Results 1 to 9 of 9
Thread: Audi a3 8v
    Apr 2018
    Audi a3 8v
    hi got issuse can any one point the write direction thanks
    Main issue
    airbags
    parking sensors
    Saturday,25,January,2020,18:03:17:56296
    VIN: WAUZZZ8V1GA056600   License Plate:
    Chassis Type: 8V-AU37 (5Q0)
    Scan: 01 03 08 09 10 15 16 17 19 42 44 52 55 5F BB BC
    VIN: WAUZZZ8V1GA056600   Mileage: 34560km-21474miles
    Address 01: Engine (J623-CUNA)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 026 BR    HW: 04L 907 309 R
       Component: R4 2,0L EDC   X22 1540
       Revision: B5X22---
       Coding: 02190012032501082000
       Shop #: WSC 26214 051 00000
       ASAM Dataset: EV_ECM20TDI01104L906026BR 002003
       ROD: EV_ECM20TDI01104L906026BR_002.rod
       VCID: 7BA200ED3368DE5F9C5-802E
    21605 - Sensor for Ambient Air Temperature (G17)
              P0070 00 [039] - Malfunction
                        Mileage: 34560 km
                        Date: 2020.01.25
                        Time: 18:54:27
                        Engine speed: 776.50 /min
                        Normed load value: 23.1 %
                        Coolant temperature: 56 °C
                        Intake air temperature: 49 °C
                        Voltage terminal 30: 14.680 V
                        Turbocharger 1 turbine inlet: temp. sensor 1 bank 1: raw value: 138.6 °C
                        Turbocharger 1 turbine outlet: temp. sensor 1 bank 1: raw value: 117.1 °C
                        Particle filt.inlet temp.sens.1 bank 1: raw value: 112.0 °C
                        Particle filter outlet temp.sens.1 bank 1: raw value: 109.4 °C
                        Exh. gas recirc.temp. sens. 2 bank 1: raw value: 2222.0 °C
                        Shut-off timer: last engine shut-off time: 740 s
       Part No SW: 3Q0 907 379 AF    HW: 3Q0 907 379 F
       Component: ESC           H42 0625
       Revision: 00000000    Serial number: 62555000000431
       Coding: 12F18AA234250A72037D060041C32948512C50C0608294F5026100788408
       Shop #: WSC 06314 790 00021
       ROD: EV_Brake1UDSContiMK100IPB_034_AU37.rod
       VCID: 7EA409F9207ACB77BBB-802A
    16411 - Display for Tire Pressure Monitoring
                        Reset counter: 26
                        Mileage: 34560 km
                        Date: 2020.01.25
                        Time: 18:54:37
       Component: AC Automat    H14 0060
       Revision: 20028000    Serial number: 00000000735735
       Coding: 03100104002000011000000000001100
       VCID: 3332E8CD5BB8D61F045-8066
       Serial number: 2FC8C8C7000000000001
    262914 - Refrigerant Pressure
              B10AB F0 [009] - Too Low
                        Reset counter: 26
                        Mileage: 34560 km
                        Date: 2020.01.25
                        Time: 18:54:24
                        Outside air temperature: ERROR
                        Engine speed: 770.00 /min
                        Temperature after evaporator: 13.0 °C
                        Refrigerant pressure: 1.0 bar
                        System run time-Terminal 15 on: 253 s
    459527 - Databus
                        Reset counter: 26
                        Mileage: 34560 km
                        Date: 2020.01.25
                        Time: 18:54:24
       Part No SW: 5Q0 937 084 AS    HW: 5Q0 937 084 AN
       Serial number: 01061526400833
       Coding: 07040A46C24122FD03844004B31C07A80000000000000000000000000000
       ROD: EV_BCMBOSCH_015.rod
       VCID: 094E6A2569B4FCCF9E9-805C
       Subsystem 1 - Part No SW: 8V2 955 119 A    HW: 8V2 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS370 150826  042 0580
       Serial number:         150902160835
       Coding: 0A47F7
       Serial number: 20663136
       Coding: 00006C
       Light switch:
       Subsystem 3 - Part No SW: 8V0 941 531 AE    HW: 8V0 941 531 AE
       Serial number: 20 07 2015  00000424
       Serial number: 000000000ZY15217163G
       Serial number: 00000000000033267789
    137217 - Outside temperature sensor
              B103F 1B [009] - Resistance Too High
                        Reset counter: 26
                        Mileage: 34560 km
                        Date: 2020.01.25
                        Time: 19:01:00
    263435 - Glass Breakage Sensor
              B145F 13 [009] - Open Circuit
                        Reset counter: 26
                        Mileage: 34560 km
                        Date: 2020.01.25
                        Time: 19:01:00
       Revision: --------    Serial number: 39391526009001
       Coding: 0010050001
       VCID: 43D2B80D0B18669F945-8016
    13637888 - Databus
