Coding: 0000008
       Revision: 00H13001
       Coding: 0021121
       Coding: 00065493
       Coding: 00208933
       Coding: 0012869
       Coding: 0010042
       Part No SW: 1K0 920 874 A    HW: 1K0 920 874 A
       Component: KOMBIINSTRUMENT VDD 2416
       Revision: V0005000    Serial number: VWZ7Z0E2910569
       Coding: 0019103
       Shop #: WSC 00000 000 393216
                        Fault Status: 00100011
                        Reset counter: 211
                        Mileage: 197129 km
                        Time: 00:16:35
                        Fault Frequency: 25
                        Reset counter: 171
                        Mileage: 197129 km
                        Time: 00:10:50
    01304 - Radio
                        Fault Frequency: 25
                        Reset counter: 171
                        Mileage: 197129 km
                        Time: 00:10:55
                        Fault Frequency: 25
                        Reset counter: 171
                        Mileage: 197129 km
                        Time: 00:10:55
       Component: IMMO            VDD 2416
    00003 - Control Module
                014 - Defective
                        Fault Status: 01101110
                        Mileage: 88423 km
                        Time: 15:29:43
       Coding: 0000182
                        Reset counter: 171
                        Mileage: 220761 km
                        Time: 00:39:06
       Coding: 0000182
       Coding: 0000003
    Address 56: Radio
    End----------(Elapsed Time: 01:19, VBatt start/end: 14.0V/14.0V)-----------
    Friday,24,January,2020,15:34:07:52522
       Coding: 0000075
    Readiness: 0010 1101
       Coding: 0000008
       Revision: 00H13001
       Coding: 0021121
       Coding: 00065493
       Coding: 00208933
       Coding: 0012869
       Coding: 0010042
       Coding: 0019103
                        Reset counter: 171
                        Mileage: 220764 km
                        Time: 14:40:13
    01304 - Radio
                        Reset counter: 171
                        Mileage: 220764 km
                        Time: 14:40:18
                        Reset counter: 171
                        Mileage: 220764 km
                        Time: 14:40:18
                014 - Defective
                        Mileage: 88423 km
                        Time: 15:29:43
       Coding: 0000182
       Coding: 0000182
       Coding: 0000003
    Address 56: Radio
    End----------(Elapsed Time: 01:03, VBatt start/end: 13.2V/13.2V)-----------
    Friday,24,January,2020,17:45:13:52522
       Coding: 0000075
       Coding: 0000008
       Revision: 00H13001
       Coding: 0021121
       Coding: 00065493
       Coding: 00208933
       Coding: 0012869
       Coding: 0010042
       Coding: 0019103
                        Fault Frequency: 21
                        Reset counter: 171
                        Mileage: 220764 km
                        Time: 14:40:13
    01304 - Radio
                        Fault Frequency: 21
                        Reset counter: 171
                        Mileage: 220764 km
                        Time: 14:40:18
                        Fault Frequency: 21
                        Reset counter: 171
                        Mileage: 220764 km
                        Time: 14:40:18
                014 - Defective
                        Mileage: 88423 km
                        Time: 15:29:43
       Coding: 0000182
       Coding: 0000182
       Coding: 0000003
    Address 56: Radio
    End----------(Elapsed Time: 01:05, VBatt start/end: 13.9V/14.0V)-----------
    Oct 2014
    Arandjelovac, Serbia
    Moved from Uwe's Bar per members request.
  5. Likes Uwe liked this post
    +00 = No Options
    +01 = Brake Pad Warning
    +02 = Seatbelt Warning
    +04 = Washer Fluid Warning
    +16 = Sedan (only VW Jetta)
    7 = 1 + 2 + 4.
    19 = 1 + 2 + 16.
    Feb 2018
    Nigeria
    +00 = No Options
    7 = 1 + 2 + 4.
    19 = 1 + 2 + 16.
    Nice. Many thanks.
  8. Likes Boki Ar liked this post
    Feb 2018
    Nigeria
    Just to feedback. My original coding (0007103) has been programmed to the newly installed (used) cluster.
