Results 1 to 10 of 17
Thread: 2011 POLO ABS CODING AFTER ECU KIT CHANGE
    Jun 2019
    I've recently had the ECU kit changed due to starting issues. The FULL kit has been installed and the car starts drives.
    The ABS, Traction and Tyre pressure lights, I understand the issue is due to the ABS module not being coded. I have issues with the EGR which I want to tackle afterwoods, my priority is the ABS module.
    Can someone help me with code for the ABS module?
    Thanks in advance.
    Thursday,23,January,2020,16:34:31:25558
    VCDS Version: 19.6.2.0 (x64)
    VIN: WVWZZZ6RZCY104372   License Plate: SILVER POLO 2011
    Mileage: 93450km-58067mi   Repair Order:
    Chassis Type: 6R-VW25 (6R0)
    Scan: 01 03 08 09 15 17 19 25 44 56 61
    VIN: WVWZZZ6RZCY104372   Mileage: 93450km-58067miles
    Address 01: Engine (J000-CFWA)       Labels:. 03P-906-021-CFW.clb
       Part No SW: 03P 906 021 C    HW: 03P 907 425
       Component: R3 1.2l TDI   H08 9978
       Revision: 12006001    Serial number:
       Coding: 00114014032501080000
       Shop #: WSC 27101 001 1048576
       ASAM Dataset: EV_ECM12TDI03103P906021C 001026
       ROD: EV_ECM12TDI03103P906021AA.rod
       VCID: 2859BE7F5390CD0FCF-807C
    16129 - Output for Starter Relay
              P0616 00 [191] - Short to Ground
              MIL ON - Confirmed - Not Tested Since Memory Clear
                        Fault Frequency: 29
                        Mileage: 93458 km
                        Date: 2020.01.07
                        Time: 22:29:25
                        Coolant temperature: 30 C
                        Intake air temperature: 10 C
                        Voltage terminal 30: 12.250 V
                        Unlearning counter according OBD: 0
                        Accelerator pedal travel-Position: 0.0 %
                        Starter control: Interlock- or P/N-signal: 00000000
                        Engine status: Engine stopped
                        Terminal 87 status: On
                        Sensor for engine block temperature: raw value: 30 C
                        Starter control: terminal 50: 00000000
                        Gear Ratio: 0
    15971 - Function Restriction due to Faults in Other Modules
              U1113 00 [047] - -
                        Fault Frequency: 58
                        Mileage: 93458 km
                        Date: 2020.01.07
                        Time: 22:29:25
                        OBD Driver demand indicated torque: 0 %
                        Mean injection quantity: 0.0 mg/stroke
                        Exh.gas temp.sen 1: 108 C
                        Outside air temperature: 11 C
                        Terminal 15 status: On
    15536 - EGR Sensor 1
              P0405 00 [191] - Signal too Low
                        Mileage: 93458 km
                        Date: 2020.01.07
                        Time: 22:29:25
                        EGR Vacuum Regulator Solen.val.: activation-PWM rate: 0.0 %
                        EGR Solen.val.: actual value-PWM rate: 54.9 %
                        EGR valve: offset closed: 10 %
                        High press EGR actuator: actual unconditioned volt val: 0.667 V
    13184 - Engine Speed Sensor (G28)
              P0322 00 [216] - No Signal
              MIL ON - Intermittent - Confirmed - Not Tested Since Memory Clear
                        Fault Frequency: 45
                        Mileage: 93458 km
                        Date: 2020.01.07
                        Time: 22:30:12
                        Coolant temperature: 29 C
                        Intake air temperature: 8 C
                        Voltage terminal 30: 10.656 V
                        Camshaft speed (RPM): 288 /min
                        P_L_Aps_camless_active: OFF
                        Engine start: start synchronization: 00
                        P_L_Aps_crankless_active: OFF
                        P_L_Aps_injection_speed-Engine_rotational_speed: 0 /min
                        P_L_Aps_no_sync_speed-Engine_rotational_speed: 0 /min
                        P_L_Aps_sync_cnt_total-Value: 2
                        P_L_Aps_sync_lost: OFF
                        P_L_Aps_sync_lost_origin-Sync_lost_status: P_L_APS_SYNC_LOST_CONF_CAM
                        P_L_Aps_sync_tasks_enabled: OFF
                        P_L_Aps_synchronised: On
                        P_L_Aps_synchronised_origin-Sync_origin: P_L_APS_SYNC_TCAM_TCAM
                        P_L_Aps_tdc_to_tooth_1_angle-Engine_timing_value: 353.991
                        P_L_Aps_timeout_detected: OFF
