Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: High Beam Assist Activation
    Jan 2020
    Spain
    I have an Audi TT 8S which has the camera installed from factory and im told that you can activate the high beam assist function. Does anyone have steps to do this or experience with it? I followed some instructions previously which created a lot of lighting errors. Thanks
    Seeing a VCDS Auto-Scan of your TT 8S will help to ensure that you get the correct instructions to enable HBA for your car.
  3. Likes Dana, Hbuk24 liked this post
    Jan 2020
    Spain
    Sure, please see an original scan below;
    Sunday,12,January,2020,16:42:30:30289
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(Parallels)
    VCDS Version 19.6.2.0 (x64)  HEX-V2 CB: 0.4508.4
    VIN: TRUZZZFV3F1009952   License Plate:
    Chassis Type: FV-AU37 (8S0)
    Scan: 01 03 05 08 09 10 15 16 17 19 2B 42 44 52 55 5F A5 A9
    VIN: TRUZZZFV3F1009952   Mileage: 91851km-57073miles
    Address 01: Engine (J623-CHHC)       Labels:. 06K-907-425-V1.clb
       Part No SW: 8S0 906 259     HW: 06K 907 425 B
       Component: 2.0l R4 TFSI  H13 0003
       Revision: --H13---
       Coding: 0A1900322424050B3002
       Shop #: WSC 06385 790 00016
       ASAM Dataset: EV_ECM20TFS0208S0906259 001004
       ROD: EV_ECM20TFS0208S0906259.rod
       VCID: 7AAEFB5F1C583CC7873-802F
    20277 - Terminal 15 Voltage
              P151B 00 [036] - Implausible
                        Mileage: 91851 km
                        Date: 2020.01.12
                        Time: 15:43:43
                        Engine speed: 798.00 /min
                        Normed load value: 3.1 %
                        Coolant temperature: 90 ∞C
                        Intake air temperature: 34 ∞C
                        Voltage terminal 30: 12.050 V
                        Engine: operating status: IS
                        STATE_LS_SAE[1]: OL_CDN
                        T_AST_SAE: 0 s
                        MAP_MES_SAE: 27 kPa
                        Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.987 V
                        FAC_TPS_1_SAE: 11.718750 %
                        FUP_H_SAE: 11000.0 kPa
    15057 - Fuel Rail/System Pressure
              P0088 00 [096] - Too High
       Part No SW: 8S0 907 379 B    HW: 8S0 907 379 B
       Component: ESC           H31 0504
       Revision: 00000000    Serial number: 63474000000378
       Coding: 32AA108D1A9915B2409A0069C2939306444C0858A8020043C96022
       ASAM Dataset: EV_Brake1UDSContiMK100IPB 052008
       ROD: EV_Brake1UDSContiMK100IPB_052.rod
       VCID: 40DA49B73A04A617897-8015
       Part No SW: 3Q0 959 435     HW: 3Q0 959 435
       Component: VWKESSYMQB    023 0522
       Revision: 00023000    Serial number: 0356563904
       Coding: 000F0F1620
       ASAM Dataset: EV_KessyHellaMQBAB 004027
       VCID: 77A8E26B2F4A21AFF8D-8023
       Part No SW: 8S0 820 047     HW: 8S0 820 047
       Component: AC Manuell el H05 0030
       Revision: 20009000    Serial number: 14190000009000
       Coding: 410040000011100100
       ASAM Dataset: EV_AirCondiMAPrehAU33x 003011
       ROD: EV_AirCondiMAPrehAU33x.rod
       VCID: 70BAD9774A247697397-8025
       Operating and display unit 1 for air conditioning:
       Subsystem 1 - Part No SW: 8S0 820 374 A    HW: 8S0 820 374 A
       Component: E774 BuA_1  H06 0010
       Serial number: 00000000000000000916
       Operating and display unit 2 for air conditioning:
       Subsystem 2 - Part No SW: 8S0 820 360 D    HW: 8S0 820 360 D
       Component: E775 BuA_2  H06 0010
       Operating and display unit 3 for air conditioning:
       Subsystem 3 - Part No SW: 8S0 820 360 C    HW: 8S0 820 360 C
       Component: E776 BuA_3  H06 0010
       Operating and display unit 4 for air conditioning:
       Subsystem 4 - Part No SW: 8S0 820 360 E    HW: 8S0 820 360 E
       Component: E777 BuA_4  H06 0010
       Operating and display unit 5 for air conditioning:
       Subsystem 5 - Part No SW: 8S0 820 374 B    HW: 8S0 820 374 B
       Component: E778 BuA_5  H06 0010
       Part No SW: 5Q0 937 084 BR    HW: 5Q0 937 084 AJ
       Component: BCM MQBAB H   H18 0136
       Serial number: 01011500600635
       Coding: 07054C46C201067D03044004B31807A80080000000000000000000000000
       ROD: EV_BCMBOSCH_013.rod
       VCID: 094C949349BE275F9E9-805D
