Hello...
So, my VW Caddy with a 1.6 TiD engine is not doing well. Engine is running rough and has poor acceleration/lack of power.
Connected my VAG-COM and it is pointing out injector no 3.
I have disconnected the plug and inspected and rinsed, but no progress.
Is it anything else I should do and check before I changed the injector?
Friday,24,January,2020,15:36:56:19306
VCDS Version: 19.6.1.0
VIN: WV1ZZZ2KZFX007889 License Plate:
Chassis Type: 2K-VN35 (7N0)
Scan: 01 03 08 09 10 15 16 17 18 19 25 42 44 46 52 56 61 69 77
VIN: WV1ZZZ2KZFX007889 Mileage: 41710km-25917miles
Address 01: Engine (J623-CAYE) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 TD HW: 03L 907 425 C
Component: R4 1.6l TDI H43 9979
Revision: --H43--- Serial number: 00000000000000
Coding: 00114034032401080000
Shop #: WSC 35110 790 50316
ASAM Dataset: EV_ECM16TDI02103L906023TD 003003
ROD: EV_ECM16TDI02103L997557R.rod
VCID: 7BFF08E5F2AE0A97CC-802E
9839 - Injector: Cylinder 3 (N32)
P0203 00 [237] - Circuit Malfunction
Mileage: 41709 km
Date: 2020.01.24
Time: 15:02:00
Engine speed: 1232.75 /min
Normed load value: 15.7 %
Coolant temperature: 66 蚓
Intake air temperature: 17 蚓
Voltage terminal 30: 14.682 V
Incorrect information on selected Piezo power level-LF_STATE_PPS_SPI[0]: 0
Injector valve 2: capacity-CAPA_INJ_MAIN[1]: 32.1019 湩
Voltage load of main injection cylinder 2-CHR_INJ_MAIN[1]: 1434.6 渙s
Measured energy of main injection cylinder 2-EGY_INJ_MAIN[1]: 3.614 mJ
Supply voltage of analog output 1-VCC_1: 4.98 V
Supply voltage of analog output 2-VCC_2: 5.00 V
Injection valve 2: voltage-V_INJ_MAIN[1]: 5.04 V
9835 - Injector: Cylinder 3 (N32)
P0203 00 [167] - Circuit Malfunction
Mileage: 41713 km
Date: 2020.01.24
Time: 15:31:25
Engine speed: 801.75 /min
Normed load value: 23.9 %
Coolant temperature: 69 蚓
Intake air temperature: 13 蚓
Voltage terminal 30: 11.746 V
Injector valve 2: capacity-CAPA_INJ_MAIN[1]: 0.0353 湩
Voltage load of main injection cylinder 2-CHR_INJ_MAIN[1]: 8.0 渙s
Measured energy of main injection cylinder 2-EGY_INJ_MAIN[1]: 0.893 mJ
Injection valve 2: voltage-V_INJ_MAIN[1]: 225.21 V
Readiness: 1 1 0 0 0
Part No SW: 1K0 907 379 BM HW: 1K0 907 379 BM
Component: ESP MK60EC1 H46 0164
Revision: 00H46001
Coding: 423C200D09220301421304EC9022C051A1000020
Shop #: WSC 35110 377 08192
VCID: 7EF901F1E9BC1FBFEB-802A
Part No SW: 7N0 907 426 CC HW: 7N0 907 426 CC
Component: AC Manuell H20 0606
Revision: 00001002
Coding: 0010004003
ROD: EV_ACManueBHBVW36X_VW32.rod
VCID: 77F714D5CE862EF7A8-8022
9672723 - Heated Seat; Front Left
B1398 13 [009] - Open Circuit
Reset counter: 137
Mileage: 41411 km
Date: 2020.01.18
Time: 11:40:48
Part No SW: 5K0 937 085 AA HW: 5K0 937 085 AA
Component: BCM PQ35 B+ 122 0174
Revision: BB122001
Coding: 611A0A3A80251A6D088800829000006403017288424FAD60648087000041
VCID: 72E125C1ADE44BDF9F-8026
