Results 11 to 20 of 22
Thread: High Beam Assist Activation
    ^^^Hbuk: Hi.
    hmm...... the words bolded in your instruction below may be greatly exaggerated!!!
    Module 09
    Long coding: No long coding at all needed on this module.. I was really surprised by this!!!!
    I'm not familiar with Audi TT 8S, but the vehicle appears to have a not uncommon MQB platform BCM. I suspect therefor that the original author of your instructions was "surprised" because the BCM that pertained to the instruction was the newer type which contained no long code. Your BCM does indeed appear to have a live and healthy long code.
    Here's the code for the pertinent Byte:
    Byte 2, Bits 0-2 (Advanced Highbeam control)
    Halogen=hex0
    Halogen_main_beam_assist=hex1
    Xenon_AFS=hex2,
    Xenon_AFS_and_main_beam_assist=hex3
    Bi-xenon_AFS=hex4
    Bi-xenon_AFS_and_main_beam_assist=hex5
    Bi-xenon_AFS_and_MDF_GLW= hex6
    Your setting for Byte 2 is Hex4C (or Binary 01001100) - so using my list, your car appears to have HiDs because Bits 0 -2 have a value of hex4. Perhaps you might try changing this to 01001101, which equals Hex 4D).
    PS: I'm not sure if making this change also means that you will lose the current headlight calibration - if so, some time spent in Basic Settings for the BCM may be needed
    PPS: Has this car been tuned?
  2. #12
    Jan 2020
    Spain
    Thanks for your response, I will look in to this shortly. The car is fitted with the standard LED headlights.
    Yes the har has been remapped, would this affect anything?
  3. #13
    Quote Originally Posted by Hbuk24 View Post
    Yes the car has been remapped, would this affect anything?
    No -I expect that it will make no difference to the HBA activation exercise - but it might explain the intermittent System Pressure -too high DTC in the hex01 module.
    Not sure how the implausible T15 error can be generated - anyone else have a view? In any event, these (and the BCM faults - have you replaced the battery in the key fob yet?) appear to be aberrations - try clearing and re-poll.
  4. Likes Uwe liked this post
  5. #14
    Jan 2020
    Spain
    Hi Don, Sorry but I don't understand. I am not aware of any errors. The autoscan comes back with all systems OK and the only morning i get is regarding traffic signs.
  6. #15
    Address 01: Engine (J623-CHHC)       Labels:. 06K-907-425-V1.clb
       Part No SW: 8S0 906 259     HW: 06K 907 425 B
       Component: 2.0l R4 TFSI  H13 0003
       Revision: --H13---
       Coding: 0A1900322424050B3002
       Shop #: WSC 06385 790 00016
       ASAM Dataset: EV_ECM20TFS0208S0906259 001004
       ROD: EV_ECM20TFS0208S0906259.rod
       VCID: 7AAEFB5F1C583CC7873-802F
    20277 - Terminal 15 Voltage
              P151B 00 [036] - Implausible
    15057 - Fuel Rail/System Pressure
              P0088 00 [096] - Too High
  7. Likes Uwe, DV52 liked this post
  8. #16
    Jan 2020
    Spain
    Im not when this scan was from, a while ago I have a lot of issues which I had resolved. I can find a recent scan and post it here.
  9. #17
    That would be helpful, otherwise we are seeing incorrect scan information and cannot properly help you.