       Subsystem 1 - Part No SW: 8S2 955 119 A    HW: 8S2 955 119 A  Labels: 5QX-955-119-V1.CLB
       Component: 43x RL 140703  032 0371
       Serial number: 00000001407010600651
       Coding: 1BC7F7
       Subsystem 2 - Part No SW: 8U0 955 559 A    HW: 8U0 955 559 A  Labels: 8U0-955-559.CLB
       Component: G397_RLS  H06 0002
       Serial number: 20170017
       Coding: 00005D
       Subsystem 3 - Part No SW: 8V0 941 531 AA    HW: 8V0 941 531 AA
       Serial number: 31 10 2014  00001298
       Subsystem 4 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
       Serial number: 000000000ZY143210P5Q
       Serial number: 00000000000031477725
    204546 - Remote key 2
                        Reset counter: 144
                        Mileage: 91818 km
                        Date: 2019.12.17
                        Time: 09:38:45
    262912 - Sensor for Anti-Theft Alarm System
              B1330 F5 [008] - Alert Emergency Activation Stage 1
                        Reset counter: 184
                        Mileage: 91818 km
                        Date: 2019.12.17
                        Time: 09:38:46
    Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-283.clb
       Part No SW: 5Q0 919 283 E    HW: 5Q0 919 283
       Component: PARKHILFE 4K  H10 0051
       Revision: --------    Serial number: 39291435205285
       Coding: 0000050001
       ASAM Dataset: EV_EPHVA14AU3700000 002022
       VCID: 3B203E5B53E2C5CFDC5-806F
       Part No SW: 5Q0 959 655 P    HW: 5Q0 959 655 P
       Component: AirbagVW20    009 0870
       Serial number: 003M7R008LLN
       Coding: 88CCF0C00C8000005C5000CFC0C800000065
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 4DC46083FD567B7F721-8019
       Subsystem 1 - Part No SW: -----------    HW: 480 000 701 15
       Serial number: 35700000000B4079621C
       Subsystem 2 - Part No SW: -----------    HW: 480 000 701 15
       Serial number: 358000000007D539621J
       Subsystem 3 - Part No SW: -----------    HW: 480 010 712 14
       Component: SideSensor_Dr  004 0108
       Serial number: 351001A014A5F5C2CECQ
       Subsystem 4 - Part No SW: -----------    HW: 480 400 910 14
       Serial number: 3550002A7175A922917%
       Front Sensor Passenger:
       Subsystem 5 - Part No SW: -----------    HW: 480 400 910 14
       Serial number: 3560002A5175A924114W
       Pedestrian Protection Center:
       Subsystem 6 - Part No SW: -----------    HW: 480 400 812 14
       Component: PedP_Sensor_C  001 6149
       Serial number: 23000029F1811B91607X
       Subsystem 7 - Part No SW: -----------    HW: 480 000 612 14
       Serial number: I0M000000007C0CC1211
       Subsystem 8 - Part No SW: -----------    HW: 480 000 612 14
       Serial number: I0N00000000C94CC1218
       Part No SW: 8S0 907 129 AL    HW: 8S0 907 129 AL
       Component: Lenks. Modul  H07 0140
       Revision: --------    Serial number: 91335OA800762
       Coding: 280C
       ASAM Dataset: EV_SMLSKLOMQB 019002
       ROD: EV_SMLSKLOMQB_010_VW37.rod
       VCID: 045285A76E9C7A37EDF-8051
    Address 17: Instruments (J285)       Labels:* Redir Fail!-SRI2
       Part No SW: 8S0 920 790     HW: 8S0 920 790
       Component: FBenRDW       H32 0221
       Coding: 24250110698006000120A8809000800000000000
       ASAM Dataset: EV_DashBoardBOSCHAU33X 001013
       ROD: EV_DashBoardBOSCHAU33X.rod
       VCID: 76B6EF6F284058A7E3B-8023
       Part No SW: 8S0 907 468 A    HW: 8S0 907 468
       Component: GW MQB TT3    012 0203
       Revision: --------    Serial number: 10121410802670
       Coding: 030100042F025A004B000268080000000000000000000000000000000001
       ASAM Dataset: EV_GatewContiAU33X 011002
       ROD: EV_GatewContiAU33X_011.rod
       VCID: 3E26374F40F0D0E7FBB-806B
       Subsystem 2 - Part No SW: 8S0 951 523 B    HW: 8S0 951 523 B
       Component: J453 MFL  H06 0001
       Serial number: 20141127192416 RD508
       Subsystem 3 - Part No SW: 8S0 915 181 A    HW: 8S0 915 181 A
       Serial number: 1322795203
       Serial number: 14000306508006
       Coding: 0100000000000000
       ROD: EV_ELVMarquMQBB.rod
       VCID: 71BCDC73412E7F9F369-8025
       Serial number: 060115BLN04479
       Coding: 001146225C01040100001402
       VCID: 42DE43BF3408B4079F3-8017
       Coding: 9103
       VCID: 3728226B6FCAE1AF38D-8063
    Address 52: Door Elect, Pass.
