ACC/distance control weirdness
cruster
C?ID=281059
Howdy - I'm having weirdness with ACC the past few weeks, and it's stumping me.
Car is a US 2016 Golf SportWagen with driver assist package, which included full ACC and front assist for 2016.
About a week ago I started getting infrequent ACC errors - ACC and/or Front Assist Not Available in the MFD. I am able to clear the codes, but the error pops up again...randomly. I can't seem to tie it to any place or action. I've had it happen two days in a row, and I've gone 6 days without it.
Turning the car off and back on always restores functionality.
The error indicates that automatic distance control is disconnected.
One note, and I don't know if it's a factor, but...I did notice about a month ago that I have a chip in the windshield that seems to have spidered-out...and it's right in front of the camera. I need to get that taken care of. I assume it's a problem with ACC, but not necessarily a root cause here.
I've also noticed some weird behavior with ACC - which I think may be related to the windshield chip - which is that some cars seem to no longer be detected by the camera. Seems to particularly happen if I have ACC and come upon a vehicle, which was previously out of range, at a stop. THe car...won't stop. Watching in the MFD, there's no car image, as if the car is not detected.
Any help would be appreciated. No accidents, no impacts (that I know of)...nothing I can think of that would be causing this issue.
Thanks in advance.
Wednesday,22,January,2020,20:27:18:37754
VCDS Version: 19.6.2.0 (x64)
VIN: 3VWC17AU6GM516369   License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 3C 42 44 47 52 55 5F
          75 A5
VIN: 3VWC17AU6GM516369   Mileage: 101719km-63205miles
Address 01: Engine (J623-CXBB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8V0 906 264 F    HW: 06K 907 425 B
   Component: 1.8l R4 TFSI  H13 0003
   Revision: --H13---
   Coding: 091A00322464002F1000
   Shop #: WSC 00066 790 00060
   ASAM Dataset: EV_ECM18TFS0208V0906264F 001003
   ROD: EV_ECM18TFS0208V0906264F.rod
   VCID: 3FA3BC81A6EEC6B79E-806A
Readiness: 1010 1101
   Part No SW: 09G 927 749 AP    HW: 09G 927 749 AP
   Component: AISIN AG6 G3  129 2943
   Coding: 010100000C000000000000000000000000000000
   ASAM Dataset: EV_TCMAQ250031 002009
   ROD: EV_TCMAQ250031_002_VW37.rod
   VCID: 07336461BEBE4E77E6-8052
   Revision: 00000000    Serial number: 62285000000052
   Coding: 04FA6AA124210972007A020681CC292056249000408194B416405052C082
   Shop #: WSC 01383 790 50316
   VCID: 7AD50D95FD4C239FE9-802E
   Revision: 00021000    Serial number: 0380115767
   Coding: 030C0C
   VCID: 3A55CD95BDCCE39FA9-806E
   Part No SW: 5GM 907 426 A    HW: 5GM 907 426 A
   Component: AC Manuell    H02 1001
   Revision: 00001K01
   Coding: 02020004200100000100000000000002
   VCID: 46ADA965F934977FDD-8012
   Part No SW: 5Q0 937 087 AA    HW: 5Q0 937 087 AA
   Revision: --------    Serial number: 86582410150230
   Coding: 00511B464041A26969E44000011407001800000000000000000000000000
   Shop #: WSC 00066 790 00206
   ROD: EV_BCMBOSCH_015.rod
   Component: WWS    150724  043 0581
   Serial number:         151204071827
   Subsystem 2 - Part No SW: 5Q0 955 559 A    HW: 5Q0 955 559 A  Labels: 5Q0-955-547.CLB
   Component: RLS  037 0059
   Serial number: S4Y15M10D23H23M00S58
   Coding: 96A8DD
   Sun Roof:
   Subsystem 3 - Part No SW: 5G0 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS22.409  H03 0004
   Serial number: 0000FST000GBTN700000
   Coding: 191800
   Roof Blind:
   Subsystem 4 - Part No SW: 5G0 959 591 A    HW: 8V3 959 591 A
   Component: J394 PS22.409  H03 0004
   Serial number: 0000FST000GBTM600000
   Coding: 191800
   Part No SW: 5Q0 919 298 K    HW: 5Q0 919 298
   Component: PARKHILFE PLA H12 0054
   Revision: --------    Serial number: 39491529501121
   Coding: 0031165011
