Results 1 to 10 of 11
Thread: 2002 Audi Quattro 2.7l V6/5VT P1649 - 35-10 - Missing Message from ABS Controller -
    Jan 2020
    Hello I'm new to Ross-Tech. auto repair support forum. I was looking for some advise on how to use the output test function to verify the auxiliary brake booster vacuum pump operation. I was looking for feedback on how to approach this issue. I initially purchased a new vacuum pump with matching numbers and have installed it with no avail. Further T/S revealed no 12vdc switching the pump any thoughts on this issue?
    Troubleshooting:
    Replaced vacuum pump and relay. Verified fuse circuit was ok,hoping I targeted the correct relay. My hope is that coding is all that is needed. My experience tells me not to erase my problem as I'll lose visibility.
    Symptom:
    brake pedal drops the floor,initially had no code or light failures reported on the instrument cluster. (Since the scanning),I have produced the (ABS) and (ESP).
    Suspect Code
    :P1649 - 35-10 - Missing Message from ABS Controller - Intermittent
    Prior work done: I had a used ABS brake module installed and coded by the local Audi dealer. I was told while researching the brake failure that it was possible to lose coding after battery failure? Is this the case?
    Auto Scan Log:
    Saturday,25,January,2020,20:35:04:27713
    VIN: WAULD64B92N144794   License Plate: 32012
    Mileage: 213806   Repair Order: Tech. Service 05
              75 76 77
    Address 01: Engine        Labels: 078-907-551-AZA.lbl
       Part No: 4B0 907 551 AL
       Component: 2.7l V6/5VT     G   0001
       Coding: 06752
       Shop #: WSC 11111
       VCID: 6E85C97ED981C1672BB-5184
       WAULD64B92N144794     AUZ7Z0B2126548
    10 Faults Found:
    17861 - Exhaust Gas Temp Sensor 1 (G235)
                P1453 - 35-00 - Open or Short to Plus
    17865 - Exhaust Gas Temp Sensor 2 (G236)
                P1457 - 35-00 - Open or Short to Plus
    17965 - Charge Pressure Control
                P1557 - 35-00 - Positive Deviation
    17831 - Secondary Air Injection System; Bank 1
                P1423 - 35-00 - Insufficient Flow
    17819 - Secondary Air Injection System; Bank 2
                P1411 - 35-00 - Insufficient Flow
    18010 - Power Supply Terminal 30
                P1602 - 35-10 - Voltage too Low - Intermittent
    17535 - Fuel Trim; Bank 1 (Mult)
                P1127 - 35-00 - System too Rich
    17537 - Fuel Trim; Bank 2 (Mult)
                P1129 - 35-00 - System too Rich
                P1570 - 35-10 -  - Intermittent
    18057 - Powertrain Data Bus
    Readiness: 0010 1001
    Address 02: Auto Trans        Labels: 01V-927-156.lbl
       Part No: 4B0 927 156 DR
       Component: AG5 01V 2.7l5VT USA 1819
       Coding: 01002
       Shop #: WSC 02325
       VCID: 7AADF52E95C99DC7873-5184
    17086 - Transm. Control Module Electrical Malf. (SAE) or Control Module Defective (VAG)
                P0702 - 35-10 -  - Intermittent
    Address 03: ABS Brakes        Labels: 4B0-614-517.lbl
       Part No: 4B0 614 517 H
       Component: ABS/ESP allrad      5328
       Coding: 06397
       Shop #: WSC 47345
       VCID: 2615F15E31F1C92793B-51F2
                35-00 - -
       Part No: 4B0 959 760 C
       Component: Sitzmemory R1 BF    0103
       Coding: 00003
       VCID: 2D070E721437FA7F521-4AE0
                07-00 - Signal too Low
                06-00 - Signal too High
    Address 08: Auto HVAC        Labels: 4B0-820-043-MY2.lbl
       Part No: 4B0 820 043 AD
       Component: A6-Klimavollautomat 0105
       Coding: 00010
       Shop #: WSC 02325
       VCID: 5CE193B63F0D43F7F5F-2578
                57-00 - Electric Circuit Failure
    Address 15: Airbags        Labels: 4B0-959-655-AI84.lbl
       Part No: 4B0 959 655 N
       Component: Airbag 8.4E         5001