       Coding: 03DE00102B200200
       ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005010
       VCID: 343215677EBC0AB71DF-8061
       Coding: E01800
       Coding: E01800
       Subsystem 3 - Part No SW: 8S0 941 329     HW: 8S0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo links  H02 S002
       Coding: E01800
       Subsystem 4 - Part No SW: 8S0 941 329     HW: 8S0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H02 S002
       Coding: E01800
    Address 5F: Information Electr. (J794)       Labels:* Redir Fail!
       Part No SW: 8S0 035 072 A    HW: 8S0 035 072
       Component: MU-H-ND-ER    041 0139
       Serial number: A587A0FB000508
       Coding: 013304013C00000011111101000800002F0000E3000000001A
       ASAM Dataset: EV_MUHig4CGen2HBAS 001115
       ROD: EV_MUHig4CGen2HBAS_AU37.rod
       VCID: 2D0400039D965B7F521-8079
       Multimedia Operating Unit:
       Subsystem 1 - Part No SW: 8S0 919 614 L    HW: 8S0 919 614 L
       Component: ControlUnit_H  H21 0129
       Serial number: C1000015111400010114
       Subsystem 2 - Part No SW: V03 959 800 EG    HW: -----------
       Component: Gracenote2  --- 1008
    Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 5Q0-980-653.clb
       Part No SW: 8S0 980 653     HW: 5Q0 980 653
       Component: MQB_MFK       H06 0002
       Serial number: 00000268359
       Coding: 0100000001010300000501000000010100
       ROD: EV_MFKBoschAU370.rod
       Part No SW: 8S0 907 159     HW: 4H0 907 159 A
       Component: SAS-GEN 2     H07 0004
       Serial number: 141203200313
    End----------(Elapsed Time: 01:24, VBatt start/end: 13.2V/13.2V)-----------
    United States
    Thanks Dave. There's a bit of history in this thread as well but we sorted those main issues and I suggested posting in Retrofits.
  6. Likes Uwe, Hbuk24 liked this post
    Jan 2020
    Spain
    I have found the instructions below online, do they look correct? I have created issues on the car before trying to activate HBA so wanted some advice before I try these. Thanks
     High Beam Assist
    Unit 9
security access 31347
adaptions
    Unit A5
security access
    Module 09
    Long coding: No long coding at all needed on this module.. I was really surprised by this!!!!
    Adaptations:
    Fernlicht_assistent:
    * Erweiterte_Fernlichtsteuerung: AFS, FLA, Fernlicht ueber AFS
    * Menuesteuerung Fernlichtassistent: Present
    * Fernlichtassistent Reset: not active
    * Menuesteuerung Fernlichtassistent Werkseinstellung: Not present
    * Assistenzfahrlicht, Empfindlichkeit per BAP einstellbar: Present
    *** I only needed to change the two that are highlighted but you can also change "Fernlichtassistent Reset" to "not active" and the Auto Assist will be remembered after switching the ignition off.
    Module A5:
    Long coding: byte 2 value 01 (bit 0 on)
    Unit A5
security access 20103
change the speed activation and deactivation of auto full beam
    Unit A5
    Security Access 20103
    Adaption
    find in the menu "activation speed for high-beam assistant"
    standard value is 57 km/h, set your speed then ok
    find in the menu "channel speed threshold for high beam recommendation off"
    standard value is 27 km/h, set your speed then ok
    find in the menu:
-activation speed for high beam assistant insert 20 on the blank space below then ok
    -speed threshold for high beam off
insert 10 on the blank space below then ok
    -check if this parameter is on:
main beam assist urban area detection, set on if not
    Jan 2015
    Bosnia and Herzegovina
    it looks ok, try and report
    There are 3 kind of services
    GOOD CHEAP FAST
    But you can only choose 2:
    GOOD and CHEAP won't be FAST
    FAST and GOOD won't be CHEAP
    CHEAP and FAST won't be GOOD
    Jan 2020
    Spain
    I could not find the following option available to try it unfortunately;
  10. #8
    Jan 2015
    did you enter security code 31347?
    GOOD CHEAP FAST
  11. Likes Hbuk24, Dana liked this post
  12. #9
    Jan 2020
    Spain
    Yes I did enter the security code
  13. #10
    United States
    Posting the Adaptation function map from 09 might be necessary but I'd search for "Fernlicht" the next time you are connected to the BCM. I believe one if the channels named Fernlichtassistent may apply.
  14. Likes Uwe liked this post
