Results 1 to 5 of 5
Thread: ABS Unknown fault
    Verified VCDS User VASTech A.D.'s Avatar
    Oct 2018
    SJ, RO
    ABS Unknown fault
    Hello!
    Anyone have a clue what fault in ABS mean? Can`t find anywhere infos. Friend google say nothing...
    Code has been erased and after a while appears again.
    Any help appreciated. Thank`s!
    Thursday,23,January,2020,17:32:52:52276
    Dealer/Shop Name: VASTech Auto Diagnostics
    Workshop Code: 444 15839 000001
    VIN: VSSZZZ5PZ5R045274   License Plate: SJ-24-BGD
    Mileage: 286610km-178091mi   Repair Order:
    Chassis Type: 5P (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
    VIN: VSSZZZ5PZ5R045274   Mileage: 286610km-178091miles
    08-Auto HVAC -- Status: Malfunction 1010
    15-Airbags -- Status: Malfunction 1010
    Address 01: Engine        Labels: 03G-906-016-BKD.clb
       Part No SW: 03G 906 016 FH    HW: 028 101 190 9
       Component: R4 2,0L EDC G000SG  6185
       Revision: 12345678    Serial number: SEZ7Z0D2704408
       Coding: 0050072
       Shop #: WSC 06402 785 00200
       VCID: EE90B6E3F95BB13FC5-80BA
    16785 - EGR System
                P0401 - 000 - Insufficient Flow
                        RPM: 1596 /min
                        Torque: 32.0 Nm
                        Speed: 23.0 km/h
                        Load: 15.7 %
                        Duty Cycle: 14.7 %
                        Bin. Bits: 00001000
                        Mass Air / Rev.: 305.0 mg/str
                        Mass Air / Rev.: 570.0 mg/str
    18043 - Powertrain Data Bus
                P1635 - 000 - Missing Message from A/C Controller - Intermittent
                        Torque: 90.0 Nm
                        Voltage: 12.16 V
                        Bin. Bits: 00001100
                        Bin. Bits: 00000000
                        (no units): 144.0
    18044 - Powertrain Data Bus
                P1636 - 000 - Missing Message from Airbag Controller - Intermittent
                        Torque: 92.0 Nm
                        Voltage: 12.24 V
                        Bin. Bits: 00001100
                        Torque: 0.0 Nm
                        Torque: 160.0 Nm
    18049 - Please check DTC Memory of A/C Controller
                P1641 - 000 -  - Intermittent
                        Torque: 92.0 Nm
                        Voltage: 12.24 V
                        Bin. Bits: 00001100
                        Temperature: 17.1°C
                        (no units): 144.0
    Readiness: 1 1 0 0 0
       Part No: 1K0 907 379 K
       Component: ESP FRONT MK60      0104
       Coding: 0023282
       VCID: BA384AB3F5932D9F29-80EE
    57344 - Unknown Error Code
                Unknown - 015 -  - MIL ON
       Part No: 5P0 907 044 B
       Component: ClimatronicPQ35 005 0202
       VCID: AF2E6BE73ED1F8378E-80FA
    00576 - Terminal 15
       Part No SW: 1K0 937 049 T    HW: 1K0 937 049 T*
       Component: Bordnetz-SG 1.0 H30 0704
       Revision: 00030000    Serial number: 00000001132077
       Coding: 81880F2700041000001E00000000000000
       VCID: C0CC385B934F774F67-8094
       Subsystem 1 - Part No: 5P0 955 119 A  Labels: 1KX-955-119.CLB
       Component: Wischer SE359  012  0402
       Coding: 00056272
    10 Faults Found:
    01598 - Drive Battery Voltage
    01502 - Bulb for Rear Fog; Left (L46)
    01064 - Terminal 58d; Interior Dimming
    01505 - Bulb for Blinkers; Rear Right (M8)
    01501 - Bulb for Blinkers; Rear Left (M6)
       Part No SW: 1K0 909 605 H    HW: 1K0 909 605 H
       Component: S3 AIRBAG VW8   023 0700
       Revision: 06023000    Serial number: 00385D0MFJHG
       Coding: 0021299
       VCID: B12A6D9F28E5EEC798-80E4
