Results 1 to 10 of 10
Thread: Injector: Cylinder 3 - Circuit Malfunction
    Apr 2015
    Norway
    Hello...
    So, my VW Caddy with a 1.6 TiD engine is not doing well. Engine is running rough and has poor acceleration/lack of power.
    Connected my VAG-COM and it is pointing out injector no 3.
    I have disconnected the plug and inspected and rinsed, but no progress.
    Is it anything else I should do and check before I changed the injector?
    Friday,24,January,2020,15:36:56:19306
    VCDS Version: 19.6.1.0
    VIN: WV1ZZZ2KZFX007889   License Plate:
    Chassis Type: 2K-VN35 (7N0)
    Scan: 01 03 08 09 10 15 16 17 18 19 25 42 44 46 52 56 61 69 77
    VIN: WV1ZZZ2KZFX007889   Mileage: 41710km-25917miles
    Address 01: Engine (J623-CAYE)       Labels:. 03L-906-023-CAY.clb
       Part No SW: 03L 906 023 TD    HW: 03L 907 425 C
       Component: R4 1.6l TDI   H43 9979
       Revision: --H43---    Serial number: 00000000000000
       Coding: 00114034032401080000
       Shop #: WSC 35110 790 50316
       ASAM Dataset: EV_ECM16TDI02103L906023TD 003003
       ROD: EV_ECM16TDI02103L997557R.rod
       VCID: 7BFF08E5F2AE0A97CC-802E
    9839 - Injector: Cylinder 3 (N32)
              P0203 00 [237] - Circuit Malfunction
                        Mileage: 41709 km
                        Date: 2020.01.24
                        Time: 15:02:00
                        Engine speed: 1232.75 /min
                        Normed load value: 15.7 %
                        Coolant temperature: 66 蚓
                        Intake air temperature: 17 蚓
                        Voltage terminal 30: 14.682 V
                        Incorrect information on selected Piezo power level-LF_STATE_PPS_SPI[0]: 0
                        Injector valve 2: capacity-CAPA_INJ_MAIN[1]: 32.1019 湩
                        Voltage load of main injection cylinder 2-CHR_INJ_MAIN[1]: 1434.6 渙s
                        Measured energy of main injection cylinder 2-EGY_INJ_MAIN[1]: 3.614 mJ
                        Supply voltage of analog output 1-VCC_1: 4.98 V
                        Supply voltage of analog output 2-VCC_2: 5.00 V
                        Injection valve 2: voltage-V_INJ_MAIN[1]: 5.04 V
    9835 - Injector: Cylinder 3 (N32)
              P0203 00 [167] - Circuit Malfunction
                        Mileage: 41713 km
                        Date: 2020.01.24
                        Time: 15:31:25
                        Engine speed: 801.75 /min
                        Normed load value: 23.9 %
                        Coolant temperature: 69 蚓
                        Intake air temperature: 13 蚓
                        Voltage terminal 30: 11.746 V
                        Injector valve 2: capacity-CAPA_INJ_MAIN[1]: 0.0353 湩
                        Voltage load of main injection cylinder 2-CHR_INJ_MAIN[1]: 8.0 渙s
                        Measured energy of main injection cylinder 2-EGY_INJ_MAIN[1]: 0.893 mJ
                        Injection valve 2: voltage-V_INJ_MAIN[1]: 225.21 V
    Readiness: 1 1 0 0 0
       Part No SW: 1K0 907 379 BM    HW: 1K0 907 379 BM
       Component: ESP MK60EC1   H46 0164
       Revision: 00H46001
       Coding: 423C200D09220301421304EC9022C051A1000020
       Shop #: WSC 35110 377 08192
       VCID: 7EF901F1E9BC1FBFEB-802A
       Part No SW: 7N0 907 426 CC    HW: 7N0 907 426 CC
       Component: AC Manuell    H20 0606
       Revision: 00001002
       Coding: 0010004003
       ROD: EV_ACManueBHBVW36X_VW32.rod
       VCID: 77F714D5CE862EF7A8-8022
    9672723 - Heated Seat; Front Left
              B1398 13 [009] - Open Circuit
                        Reset counter: 137
                        Mileage: 41411 km
                        Date: 2020.01.18
                        Time: 11:40:48
       Part No SW: 5K0 937 085 AA    HW: 5K0 937 085 AA
       Component: BCM PQ35 B+   122 0174
       Revision: BB122001
       Coding: 611A0A3A80251A6D088800829000006403017288424FAD60648087000041
       VCID: 72E125C1ADE44BDF9F-8026
       Subsystem 1 - Part No: 1T1 955 119 A  Labels: 1KX-955-119.CLB
       Component: Wischer 16051  26  0512
       Coding: 009795
    Address 10: Park/Steer Assist (J446)       Labels:| 1Q0-919-475.clb
       Part No SW: 2K0 919 475     HW: 1Q0 919 475
       Component: PARKHILFE 4K  H03 0004
       Revision: --------    Serial number: 32901412802666
       Coding: 118001
       ASAM Dataset: EV_EPHVA14VN3370000 001006
       ROD: EV_EPHVA14VN3370000.rod
       VCID: 70E52FC9ABE879CF69-8024
       Part No SW: 7E0 959 655 B    HW: 7E0 959 655 B
       Component: VW10Airbag029 H07 0013
       Revision: --------    Serial number: 003HL00R10D$
       Coding: 000000000000000000000000000000003239
       VCID: 356BDEDD940A1CE77A-8060
       Part No SW: 5K0 953 521 DQ    HW: 5K0 953 569 AH
       Revision: FF010042    Serial number: 20140522200806
       Coding: 1082160000
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 7EF901F1E1BC1FBFEB-802A