   ASAM Dataset: EV_EPHVA2CAU3700000 003021
   ROD: EV_EPHVA2CAU3700000_003.rod
   VCID: 47B3A461FE3E8E7726-8012
   Part No SW: 5Q0 907 572 F    HW: 5Q0 907 572 F
   Component: ACC Bosch MQB H05 0400
   Serial number: 04071503212235
   Coding: 010C5400FE0739
   ASAM Dataset: EV_ACCMRRBoschVW372 001016
1043 - Automatic Distance Control
          B10E7 F0 [008] - Disconnected
                    Reset counter: 196
                    Mileage: 101693 km
                    Date: 2020.01.22
                    Time: 16:52:46
                    Control Module temperature: 24 °C
                    Voltage terminal 15: 14.3 V
                    Vehicle speed: 17.29 m/s
                    Acceleration: -0.14 m/s²
   Serial number: 003GCR03FYJ0
   ROD: EV_AirbaVW20SMEVW37X.rod
   Occupant Detection:
   Component: BF-Gewichtss.  H11 0021
   Serial number: IBH000000000003WUL25
   Coding: 303135
   Subsystem 2 - Part No SW: -----------    HW: 480 002 509 15
   Serial number: 35700000000D772C361N
   Subsystem 3 - Part No SW: -----------    HW: 480 002 409 15
   Serial number: 35800000000C5A9CE61%
   Subsystem 4 - Part No SW: -----------    HW: 480 402 109 15
   Serial number: 3510002AB1D1B5D300E7
   Subsystem 5 - Part No SW: -----------    HW: 480 402 109 15
   Serial number: 3520002B71CF2DA5626G
   Subsystem 6 - Part No SW: -----------    HW: 480 401 609 15
   Serial number: 3550002C51CF2D83C1ER
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 401 609 15
   Serial number: 3560002C51CF2D83B2DR
   Part No SW: 5Q0 953 521 BB    HW: 5Q0 953 569 A
   Revision: FF033033    Serial number: 20150912500930
   Coding: 0C10
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 73CB20B1DA2652D7AA-8026
   Part No SW: 5G1 920 840 A    HW: 5G1 920 840 A
   Component: KOMBI         242 6420
   Coding: 0BA5111AED98CF0502887E0B5000000000000000
   VCID: 256F0EE924727C67F4-8070
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2246
   Revision: --------    Serial number: 11101510520536
   Coding: 0901000830085900FB00001A1C0F00000001050000000000000000000000
   Shop #: WSC 00066 790 07026
   ROD: EV_GatewConti_013.rod
   VCID: 79D71299F84A2887E0-802C
   Subsystem 2 - Part No SW: 5G0 959 442 R    HW: 5G0 959 442 R  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H16 0040
   Serial number: 29150001481320065294
   Coding: 35FFFF
   Power Converter DC AC:
   Subsystem 3 - Part No SW: 5Q0 907 155 A    HW: 5Q0 907 155 A
   Component: WECHSELRICHTE  H53 0041
   Serial number: 0083351
   Revision: 00000000    Serial number: 15000212593001
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 3449E3AD9FA815EF73-8060
   Component: HRE_Master    H11 0071
   Serial number: 0379666889
   Coding: 02011103
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3C59CB8DB7F8DDAFBB-8068
   Lane Change Assistant 2:
   Component: HRE_Slave  H11 0071
   Serial number: 0379002070
   Coding: 020111
   Serial number: 20111506050AUC
   Coding: 003A13200000020000000000
   VCID: 43ABB071CA06A257FA-8016
   Serial number: 00000000000002310599
   Coding: 011000
   Component: EPS_MQB_ZFLS  126 1063
   Coding: 1302
   VCID: 44A9B36DCF08A56FC3-8010
Address 47: Sound System (J525)       Labels:| 5Q0-035-456.clb
   Part No SW: 5Q0 035 456     HW: 5Q0 035 456
   Component: MIB2_lite_amp H20 0130
   Revision: 00000001    Serial number: VWZ8Z1FBA00YD2C
   Coding: 2200000000AAAAAA000000000000
   ASAM Dataset: EV_AMPMst12C1Gen2ALPI 001003
   ROD: EV_AMPMst12C1Gen2ALPI.rod
   VCID: 6DFF36C9BC0284277C-8038
0570 - Loudspeaker 2 in Double-Subwoofer
          B130D 13 [008] - Open Circuit
                    Reset counter: 196
                    Mileage: 92961 km
                    Date: 2019.09.24
                    Time: 20:22:52
                    Voltage terminal 30: 12.1 V
   Serial number: 171115060502F4
   VCID: 42A5B575D51CAB5FF1-8016
   Serial number: 00000000000001962165