  10. Likes Uwe, Hbuk24 liked this post
  11. #18
    Jan 2020
    Spain
    Please see below the latest scan from yesterday;
    Wednesday,29,January,2020,18:57:26:30289
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(Parallels)
    VCDS Version 19.6.2.0 (x64)  HEX-V2 CB: 0.4508.4
    VIN: TRUZZZFV3F1009952   License Plate:
    Chassis Type: FV-AU37 (8S0)
    Scan: 01 03 05 08 09 10 15 16 17 19 2B 42 44 52 55 5F A5 A9
    VIN: TRUZZZFV3F1009952   Mileage: 94785km-58896miles
      Component: 2.0l R4 TFSI  H13 0004
      Revision: --H13---
      ASAM Dataset: EV_ECM20TFS0208S0906259 001005
    Readiness: 0010 0001
      Part No SW: 8S0 907 379 B    HW: 8S0 907 379 B
      Component: ESC           H31 0504
      Revision: 00000000    Serial number: 63474000000378
      Coding: 32AA108D1A9915B2409A0069C2939306444C0858A8020043C96022
      ASAM Dataset: EV_Brake1UDSContiMK100IPB 052008
      ROD: EV_Brake1UDSContiMK100IPB_052.rod
      VCID: 40DA49B73A04A617897-8015
      Part No SW: 3Q0 959 435     HW: 3Q0 959 435
      Component: VWKESSYMQB    023 0522
      Revision: 00023000    Serial number: 0356563904
      Coding: 000F0F1620
      ASAM Dataset: EV_KessyHellaMQBAB 004027
      VCID: 77A8E26B2F4A21AFF8D-8023
      Part No SW: 8S0 820 047     HW: 8S0 820 047
      Component: AC Manuell el H05 0030
      Revision: 20009000    Serial number: 14190000009000
      Coding: 410040000011100100
      ASAM Dataset: EV_AirCondiMAPrehAU33x 003011
      ROD: EV_AirCondiMAPrehAU33x.rod
      VCID: 70BAD9774A247697397-8025
      Operating and display unit 1 for air conditioning:
      Subsystem 1 - Part No SW: 8S0 820 374 A    HW: 8S0 820 374 A
      Component: E774 BuA_1  H06 0010
      Serial number: 00000000000000000916
      Operating and display unit 2 for air conditioning:
      Subsystem 2 - Part No SW: 8S0 820 360 D    HW: 8S0 820 360 D
      Component: E775 BuA_2  H06 0010
      Operating and display unit 3 for air conditioning:
      Subsystem 3 - Part No SW: 8S0 820 360 C    HW: 8S0 820 360 C
      Component: E776 BuA_3  H06 0010
      Operating and display unit 4 for air conditioning:
      Subsystem 4 - Part No SW: 8S0 820 360 E    HW: 8S0 820 360 E
      Component: E777 BuA_4  H06 0010
      Operating and display unit 5 for air conditioning:
      Subsystem 5 - Part No SW: 8S0 820 374 B    HW: 8S0 820 374 B
      Component: E778 BuA_5  H06 0010
      Part No SW: 5Q0 937 084 BR    HW: 5Q0 937 084 AJ
      Component: BCM MQBAB H   H18 0136
      Serial number: 01011500600635
      Coding: 07054C46C201067D03044004B31807A80080000000000000000000000000
      ROD: EV_BCMBOSCH_013.rod
      VCID: 094C949349BE275F9E9-805D
      Subsystem 1 - Part No SW: 8S2 955 119 A    HW: 8S2 955 119 A  Labels: 5QX-955-119-V1.CLB
      Component: 43x RL 140703  032 0371
      Serial number: 00000001407010600651
      Coding: 1BC7F7
      Subsystem 2 - Part No SW: 8U0 955 559 A    HW: 8U0 955 559 A  Labels: 8U0-955-559.CLB
      Component: G397_RLS  H06 0002
      Serial number: 20170017
      Coding: 00005D
      Light switch:
      Subsystem 3 - Part No SW: 8V0 941 531 AA    HW: 8V0 941 531 AA
      Serial number: 31 10 2014  00001298
      Subsystem 4 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
      Serial number: 000000000ZY143210P5Q
      Serial number: 00000000000031477725
      Part No SW: 5Q0 919 283 E    HW: 5Q0 919 283
      Component: PARKHILFE 4K  H10 0051
      Revision: --------    Serial number: 39291435205285
      Coding: 0000050001
      VCID: 3B203E5B53E2C5CFDC5-806F
      Part No SW: 5Q0 959 655 P    HW: 5Q0 959 655 P
      Component: AirbagVW20    009 0870
      Serial number: 003M7R008LLN
      Coding: 88CCF0C00C8000005C5000CFC0C800000065
      ROD: EV_AirbaVW20SMEVW37X.rod
      VCID: 4DC46083FD567B7F721-8019
      Subsystem 1 - Part No SW: -----------    HW: 480 000 701 15
      Serial number: 35700000000B4079621C
      Subsystem 2 - Part No SW: -----------    HW: 480 000 701 15
      Serial number: 358000000007D539621J
      Subsystem 3 - Part No SW: -----------    HW: 480 010 712 14
      Component: SideSensor_Dr  004 0108
      Serial number: 351001A014A5F5C2CECQ
      Subsystem 4 - Part No SW: -----------    HW: 480 400 910 14
      Serial number: 3550002A7175A922917%
      Front Sensor Passenger:
      Subsystem 5 - Part No SW: -----------    HW: 480 400 910 14
      Serial number: 3560002A5175A924114W
      Pedestrian Protection Center:
      Subsystem 6 - Part No SW: -----------    HW: 480 400 812 14
      Serial number: 23000029F1811B91607X
      Subsystem 7 - Part No SW: -----------    HW: 480 000 612 14
      Serial number: I0M000000007C0CC1211
      Subsystem 8 - Part No SW: -----------    HW: 480 000 612 14
      Serial number: I0N00000000C94CC1218
      Part No SW: 8S0 907 129 AL    HW: 8S0 907 129 AL
      Component: Lenks. Modul  H07 0140
      Revision: --------    Serial number: 91335OA800762
      Coding: 280C
      ASAM Dataset: EV_SMLSKLOMQB 019002
      ROD: EV_SMLSKLOMQB_010_VW37.rod
      VCID: 045285A76E9C7A37EDF-8051
    Address 17: Instruments (J285)       Labels:* Redir Fail!-SRI2
      Part No SW: 8S0 920 790     HW: 8S0 920 790
      Component: FBenRDW       H32 0221
      Coding: 242D0110698406000122F8809000800000000000
      ASAM Dataset: EV_DashBoardBOSCHAU33X 001013
      ROD: EV_DashBoardBOSCHAU33X.rod
      VCID: 76B6EF6F284058A7E3B-8023
      Part No SW: 8S0 907 468 A    HW: 8S0 907 468
      Component: GW MQB TT3    012 0203
      Revision: --------    Serial number: 10121410802670
      Coding: 030100042F025A004B000268080000000000000000000000000000000001
      ASAM Dataset: EV_GatewContiAU33X 011002
      ROD: EV_GatewContiAU33X_011.rod
      VCID: 3E26374F40F0D0E7FBB-806B
      Subsystem 2 - Part No SW: 8S0 951 523 B    HW: 8S0 951 523 B
      Component: J453 MFL  H06 0001
      Serial number: 20141127192416 RD508
      Subsystem 3 - Part No SW: 8S0 915 181 A    HW: 8S0 915 181 A
      Serial number: 1322795203
      Serial number: 14000306508006
      Coding: 0100000000000000
      ROD: EV_ELVMarquMQBB.rod
      VCID: 71BCDC73412E7F9F369-8025
      Part No SW: 5Q0 959 593 D    HW: 5Q0 959 593 B
      Serial number: 060115BLN04479
      Coding: 001546225C01040100001402
      VCID: 42DE43BF3408B4079F3-8017
      Coding: 9103
      VCID: 3728226B6FCAE1AF38D-8063
      Part No SW: 5Q0 959 592 D    HW: 5Q0 959 592 B
      Serial number: 100115BA91780A
      Coding: 001546225E01040100001402
      VCID: 41DC4CB3310EAF1F869-8015
      Coding: 03DE00102B200200
      ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005010
      VCID: 343215677EBC0AB71DF-8061
      Coding: E01800
      Coding: E01800
      Subsystem 3 - Part No SW: 8S0 941 329     HW: 8S0 941 329   Labels: 3D0-941-329.CLB
      Component: LeiMo links  H02 S002
      Coding: E01800
      Subsystem 4 - Part No SW: 8S0 941 329     HW: 8S0 941 329   Labels: 3D0-941-329.CLB
      Component: LeiMo rechts  H02 S002
      Coding: E01800
    Address 5F: Information Electr. (J794)       Labels:* Redir Fail!
      Part No SW: 8S0 035 072 A    HW: 8S0 035 072
      Component: MU-H-ND-ER    041 0139
      Serial number: A587A0FB000508
      Coding: 013304013C00000011111101000800002F0000E3000000001E
      ASAM Dataset: EV_MUHig4CGen2HBAS 001115
      ROD: EV_MUHig4CGen2HBAS_AU37.rod
      VCID: 2D0400039D965B7F521-8079
      Subsystem 1 - Part No SW: V03 959 801 ET    HW: -----------
      Component: ECE 2015  --- 0105
      Multimedia Operating Unit:
      Subsystem 2 - Part No SW: 8S0 919 614 L    HW: 8S0 919 614 L
      Component: ControlUnit_H  H21 0129
      Serial number: C1000015111400010114
      Component: Gracenote2  --- 1008
    Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 5Q0-980-653.clb
      Part No SW: 8S0 980 653     HW: 5Q0 980 653
      Component: MQB_MFK       H06 0002
      Serial number: 00000268359
      Coding: 0101000001010300000501000000010100
      ROD: EV_MFKBoschAU370.rod
      Part No SW: 8S0 907 159     HW: 4H0 907 159 A
      Component: SAS-GEN 2     H07 0004
      Serial number: 141203200313
    End----------(Elapsed Time: 01:25, VBatt start/end: 12.1V/12.1V)-----------
  12. #19
    Jan 2015
    Bosnia and Herzegovina
    did you try to change any adaptations channels? do a back up first in case you need to revert to factory
    There are 3 kind of services
    GOOD CHEAP FAST
    But you can only choose 2:
    GOOD and CHEAP won't be FAST
    FAST and GOOD won't be CHEAP
    CHEAP and FAST won't be GOOD
  13. Likes Hbuk24 liked this post
  14. #20
    Jan 2020
    Spain
    No, Im not sure what this is?
