Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: 2011 POLO ABS CODING AFTER ECU KIT CHANGE
    Jun 2019
    Thanks iichel, running through the basic settings for G85 sensor has removed the traction control light also. Thanks for all the guidance.
  2. Likes Uwe liked this post
  3. #12
    Jun 2019
    thanks for the information, i've made the adjustment in the ABS module and the traction control light has also disappeared.
    I do still however get the message START/STOP ERROR flash up when I come to a stop
  4. #13
    Quote Originally Posted by VAGMAN View Post
    I think we might need to see an Auto-Scan with the car as it is now to try and get more information about the START/STOP ERROR cause(s).
  5. #14
    Jun 2019
    here is the most recent full scan
    Tuesday,04,February,2020,14:22:12:25558
    VCDS Version: 19.6.2.0 (x64)
    VIN: WVWZZZ6RZCY104372   License Plate:
    Mileage: 93530km-58116mi   Repair Order:
    Chassis Type: 6R-VW25 (6R0)
    Scan: 01 03 08 09 15 17 19 25 44 56 61
    VIN: WVWZZZ6RZCY104372   Mileage: 93530km-58116miles
    Address 01: Engine (J000-CFWA)       Labels:. 03P-906-021-CFW.clb
       Part No SW: 03P 906 021 C    HW: 03P 907 425
       Component: R3 1.2l TDI   H08 9978
       Revision: 12006001    Serial number:
       Coding: 00114014032501080000
       Shop #: WSC 27101 001 1048576
       ASAM Dataset: EV_ECM12TDI03103P906021C 001026
       ROD: EV_ECM12TDI03103P906021AA.rod
       VCID: 2859BE7F5390CD0FCF-807C
    16129 - Output for Starter Relay
              P0616 00 [249] - Short to Ground
              MIL ON - Confirmed - Not Tested Since Memory Clear
                        Mileage: 93530 km
                        Date: 2020.02.04
                        Time: 00:39:36
                        Coolant temperature: 7 C
                        Intake air temperature: 7 C
                        Voltage terminal 30: 11.726 V
                        Unlearning counter according OBD: 0
                        Accelerator pedal travel-Position: 0.0 %
                        Starter control: Interlock- or P/N-signal: 00000000
                        Engine status: Engine stopped
                        Terminal 87 status: On
                        Sensor for engine block temperature: raw value: 7 C
                        Starter control: terminal 50: 00000000
                        Gear Ratio: 0
    13184 - Engine Speed Sensor (G28)
              P0322 00 [120] - No Signal
                        Mileage: 93530 km
                        Date: 2020.02.04
                        Time: 00:44:19
                        Intake air temperature: 14 C
                        Voltage terminal 30: 10.539 V
                        Camshaft speed (RPM): 192 /min
                        P_L_Aps_camless_active: OFF
                        Engine start: start synchronization: 00
                        P_L_Aps_crankless_active: OFF
                        P_L_Aps_injection_speed-Engine_rotational_speed: 0 /min
                        P_L_Aps_no_sync_speed-Engine_rotational_speed: 0 /min
                        P_L_Aps_sync_cnt_total-Value: 1
                        P_L_Aps_sync_lost: On
                        P_L_Aps_sync_lost_origin-Sync_lost_status: P_L_APS_SYNC_LOST_CONF_CAM
                        P_L_Aps_sync_tasks_enabled: OFF
                        P_L_Aps_synchronised: On
                        P_L_Aps_synchronised_origin-Sync_origin: P_L_APS_SYNC_TCAM_TCAM
                        P_L_Aps_tdc_to_tooth_1_angle-Engine_timing_value: 353.991
                        P_L_Aps_timeout_detected: OFF
                        System status for the start/stop function master: 62
    15536 - EGR Sensor 1
              P0405 00 [046] - Signal too Low
                        Fault Frequency: 114
                        Mileage: 93530 km
                        Date: 2020.02.04
                        Time: 00:44:24
                        Engine speed: 1020.50 /min
                        Normed load value: 31.8 %
                        Intake air temperature: 21 C
