Results 1 to 7 of 7
Thread: 2018 Audi B9 A5 Steering Angle Calibration Issue
    Jan 2020
    Recently changed steering wheel, and in the process I broke clock spring. Ordered a new Steering wheel column multi-function switch, and took out just the clock spring and replaced it on the current/factory column switch.
    A5 is still mad and triggers warnings on EPS, Audi Pre-sense, steering wheel malfunction, blind spot, and other steering related assist features. I tried auto calibration by turning steering wheel at least 30 degrees to left or right then drive straight kind of thing, then tried to reset angle to 0 by going into Select -> 16-Steering wheel but it gives an error that some requirements are not met. I can take a screenshot of the exact error message if its important.
    Wednesday,22,January,2020,21:00:07:60834
    Dealer/Shop Name: TheGarageAuto31
    VIN: WAUENCF51JA129563   License Plate:
    Chassis Type: F5-AU49 (8W6)
    Scan: 01 02 03 08 09 15 16 17 19 29 36 39 3C 42 44 46 47 52 5F 6C
              6D 81 A5 A9 BB BC CA CF D6 D7
    VIN: WAUENCF51JA129563   Mileage: 26300km-16342miles
    CA-Sunroof -- Status: OK 0000
    CF-Lane Chge Asst 2 -- Status: Malfunction 0010
    Address 01: Engine (J623-CYMC)       Labels:. 06K-907-425-V2.clb
       Part No SW: 8W0 906 259 J    HW: 06L 907 425 C
       Component: 2.0l R4 TFSI  H15 0002
       Revision: --H15---
       Coding: 1A2500322326010E34280000000000000000000000000000
       Shop #: WSC 06314 790 00001
       ASAM Dataset: EV_ECM20TFS0208W0906259J 001003
       ROD: EV_ECM20TFS020_AU49.rod
       VCID: 48C95FD9323D2167417-801C
    17178 - Databus
              U1123 00 [047] - Received Error Message
                        Mileage: 26223 km
                        Date: 2020.01.21
                        Time: 21:46:05
                        Engine speed: 1372.75 /min
                        Normed load value: 6.3 %
                        Coolant temperature: 96 °C
                        Intake air temperature: 44 °C
                        Voltage terminal 30: 11.875 V
                        Engine: operating status: IS
                        ECU_STATE: SYN_ENG_IGK_ON
                        ACC variants (coding): CCS
    23081 - Implausible Data Received from Steering Column Control Module
              U0429 00 [047] - -
                        Mileage: 26223 km
                        Date: 2020.01.21
                        Time: 21:26:53
                        Engine speed: 766.25 /min
                        Normed load value: 11.4 %
                        Vehicle speed: 255 km/h
                        Coolant temperature: 91 °C
                        Intake air temperature: 31 °C
                        Voltage terminal 30: 14.921 V
                        LF_MVB_PDU_INTC_DIAG_1: 0
                        LF_MVB_PDU_INTC_DIAG_2: 49152
                        LF_MVB_PDU_INTC_DIAG_3: 3
                        LF_MVB_PDU_INTC_DIAG_4: 12288
                        LF_MVB_PDU_INTC_DIAG_5: 0
                        LF_MVB_PDU_INTC_DIAG_6: 61472
                        LF_MVB_BUS_INTC_DIAG: 256
    Readiness: 1000 0100
       Part No SW: 8W2 927 155 BA    HW: 0CJ 927 156
       Component: 0CL 20TFSINAR H05 0001
       Revision: --H05---    Serial number: 0000000831
       Coding: 000001
       ASAM Dataset: EV_TCMDL382021 002027
       ROD: EV_TCMDL382021_AU49.rod
       VCID: 015F82FD5187D02FC69-8054
       Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 L
       Component: V553 MTFP  003 0576
       Serial number: 75145041180171000039
    Address 03: ABS Brakes (J104)       Labels: 8W0-907-379-PLU-V1.clb
       Part No SW: 8W0 907 379 Q    HW: 8W0 907 379 J
       Component: ESP9 Plus     H10 0775
       Coding: 18AA409A28A40A9F11A3489700805292E5359A180214508812004A49A7AC59
       Shop #: WSC 06334 790 00001
       ASAM Dataset: EV_ESP9BOSCHCMP 002013
       ROD: EV_ESP9BOSCHCMP_002.rod
       VCID: 53F378B5FB7B92BF245-8006
    6293504 - Steering Angle Sensor
              C2008 00 [175] - Signal Qualification
                        Mileage: 26223 km
                        Date: 2020.01.21
                        Time: 21:26:53
                        95 00 00 00 CA 00 00 00 00 00
                        Unlearning counter according OBD-OBD unlearning counter: 28
    Address 08: Auto HVAC (E87)       Labels:* Redir Fail!
