Results 1 to 2 of 2
Thread: 2009 Audi TT Quattro 3.2L
    Jan 2020
    Puerto Rico, USA
    Hi;
    This is the Auto Scan of my second car. Last week I posted my Jetta GLI's. Thanks very much for your response.
    The Audi is having a very strange issue. When driving at any speed, if the brake pedal is press hard it locks the front left wheel and the pedal do not react until the car is at full stop. Then the pedal goes to the normal position and the car can be driven as normal. The ABS pump seems to be working fine. No fault code is posted nor the ABS light comes on.... Now using ypur softare and cable a fault code is posted. Don't know if it is related.
    Thanks for your ussual support.
    Regards;
    German
    Friday,24,January,2020,13:43:25:07067
    VIN: TRUDD38J291008408   License Plate: IAQ-303
    Mileage: 71790km-44608mi   Repair Order:
    Chassis Type: 8J (1K0)
    Scan: 01 03 08 09 0F 15 16 17 19 22 25 42 44 46 47 52 55 56 65 77
    VIN: TRUDD38J291008408   Mileage: 71790km-44608miles
    03-ABS Brakes -- Status: Malfunction 0010[/COLOR]
    Address 01: Engine        Labels: None
       Part No SW: 022 906 032 LR    HW: 022 906 032 GP
       Component: TT-3.2-HS-LEV2  G   2571
       Revision: 1QH04---    Serial number: AUX7Z0H6FN100J
       Coding: 0000172
       Shop #: WSC 01236 785 00200
       VCID: 6695B1778466748753B-8032
    Address 03: ABS Brakes        Labels: 8J0-614-517.clb
       Part No SW: 8J0 614 517 D    HW: 8J0 614 517 D
       Component: ESP MK60E1          0030
       Revision: 00H60001
       Coding: 0085841
       Shop #: WSC 46666 000 1048576
       VCID: 2E0509576C16FCC76BB-807A
                        Reset counter: 162
                        Mileage: 71032 km
                        Date: 2019.12.19
                        Time: 18:53:23
                        Count: 128
                        Count: 11077
                        Count: 128
                        Count: 34816
       Part No SW: 8J0 820 043 AH    HW: 8J0 820 043 AH
       Component: J255  Klima 1 Zone  0080
       Revision: 00H07004    Serial number: 00000001095909
       Coding: 1048614
       VCID: 6C81C35F9A8A4ED705F-8038
    Address 09: Cent. Elect.        Labels:. 8P0-907-279-30-H.lbl
       Part No SW: 8P0 907 279 P    HW: 8P0 907 279 P
       Component: Bordnetz-SG     H53 2902
       Revision: 00H53000    Serial number: 00000008579773
       Coding: F1041E83C0141C804F1800001800000000284E075A250802000000000000
       VCID: 4ACD65C7F0BEB0E7573-801E
       Subsystem 1 - Part No: 8J1 955 119 A  Labels: 1KX-955-119.CLB
       Component: Wischer AU354   H07 0070
       Coding: 00064784
       Shop #: WSC 01236
       Coding: 00149804
       Shop #: WSC 01236
       Revision: 00000000    Serial number: AUZ4Z7H0358032
       Coding: 0000100
       VCID: 333318238734D12F045-8066
                        Reset counter: 134
                        Mileage: 71653 km
                        Date: 2020.01.13
                        Time: 16:32:38
    Address 15: Airbags        Labels: 8J0-959-655.lbl
       Part No SW: 8J0 959 655     HW: 8J0 959 655
       Component: -E Airbag 9.43  H02 0020
       Revision: 93H02002    Serial number: 0036K002X30O
       Coding: 0011589
       VCID: 79AFEA0BE5D8EB7F8E9-802C
       Subsystem 1 - Part No: 8J0 910 339 A
       Component: BF-Gewichtsens. H02 0030
       Subsystem 2 - Serial number: 02H4M
       Subsystem 3 - Serial number: 0001.01.0000H0200000000000˙†63
       Subsystem 4 - Serial number: 000000˙†6332DRB4076445AAT˙†63