                        Voltage terminal 30: 11.304 V
                        EGR Vacuum Regulator Solen.val.: activation-PWM rate: 0.0 %
                        EGR Solen.val.: actual value-PWM rate: 50.2 %
                        EGR valve: offset closed: 10 %
                        High press EGR actuator: actual unconditioned volt val: 0.687 V
    Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
       Part No SW: 6R0 907 379 BC    HW: 6R0 907 379 AF
       Component: ESP8.2i front H05 0002
       Revision: --------
       Coding: 230224E3416D00B6C42824E982D300921700
       Shop #: WSC 00788 648 00255
       VCID: 0009C6DF9760D54FA7-8054
                        Fault Status: 00100101
                        Reset counter: 28
                        Mileage: 93465 km
                        Date: 2014.06.21
                        Time: 02:35:12
                        Hex Value: 0x4007
                        Hex Value: 0x0002
                        Hex Value: 0x32E1
                        Hex Value: 0x20BB
                        Hex Value: 0x00FF
                        Hex Value: 0x7F7F
                        Hex Value: 0x7F00
    Address 08: Auto HVAC (J301)       Labels: 6R0-820-045-9AB.clb
       Part No SW: 6R0 820 045 N    HW: 6R0 820 045 N
       Component: Man AC        H02 0202
       Revision: 0003SH02
       VCID: 397F6B3BB03A4487A0-806C
       Part No SW: 6R0 937 088 F    HW: 6R0 937 088
       Component: BCM PQ25 Re4  H50 0351
       Revision: BU050001    Serial number: 0456 260110745
       Coding: 24B029BF08A10000002009B02C2B0CD05F80612F7E860441A00000000000
       Shop #: WSC 124697 483 00190
       VCID: 418F03DBD8EA1C47E8-8014
       Subsystem 1 - Part No SW: 6R0 959 802 AB    HW: 6R0 959 802 AB  Labels: 6R0-959-802.CLB
       Component: J386__TSG_FT  008 1611
       Serial number: KU0KU009111100011886
       Coding: 58BC30
       Subsystem 2 - Part No SW: 6R0 959 801 AD    HW: 6R0 959 801 AD  Labels: 6R0-959-801.CLB
       Component: J387__TSG_BT  008 1611
       Serial number: KU0KU021101100013695
       Coding: 48BC30
       Part No SW: 6R0 959 655 K    HW: 6R0 959 655 K
       Component: VW10Airbag027 H09 0020
       Revision: --------    Serial number: 003GX01011W1
       Coding: 003237
       ROD: EV_AirbaVW10BPAVW250.rod
       VCID: 4A9D24F7EDDCDF1F39-801E
       Serial number: 3575HRB40630U2UQG1BW
       Serial number: 3585HRB40650U2UQCG4$
       Serial number: 3515RRB405T0TO4MFPL%
       Serial number: 3525RRB405B0TQMALPCU
       Part No SW: 6R0 920 961 H    HW: 6R0 920 961 H
       Component: KOMBI         H03 0505
       Coding: 440A01
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
       ROD: EV_Kombi_UDS_VDD_RM09_004_VW23.rod
       VCID: 3B737133B2067697B2-806E
    Address 19: CAN Gateway (J533)       Labels:. 6R0-907-530-V2.clb
       Part No SW: 6R0 907 530 D    HW: 1K0 907 951
       Component: J533  Gateway H38 0035
       Revision:   H38       Serial number: 061111F1000575
       Coding: 2500C3
       VCID: 34615A0F9758B9EF73-8060
       Component: IMMO          H03 0505
       VCID: 6ADD84778D1C3F1F19-803E
       Part No: 6R0 423 156 B
       Coding: 11230
       Shop #: WSC 00788
       VCID: 2F6B5563EA7E9A370E-807A
       Part No SW: 5M0 035 186 J    HW: 5M0 035 186 J
       Component: Radio RCD310  042 0082
       Revision: 01000001    Serial number: VWZ1Z2L3594700
       Coding: 05000400020001
       VCID: 336359139256BED76A-8066
       Part No SW: 6R0 907 534     HW: 1K0 907 951
       Component: Batt.regelung H38 0035
       Coding: 030B1A59
       VCID: 74E19A0FD7D8F9EFB3-8020
       Subsystem 1 - Part No SW: 6R0 915 181 D    HW: 6R0 915 181
       Component: J367-BDM  H07 0180
       Serial number: 00000000008900217536
    End-------------------------(Elapsed Time: 02:05)--------------------------
  6. #15
    Jun 2019
    the glowplug light is also flashing, is this related to the EGR message?
  7. #16
    Aug 2016
    Eindhoven, NB, NL
    Very likely, yes
  8. #17
    Hmm... "Output for Starter Relay - Short to Ground" explicitly has, "MIL ON"