       Part No SW: 8W0 820 043 T    HW: 8W0 820 043 T
       Component: Klima Zone 3  H60 0251
       Coding: 140805095548000D10000100880000000000000000000000000000000000
       Shop #: WSC 06335 790 00001
       ROD: EV_AirCondiBHTCAU491.rod
       VCID: 44D14BE90E150507ADF-8010
       Subsystem 1 - Part No SW: 4M1 820 021 B    HW: 4M1 820 021 B
       Component: J126 FLuftV  H09 0003
       Serial number: 00000000000002543233
       Component: AQ_Hum_Sensor  H02 0007
       Serial number: 5080153900PAG0MUFU02
       Subsystem 3 - Part No SW: 8W0 919 158 A    HW: 8W0 919 158 A
       Component: E265 Kli Fond  H40 0080
       Part No SW: 8W0 907 063 CG    HW: 8W0 907 063 BG
       Component: BCM1 MLBevo   H13 0267
       Coding: 07500363E0081CCD0515871518AC98B9110B3D08000000000000000020001A010A690122025705
       VCID: 025D8DF15481CB37DF3-8056
       Subsystem 1 - Part No SW: 8W6 955 119     HW: 8W6 955 119   Labels: 1KX-955-119.CLB
       Component: 494 LL 050618  036 0471
       Serial number: 00000001805290301894
       Coding: 5FC7F7
       Serial number: 21563837X81A955555A0
       Coding: 02005D
       Light switch:
       Subsystem 3 - Part No SW: 4M0 941 531 AK    HW: 4M0 941 531 AK
       Component: E1 - LDS  H06 0008
       Serial number: 28 03 2018  01380012
       Subsystem 4 - Part No SW: 4N0 907 410 A    HW: 4M0 907 410 A
       Component: USHL5  H10 0100
       Serial number: 0000009600350Z012602
       Coding: 350000
       Subsystem 5 - Part No SW: 4M0 959 719 A    HW: 4M0 959 719 A
       Component: GTO BF  H01 0010
       Serial number: 20180611185947 01062
       Subsystem 6 - Part No SW: 8W0 857 511 B    HW: 8W0 857 511 B
       Component: Y7_Innenspieg  H01 0002
       Serial number: GX1CE113041823610455
       Interior Light Module:
       Subsystem 7 - Part No SW: 8W0 947 135 CS    HW: 8W0 947 135
       Component: J528-Dachele  H14 0130
       Serial number: B00863956
       Subsystem 8 - Part No SW: 8W0 925 301 BC    HW: 8W0 925 301 BC
       Component: SL-B9/Q5NF  H17 0010
       Serial number: 2818000059627004
    131945 - Databus
              [EPS control module: received error value in signal EPS_steering-rack_pos]
                        Reset counter: 225
                        Mileage: 26223 km
                        Date: 2020.01.21
                        Time: 21:26:52
                        average_Voltage_terminals: 15.00 V
                        Outside air temperature sensor-Resistance: 2.56 kOhm
                        Outside air temperature sensor-Outside air temperature on CAN: -3.00 °C
                        interior_temperature: 16.00 °C
                        Vehicle speed: 0.00 km/h
    196758 - Databus
              [Brake control module: received error value in signal ESP system status]
                        Fault Frequency: 7
                        Reset counter: 225
                        Mileage: 26223 km
                        Date: 2020.01.21
                        Time: 21:26:53
    196761 - Databus
              [Power steering control module: received error value in signal EPS steering rack position]
                        Fault Frequency: 7
                        Reset counter: 225
                        Mileage: 26223 km
                        Date: 2020.01.21
                        Time: 21:26:53
    Address 15: Airbags (J234)       Labels:| 8W0-959-655.clb
       Part No SW: 8W0 959 655 G    HW: 8W0 959 655 G
       Component: Airbag10.44   H05 0107
       Serial number: 003UQ00315ZH
       Coding: BFCCF0C000800000A0000033D24C00000000
       ASAM Dataset: EV_AirbaAU10BPAAU736 006016
       ROD: EV_AirbaAU10BPAAU736_006_AU49.rod
       VCID: 4DC76ECDDD5FC44F721-8018
       Belt Pretensioner left:
       Subsystem 1 - Part No SW: 4M0 980 945 B    HW: 4M0 980 945 B
       Component: BeltPretRevFL  306 2033
       Serial number: 8W0857705G0173S01599
       Coding: 80000D
       Belt Pretensioner right:
       Subsystem 2 - Part No SW: 4M0 980 946 B    HW: 4M0 980 946 B
       Component: BeltPretRevFR  306 2033
       Serial number: 8W0857706J0178S00012
       Coding: 80000D
       Occupant Detection:
       Subsystem 3 - Part No SW: 4M0 959 339     HW: 4M0 959 339
       Component: BF-Gewichtss.  H11 0022
       Serial number: IBH0000J180009PM0708
       Subsystem 4 - Part No SW: -----------    HW: 442 062 706 18
       Serial number: 3577Y0099279D02434A%
       Subsystem 5 - Part No SW: -----------    HW: 442 062 706 18
       Serial number: 3587Y00B527DBDE293BT
       Subsystem 6 - Part No SW: -----------    HW: 442 0B2 106 18