       Coding: 0000307
       Shop #: WSC 02325 785 00200
       VCID: 3B23302ADF7364CFDC5-5160
    00532 - Supply Voltage B+
    Address 16: Steering wheel        Labels: 4B0-907-487.lbl
       Part No: 4B0 907 487 H
       Component: Lenkradelektronik   D01
       Coding: 01012
       Shop #: WSC 02325
       VCID: 313F1202080F9E9F769-5216
    00926 - Terminal 30
    00926 - Terminal 30
                06-10 - Signal too High - Intermittent
    Address 17: Instruments        Labels: 4B0-920-xxx-17.lbl
       Part No: 4B0 920 981 P
       Component: KOMBI+WEGFAHRS. VDO D11
       Coding: 02264
       Shop #: WSC 29120
       VCID: 3333180AF223AC8F045-5184
    01176 - Key
    Address 35: Centr. Locks        Labels:. 4B0-962-258.clb
       Part No: 4B0 962 258 J
       Component: Central Lock/Alarm  D35
       Coding: 15949
       Shop #: WSC 11111
       VCID: 3039170603059797797-4EEA
    01370 - Alarm triggered by Interior Monitoring
                35-00 - -
    00955 - Key 1
                09-10 - Adaptation Limit Surpassed - Intermittent
    00956 - Key 2
                09-00 - Adaptation Limit Surpassed
       Part No: 4B0 959 760 B
       Component: Sitzmemory R1 F     0102
       Coding: 00001
       VCID: 2C0103762F2DF37745F-4AE0
    Address 45: Inter. Monitor        Labels: 4B0-951-178.lbl
       Part No: 4B0 951 178 A
       Component: Innenraumueberw.    D04
       Coding: 00101
       Shop #: WSC 02325
       VCID: 2615F15E31C1C92793B-508A
    01349 - Alarm via Theft Warning System; Front
                35-00 - -
       Part No: 4Z7 907 357
       Component: dynamische LWR       D07
       Coding: 00050
       Shop #: WSC 11407
       VCID: 04518BD6E73DDB37EDF-4B00
       Part No: 4B0 035 195 J
       Component: symphony II NP2    0050
       Coding: 00205
       VCID: 270BFC5A36CBD02FA8D-4E20
    Address 76: Park Assist        Labels: 8Z0-919-283.lbl
       Part No: 8Z0 919 283
       Component: Parkingsyst. A6 USA D08
       Coding: 01126
       Shop #: WSC 02325
       VCID: 025D8DCEFD29D507DF3-5118
    End----------(Elapsed Time: 04:37, VBatt start/end: 12.6V/12.5V)-----------
    Jan 2020
    I thought I should add my first (Auto Scan):
    Thursday,16,January,2020,20:35:10:27713
    Mileage: 213806   Repair Order: Tech Serv 1
    TID 01 - Rich to lean sensor threshold voltage Test:0.435 V
    TID 02 - Lean to rich sensor threshold voltage N/A
    TID 03 - Low sensor voltage for switch time calculation N/A
    TID 04 - High sensor voltage for switch time calculation N/A
    TID 05 - Rich to lean sensor switch time N/A
    TID 06 - Lean to rich sensor switch time N/A
    TID 07 - Minimum sensor voltage for test cycle Test:0.005 V - Min:0.000 V - Max:0.385 V
    TID 08 - Maximum sensor voltage for test cycle N/A
    TID 09 - Time between sensor transitions Test:0.160 s - Min:0.080 s - Max:1.280 s
    TID 10 - Sensor period N/A
    Mode 07: Pending emission related fault codes
    Address 10 (Engine): 2 Faults Found:
    P0172 - Fuel Trim; Bank 1: System Too Rich
    P0175 - Fuel Trim; Bank 2: System Too Rich
    Mode 9 : Calibration Identification
    Type 04 - Calibration ID : 4B0907551AL 0001 (Address 10)
    Type 04 - Calibration ID : 4B0927156DR 1819 (Address 1A)
    Type 06 - Calibration Verification Number : 2535C156 (Address 10)
    Thursday,16,January,2020,20:42:54
    VCDS Release 19.6.2:  Generic OBD2
    Mode 1:Read Data
    0C:Engine RPM
    0E:Ignition timing advance for cyl #1     11.0 Degrees
    0F:Intake air temperature
    10:Mass Air Flow     8.75 g/s
    TID 02 - Lean to rich sensor threshold voltage Test:0.435 V
    TID 08 - Maximum sensor voltage for test cycle Test:0.890 V - Min:0.480 V - Max:1.005 V
              75 76 77
       Coding: 06752
       Shop #: WSC 11111
