Octavia VRS CR FL 2010 - headlights very dim
Fatbloke
Scotland
After accident, passenger headlight unit and a headlight control unit ??? were replaced. Ever since then both headlights are very dim. They used to be much brighter before the accident. It's as if they are on low power. I have tried different halogen bulbs and also LED bulbs. The LED bulbs are slightly brighter than the halogens but they are still dim.
It was suggested that the new control unit (I think that was what the body shop said was fitted. It seemingly had to get welded in) may be set on low power to increase bulb lifespan.
Where would I look with VCDS to set headlight power back to full??
Any other suggestions??
Please post an Auto-Scan so people can see how this car is equipped & configured, and what faults are present.
Fatbloke
Scotland
Log from today.
I already knew about the alarm siren. Suspect it needs new battery.
I have new mirror indicators ordered to replace both sides. Passenger side not working and drivers side was flickering at MOT test.
Tested heated mirror wiring and no power so break in wiring somewhere or maybe a loose plug??
Headlight looks like 11.7 volts. Can this be increased??
Any other thoughts??
Saturday,25,January,2020,16:44:40:62090
VCDS Version: 19a6.2.0 (x64)
VIN:   License Plate:
Chassis Type: 1Z-SK35 (1K0)
VIN:    Mileage: 152240km-94597miles
Address 01: Engine (CEG)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 RD    HW: 03L 906 022 GA
   Component: R4 2,0L EDC G000SG  5751
   Revision: 13H03---    Serial number:
   Coding: 0001072
   Shop #: WSC 00642 210 45725
   VCID: 78FE6A4C0B21C18F9F-802C
   Part No SW: 1K0 907 379 AH    HW: 1K0 907 379 AH
   Revision: 00H30001
   Coding: 163B601C09290003681306E890220082340800
   Shop #: WSC 73430 790 00999
   VCID: 78FE6A4CCB21C18F9F-802C
02214 - Tire Pressure Warning
                    Reset counter: 175
                    Mileage: 151405 km
                    Date: 2014.04.10
                    Time: 15:29:32
                    Count: 32768
                    Count: 4608
                    Count: 397
                    Count: 52528
                    Count: 65024
   Part No SW: 3T0 907 044 AS    HW: 3T0 907 044 AS
   Component: Climatronic   H15 0401
   Revision: 00005001
   Coding: 0000000002
   ROD: EV_ClimaAutoBasis_SK35.rod
   VCID: 03040DA08AE79257BA-8056
   Part No SW: 1K0 937 087 D    HW: 1K0 937 087 D
   Component: BCM PQ35  H   103 0575
   Revision: 00103 AG
   Coding: 48180AB8B05BB1C040080080110001E4430000AE424D8560800440040000
   Shop #: WSC 20014 576 89718
   VCID: 326A98646DDDEBDF61-8066
   Subsystem 1 - Part No: 1Z2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 16120  22  0601
   Coding: 00D7B7
   Subsystem 2 - Part No: 1Z0 951 171
   Component: Innenraumuebe  008 5101
   Subsystem 3 - Part No: 1K8 951 605
   Component: LIN BACKUP HO  H09 9002
01134 - Alarm Horn (H12)
                    Reset counter: 107
                    Mileage: 138925 km
                    Date: 2012.12.14
                    Time: 13:34:32
                        Term 15 On
                    Voltage: 12.30 V
                        Term 50 Off
                    Fault Status: 01100010
                    Reset counter: 144
                    Mileage: 140481 km
                    Date: 2013.03.19
                    Time: 07:48:26
                        Term 15 Off
                    Voltage: 14.45 V
                        Term 50 Off
                    Fault Status: 00101010
                    Reset counter: 193
                    Mileage: 152040 km
                    Date: 2014.06.11
                    Time: 10:35:10
                        Term 15 On
                    Voltage: 11.70 V
                        Term 50 Off
   Component: Q4 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD2HS0W%
   Coding: 0020788
   VCID: 3D70BB58648324A78C-8068
   Subsystem 1 - Serial number: 6332MSME4C602D7CR
   Subsystem 2 - Serial number: 6342MSME4E634629K
   Part No SW: 1K0 953 549 CQ    HW: 1K0 953 549 CQ
   Component: J0527           053 0111
   Coding: 0000034
   VCID: 03040DA042E79257BA-8056
   Part No SW: 1Z0 920 943 J    HW: 1Z0 920 943 J
   Component: KOMBI         H05 0305
   Coding: 410B00
   Shop #: WSC 73430 031 00999
   ROD: EV_Kombi_UDS_VDD_RM09_004_SK34.rod
   VCID: 408EC2ACDB71494FE7-8014
   Component: J533  Gateway   H16 0233
   Revision:   H16       Serial number: 4520K09C190630
   Coding: E9807F06000202001303
   VCID: 69D83F08408B680710-803C
                    Fault Status: 00101011
                    Fault Frequency: 9
                    Reset counter: 181
                    Mileage: 150369 km
   Component: IMMO          H05 0305
   VCID: 6ADA40048D8D631F19-803E
   Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
   Component: Tuer-SG         009 2114
   Coding: 0000756
   VCID: 489EDA8C3B41710F2F-801C
00100 - Drivers Interior Locking Button (E308)
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 74     3001
   Revision: 00H17000
   VCID: 31689768A8DBD0C718-8064
   Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
   Coding: 0000756
   VCID: 479CD9B0365F7E7726-8012
   Part No SW: 1Z0 035 156 F    HW: 1Z0 035 156 F
   Component: BOLERO        008 0053
   Revision: 0A001001    Serial number: SKZ1Z3I8180238
   Coding: 050004000001
   VCID: 3560A3789CB3FCE744-8060
   Part No SW: 5K0 959 703 A    HW: 5K0 959 703 A
   Coding: 0000144
   Shop #: WSC 73430 790 1012551
   VCID: 326A9864ADDDEBDF61-8066
   Part No SW: 5K0 959 704 A    HW: 5K0 959 704 A
   Coding: 0000144
   VCID: 33649D6052C7E2D76A-8066
End-------------------------(Elapsed Time: 02:28)--------------------------
That's not voltage at the headlight. That's system voltage at the time the fault code was set.
I would suggest verifying the connections between the BCM and the headlights. Check for voltage drop under load. Also check for voltage drop between the ground side of the headlights and a known good ground.
Fatbloke
Scotland
Thanks Uwe.
How do I check the voltage to the lights? Can it be adjusted?
What Uwe aforementioned is correct.
Additionally with DVOM in series to ground or hot you can see the draw of current measured to qualify the tracks ability to carry current and with visual load light.
Usually the issue is a ground but sometimes the bulb or inadequate feed, so check it all by isolating each part.
