Results 1 to 5 of 5
Thread: RNS-315 Bluetooth Capability Disappeared
    Nov 2017
    Texas (USA)
    Hello all,
    2012 Jetta TDI Premium
    My RNS-315 head unit has the built in Bluetooth module (I believe) and came with the car when I bought it. I drove home with my phone connected to Bluetooth and was streaming music no issues. Also I was able to make and receive phone calls. Turned the car off, and when I left for work the next day, the screen says "telephone not supported". So basically I can not connect to Bluetooth anymore as if the internal module went Tango Uniform. Could this be a coding thing that somehow dropped off when I turned the vehicle off? Is there a known issue with the internal Bluetooth modules as compared to the external ones? Any help or info would be appreciated. I have been driving around with out it for a while now.
    Wednesday,22,January,2020,13:58:34:59350
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows Vista x64
    VCDS Version: 19.6.1.0 (x64)
    VIN: 3VWLL7AJ6CM393621   License Plate:
    Mileage: 241810km-150253mi   Repair Order:
    Chassis Type: AJ-VW36 (6N0)
    Scan: 01 02 03 05 08 09 15 17 19 25 2B 2E 37 44 47 56
    VIN: 3VWLL7AJ6CM393621   Mileage: 241810km-150253miles
    Address 01: Engine (CJA)       Labels: 03L-906-022-CBE.clb
       Part No SW: 03L 997 030 M    HW: 03L 907 309 AA
       Component: R4 2.0l TDI G000AG  9983
       Revision: 12H14---    Serial number:
       Coding: 0050078
       VCID: 387F62E34BB45D8F61-806C
    Readiness: 0 0 0 1 1
       Part No SW: 02E 300 062 B    HW: 02E 927 770 AL
       Component: GSG DSG AG6     512 9430
       Revision: 05551213    Serial number: 00001112151651
       VCID: 1427F653379C59EF2D-8040
       Revision: 00H31001
       Coding: B14B400C492B00FD8D1102E6921A0042A71000
       VCID: 7DF1B3F7E416B8A7F2-8028
       Revision: 00085000    Serial number: 0162918823
       Coding: 030C0C
       VCID: 346756D39FDCB9EF4D-8060
       Part No SW: 5C0 820 047 AQ    HW: 5C0 820 047 AQ
       Component: J301  Klimaanlage   0203
       Revision: 2001010S    Serial number: 00000000838963
       VCID: 6FED99BF7E7ADA3770-803A
       Part No SW: 5C0 937 087 E    HW: 5C0 937 087 A
       Component: BCM25 JLB H3  H66 0257
       Revision: B2066001    Serial number: 04371070120025
       Coding: 7A994B9A08AB0B0008382000240884C50082502E6000000030A000000000
       Shop #: WSC 28600 002 1048576
       VCID: 2F6D59BF7EFA9A3730-807A
       Subsystem 1 - Part No SW: 6R0 959 801 AF    HW: 6R0 959 801 AF  Labels: 6R0-959-801.CLB
       Component: J386__TSG_FT  004 3464
       Coding: 820000
       Subsystem 2 - Part No SW: 6R0 959 802 AF    HW: 6R0 959 802 AF  Labels: 6R0-959-802.CLB
       Component: J387__TSG_BT  004 3464
       Coding: 820000
       Subsystem 3 - Part No SW: 5K0 959 591     HW: 5K0 959 591
       Component: J245 PS41.022  H09 0007
       Serial number:     WRH0004CCWU
       Coding: 180000
       Subsystem 4 - Part No SW: 5K0 959 542 A    HW: 5K0 959 542 A
       Serial number: 0105934
       Coding: 020000
       Subsystem 5 - Part No SW: 6R0 959 811 H    HW: 6R0 959 811 H
       Component: J388__TSG_HL  004 3464
       Coding: 800000
       Subsystem 6 - Part No SW: 6R0 959 812 H    HW: 6R0 959 812 H
       Component: J389__TSG_HR  004 3464
       Coding: 800000
       Part No SW: 5C0 959 655 E    HW: 5C0 959 655 E
       Component: AirbagVW10G   014 0808
       Serial number: 003GTM04XSKQ
       Coding: 00003936
       ASAM Dataset: EV_AirbaVW10SMEVW360 A01023
       ROD: EV_AirbaVW10SMEVW360.rod
       Subsystem 1 - Part No SW: 5C6 959 339 A    HW: 5C6 959 339 A
       Component: BF-Gewichtss.  H10 0045