       Subsystem 1 - Part No SW: 5K0 959 542 C    HW: 5K0 959 542 C  Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAS  H31 0037
       Coding: 820000
       Part No SW: 2K0 920 876 F    HW: 2K0 920 876 F
       Component: KOMBI         H03 0905
       Coding: 180A00
       VCID: 336FE0C59A7E02D754-8066
    Address 18: Aux. Heat        Labels: 1K0-815-007.clb
       Part No: 7N0 963 272 E
       Component: Standheizer     044 4941
       Revision: 00044000    Serial number: 09028239000000
       Coding: 0031032
       Shop #: WSC 35110 377 00182
       VCID: 3777D4D54606EEF768-8062
       Part No SW: 7N0 907 530 AQ    HW: 7N0 907 530 AL
       Component: J533  Gateway H58 1653
       Revision:   H58       Serial number: 190514F1002926
       Coding: 357400
       VCID: 7F07FCF5EEB616B7E0-802A
       Component: IMMO          H03 0905
       VCID: 6AD13DA18D34831F27-803E
       Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
       Component: Tuer-SG         009 2109
       Coding: 0132144
       VCID: 4895A7293BF8910F11-801C
    01706 - Switch for Mirror-Adjust (E43)
       Part No: 1K0 909 144 R
       Component: EPS_ZFLS Kl. 140    3501
       Revision: 00H22000
       VCID: 3973D2ED7012F8879E-806C
       Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
       Coding: 0132144
       VCID: 4797A41536E69E7718-8012
       Part No SW: 3C8 035 195 H    HW: 3C8 035 195 H
       Component: Radio RCD510  006 0246
       Revision: 00000001    Serial number: VWZ1Z3P0295214
       Coding: 05000200020013
       VCID: 2D5BF6BD745A542702-8078
    02877 - Digital Radio Antenna (R183)
                        Fault Status: 00100111
                        Reset counter: 185
                        Mileage: 41354 km
                        Date: 2014.06.09
                        Time: 13:47:56
       Part No SW: 7N0 907 534     HW: 7N0 907 530 AL
       Component: Batt.regelung H58 1653
       Coding: 330F1859
       VCID: 71E32ACDA8E270C766-8024
       Component: J367-BDM  H07 0180
       Serial number: 31135H57431491229011
       Part No SW: 1K0 907 383 G    HW: 1K0 907 383 G
       Component: Anhaenger     H10 0110
       Revision: 3B001001    Serial number: 00008200432976
       Coding: 010D000101000000
       VCID: 3163EACD686230C726-8064
       Part No SW: 7P6 035 730 M    HW: 7P6 035 730 M
       Component: TELEFON       H16 4217
       Revision: 1B001001    Serial number: 00007666270359
       Coding: 0A01010000010110
       ASAM Dataset: EV_UHVNA 002720
       ROD: EV_UHVNA_002.rod
       VCID: 3C7DCBF9B720CDAF85-8068
    End-------------------------(Elapsed Time: 03:12)--------------------------
    Did you check wiring with load light from ECU to injector plug using WD and RTFB?
    Apr 2015
    Norway
    Thanks for the tip... The circuit tester with bulb shows me that the ECU is firing the injector.
  4. Likes Jack@European_Parts liked this post
    Nov 2016
    Ireland
    I've seen Injectors on these give lots of bother.
    If you've had the VW emmision update done, in the last 2yrs, VW will replace injectors under warranty.... (In Ireland anyway)
  6. Likes Uwe, Jack@European_Parts liked this post
    Apr 2015
    Norway
    Quote Originally Posted by Jonesy View Post
    Thanks for your reply. Do you know why they replace them under warranty? (I need some good points so I can argue my case with my VW dealer).
    Nov 2016
    Ireland
    Quote Originally Posted by UWSCSI View Post
    I'm guessing it's their way of accepting liability. I don't know what they say officially but they do replace them once it's within 2yrs of software update being done 👍
  10. #8
    Nov 2014
    New Zealand
    1.6 TDI injector failure is very common. Ask Uncle Google.
    The replacements are apparently updated and are more reliable (S suffix?)... but remember you may still have 3 other originals.
    Dont get "rebuit" ones, as its usually the non-replacable driver coil that fails.
    Allan
    The R32ran Thread
    How to post a full Auto-Scan
  11. Likes Jack@European_Parts liked this post
  12. #9
    Tartu, Estonia
    Lucky You, who You get it replaced Under warranty.
    There is TPI that states that injectors are not included in "Trust building measures".
    The world is my oyster...
  13. #10
    Apr 2015
    Norway
    Hi guys... I went to the VW dealer and addressed the problem. They acknowledged the fault and replaced 2 injectors free of charge...
    The car is from 2014 and the VW emmision update was performed February 2018...
    The VW dealership stated that it had nothing to do with the VW emmision update, but more to the fact that there has been a lot of problems with these injectors.
    Anyway, I am happy that the VW dealership actually took responsibility and fixed the problem free of charge this time.
    Thanks for all the help.
    Best regards from Norway.
  14. Likes Jack@European_Parts, Uwe liked this post