                        System status for the start/stop function master: 62
    16099 - Fuel Pressure Sensor (G247)
              P0191 00 [136] - Implausible Signal
                        Fault Frequency: 15
                        Mileage: 93459 km
                        Date: 2020.01.08
                        Time: 22:25:11
                        Coolant temperature: 11 C
                        Intake air temperature: 0 C
                        Voltage terminal 30: 10.312 V
                        Fuel pressure: 7700 kPa rel
                        Rail pressure regulation: status: RPC_TL_FILLING_RAIL
                        P_L_Rail_pres_sample_cnts-counts: 130.999 counts
                        Fuel tank fill level: 12.9 %
                        Fuel temperature: unconditioned voltage: 3.572 V
                        Valve for fuel metering: feedback value measured-Fuel pressure regulator valve actual value: 97.44 mA
                        Fuel pressure regulator valve actual value: 636.56 mA
                        Sensor for engine block temperature: raw value: 11 C
                        Cruise Control System (CCS): status: 00000100
                        OBD maximum indicated torque: 0 Nm
    Readiness: 1 3 0 0 1
    Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
       Part No SW: 6R0 907 379 BC    HW: 6R0 907 379 AF
       Component: ESP8.2i front H05 0002
       Revision: --------
       Shop #: WSC 00788 648 00255
       VCID: 0009C6DF9760D54FA7-8054
                        Reset counter: 244
                        Mileage: 93459 km
                        Date: 2014.06.14
                        Time: 20:07:01
                        Hex Value: 0x0002
                        Hex Value: 0x0002
                        Hex Value: 0x1213
                        Hex Value: 0x1484
                        Hex Value: 0x00FF
                        Hex Value: 0x7F82
                        Hex Value: 0x7FF8
                        Fault Status: 01100101
                        Fault Frequency: 55
                        Reset counter: 244
                        Mileage: 93458 km
                        Date: 2014.05.30
                        Time: 22:32:17
                        Hex Value: 0x0007
                        Hex Value: 0x0000
                        Hex Value: 0x1251
                        Hex Value: 0x1BBD
                        Hex Value: 0x00FF
                        Hex Value: 0x7F7F
                        Hex Value: 0x7F00
    00493 - ESP-Sensor Unit (G419)
                        Fault Frequency: 55
                        Reset counter: 244
                        Mileage: 93458 km
                        Date: 2014.05.30
                        Time: 22:32:17
                        Hex Value: 0x0007
                        Hex Value: 0x0000
                        Hex Value: 0x12E1
                        Hex Value: 0x20BD
                        Hex Value: 0x00FF
                        Hex Value: 0x7F7F
                        Hex Value: 0x7F00
    03306 - Coding Not Valid
                        Reset counter: 28
                        Mileage: 93459 km
                        Date: 2014.06.15
                        Time: 02:31:37
                        Hex Value: 0x0003
                        Hex Value: 0x0002
                        Hex Value: 0x32E7
                        Hex Value: 0x2596
                        Hex Value: 0x00FF
                        Hex Value: 0x7F82
                        Hex Value: 0x82F8
    Address 08: Auto HVAC (J301)       Labels: 6R0-820-045-9AB.clb
       Part No SW: 6R0 820 045 N    HW: 6R0 820 045 N
       Component: Man AC        H02 0202
       Revision: 0003SH02
       VCID: 397F6B3BB03A4487A0-806C
                        Reset counter: 29
                        Mileage: 93459 km
                        Date: 2014.06.06
                        Time: 03:11:39
       Part No SW: 6R0 937 088 F    HW: 6R0 937 088
       Component: BCM PQ25 Re4  H50 0351
       Revision: BU050001    Serial number: 0456 260110745
       Coding: 24B029BF08A10000002009B02C2B0CD05F80612F7E860441A00000000000
       Shop #: WSC 124697 483 00190
       VCID: 418F03DBD8EA1C47E8-8014
       Subsystem 1 - Part No SW: 6R0 959 802 AB    HW: 6R0 959 802 AB  Labels: 6R0-959-802.CLB
       Component: J386__TSG_FT  008 1611
       Serial number: KU0KU009111100011886
       Coding: 58BC30
       Subsystem 2 - Part No SW: 6R0 959 801 AD    HW: 6R0 959 801 AD  Labels: 6R0-959-801.CLB
       Component: J387__TSG_BT  008 1611
       Serial number: KU0KU021101100013695