       Serial number: 3517700AF2A77571E2BS
       Subsystem 7 - Part No SW: -----------    HW: 442 0B2 006 18
       Serial number: 3527700A729299631444
       Subsystem 8 - Part No SW: -----------    HW: 442 0C2 106 18
       Serial number: 3557500A72AEF870B14S
       Front Sensor Passenger:
       Subsystem 9 - Part No SW: -----------    HW: 442 0C2 106 18
       Component: FrontSensor_P  1C5 014A
       Serial number: 3567500A72AEF870E11T
    9682162 - Multiple collision brake
              B13BC F2 [137] - No function
                        Reset counter: 188
                        Mileage: 24871 km
                        Date: 2020.01.06
                        Time: 07:24:58
    1050117 - Databus
              [NWD: 0x086 LWI_01 error value LWI_Lenkradwinkel]
                        Reset counter: 223
                        Mileage: 26223 km
                        Date: 2020.01.21
                        Time: 21:26:52
    1061893 - Databus
              [NWD: 0x0A0 LH_EPS_04 error value EPS_Zahnstangen_Pos]
                        Reset counter: 225
                        Mileage: 26223 km
                        Date: 2020.01.21
                        Time: 21:26:52
       Part No SW: 4M0 907 129 GK    HW: 4M0 907 129 GK
       Component: Lenks.Modul   H11 0009
       ROD: EV_SMLSKLOAU736_006.rod
       VCID: 7F5B04052773A6DFB0D-802A
    5586944 - Steering angle sensor
              B1168 04 [009] - Internal System Fault
                        Mileage: 24945 km
                        Date: 2020.01.06
                        Time: 18:36:19
                        Freeze_Frame_SAS_Failures-Angle_Qualifier: 00
                        Freeze_Frame_SAS_Failures-corresponding_SAS_Velocity: 0 °/s
                        Freeze_Frame_SAS_Failures-last_valid_Sign_Steering_Angle_Main: 00
                        Freeze_Frame_SAS_Failures-last_valid_Steering_Angle_Main: 192.0 °
                        Freeze_Frame_SAS_Failures-second_to_last_valid_Sign_Steering_Angle_Main: 00
                        Freeze_Frame_SAS_Failures-second_to_last_valid_Steering_Angle_Main: 192.0 °
                        Freeze_Frame_SAS_Failures-Sign_SAS_Speed: 00
                        Freeze_Frame_SAS_Failures-Vehicle_Speed_FL: 0.00 km/h
                        Freeze_Frame_SAS_Failures-Voltage_12V: 12060.94 mV
                        Freeze_Frame_SAS_Failures-VZ_Vehicle_Speed_VL: 00
       Part No SW: 8W5 920 890 G    HW: 8W5 920 890 G
       Component: FBenUSA       H19 0377
       Coding: 09E641C72888CF05022369601800000008000000
       ASAM Dataset: EV_DashBoardAU736 001027
       VCID: 47CB5CE53F232E1F48D-8012
       Part No SW: 8W6 907 468 F    HW: 8W6 907 468 E
       Component: Gateway       H43 0123
       Revision: 7B000002    Serial number: 0287B773918629
       Coding: 030100010000064029070000005900126C180007100000000175078E10000000
       ASAM Dataset: EV_CGateCONTIAU491 003111
       ROD: EV_CGateCONTIAU491_003_AU49.rod
       Subsystem 1 - Part No SW: 36A 953 509 C    HW: 36A 953 509 C
       Component: J453 MFL  H04 0002
       Serial number: 20170109105555 RD058
       Serial number: 0136468404
    Address 29: Left Light (J1018)       Labels: 4M0-907-397.clb
       Part No SW: 4M0 907 397 AC    HW: 4M0 907 397 C
       Component: LCM_MLBevoH05 0024
       VCID: 78A9EF19025D91E7F17-802C
       Part No SW: 4M4 959 760     HW: 4M4 959 760
       Component: MEM-FS        009 0042
       Serial number: 00000330825135
       Coding: 005C1B000000B0010000010101010000000000000000000000000000000000
       VCID: 79AFEA1D395788EF8E9-802C
    Address 39: Right Light (J1023)       Labels: 4M0-907-397.clb
    Address 3C: Lane Change (J769)       Labels:* None
       Part No SW: 4M0 907 566 E    HW: 4M0 907 566
       Component: MRR1Rear      H20 0430
       Revision: --------
       Coding: 0E8002
       ASAM Dataset: EV_RearRadarS1BoschAU736 001022
       ROD: EV_RearRadarS1BoschAU736.rod
       VCID: 372B2C254FC35E9F38D-8062
    1192224 - Databus
              [databus error value received - EPS_Zahnstangen_Pos]
                        Reset counter: 223
                        Mileage: 26223 km
                        Date: 2020.01.21
                        Time: 21:26:51
                        Control Module temperature: 31 °C
                        Voltage terminal 30: 15.00 V
                        Terminal 15 status: On
                        Voltage terminal 15: Measured value not available
    1192210 - Databus
              [databus error value received - ESP_Systemstatus]
