2011 POLO ABS CODING AFTER ECU KIT CHANGE
VAGMAN
C?ID=374246
I've recently had the ECU kit changed due to starting issues. The FULL kit has been installed and the car starts drives.
The ABS, Traction and Tyre pressure lights, I understand the issue is due to the ABS module not being coded. I have issues with the EGR which I want to tackle afterwoods, my priority is the ABS module.
Can someone help me with code for the ABS module?
Thanks in advance.
Thursday,23,January,2020,16:34:31:25558
VCDS Version: 19.6.2.0 (x64)
VIN: WVWZZZ6RZCY104372   License Plate: SILVER POLO 2011
Mileage: 93450km-58067mi   Repair Order:
Chassis Type: 6R-VW25 (6R0)
Scan: 01 03 08 09 15 17 19 25 44 56 61
VIN: WVWZZZ6RZCY104372   Mileage: 93450km-58067miles
Address 01: Engine (J000-CFWA)       Labels:. 03P-906-021-CFW.clb
   Part No SW: 03P 906 021 C    HW: 03P 907 425
   Component: R3 1.2l TDI   H08 9978
   Revision: 12006001    Serial number:
   Coding: 00114014032501080000
   Shop #: WSC 27101 001 1048576
   ASAM Dataset: EV_ECM12TDI03103P906021C 001026
   ROD: EV_ECM12TDI03103P906021AA.rod
   VCID: 2859BE7F5390CD0FCF-807C
16129 - Output for Starter Relay
          P0616 00 [191] - Short to Ground
          MIL ON - Confirmed - Not Tested Since Memory Clear
                    Fault Frequency: 29
                    Mileage: 93458 km
                    Date: 2020.01.07
                    Time: 22:29:25
                    Coolant temperature: 30 °C
                    Intake air temperature: 10 °C
                    Voltage terminal 30: 12.250 V
                    Unlearning counter according OBD: 0
                    Accelerator pedal travel-Position: 0.0 %
                    Starter control: Interlock- or P/N-signal: 00000000
                    Engine status: Engine stopped
                    Terminal 87 status: On
                    Sensor for engine block temperature: raw value: 30 °C
                    Starter control: terminal 50: 00000000
                    Gear Ratio: 0
15971 - Function Restriction due to Faults in Other Modules
          U1113 00 [047] - -
                    Fault Frequency: 58
                    Mileage: 93458 km
                    Date: 2020.01.07
                    Time: 22:29:25
                    OBD Driver demand indicated torque: 0 %
                    Mean injection quantity: 0.0 mg/stroke
                    Exh.gas temp.sen 1: 108 °C
                    Outside air temperature: 11 °C
                    Terminal 15 status: On
15536 - EGR Sensor 1
          P0405 00 [191] - Signal too Low
                    Mileage: 93458 km
                    Date: 2020.01.07
                    Time: 22:29:25
                    EGR Vacuum Regulator Solen.val.: activation-PWM rate: 0.0 %
                    EGR Solen.val.: actual value-PWM rate: 54.9 %
                    EGR valve: offset closed: 10 %
                    High press EGR actuator: actual unconditioned volt val: 0.667 V
13184 - Engine Speed Sensor (G28)
          P0322 00 [216] - No Signal
          MIL ON - Intermittent - Confirmed - Not Tested Since Memory Clear
                    Fault Frequency: 45
                    Mileage: 93458 km
                    Date: 2020.01.07
                    Time: 22:30:12
                    Coolant temperature: 29 °C
                    Intake air temperature: 8 °C
                    Voltage terminal 30: 10.656 V
                    Camshaft speed (RPM): 288 /min
                    P_L_Aps_camless_active: OFF
                    Engine start: start synchronization: 00
                    P_L_Aps_crankless_active: OFF
                    P_L_Aps_injection_speed-Engine_rotational_speed: 0 /min
                    P_L_Aps_no_sync_speed-Engine_rotational_speed: 0 /min
                    P_L_Aps_sync_cnt_total-Value: 2
                    P_L_Aps_sync_lost: OFF
                    P_L_Aps_sync_lost_origin-Sync_lost_status: P_L_APS_SYNC_LOST_CONF_CAM
                    P_L_Aps_sync_tasks_enabled: OFF
                    P_L_Aps_synchronised: On
                    P_L_Aps_synchronised_origin-Sync_origin: P_L_APS_SYNC_TCAM_TCAM
                    P_L_Aps_tdc_to_tooth_1_angle-Engine_timing_value: 353.991 °
                    P_L_Aps_timeout_detected: OFF
                    System status for the start/stop function master: 62
16099 - Fuel Pressure Sensor (G247)
          P0191 00 [136] - Implausible Signal
                    Fault Frequency: 15
                    Mileage: 93459 km
                    Date: 2020.01.08
                    Time: 22:25:11
                    Coolant temperature: 11 °C
                    Intake air temperature: 0 °C
                    Voltage terminal 30: 10.312 V
                    Fuel pressure: 7700 kPa rel
                    Rail pressure regulation: status: RPC_TL_FILLING_RAIL
                    P_L_Rail_pres_sample_cnts-counts: 130.999 counts
                    Fuel tank fill level: 12.9 %
                    Fuel temperature: unconditioned voltage: 3.572 V