       Serial number: 6940000Y120000AE3D0A
       Coding: 303044
       Serial number: 3572MSME3225506AZZZQ
       Serial number: 3582MSME116C536AZZZ
       Serial number: 3516KSME39464217ZZZP
       Serial number: 3526KSME3C045B17ZZZX
       Serial number: 3556LSME151B2515ZZZP
       Serial number: 3566LSME40612515ZZZJ
       Part No SW: 5C6 920 951 A    HW: 5C6 920 951 A
       Component: KOMBI         H04 0604
       Coding: 270A01
       Shop #: WSC 00066 000 00123
       VCID: 2959B7A7481EF407EE-807C
       Part No SW: 6N0 909 901     HW: 5C0 937 087 A
       Component: GW-K-CAN TP20 H66 0257
       Revision: B2066001
       Coding: 102200
       VCID: 70EF9AC3A344C5CF69-8024
       Component: IMMO          H04 0604
       Coding: 000007
       VCID: 6ADB88AB8D983F1F27-803E
       Part No SW: 5K0 905 861 A    HW: 5K0 905 861 A
       Component: ELV-PQ35      H20 0230
       Revision: 00000000    Serial number: 11000227901003
       Coding: 4900000000000000
       Shop #: WSC 00066 790 50316
       ROD: EV_ELVMarquMPVW36X.rod
       VCID: 2E5344BB71F0933F3B-807A
       Revision: A1001003    Serial number: 7661874335
       Coding: 020000
       VCID: 2959B7A7401EF407EE-807C
       Part No SW: 1K0 035 274 E    HW: 1K0 035 274 E
       Component: RNS315-NAR    H62 0319
       Serial number: VWZAZ2N0556613
       Coding: 06090001010006000000100A
       Shop #: WSC 64522 123 104857
       ROD: EV_RNS315NARV2UDS.rod
       VCID: 2643BC9B5900DB7FC3-8072
    1048630 - CD Changer
              B1101 31 [009] - No Signal
                        Reset counter: 149
                        Mileage: 241817 km
                        Date: 2020.01.22
                        Time: 13:56:15
    1048669 - Tuner for Satellite Radio
              B11CF 53 [009] - Deactivated
                        Reset counter: 149
                        Mileage: 241817 km
                        Date: 2020.01.22
                        Time: 13:56:15
       Part No: 1K0 909 144 P
       Component: EPS_ZFLS Kl. 70     3305
       Revision: 00H22000
       VCID: 377D61DF46AA52F768-8062
       Part No SW: 3T0 035 456 B    HW: 3T0 035 456 B
       Component: KonzernAmp10K H06 0362
       Revision: --------    Serial number: BP225311013876
       VCID: 306F5AC36BC485CF29-8064
    End-------------------------(Elapsed Time: 03:32)--------------------------
    Jun 2014
    Remove all connected Bluetooth devices in the radio and then re-connect your phone.
    Golf VII, 1.6TDI BM Ed. 40 - 110 PK
  3. Likes Uwe, Dana liked this post
    Nov 2017
    Texas (USA)
    I have tried that. I was wondering if anyone knew of what coding was needed to be checked to have it work? I rummaged around under Navigation long codes and I do not see where I have the ability to turn on or off Bluetooth. Also is weird that it just one day "POOF" gone. I think I already know the answer (internal Bluetooth module gave up the ghost) but just want to see if anyone else has had this happen or I am not looking in the right area before I give up on it.
    Jun 2014
    Would be very strange if coding was changed... Try restarting you phone... that sometimes clears problems... You must have paired Phone and RNS315 the first time, try do that again...
    United States
    I don't believe your RNS is coded properly however the bit in question shouldn't cause Bluetooth issues. You might want to try this: 04090001010006000000100A
    ... followed by clearing codes.
    Rebooting the unit might not be a bad idea as well. It it won't reboot gracefully (by pressing and holding buttons on the face) I'd pull all fused power(s) or remove it from the dash and unplug it for a while.