   Coding: 091000
   Coding: 061A00000B000400
   VCID: 40A1BF7DDB10B94FE7-8014
   Subsystem 1 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0004
   Coding: 2E0000
   Subsystem 2 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0004
   Coding: 2E0000
   Part No SW: 3Q0 035 844     HW: 3Q0 035 844
   Component: MU-S-S-US     620 0613
   Coding: 027302000000000051220002001808001F0100F40120010002
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 6CF93BCD87188D2F6B-8038
   Subsystem 1 - Part No SW: 3G0 919 605 H    HW: 3G0 919 605 H
   Component: ABT_Std-2  H52 1028
   Serial number: VWZ8Z9RES00Y5C
   Component: OCULowMQBUS   007 0568
   Coding: 02730202C2823A017F1E06000000
   ROD: EV_OCULowMQB.rod
Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 5Q0-980-653.clb
   Part No SW: 5Q0 980 653 G    HW: 5Q0 980 653
   Component: MQB_MFK       H06 0060
   Serial number: 10000420370
   Coding: 0100010000020300000400010100000100
   ROD: EV_MFKBoschAU370.rod
End-------------------------(Elapsed Time: 04:12)--------------------------
Controller Software Versions:
ECU 1 = Engine 0003
ECU 2 = Auto Trans 2943
ECU 3 = ABS Brakes 0723
ECU 4 = Acc/Start Auth. 0604
ECU 5 = Auto HVAC 1001
ECU 6 = Cent. Elect. 0162
Sub ECU 6 > 1 = Cent. Elect. 0581
Sub ECU 6 > 2 = Cent. Elect. 0059
Sub ECU 6 > 3 = Cent. Elect. 0004
Sub ECU 6 > 4 = Cent. Elect. 0004
ECU 7 = Park/Steer Assist 0054
ECU 8 = Auto Dist. Reg 0400
ECU 9 = Airbags 0830
Sub ECU 9 > 1 = Airbags 0021
Sub ECU 9 > 2 = Airbags 0887
Sub ECU 9 > 3 = Airbags 0887
Sub ECU 9 > 4 = Airbags 6149
Sub ECU 9 > 5 = Airbags 6149
Sub ECU 9 > 6 = Airbags 6149
Sub ECU 9 > 7 = Airbags 6149
ECU 10 = Steering wheel 0195
ECU 11 = Instruments 6420
ECU 12 = CAN Gateway 2246
Sub ECU 12 > 1 = CAN Gateway 0040
Sub ECU 12 > 2 = CAN Gateway 0041
ECU 13 = Steer. Col. Lock 0120
ECU 14 = Lane Change 0071
Sub ECU 14 > 1 = Lane Change 0071
ECU 15 = Door Elect, Driver 0041
Sub ECU 15 > 1 = Door Elect, Driver 0002
ECU 16 = Steering Assist 1063
ECU 17 = Sound System 0130
ECU 18 = Door Elect, Pass. 0041
Sub ECU 18 > 1 = Door Elect, Pass. 0002
ECU 19 = Headlight Range 0090
Sub ECU 19 > 1 = Headlight Range 0004
Sub ECU 19 > 2 = Headlight Range 0004
ECU 20 = Information Electr. 0613
Sub ECU 20 > 1 = Information Electr. 1028
ECU 21 = Telematics 0568
ECU 22 = Frt Sens. Drv. Assist 0060
downtime
C?ID=280813
The radar is still the main detector for cars, the camera is just helping in it. So if there's no car image in front the radar has not detected it.
And the radar does not pick up cars that have stopped. The car in front needs to move so that the radar detects it. This is how the system has been designed to work.
cruster
C?ID=281059
Thanks - that would totally jibe with what's happening, it just seems like...it wasn't working that way before, but maybe it was. The system does seem to detect obstacles/stopped vehicles "some of the time", but maybe that's only when they come to a stop after they've been detected, and not when I come upon a stopped car coming around the corner. I've had the car going on 4 years...but I also know with the recent front assist errors I'm paying more attention.
Thanks for chiming in.
downtime
C?ID=280813
Can you get your car autoscanned with a newer HEX CAN v2 cable? It would show the extended info for the error. Might give some hints why the radar is disconnected. That disconnect message is a generic error and there are many reasons that cause it.
Is the radar behind VW bagde or on the lower part of the bumper? If it's behind VW badge check that the badge is clean. It is very sensitive to any dirt and seems to disconnect the radar even in heavy rain.
The additional info for that fault looks quite cryptic: FAULT_CIS_TSK_IRREV_FAIL
downtime
C?ID=280813
^ That error I’ve seen when the ACC view is obstructed. Means there’s dirt or something blocking ACC view.