                        Reset counter: 223
                        Mileage: 26223 km
                        Date: 2020.01.21
                        Time: 21:26:51
                        Voltage terminal 30: 14.90 V
    267010 - Databus
              [FAULT_SLAVE]
                        Reset counter: 223
                        Mileage: 26223 km
                        Date: 2020.01.21
                        Time: 21:26:51
       Part No SW: 4M0 959 793 H    HW: 4M0 959 793 F
       Component: TSG FS        005 0129
       Serial number: 0000329063667
       Coding: 005F4B625E00108000010432
       VCID: 43D348F50B1B023F945-8016
       Part No SW: 8W0 909 144 H    HW: 8W0 909 144 B
       Component: EPS_MLBEVO_ZF H08 0410
       Coding: 09000380008000
       ASAM Dataset: EV_EPSZFAU49X 003023
       ROD: EV_EPSZFAU49X_003.rod
       VCID: 42DD4DF114010B379F3-8016
    44032 - Terminal 30
              U140A 00 [008] - Open Circuit
              [KFC_RESET_ZERO]
                        Reset counter: 8
                        Mileage: 26223 km
                        Time: 00:00:00
                        Expanded ambient data 1-Engine running: Engine_Running_Stable
                        Expanded ambient data 1-Supply voltage: 0.00 V
                        Expanded ambient data 1-Temperature: -70 °C
                        Expanded ambient data 1-System status: 4
                        Expanded ambient data 1: 00
                        Expanded ambient data 1-driving_direction: 0
                        Expanded ambient data 1-KFA: 0
                        Expanded ambient data 1-KFC: 172
                        Expanded ambient data 1-Ready_To_Drive_Bit: 0
                        Expanded ambient data 1-StartStop Info: 0
                        Expanded ambient data 1-Steering_Angle_Calculated: 0 °
                        Expanded ambient data 1-Steering_Angle_Calculated_Sign: 0
                        Expanded ambient data 1-Steering_torque: 0.00 Nm
                        Expanded ambient data 1-Steering_Torque_Sign: 0
                        Expanded ambient data 14-KFA_FAST_RESET: 0
                        Expanded ambient data 14-KFC_FAST_RESET: 0
                        Expanded ambient data 14-Switched_voltage_terminal_30_unfiltered: 14.91 V
                        Expanded ambient data 14-Voltage_terminal_30_unfiltered: 15.03 V
    27136 - Databus
              [KFC_LWI_01_SNA]
                        Reset counter: 223
                        Mileage: 26223 km
                        Expanded ambient data 1-System status: 5
                        Expanded ambient data 1-KFC: 106
                        Expanded ambient data 1-Steering_torque: 0.20 Nm
                        Expanded ambient data 15-MsgStateFifo_Byte0: 00 00 00 00
                        Expanded ambient data 15-MsgStateFifo_Byte1: FF FF FF FF
                        Expanded ambient data 15-MsgStateFifo_Byte2: FF FF FF FF
                        Expanded ambient data 15-MsgStateFifo_Byte3: FF FF FF FF
                        Expanded ambient data 15-NumOfMsgCntFaults: 00
                        Expanded ambient data 15-NumOfMsgCrcFaults_2: 00
                        Expanded ambient data 15-NumOfMsgNoFaults_3: 00
                        Expanded ambient data 15-NumOfMsgTimoFaults_1: 00
    17664 - Databus
              [KFC_ESP_22_SNA]
                        Reset counter: 225
                        Mileage: 26223 km
                        Expanded ambient data 1-KFC: 69
                        Expanded ambient data 15-MsgStateFifo_Byte1: 00 00 00 00
                        Expanded ambient data 15-MsgStateFifo_Byte2: 00 00 00 00
                        Expanded ambient data 15-MsgStateFifo_Byte3: 00 00 00 00
       Part No SW: 8W0 907 064 EC    HW: 8W0 907 064 DC
       Component: BCM2 MLBevo   025 0387
       Coding: 013400004FB100C0650BA0006E01080233024000810026502F0400000F04803F001E0001000000
       ASAM Dataset: EV_BCM2HellaAU736 014014
       ROD: EV_BCM2HellaAU736_014_AU49.rod
       Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
       Serial number: 000000000ZY181421QES
       Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
       Serial number: 00000000000099409366
       Subsystem 3 - Part No SW: 3AA 962 243 H    HW: 3AA 962 243 H
       Component: GEB.F.Heckoef  H16 0905
       Serial number: 12045793
    65896 - Databus
              [Climatronic control module: Klima_03: no signal/communication]
                        Fault Frequency: 11