              [Steuergerät für Schalttafeleinsatz-J285 - Kombi_02.KBI_Aussen_Temp_gef - Fehlerspeicher auslesen]
                        Reset counter: 26
                        Mileage: 34560 km
                        Date: 2020.01.25
                        Time: 18:54:25
       Component: AirbagVW20    012 0361
       Serial number: 003M2R12ZNTF
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 4BC2902D2348AEDF6C5-801E
       Subsystem 1 - Part No SW: -----------    HW: 480 001 709 15
       Serial number: 35767000000AD6B4D616
       Subsystem 2 - Part No SW: -----------    HW: 480 001 709 15
       Serial number: 358670000006C6B4D612
       Subsystem 3 - Part No SW: -----------    HW: 480 401 609 15
       Serial number: 3516502AD1D25F724019
       Subsystem 4 - Part No SW: -----------    HW: 480 401 509 15
       Serial number: 3526502A31CB0C23232+
       Subsystem 5 - Part No SW: -----------    HW: 480 401 108 15
       Serial number: 3556502BB1D1B625338F
       Pedestrian Protection Driver:
       Subsystem 6 - Part No SW: -----------    HW: 480 400 309 15
       Serial number: 2286502B91C1EFA1C27Y
       Subsystem 7 - Part No SW: -----------    HW: 480 400 309 15
       Serial number: 2296502A31D1B623122
       Pedestrian Protection Center:
       Subsystem 8 - Part No SW: -----------    HW: 480 400 309 15
       Serial number: 2306502AB1C1EFA5012E
    9451547 - Igniter 1 for pedestrian protection
              B1038 1B [137] - Resistance Too High
                        Mileage: 34560 km
                        Date: 2020.01.25
                        Time: 19:00:18
    9451803 - Igniter 2 for pedestrian protection
              B1039 1B [137] - Resistance Too High
                        Mileage: 34560 km
                        Date: 2020.01.25
                        Time: 19:00:18
    1054981 - Databus
              [NWD: 0x6B7 Kombi_02 error value KBI_Aussen_Temp_gef]
                        Reset counter: 26
                        Mileage: 34560 km
                        Date: 2020.01.25
                        Time: 19:00:22
       Part No SW: 8V0 953 521 EH    HW: 5Q0 953 549 E
       Component: Lenks. Modul  003 0110
       Revision: --------    Serial number: 19091508490588
       Coding: A408
       ROD: EV_SMLSKLOMQB_010_AU37.rod
       VCID: 04507B114E96A1A7EDF-8050
       Part No SW: 8V0 920 971 R    HW: 8V0 920 971 R
       Component: KOMBI         H03 6420
       Coding: 27A409002B8026000100E8001000000000000000
       VCID: 4CC093312646A9E765F-8018
    13639936 - Databus
              [Steuergerät für BCM / Bordnetz / el. ZE: bitte Fehlerspeicher auslesen]
                        Reset counter: 26
                        Mileage: 34560 km
                        Date: 2020.01.25
                        Time: 18:54:24
       Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 F
       Component: GW MQB High   128 1224
       Revision: --------    Serial number: 0003963582
       Coding: 030100041F0873005B000248080B00000001010000000000000000000000
       ROD: EV_GatewLear_013.rod
       VCID: 75B616D5154C882FEA1-8020
       Serial number: 01 09 2015  A0003717
       Subsystem 3 - Part No SW: 5Q0 915 181 H    HW: 5Q0 915 181 H
       Component: J367-BDMConti  H02 1011
       Serial number: 74185704001509093002
       Serial number: 010915BI102489
       Coding: 00518A205C01040000001002
       Component: EPS_MQB_ZFLS  125 1063
       Coding: 8103
       VCID: 44D0BB110E1661A7ADF-8010
       Serial number: 030915BI212167
       Coding: 005182205E01040000001002
       VCID: 42DCBD0914026F979F3-8016
       Coding: 019E000001000000
       Part No SW: 8V0 035 874 C    HW: 8V0 035 874 B
       Component: MU-S-ND-ER    042 0461
       Serial number: A7F01609151051
       Coding: 017303010000000021111102000A00002F0004260100010006
       ROD: EV_MUStd4CPASE_VW37.rod
       VCID: 3C20C3F176E61967D5F-8068
       Subsystem 1 - Part No SW: 8V0 919 866 C    HW: -----------
       Component:  ECE 2015  --- 0045
       Subsystem 2 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
       Component: DU Std  H49 0014
       Serial number: AUZ8Z9FY30D5R2
       Multimedia Operating Unit:
       Subsystem 3 - Part No SW: 8V0 919 614 P    HW: 8V0 919 614 P
       Serial number: C1000001071500030242
       Serial number: 090715BG820445
       Coding: 004182204001040000001002
       VCID: 45D6A615052C58AFBA1-8010
       Serial number: 090715BG808669
    End----------(Elapsed Time: 01:17, VBatt start/end: 14.8V/14.6V)-----------
    Jan 2018
    Cheshire UK
    Wow, you should put the car back together first, clear fault codes and then see what you have left.