       Coding: 48BC30
       Part No SW: 6R0 959 655 K    HW: 6R0 959 655 K
       Component: VW10Airbag027 H09 0020
       Revision: --------    Serial number: 003GX01011W1
       Coding: 003237
       ROD: EV_AirbaVW10BPAVW250.rod
       VCID: 4A9D24F7EDDCDF1F39-801E
       Serial number: 3575HRB40630U2UQG1BW
       Serial number: 3585HRB40650U2UQCG4$
       Serial number: 3515RRB405T0TO4MFPL%
       Serial number: 3525RRB405B0TQMALPCU
       Part No SW: 6R0 920 961 H    HW: 6R0 920 961 H
       Component: KOMBI         H03 0505
       Coding: 440A01
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
       ROD: EV_Kombi_UDS_VDD_RM09_004_VW23.rod
       VCID: 3B737133B2067697B2-806E
    Address 19: CAN Gateway (J533)       Labels:. 6R0-907-530-V2.clb
       Part No SW: 6R0 907 530 D    HW: 1K0 907 951
       Component: J533  Gateway H38 0035
       Revision:   H38       Serial number: 061111F1000575
       Coding: 2500C3
       VCID: 34615A0F9758B9EF73-8060
       Component: IMMO          H03 0505
       VCID: 6ADD84778D1C3F1F19-803E
       Part No: 6R0 423 156 B
       Component: LenkhilfeTRW        V277
       Coding: 11230
       Shop #: WSC 00788
       VCID: 2F6B5563EA7E9A370E-807A
       Part No SW: 5M0 035 186 J    HW: 5M0 035 186 J
       Component: Radio RCD310  042 0082
       Revision: 01000001    Serial number: VWZ1Z2L3594700
       Coding: 05000400020001
       VCID: 336359139256BED76A-8066
       Part No SW: 6R0 907 534     HW: 1K0 907 951
       Component: Batt.regelung H38 0035
       Coding: 030B1A59
       VCID: 74E19A0FD7D8F9EFB3-8020
       Subsystem 1 - Part No SW: 6R0 915 181 D    HW: 6R0 915 181
       Component: J367-BDM  H07 0180
       Serial number: 00000000008900217536
    End-------------------------(Elapsed Time: 02:42)--------------------------
    Do you not have a scan from prior to changing the "full kit" (whatever that is)?
    Hint: Look in your Scans sub-folder.
    Aug 2016
    The Hague, NL
    My first guess: 230224E3416D00B6C42824E982D300891700
  5. Likes Jack@European_Parts, Uwe liked this post
  6. #4
    Aug 2016
    The Hague, NL
    I think he has a new ECU, tacho, keys and locks.
  7. Likes Jack@European_Parts liked this post
  8. #5
    Jun 2019
    iichel you're correct, I had the ECU, Locks, BCM swapped from a donor car to resolve the starting issue.
    I tried your code however it failed to accept it with the following message: Coding rejected Error: Conditions not correct or request sequence error.
    Unfortunately I didn't take a scan before the changes however the technician who did says the original coding is: 230224E3417200B4C42A24EB82D800921300 This code also fails with the above message, I assume I simply open the ABS module, apply the security code and then apply the code into the long field and press 'do it'?
    are these codes tied to the VIN number? as the ECU has the VIN from the donor car?
    thanks in advance
  9. #6
    Jan 2018
    Cheshire UK
    Probably due to a mismatch of VIN' no's in the modules. You would need to go online and recode the modules with the correct VIn so they are all the same.
    A6 BiTdi Avant MTM
    Retrofitted: Full Led Headlights, DAB, Full Electric Seats, Power Tailgate, Surround View Cameras, Genuine RS6 Grille, RS6 Seats,Leather Door Armrests, Soft Close Doors, Rear Side Blinds, Electric Steering Column, LED Sill Plates, Ambient Lighting Pack, High Beam Assist, Eibach Springs, Led Roof Console, 4 Zone Climate, Rear Heated Seats, Head Up Display, Side assist, Alcantara Interior Retrim
  11. #7
    Aug 2016
    The Hague, NL
    Your old, mechanical, VIN ends in 52597, correct?
    230224E3416D00B6C42824E982D300921300 no XDS
    230224E3416D00B6C42824E982D300921700 with XDS
    Give these a try please
  12. Likes Uwe, Boki Ar liked this post
  13. #8
    Jun 2019
    Thanks iichel, both codes have been accepted, how do I know if my car has XDS?
  14. #9
    Jun 2019
    Hi, I'm wanting to carry out the angle sensor adaptation to remove the traction control light however when I go into to steering angle module the security access - 16 option is greyed out. When entering the adaptation option there are no values, going from 0-99 all display ERROR channel not available.
    Thanks in advance
  15. #10
    Aug 2016
    The Hague, NL
    I think you need to adjust the steering angle sensor in the ABS module. 40168 is the security acces in that module.
    Every car with ESP has XDS. It's solely a software feature. I guess I just gave it to you for free
  16. Likes Uwe, Fredrick Awuor liked this post