                        Reset counter: 10
                        Mileage: 26224 km
                        Date: 2020.01.21
                        Time: 21:49:54
                        Supply voltages-Supply voltage: Terminal 30: 12.745 V
                        Supply voltages-Supply voltage Terminal 30 - 2: 12.758 V
                        Supply voltages-Supply voltage Terminal 30 - 3: 12.785 V
                        general_additional_freeze_frame-Ambient_temperature_not_filtered: -50.0 °C
                        general_additional_freeze_frame-coprocessor_spi_status: 00000000
                        general_additional_freeze_frame-dataflash_status: 00000000
                        general_additional_freeze_frame-interior_temperature: -50.0 °C
                        general_additional_freeze_frame-Operating_Status: 00000000 00000000
                        general_additional_freeze_frame-production_mode: not active
                        general_additional_freeze_frame-reset_cause: 00000000
                        general_additional_freeze_frame-Reset_counter: 0
                        general_additional_freeze_frame-Stall_current_cutoff_level: Deactivation stage 0
                        general_additional_freeze_frame-Stall_Current_Measuring_Mode: not active
                        general_additional_freeze_frame-subnetwork_status: 00000000 00000000
                        general_additional_freeze_frame-terminal_control_intern_status: 40 04 5A 10 00 80
                        general_additional_freeze_frame-Transport_Mode: not active
                        general_additional_freeze_frame-Vehicle speed: 0.00 km/h
                        can_lin_communication_freeze_frame: 00000000 00000000 00000000 00000000
       Part No SW: 8W0 035 465     HW: 8W0 035 465
       Component: MIB2_amp_P_B9 H11 0420
       Revision: 00000001    Serial number: AUZ8ZAJJA04H61W
       Coding: 0194030800AFAAAFAA0000010000
       ASAM Dataset: EV_AMPMst16C2Gen2ALPI 001012
       ROD: EV_AMPMst16C2Gen2ALPI.rod
       VCID: 76B5E1210849E797E3B-8022
       Part No SW: 4M0 959 792 H    HW: 4M0 959 792 F
       Component: TSG BFS       005 0129
       Serial number: 0000329102500
       Coding: 005F4B225E00108000010430
    Address 5F: Information Electr. (J794)       Labels:* 8W0-035-MIB-HGH2.clb
       Part No SW: 8W5 035 880 D    HW: 8W5 035 880
       Component: MU-P-LNS-US   034 1320
       Serial number: A798F0JB111166
       Coding: 019403020000000053220002041A00102F000EE501700904FE
       VCID: 40D947F91A0D1927897-8014
       Subsystem 1 - Part No SW: V03 959 803 AF    HW: -----------
       Component: NAR 2020  --- 0076
       Subsystem 2 - Part No SW: 8W1 919 605     HW: 8W1 919 605
       Component: DU High AU49x  H32 0170
       Serial number: TPO00118051800820292
       Multimedia Operating Unit:
       Subsystem 3 - Part No SW: 8W0 919 614 T    HW: 8W0 919 614 T
       Serial number: APVAK115061800020901
       Component: Gracenote2  --- 3012
              B11CF 53 [009] - Deactivated
                        Reset counter: 223
                        Mileage: 26224 km
                        Date: 2020.01.22
                        Time: 07:26:18
                        Voltage terminal 30: 13.0 V
                        Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
                        Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
    Address 6C: Back-up Cam. (J772)       Labels:* Redir Fail!
       Part No SW: 4M0 980 556 A    HW: 4M0 980 556 A
       Component: RVC Compact   H12 0250
       Coding: 0294030102002001400040
       ASAM Dataset: EV_CamSysRVRVCPANAMLBEv 005010
       ROD: EV_CamSysRVRVCPANAMLBEv_005_AU49.rod
       VCID: 333318355BBBB2BF045-8066
    13705996 - Databus
              [Errorvalue-monitoring LH_EPS_04.EPS_Zahnstangen_Pos]
                        Reset counter: 223
                        Mileage: 26223 km
                        Date: 2020.01.21
                        Time: 21:26:52
                        passive
       Part No SW: 8W8 959 107 B    HW: 8W8 959 107
       Component: HDSG-Modul    H13 0166
       Revision: --------    Serial number: 32005184600000
       Coding: 0630
       ASAM Dataset: EV_DeckLidCONTIAU736 001016
    Address 81: Gear Shift (J587)       Labels: 4MX-713-041-81.clb
       Part No SW: 8W1 713 041 G    HW: 8W1 713 041 J
       Component: GSM-LL        H09 0077
       Revision: 0L0D5012    Serial number: 18062748001940
       ROD: EV_GSMWaehlZFAU736.rod
    Address A5: Frt Sens. Drv. Assist (R242)       Labels:* Redir Fail!