                    Valve for fuel metering: feedback value measured-Fuel pressure regulator valve actual value: 97.44 mA
                    Fuel pressure regulator valve actual value: 636.56 mA
                    Sensor for engine block temperature: raw value: 11 °C
                    Cruise Control System (CCS): status: 00000100
                    OBD maximum indicated torque: 0 Nm
Readiness: 1 3 0 0 1
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 BC    HW: 6R0 907 379 AF
   Component: ESP8.2i front H05 0002
   Revision: --------
   Shop #: WSC 00788 648 00255
   VCID: 0009C6DF9760D54FA7-8054
                    Fault Frequency: 8
                    Reset counter: 244
                    Mileage: 93459 km
                    Date: 2014.06.14
                    Time: 20:07:01
                    Hex Value: 0x0002
                    Hex Value: 0x0002
                    Hex Value: 0x1213
                    Hex Value: 0x1484
                    Hex Value: 0x00FF
                    Hex Value: 0x7F82
                    Hex Value: 0x7FF8
                    Fault Status: 01100101
                    Fault Frequency: 55
                    Reset counter: 244
                    Mileage: 93458 km
                    Date: 2014.05.30
                    Time: 22:32:17
                    Hex Value: 0x0007
                    Hex Value: 0x0000
                    Hex Value: 0x1251
                    Hex Value: 0x1BBD
                    Hex Value: 0x00FF
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
                    Fault Frequency: 55
                    Reset counter: 244
                    Mileage: 93458 km
                    Date: 2014.05.30
                    Time: 22:32:17
                    Hex Value: 0x0007
                    Hex Value: 0x0000
                    Hex Value: 0x12E1
                    Hex Value: 0x20BD
                    Hex Value: 0x00FF
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
03306 - Coding Not Valid
                    Reset counter: 28
                    Mileage: 93459 km
                    Date: 2014.06.15
                    Time: 02:31:37
                    Hex Value: 0x0003
                    Hex Value: 0x0002
                    Hex Value: 0x32E7
                    Hex Value: 0x2596
                    Hex Value: 0x00FF
                    Hex Value: 0x7F82
                    Hex Value: 0x82F8
Address 08: Auto HVAC (J301)       Labels: 6R0-820-045-9AB.clb
   Part No SW: 6R0 820 045 N    HW: 6R0 820 045 N
   Component: Man AC        H02 0202
   Revision: 0003SH02
   VCID: 397F6B3BB03A4487A0-806C
                    Reset counter: 29
                    Mileage: 93459 km
                    Date: 2014.06.06
                    Time: 03:11:39
   Part No SW: 6R0 937 088 F    HW: 6R0 937 088
   Component: BCM PQ25 Re4  H50 0351
   Revision: BU050001    Serial number: 0456 260110745
   Coding: 24B029BF08A10000002009B02C2B0CD05F80612F7E860441A00000000000
   Shop #: WSC 124697 483 00190
   VCID: 418F03DBD8EA1C47E8-8014
   Subsystem 1 - Part No SW: 6R0 959 802 AB    HW: 6R0 959 802 AB  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  008 1611
   Serial number: KU0KU009111100011886
   Coding: 58BC30
   Subsystem 2 - Part No SW: 6R0 959 801 AD    HW: 6R0 959 801 AD  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  008 1611
   Serial number: KU0KU021101100013695
   Coding: 48BC30
   Part No SW: 6R0 959 655 K    HW: 6R0 959 655 K
   Component: VW10Airbag027 H09 0020
   Revision: --------    Serial number: 003GX01011W1
   Coding: 003237
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4A9D24F7EDDCDF1F39-801E
   Serial number: 3575HRB40630U2UQG1BW
   Serial number: 3585HRB40650U2UQCG4$
   Serial number: 3515RRB405T0TO4MFPL%
   Serial number: 3525RRB405B0TQMALPCU
   Part No SW: 6R0 920 961 H    HW: 6R0 920 961 H
   Component: KOMBI         H03 0505
   Coding: 440A01
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
   ROD: EV_Kombi_UDS_VDD_RM09_004_VW23.rod
   VCID: 3B737133B2067697B2-806E
Address 19: CAN Gateway (J533)       Labels:. 6R0-907-530-V2.clb
   Part No SW: 6R0 907 530 D    HW: 1K0 907 951
   Component: J533  Gateway H38 0035
   Revision:   H38       Serial number: 061111F1000575
   Coding: 2500C3
   VCID: 34615A0F9758B9EF73-8060
   Component: IMMO          H03 0505
   VCID: 6ADD84778D1C3F1F19-803E
   Part No: 6R0 423 156 B
   Coding: 11230
   Shop #: WSC 00788
   VCID: 2F6B5563EA7E9A370E-807A
   Part No SW: 5M0 035 186 J    HW: 5M0 035 186 J
   Component: Radio RCD310  042 0082
   Revision: 01000001    Serial number: VWZ1Z2L3594700
   Coding: 05000400020001
   VCID: 336359139256BED76A-8066
   Part No SW: 6R0 907 534     HW: 1K0 907 951
   Component: Batt.regelung H38 0035
   Coding: 030B1A59
   VCID: 74E19A0FD7D8F9EFB3-8020
   Subsystem 1 - Part No SW: 6R0 915 181 D    HW: 6R0 915 181
   Component: J367-BDM  H07 0180
   Serial number: 00000000008900217536
End-------------------------(Elapsed Time: 02:42)--------------------------
Do you not have a scan from prior to changing the "full kit" (whatever that is)?
