Results 1 to 7 of 7
Thread: Octavia VRS CR FL 2010 - headlights very dim
    Nov 2016
    Scotland
    After accident, passenger headlight unit and a headlight control unit ??? were replaced. Ever since then both headlights are very dim. They used to be much brighter before the accident. It's as if they are on low power. I have tried different halogen bulbs and also LED bulbs. The LED bulbs are slightly brighter than the halogens but they are still dim.
    It was suggested that the new control unit (I think that was what the body shop said was fitted. It seemingly had to get welded in) may be set on low power to increase bulb lifespan.
    Where would I look with VCDS to set headlight power back to full??
    Any other suggestions??
    Please post an Auto-Scan so people can see how this car is equipped & configured, and what faults are present.
    Nov 2016
    Scotland
    Log from today.
    I already knew about the alarm siren. Suspect it needs new battery.
    I have new mirror indicators ordered to replace both sides. Passenger side not working and drivers side was flickering at MOT test.
    Tested heated mirror wiring and no power so break in wiring somewhere or maybe a loose plug??
    Headlight looks like 11.7 volts. Can this be increased??
    Any other thoughts??
    Saturday,25,January,2020,16:44:40:62090
    VCDS Version: 19a6.2.0 (x64)
    VIN:   License Plate:
    Chassis Type: 1Z-SK35 (1K0)
    VIN:    Mileage: 152240km-94597miles
    Address 01: Engine (CEG)       Labels: 03L-906-022-CBA.clb
       Part No SW: 03L 906 022 RD    HW: 03L 906 022 GA
       Component: R4 2,0L EDC G000SG  5751
       Revision: 13H03---    Serial number:
       Coding: 0001072
       Shop #: WSC 00642 210 45725
       VCID: 78FE6A4C0B21C18F9F-802C
       Part No SW: 1K0 907 379 AH    HW: 1K0 907 379 AH
       Revision: 00H30001
       Coding: 163B601C09290003681306E890220082340800
       Shop #: WSC 73430 790 00999
       VCID: 78FE6A4CCB21C18F9F-802C
    02214 - Tire Pressure Warning
                        Reset counter: 175
                        Mileage: 151405 km
                        Date: 2014.04.10
                        Time: 15:29:32
                        Count: 32768
                        Count: 4608
                        Count: 397
                        Count: 52528
                        Count: 65024
       Part No SW: 3T0 907 044 AS    HW: 3T0 907 044 AS
       Component: Climatronic   H15 0401
       Revision: 00005001
       Coding: 0000000002
       ROD: EV_ClimaAutoBasis_SK35.rod
       VCID: 03040DA08AE79257BA-8056
       Part No SW: 1K0 937 087 D    HW: 1K0 937 087 D
       Component: BCM PQ35  H   103 0575
       Revision: 00103 AG
       Coding: 48180AB8B05BB1C040080080110001E4430000AE424D8560800440040000
       Shop #: WSC 20014 576 89718
       VCID: 326A98646DDDEBDF61-8066
       Subsystem 1 - Part No: 1Z2 955 119 C  Labels: 1KX-955-119.CLB
       Component: Wischer 16120  22  0601
       Coding: 00D7B7
       Subsystem 2 - Part No: 1Z0 951 171
       Component: Innenraumuebe  008 5101
       Subsystem 3 - Part No: 1K8 951 605
       Component: LIN BACKUP HO  H09 9002
    01134 - Alarm Horn (H12)
                        Reset counter: 107
                        Mileage: 138925 km
                        Date: 2012.12.14
                        Time: 13:34:32
                            Term 15 On
                        Voltage: 12.30 V
                            Term 50 Off
                        Fault Status: 01100010
                        Reset counter: 144
                        Mileage: 140481 km
                        Date: 2013.03.19
                        Time: 07:48:26
                            Term 15 Off
                        Voltage: 14.45 V
                            Term 50 Off
                        Fault Status: 00101010
                        Reset counter: 193
                        Mileage: 152040 km
                        Date: 2014.06.11
                        Time: 10:35:10
                            Term 15 On
                        Voltage: 11.70 V
                            Term 50 Off
       Component: Q4 AIRBAG VW8   020 2300
       Revision: 05020000    Serial number: 0038PD2HS0W%
       Coding: 0020788
       VCID: 3D70BB58648324A78C-8068
       Subsystem 1 - Serial number: 6332MSME4C602D7CR
       Subsystem 2 - Serial number: 6342MSME4E634629K
       Part No SW: 1K0 953 549 CQ    HW: 1K0 953 549 CQ
       Component: J0527           053 0111
       Coding: 0000034
       VCID: 03040DA042E79257BA-8056
       Part No SW: 1Z0 920 943 J    HW: 1Z0 920 943 J
       Component: KOMBI         H05 0305
       Coding: 410B00
       Shop #: WSC 73430 031 00999
       ROD: EV_Kombi_UDS_VDD_RM09_004_SK34.rod
       VCID: 408EC2ACDB71494FE7-8014
       Component: J533  Gateway   H16 0233
       Revision:   H16       Serial number: 4520K09C190630
       Coding: E9807F06000202001303
       VCID: 69D83F08408B680710-803C
                        Fault Status: 00101011
                        Fault Frequency: 9
                        Reset counter: 181
                        Mileage: 150369 km
       Component: IMMO          H05 0305
       VCID: 6ADA40048D8D631F19-803E
       Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
       Component: Tuer-SG         009 2114
       Coding: 0000756
       VCID: 489EDA8C3B41710F2F-801C
    00100 - Drivers Interior Locking Button (E308)
       Part No: 1K0 909 144 J
       Component: EPS_ZFLS Kl. 74     3001
       Revision: 00H17000
       VCID: 31689768A8DBD0C718-8064
       Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
       Coding: 0000756
       VCID: 479CD9B0365F7E7726-8012
       Part No SW: 1Z0 035 156 F    HW: 1Z0 035 156 F
       Component: BOLERO        008 0053
       Revision: 0A001001    Serial number: SKZ1Z3I8180238
       Coding: 050004000001
       VCID: 3560A3789CB3FCE744-8060
       Part No SW: 5K0 959 703 A    HW: 5K0 959 703 A
       Coding: 0000144
       Shop #: WSC 73430 790 1012551
       VCID: 326A9864ADDDEBDF61-8066
       Part No SW: 5K0 959 704 A    HW: 5K0 959 704 A
       Coding: 0000144
       VCID: 33649D6052C7E2D76A-8066
    End-------------------------(Elapsed Time: 02:28)--------------------------
    Quote Originally Posted by Fatbloke View Post
    That's not voltage at the headlight. That's system voltage at the time the fault code was set.
    I would suggest verifying the connections between the BCM and the headlights. Check for voltage drop under load. Also check for voltage drop between the ground side of the headlights and a known good ground.
  5. Likes Jack@European_Parts liked this post
    Nov 2016
    Scotland
    Thanks Uwe.
    How do I check the voltage to the lights? Can it be adjusted?
    With a multimeter.
    What Uwe aforementioned is correct.
    Additionally with DVOM in series to ground or hot you can see the draw of current measured to qualify the tracks ability to carry current and with visual load light.
    Usually the issue is a ground but sometimes the bulb or inadequate feed, so check it all by isolating each part.