       Subsystem 1 - Serial number: 6332MSME173E2905
       Subsystem 2 - Serial number: 6342MSME495E6404
       Subsystem 3 - Serial number: 6351HSME5B517504
       Subsystem 4 - Serial number: 6361HSME4A177004
    01217 - Side Airbag Igniter; Driver Side (N199)
                001 - Upper Limit Exceeded - Intermittent - MIL ON
       Part No SW: 1K0 953 549 B    HW: 1K0 953 549 B
       Component: Lenksäulenmodul 013 0010
       Coding: 0002042
       Component: Lenkradmodul    004 0060
       Part No: 5P0 920 822 E
       Component: KOMBIINSTRUMENT VO3 1056
       Coding: 0000101
       Shop #: WSC 09026 224 81184
       Part No SW: 1K0 907 530 C    HW: 1K0 907 951
       Component: Gateway         H08 0080
       Revision: 08          Serial number: 26001049010016
       Coding: 3D3F0340071202
       VCID: A71E83C71621A07746-80F2
    01304 - Radio
                        Reset counter: 41
                        Mileage: 280046 km
                        Time: 13:58:05
                        Reset counter: 81
                        Mileage: 280046 km
                        Time: 14:01:38
                        Reset counter: 81
                        Mileage: 285836 km
                        Time: 02:51:07
                        Reset counter: 81
                        Mileage: 286593 km
                        Time: 02:54:50
       Component: IMMO                1056
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX1.lbl
       Part No: 1T0 959 701 A
       Component: Tuersteuergeraet 09 0139
       Coding: 0000016
       VCID: B522598FDC8DC2E7C4-80E0
       Part No: 1K1 909 144 G
       Component: EPS_ZFLS Kl.13      1401
    Address 46: Central Conv.        Labels:. 1K0-959-433-MIN.clb
       Part No: 1K0 959 433 BL
       Component: 01 KSG              0301
       Coding: 99C000BC090005054C4F863000
       VCID: FBB68FB7BA29D49772-80AE
       Subsystem 3 - Component:      IRUE No Answer
    01134 - Alarm Horn (H12)
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX1.lbl
       Part No: 1T0 959 702 A
       Coding: 0000016
       VCID: B6205E83C18BC9FFCD-80E2
    Address 56: Radio
    Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN1.lbl
       Part No: 1K0 959 703 B
       Component: Tuersteuergeraet 06 0216
       Coding: 0000016
    Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN1.lbl
       Part No: 1K0 959 704 B
       Coding: 0000016
       VCID: B02C689B23EFE7CF97-80E4
    End----(Elapsed Time: 01:08, VBatt start/end: 13.6V/13.8V. VIgn 0.0V)------
    HQ
    Manufacturer Controlled DTC
    I am guessing here, so don't take this as hard fact just yet... but I suspect you have a failed ABS module. I'd verify the powers/grounds are good, no voltage drop issues. If voltage supply is good, replace ABS module. And with that, I strongly suggest you get 2nd and 3rd opinions on this.
    Jef
    Sep 2016
    Riga, Latvia
    Does this fault switches on ABS and/or ESP warning lamps, too?
    Oct 2018
    SJ, RO
    No, It`s not triggering any light in dash. I know on error log say it is MIL ON, but it`s not.
    16.4905° S, 151.7375° W
    Quote Originally Posted by VASTech A.D. View Post
    Hi, I agree with Jef, this sounds like an internal ABS Controller fault. The fault code is not on any list any where in any documentation for any Volkswagen product..
    If it was me, I would drive the vehicle to an area that I can test the functions of the ABS system and see if any more faults show up.
    Maybe unplug a wheel sensor to see if the ABS Controller can properly report the obvious fault of a disconnected sensor.
    If all looks good, maybe just keep an eye on it?
    Be safe, hope this helps,
    drpeter