       Part No SW: 8W6 907 217 A    HW: 8W6 907 217 A
       Component: BVS           H17 0050
       Coding: 0404090300000203022023A2A50000FC00F0C020C000
       ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
    8 Faults Found:
    1123080 - Databus
              [LWI_01_LWI_QBit_Lenkradwinkel]
                        Reset counter: 223
                        Mileage: 26223 km
                        Date: 2020.01.21
                        Time: 21:26:52
                        Control Module temperature: 24 °C
                        Voltage terminal 15: 15.00 V
    1123714 - Databus
              [Airbag_01_AB_Systemfehler]
                        Reset counter: 223
                        Mileage: 26223 km
                        Date: 2020.01.21
                        Time: 21:26:56
                        Voltage terminal 15: 14.80 V
    1123157 - Databus
              [LH_EPS_03_EPS_Berechneter_LW]
                        Reset counter: 223
                        Mileage: 26223 km
                        Date: 2020.01.21
                        Time: 21:26:52
    1123159 - Databus
              [LH_EPS_04_EPS_Zahnstangen_Pos]
                        Reset counter: 223
                        Mileage: 26223 km
                        Date: 2020.01.21
                        Time: 21:26:52
    1123173 - Databus
              [ESP_21_ESP_Systemstatus]
                        Reset counter: 223
                        Mileage: 26223 km
                        Date: 2020.01.21
                        Time: 21:26:52
    1123186 - Databus
              [LWI_01_LWI_Lenkradwinkel]
                        Reset counter: 223
                        Mileage: 26223 km
                        Date: 2020.01.21
                        Time: 21:26:52
    1123188 - Databus
              [LWI_01_LWI_Lenkradw_Geschw]
                        Reset counter: 223
                        Mileage: 26223 km
                        Date: 2020.01.21
                        Time: 21:26:52
    1123733 - Databus
              [SWA_01_SWA_rel_Fehler]
                        Reset counter: 225
                        Mileage: 26223 km
                        Date: 2020.01.21
                        Time: 21:26:52
    Address A9: Struct. Borne Sound (J869)       Labels: None
       Part No SW: 8W0 907 159 H    HW: 4H0 907 159 A
       Component: SAS-GEN 2     H07 0008
       Serial number: 180525201207
       VCID: 46D551E138293717B3B-8012
       Part No SW: 4M0 959 795 H    HW: 4M0 959 795 F
       Component: TSG HFS       005 0130
       Serial number: 0000329884414
       Coding: 000F4B220000108040000020
       VCID: 45D756ED052F3C0FBA1-8010
       Component: TSG HBFS      005 0130
       Serial number: 0000329887109
       Coding: 228000049301
       VCID: 3D273E0D6DFF74CFE21-8068
    Address CF: Lane Chge Asst 2 (J770)       Labels: None
       Part No SW: 4M0 907 590 E    HW: 4M0 907 590
       Revision: --------
       Coding: 0E8002
       ASAM Dataset: EV_RearRadarS2BoschAU736 001022
       ROD: EV_RearRadarS2BoschAU736.rod
       VCID: 34311B295EB5B5871DF-8060
    1192224 - Databus
                        Reset counter: 223
                        Mileage: 26223 km
                        Date: 2020.01.21
                        Time: 21:26:51
                        Control Module temperature: 28 °C
       Part No SW: 7PP 941 572 AC    HW: 7PP 941 572 A
       Component: LED1L         H09 0008
       VCID: 176BCCA52F037E9F18D-8042
       Component: LED1R         H09 0008
    End----------(Elapsed Time: 02:08, VBatt start/end: 12.0V/12.0V)-----------
                    Address 16: Steering wheel  (4M0 907 129 GK)
    21:05:51
      IDE08696-MAS00037   Steerg. wheel angle sens.-Calibration status not calibrated
      IDE08696-MAS02128   Steerg. wheel angle sens.-Q bit: steering wheel angle invalid
      IDE08696-MAS02358   Steerg. wheel angle sens.-Calibration angle outside permissible range
      IDE08696-MAS02406   Steerg. wheel angle sens.-Steering wheel angle: internal value 295.0 °
      IDE08696-MAS02453   Steerg. wheel angle sens.-Steering wheel angle offset 0.0 °
      IDE08696-MAS02983   Steerg. wheel angle sens.-Steering wheel angle 819.1 °
    21:05:53
    I see bunch of fault codes and tried clearing ABS Brake, Steering Wheel and Steering Wheel Assist, but no luck so far. I also just started using VCDS, so I figured I'd reach out for help before breaking anything else. Would I be able to calibrate the steering angle using VCDS?