Subsystem 1 - Part No: 1T1 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer 16051 26 0512
Coding: 009795
Address 10: Park/Steer Assist (J446) Labels:| 1Q0-919-475.clb
Part No SW: 2K0 919 475 HW: 1Q0 919 475
Component: PARKHILFE 4K H03 0004
Revision: -------- Serial number: 32901412802666
Coding: 118001
ASAM Dataset: EV_EPHVA14VN3370000 001006
ROD: EV_EPHVA14VN3370000.rod
VCID: 70E52FC9ABE879CF69-8024
Part No SW: 7E0 959 655 B HW: 7E0 959 655 B
Component: VW10Airbag029 H07 0013
Revision: -------- Serial number: 003HL00R10D$
Coding: 000000000000000000000000000000003239
VCID: 356BDEDD940A1CE77A-8060
Part No SW: 5K0 953 521 DQ HW: 5K0 953 569 AH
Revision: FF010042 Serial number: 20140522200806
Coding: 1082160000
ROD: EV_SMLSNGVOLWS.rod
VCID: 7EF901F1E1BC1FBFEB-802A
Subsystem 1 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H31 0037
Coding: 820000
Part No SW: 2K0 920 876 F HW: 2K0 920 876 F
Component: KOMBI H03 0905
Coding: 180A00
VCID: 336FE0C59A7E02D754-8066
Address 18: Aux. Heat Labels: 1K0-815-007.clb
Part No: 7N0 963 272 E
Component: Standheizer 044 4941
Revision: 00044000 Serial number: 09028239000000
Coding: 0031032
Shop #: WSC 35110 377 00182
VCID: 3777D4D54606EEF768-8062
Part No SW: 7N0 907 530 AQ HW: 7N0 907 530 AL
Component: J533 Gateway H58 1653
Revision: H58 Serial number: 190514F1002926
Coding: 357400
VCID: 7F07FCF5EEB616B7E0-802A
Component: IMMO H03 0905
VCID: 6AD13DA18D34831F27-803E
Part No SW: 1T0 959 701 T HW: 1T0 959 701 T
Component: Tuer-SG 009 2109
Coding: 0132144
VCID: 4895A7293BF8910F11-801C
01706 - Switch for Mirror-Adjust (E43)
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 140 3501
Revision: 00H22000
VCID: 3973D2ED7012F8879E-806C
Part No SW: 1T0 959 702 R HW: 1T0 959 702 R
Coding: 0132144
VCID: 4797A41536E69E7718-8012
Address 56: Radio (J0503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 3C8 035 195 H HW: 3C8 035 195 H
Component: Radio RCD510 006 0246
Revision: 00000001 Serial number: VWZ1Z3P0295214
Coding: 05000200020013
VCID: 2D5BF6BD745A542702-8078
02877 - Digital Radio Antenna (R183)
Fault Status: 00100111
Reset counter: 185
Mileage: 41354 km
Date: 2014.06.09
Time: 13:47:56
Part No SW: 7N0 907 534 HW: 7N0 907 530 AL
Component: Batt.regelung H58 1653
Coding: 330F1859
VCID: 71E32ACDA8E270C766-8024
Component: J367-BDM H07 0180
Serial number: 31135H57431491229011
Part No SW: 1K0 907 383 G HW: 1K0 907 383 G
Component: Anhaenger H10 0110
Revision: 3B001001 Serial number: 00008200432976
Coding: 010D000101000000
VCID: 3163EACD686230C726-8064
Part No SW: 7P6 035 730 M HW: 7P6 035 730 M
Component: TELEFON H16 4217
Revision: 1B001001 Serial number: 00007666270359
Coding: 0A01010000010110
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_002.rod
VCID: 3C7DCBF9B720CDAF85-8068
End-------------------------(Elapsed Time: 03:12)--------------------------