    10 Faults Found:
    17866 - Exhaust Gas Temp Sensor 2 (G236)
                P1458 - 35-10 - Short to Ground - Intermittent
       Coding: 01002
       Shop #: WSC 02325
       Coding: 06397
       Shop #: WSC 47345
    18256 - Please check DTC Memory of Engine Controller
                P1848 - 35-10 -  - Intermittent
    65535 - Internal Control Module Memory Error
                00-00 - -
       Coding: 00003
       Coding: 00010
       Shop #: WSC 02325
       VCID: 5CE193B63F0D43F7F5F-2580
       Coding: 0000307
       Coding: 01012
       Shop #: WSC 02325
       VCID: 313F1202080F9E9F769-523C
    00926 - Terminal 30
       Coding: 02264
       Shop #: WSC 29120
    01176 - Key
       Coding: 15949
       Shop #: WSC 11111
                35-00 - -
    00955 - Key 1
    01561 - Rear left door
       Coding: 00001
       Coding: 00101
       Shop #: WSC 02325
       Coding: 00050
       Shop #: WSC 11407
       Coding: 00205
       Coding: 01126
       Shop #: WSC 02325
    End----------(Elapsed Time: 05:00, VBatt start/end: 14.0V/13.9V)-----------
    Hello & welcome OP
    Better check modules on floor for water ingress FOD huh?
    JPPSG
  4. Likes PetrolDave liked this post
    Jan 2020
    I believe I generated this code:P0702. During all (Auto Scan) operations the battery voltage dropped again. I had to trickle charge for 2 days. Please refer to first (Scan) Tech, Service 01
    Did you know the, vacuum pump function basic setting is performed in Engine 0x01 with engine OFF and key ON, select channel for adaptation, turn basic settings ON in VCDS and press brake to initiate pump and count down of 4TH field to be set to OK or 100 last three binary after an observation of booster circuit is indicated?
    If mechanical conditions exist or system requires bleeding the RTFB should be referred to at Erwin.
    Jan 2020
    No! I didn't know about the basic function in adaption. I will try this and let you know. Thanks
    Jan 2020
    I went to the Ross-Tech. and realize is that adaption is learning and driving. How long does it take the primary control. adaption to relearn? Driving? why? would I use adaption for basic output testing? /VCDS and selected 01-Eng
  9. #8
    Time to RTFB and the VCDS manual!
  10. #9
    Jan 2020
    Cool 2002 Audi Quattro 2.7 Liter TT AWD P1649 - 35-10 - Missing Message from ABS Controlle
       Coding: 06397
       Shop #: WSC 47345
                35-00 - -
    Symptom: ABS/CODING
    Cause: Replaced ABS/MODULE, battery failed and cause code loss.
    Repair: Will not communicate during login and coding procedure. Suspect I'm doing something out of order. Need help,any Ideas?:banghead:
    "Auto Scan" VCDS
    Sunday,02,February,2020,07:17:09:27713
              75 76 77
       Coding: 06752
       Shop #: WSC 11111
    Readiness: 0110 1101
       Coding: 01002
       Shop #: WSC 02325
       Coding: 06397
       Shop #: WSC 47345
                35-00 - -
       Coding: 00003
       Coding: 00010
       Shop #: WSC 02325
       Coding: 0000307
       Coding: 01012
       Shop #: WSC 02325
    00926 - Terminal 30
    00926 - Terminal 30
       Coding: 02264
       Shop #: WSC 29120
       VCID: 3333180AF223AC8F045-5160
    01176 - Key
       Coding: 15949
       Shop #: WSC 11111
                35-00 - -
    00955 - Key 1
    00956 - Key 2
       Coding: 00001
       Coding: 00101
       Shop #: WSC 02325
                35-00 - -
       Coding: 00050
       Shop #: WSC 11407
       Coding: 00205
       Coding: 01126
       Shop #: WSC 02325
    End----(Elapsed Time: 04:42, VBatt start/end: 11.7V/11.7V. VIgn 11.6V)-----
  11. #10
    Has the Trans & ABS/ESP been under water on floor, seems awful likely huh?
    If you need them I have them.
    https://forums.ross-tech.com/showthr...l=1#post189930