    Any input is greatly appreciated.
    Jan 2020
    Audi Steering Wheel Angle Calibration B9
    Re-posting:
    Recently changed steering wheel on 2018 A5, and in the process I broke clock spring. Ordered a new Steering wheel column multi-function switch, and took out just the clock spring and replaced it on the current/factory column switch.
    Car is still mad and throws bunch of fault codes on steering related assist features. I tried resetting ABS Brake, and auto calibration by turning steering wheel at least 30 degrees to left or right then drive straight kind of trick. Then tried to reset steering angle by going into Select -> 16-Steering Wheel, but it gives an error that some requirements are not met.
    Dealer/Shop Name:
       Revision: --H15---
    17178 - Databus
                        Mileage: 26223 km
                        Date: 2020.01.21
                        Time: 21:46:05
              U0429 00 [047] - -
                        Mileage: 26223 km
                        Date: 2020.01.21
                        Time: 21:26:53
       Coding: 000001
                        Mileage: 26223 km
                        Date: 2020.01.21
                        Time: 21:26:53
       Coding: 5FC7F7
       Coding: 02005D
       Light switch:
       Coding: 350000
    131945 - Databus
                        Reset counter: 225
                        Mileage: 26223 km
                        Date: 2020.01.21
                        Time: 21:26:52
    196758 - Databus
                        Fault Frequency: 7
                        Reset counter: 225
                        Mileage: 26223 km
                        Date: 2020.01.21
                        Time: 21:26:53
    196761 - Databus
                        Fault Frequency: 7
                        Reset counter: 225
                        Mileage: 26223 km
                        Date: 2020.01.21
                        Time: 21:26:53
       Coding: 80000D
       Coding: 80000D
       Occupant Detection:
                        Reset counter: 188
                        Mileage: 24871 km
                        Date: 2020.01.06
                        Time: 07:24:58
    1050117 - Databus
                        Reset counter: 223
                        Mileage: 26223 km
                        Date: 2020.01.21
                        Time: 21:26:52
    1061893 - Databus
                        Reset counter: 225
                        Mileage: 26223 km
                        Date: 2020.01.21
                        Time: 21:26:52
                        Mileage: 24945 km
                        Date: 2020.01.06
                        Time: 18:36:19
       Revision: --------
       Coding: 0E8002
    1192224 - Databus
                        Reset counter: 223
                        Mileage: 26223 km
                        Date: 2020.01.21
                        Time: 21:26:51
    1192210 - Databus
                        Reset counter: 223
                        Mileage: 26223 km
                        Date: 2020.01.21
                        Time: 21:26:51
    267010 - Databus
              [FAULT_SLAVE]
                        Reset counter: 223
                        Mileage: 26223 km
                        Date: 2020.01.21
                        Time: 21:26:51
    44032 - Terminal 30
              [KFC_RESET_ZERO]
                        Reset counter: 8
                        Mileage: 26223 km
                        Time: 00:00:00
    27136 - Databus
              [KFC_LWI_01_SNA]
                        Reset counter: 223
                        Mileage: 26223 km
    17664 - Databus
              [KFC_ESP_22_SNA]
                        Reset counter: 225
                        Mileage: 26223 km
    65896 - Databus
                        Fault Frequency: 11
                        Reset counter: 10
                        Mileage: 26224 km
                        Date: 2020.01.21
                        Time: 21:49:54
                        Reset counter: 223
                        Mileage: 26224 km
                        Date: 2020.01.22
                        Time: 07:26:18
    13705996 - Databus
                        Reset counter: 223
                        Mileage: 26223 km
                        Date: 2020.01.21
                        Time: 21:26:52
                        passive
       Coding: 0630
    8 Faults Found:
    1123080 - Databus
                        Reset counter: 223
                        Mileage: 26223 km
                        Date: 2020.01.21
                        Time: 21:26:52
    1123714 - Databus
                        Reset counter: 223
                        Mileage: 26223 km
                        Date: 2020.01.21
                        Time: 21:26:56
    1123157 - Databus
                        Reset counter: 223
                        Mileage: 26223 km
                        Date: 2020.01.21
                        Time: 21:26:52
    1123159 - Databus
                        Reset counter: 223
                        Mileage: 26223 km
                        Date: 2020.01.21
                        Time: 21:26:52
    1123173 - Databus
                        Reset counter: 223
                        Mileage: 26223 km
                        Date: 2020.01.21
                        Time: 21:26:52
    1123186 - Databus
                        Reset counter: 223
                        Mileage: 26223 km
                        Date: 2020.01.21
                        Time: 21:26:52
    1123188 - Databus
                        Reset counter: 223
                        Mileage: 26223 km
                        Date: 2020.01.21
                        Time: 21:26:52
    1123733 - Databus
                        Reset counter: 225
                        Mileage: 26223 km
                        Date: 2020.01.21
                        Time: 21:26:52
       Revision: --------
       Coding: 0E8002
    1192224 - Databus
                        Reset counter: 223
                        Mileage: 26223 km
                        Date: 2020.01.21
                        Time: 21:26:51
    21:05:51
    21:05:53
    Quote Originally Posted by kartashon View Post
    Re-posting
    Threads merged. Please don't open duplicate threads with the same question about the same car. If someone had an immediate answer for you, I'm sure they'd post it.