    Airbag issue needs new bonnet actuators. These blow after a frontal impact and raise the bonnet upwards at the hinge side.
    A6 BiTdi Avant MTM
    Retrofitted: Full Led Headlights, DAB, Full Electric Seats, Power Tailgate, Surround View Cameras, Genuine RS6 Grille, RS6 Seats,Leather Door Armrests, Soft Close Doors, Rear Side Blinds, Electric Steering Column, LED Sill Plates, Ambient Lighting Pack, High Beam Assist, Eibach Springs, Led Roof Console, 4 Zone Climate, Rear Heated Seats, Head Up Display, Side assist, Alcantara Interior Retrim
  3. Likes Uwe, PetrolDave liked this post
    Apr 2018
    hi have put everthing back together but these fault not going is there any way to bypass the bonnet hinges with resistor for temporary
    Quote Originally Posted by zeeshan View Post
    Put back together how? Did you install new bonnet actuators?
  6. Likes DV52 liked this post
    Jan 2018
    Cheshire UK
    Yes, Audi sell bypass resistors. Just ask the parts department which airbag you want to bypass and they will supply you one. Steering airbag resistors are always in stock.
    A6 BiTdi Avant MTM
  8. Likes downtime, MartinsX, NZDubNurd liked this post
  9. #6
    Quote Originally Posted by morski View Post
  10. Likes downtime, NZDubNurd liked this post
  11. #7
    Jan 2018
    Cheshire UK
    Sorry...my sarcasm comes across as a bit strong at times..
    A6 BiTdi Avant MTM
  12. Likes Uwe, NZDubNurd liked this post
  13. #8
    Apr 2018
    Wednesday,29,January,2020,10:12:27:56296
    VIN: WAUZZZ8V1GA056600   Mileage: 34561km-21475miles
       Revision: B5X22---
              P0070 00 [175] - Malfunction
                        Mileage: 34561 km
                        Date: 2020.01.29
                        Time: 10:51:24
                        Engine speed: 1061.50 /min
                        Normed load value: 18.8 %
                        Coolant temperature: 53 °C
                        Intake air temperature: 47 °C
                        Turbocharger 1 turbine inlet: temp. sensor 1 bank 1: raw value: 158.0 °C
                        Turbocharger 1 turbine outlet: temp. sensor 1 bank 1: raw value: 114.0 °C
                        Particle filt.inlet temp.sens.1 bank 1: raw value: 105.6 °C
                        Particle filter outlet temp.sens.1 bank 1: raw value: 89.5 °C
                        Shut-off timer: last engine shut-off time: 55518 s
    Readiness: 1 1 0 0 1
                        Reset counter: 26
                        Mileage: 34561 km
                        Date: 2020.01.29
                        Time: 11:04:32
                        Reset counter: 26
                        Mileage: 34561 km
                        Date: 2020.01.29
                        Time: 10:51:37
                        Engine speed: 1040.50 /min
                        Temperature after evaporator: 9.0 °C
                        Refrigerant pressure: 1.2 bar
    459527 - Databus
                        Reset counter: 26
                        Mileage: 34561 km
                        Date: 2020.01.29
                        Time: 10:51:37
       Coding: 0A47F7
       Coding: 00006C
       Light switch:
    8970 - Bulb for Right Fog Lamp
              B1220 15 [009] - Open or Short to Plus
                        Reset counter: 26
                        Mileage: 34561 km
                        Date: 2020.01.29
                        Time: 10:51:42
                        Reset counter: 26
                        Mileage: 34561 km
                        Date: 2020.01.29
                        Time: 10:51:42
                        Reset counter: 26
                        Mileage: 34561 km
                        Date: 2020.01.29
                        Time: 10:51:42
       Coding: 0010050001
    13637888 - Databus
                        Reset counter: 26
                        Mileage: 34561 km
                        Date: 2020.01.29
                        Time: 11:12:06
    1054981 - Databus
                        Reset counter: 26
                        Mileage: 34561 km
                        Date: 2020.01.29
                        Time: 10:51:52
       Coding: A408
    13639936 - Databus
                        Reset counter: 26
                        Mileage: 34561 km
                        Date: 2020.01.29
                        Time: 11:11:04
       Coding: 8103
    End----(Elapsed Time: 01:20, VBatt start/end: 11.6V/11.6V. VIgn 11.6V)-----
  14. #9
    Apr 2018
    still parking sensors and tpms not working