       Subsystem 5 - Serial number: 445AAT˙†6342DRB40762CDB4$˙†63
       Subsystem 6 - Serial number: 2CDB4$˙†63747RB403DBAA6D6˙†63
       Subsystem 7 - Serial number: BAA6D6˙†63847RB403BF3559Z˙
       Subsystem 8 - Serial number: F3559Z˙
    Address 16: Steering wheel        Labels: 8P0-953-549-F.lbl
       Part No SW: 8P0 953 549 F    HW: 8P0 953 549 F
       Component: J0527           H36 0070
       Coding: 0004041
       VCID: 41DF42EBCD8873BF869-8014
       Component: E0221           H06 0030
    Address 17: Instruments        Labels: 8J0-920-xxx-17-MY8.clb
       Part No SW: 8J0 920 990 F    HW: 8J0 920 990 F
       Component: KOMBIINSTR. VDO H13 0320
       Revision: D0H13004    Serial number: 2246H004000854
       Coding: 0021288
       Shop #: WSC 05142 067 57207
       VCID: 3537263B8940CF1F2A1-8060
       Component: J533__Gateway   H16 0202
       Revision:   H16       Serial number: 2700K085308209
       Coding: E9831F071007024100
                        Reset counter: 136
                        Mileage: 70661 km
                        Date: 2019.11.12
                        Time: 10:17:59
       Part No SW: 0BR 907 554 A    HW: 0BR 907 554 A
       Component: Haldex 4Motion      3016
       Coding: 0000005
       VCID: 43D348E3D79461AF945-8016
       Revision: D0H13004    Serial number: AUX7Z0H6FN100J
       Shop #: WSC 07471 002 1048576
    Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN3.lbl
       Part No SW: 8J8 959 801 E    HW: 8J8 959 801 E
       Component: Tuer-SG         H02 0060
       Coding: 0001077
       VCID: 3FDB4413BB7C054FF0D-806A
       Part No: 8J1 909 143 C
       Component: EPS_ZFLS Kl.155 H08 1903
       VCID: 3039172F7622EA37797-8064
    Address 46: Central Conv.        Labels:. 8J0-959-433.lbl
       Part No: 8J0 959 433 C
       Component:    KSG          H11 0080
       Coding: 1B90328201382D290F0FC88A0477
       VCID: 363521379446C40723B-8062
    Address 47: Sound System        Labels: 8J0-035-223.lbl
       Part No SW: 8J0 035 223 B    HW: 8J0 035 223 B
       Component: J525 Amp Std    H03 0120
       Revision: 00H03001    Serial number: 93802007101011
       Coding: 0106116
       VCID: 2313E86337D441AFF45-8076
       Part No SW: 8J8 959 802 E    HW: 8J8 959 802 E
       Coding: 0001076
       VCID: 40D947EFC6827AB7897-8014
       Part No: 8P0 907 357 H
       Coding: 0000010
       Part No SW: 8J0 035 186 P    HW: 8J0 035 186 P
       Component: R Concert2+     H03 0270
       Revision: 00H03000    Serial number: AUZ1Z3H7164017
       Coding: 0750102
       VCID: 392F2A0BA5582B7FCE9-806C
    Address 65: Tire Pressure        Labels: 8J0-907-273.lbl
       Part No SW: 8J0 907 273 A    HW: 8J0 907 273 A
       Component: J502-RDK        H03 0370
       Revision: --H03-D0    Serial number: 12956781242245
       Coding: 0840019
       VCID: 2F3B14536B1CF5CF60D-807A
       Part No SW: 8P0 862 335 P    HW: 8P0 862 335 P
       Component: FSE_256x BT     H34 0520
       Revision: 00000000    Serial number: 00000005003937
       Coding: 0001277
    End----------(Elapsed Time: 01:25, VBatt start/end: 12.2V/12.2V)-----------
    I doubt the Terminal 30 Voltage fault is related, but if it were mine, I would clear that fault, then do whatever it takes to reproduce the misbehavior, followed by scanning it again.
    What you're describing sounds like a stuck valve of some sort in the ABS system?
    But I'd also check the calipers. Pull them off, make sure the piston(s) move freely, and that the calipers are free to float as they should.