    Have you looked at the values from the steering angle sensor?
    I would start with IDE00326 -- Steering wheel angle in the ABS module. It should be close to zero with the front wheels pointed straight ahead and the steering wheel centered. It should go negative when the steering wheel is turned one way and positive when it's turned the other way.
  4. Likes kartashon liked this post
    Jan 2020
    My bad, new here and didn't know existing posts go on top of the first page if I update it. I know that B9 is relatively new and resources are still quite limited, but felt little bit rushed to fix it as like 7 different warning beeps/chimes beat my eardrums every time I start the car.
    As of now, I managed to get steering angle to almost 0 (+-2, within permissible range) when steering wheel is centered, but I get one more reading of 819 degree that flashes back and forth with 0 - is this normal? I did research but was not able to find anything with two steering angles.
    I am still getting errors when trying to reset values or calibrate steering wheel angle. I guess that if I manage to get the 819 degree to near 0, I will be able to reset the value and calibrate steering wheel angle with IDE00326 or similar, but the reading does not seem to change even if I steer.
    I don't think so, but I have no personal experience with that vehicle.
  7. Likes kartashon liked this post
    United States
    You may already have this sorted however this info from Address 16: Steering wheel makes is look like the slip ring could be 1, if not 2, turns off from center mechanically:
    I found a few examples of IDE08696-MAS02406 but this was a non-broken 2018 Audi S5 Cabriolet: https://forums.ross-tech.com/showthr...l=1#post106275
    The wheel probably wasn't perfectly straight but that vehicle had:
    [16-Steering wheel]
    IDE08696-MAS02406,Steerg. wheel angle sens.-Steering wheel angle: internal value,5.2, °
    IDE08696-MAS02453,Steerg. wheel angle sens.-Steering wheel angle offset,0.3, °
    IDE08696-MAS02983,Steerg. wheel angle sens.-Steering wheel angle,4.6, °
    [03-ABS Brakes]
    IDE00326,Steering wheel angle,2.30, °
    I would be inclined to trust the "internal value" because that should be the actual internal G85 data in address 16 itself. If you can get that to zero, and stay on zero, it should be possible to calibrate G85. If you cannot because the readings are erratic please verify that the new unit wasn't a turn or two off center. I hope not because that can damage the unit.
    Jan 2020
    I did not fix it until yesterday actually. Apparently, I thought I only broke the clock spring, but it turned out I did more extensive damage to the steering wheel column. The steering wheel angle: internal value was stuck at 819.1, while steering wheel angle was flickering between the real input value and the internal value. No matter what I did, the internal value did not budge.
    In the beginning I only swapped the clock spring out of the new steering wheel column switch to minimize workloads and risk of breaking something even more. Then I decided to swap the whole column switch, which was an easier job than I imagined, then the flickering on the angle stopped while showing only one value and fixed everything. I manually calibrated the steering wheel angle to be near 0 when steering wheel is pointing straight, and checked that IDE08696-MAS02358: steering wheel calibration angle is in a permissible range. Then drove for few miles, maneuvered widely in an empty parking lot under 15mph hoping that it would calibrate on its own, and it did, as all the warnings went away after restarting the engine. Cleared all default codes including airbags, and they did not comeback on later, at least on the dash. Steering wheel 16-> Basic settings -> Reset steering wheel angle calibration was not throwing any more errors and I was successfully run them as well.
    All the steering wheel related features/assists like blind spot monitoring, ESP, cornering lights, etc, are working. Feels like I got an upgrade after a month of driving without them. Steering wheel feedback feels very strange now after driving without power steering/assist. Good decision to get VCDS instead of taking it to the dealer, worth every penny just for this fix alone. Now I am learning how to configure/code B9. Locking the car while engine is running is pretty convenient. Hopefully I can retrofit multi-color ambient lights using VCDS and swapping the current white lights with QQ2 RGB LED modules.
    Thanks @Uwe and @Dana for your inputs, greatly appreciated!
  10. Likes Dana, Uwe liked this post