Hint: Look in your Scans sub-folder.
VAGMAN
C?ID=374246
iichel you're correct, I had the ECU, Locks, BCM swapped from a donor car to resolve the starting issue.
I tried your code however it failed to accept it with the following message: Coding rejected Error: Conditions not correct or request sequence error.
Unfortunately I didn't take a scan before the changes however the technician who did says the original coding is: 230224E3417200B4C42A24EB82D800921300 This code also fails with the above message, I assume I simply open the ABS module, apply the security code and then apply the code into the long field and press 'do it'?
are these codes tied to the VIN number? as the ECU has the VIN from the donor car?
thanks in advance
Morski
Cheshire UK
C?ID=90186
Probably due to a mismatch of VIN' no's in the modules. You would need to go online and recode the modules with the correct VIn so they are all the same.
iichel
Netherlands, eastern part
C?ID=284912
Your old, mechanical, VIN ends in 52597, correct?
230224E3416D00B6C42824E982D300921300 no XDS
230224E3416D00B6C42824E982D300921700 with XDS
Give these a try please
VAGMAN
C?ID=374246
Thanks iichel, both codes have been accepted, how do I know if my car has XDS?
VAGMAN
C?ID=374246
Hi, I'm wanting to carry out the angle sensor adaptation to remove the traction control light however when I go into to steering angle module the security access - 16 option is greyed out. When entering the adaptation option there are no values, going from 0-99 all display ERROR channel not available.
Thanks in advance
iichel
C?ID=284912
I think you need to adjust the steering angle sensor in the ABS module. 40168 is the security acces in that module.
Every car with ESP has XDS. It's solely a software feature. I guess I just gave it to you for free :)
VAGMAN
C?ID=374246
Thanks iichel, running through the basic settings for G85 sensor has removed the traction control light also. Thanks for all the guidance.
VAGMAN
C?ID=374246
thanks for the information, i've made the adjustment in the ABS module and the traction control light has also disappeared.
I do still however get the message START/STOP ERROR flash up when I come to a stop
I think we might need to see an Auto-Scan with the car as it is now to try and get more information about the START/STOP ERROR cause(s).
VAGMAN
C?ID=374246
here is the most recent full scan
Tuesday,04,February,2020,14:22:12:25558
Mileage: 93530km-58116mi   Repair Order:
VIN: WVWZZZ6RZCY104372   Mileage: 93530km-58116miles
          P0616 00 [249] - Short to Ground
                    Mileage: 93530 km
                    Date: 2020.02.04
                    Time: 00:39:36
                    Coolant temperature: 7 °C
                    Intake air temperature: 7 °C
                    Voltage terminal 30: 11.726 V
                    Sensor for engine block temperature: raw value: 7 °C
                    Gear Ratio: 0
          P0322 00 [120] - No Signal
                    Mileage: 93530 km
                    Date: 2020.02.04
                    Time: 00:44:19
                    Intake air temperature: 14 °C
                    Voltage terminal 30: 10.539 V
                    Camshaft speed (RPM): 192 /min
                    P_L_Aps_sync_cnt_total-Value: 1
                    P_L_Aps_sync_lost: On
          P0405 00 [046] - Signal too Low
                    Fault Frequency: 114
                    Mileage: 93530 km
                    Date: 2020.02.04
                    Time: 00:44:24
                    Engine speed: 1020.50 /min
                    Normed load value: 31.8 %
                    Intake air temperature: 21 °C
                    Voltage terminal 30: 11.304 V
                    EGR Solen.val.: actual value-PWM rate: 50.2 %
                    High press EGR actuator: actual unconditioned volt val: 0.687 V
   Revision: --------
   Coding: 230224E3416D00B6C42824E982D300921700
                    Fault Status: 00100101
                    Reset counter: 28
                    Mileage: 93465 km
                    Date: 2014.06.21
                    Time: 02:35:12
                    Hex Value: 0x4007
                    Hex Value: 0x0002
                    Hex Value: 0x32E1
                    Hex Value: 0x20BB
                    Hex Value: 0x00FF
                    Hex Value: 0x7F7F
                    Hex Value: 0x7F00
   Revision: 0003SH02
   Coding: 58BC30
   Coding: 48BC30
   Coding: 003237
   Coding: 440A01
   Coding: 2500C3
   Coding: 11230
   Shop #: WSC 00788
   Coding: 030B1A59
End-------------------------(Elapsed Time: 02:05)--------------------------
VAGMAN
C?ID=374246
the glowplug light is also flashing, is this related to the EGR message?
Hmm... "Output for Starter Relay - Short to Ground" explicitly has, "MIL ON"
