Results 1 to 4 of 4
Thread: 2008 audi TT Traction stuck in the off
    Jan 2020
    I was screwing around with my part car, ended up switching clusters
    and car would start ad shut off. switched back to original cluster everything fine,
    except for 2 codes.
    Tuesday,14,January,2020,18:11:21:03179
    VIN: TRUBF38J281047838   License Plate:
    Chassis Type: 8J (1K0)
    Scan: 01 02 03 08 09 0F 15 16 17 19 25 37 42 44 46 47 52 56 65 77
    VIN: TRUBF38J281047838   Mileage: 266700km-165719miles
    52-Door Elect, Pass. -- Status: Sporadic communication error 1000
       Part No SW: 8J0 907 115 B    HW: 8J0 907 115
       Revision: 5BH16---    Serial number: AUX7Z0H3FNB0NB
       Coding: 0113010A1C070160
       Shop #: WSC 01236 785 00200
       VCID: 2B1627F78A095B1722-807E
       Part No SW: 02E 300 050 J    HW: 02E 927 770 AD
       Component: GSG DSG         082 1406
       Revision: 05308020    Serial number: 00001102051825
       Shop #: WSC 04940 001 00001
       VCID: 197AED3FD095D98740-804C
    Address 03: ABS Brakes        Labels: 8J0-614-517.clb
       Part No SW: 8J0 614 517     HW: 8J0 614 517
       Component: ESP MK60E1          0130
       Revision: 00H52001
       Coding: 0017424
       VCID: 6A98E2F34573821F19-803E
                        Fault Status: 01100101
                        Reset counter: 3
                        Mileage: 266709 km
                        Date: 2020.01.14
                        Time: 21:06:31
                        Count: 128
                        Count: 12545
                        Count: 279
                        Count: 50944
                        Reset counter: 3
                        Mileage: 266709 km
                        Date: 2020.01.14
                        Time: 21:06:31
                        Count: 128
                        Count: 12545
                        Count: 270
                        Count: 50944
       Part No SW: 8J0 820 043 AJ    HW: 8J0 820 043 AJ
       Component: J255  Klima 1 Zone  0080
       Revision: 00H07004    Serial number: 00000001085020
       Coding: 1572900
       VCID: 6E90EEE3799B6E3F45-803A
    Address 09: Cent. Elect.        Labels:. 8P0-907-279-30-H.lbl
       Part No SW: 8P0 907 279 K    HW: 8P0 907 279 K
       Component: Bordnetz-SG     H54 2501
       Revision: 00H54000    Serial number: 00000008333598
       Coding: E1041E82C0141C004F1800001800000000285E075C210802000000000000
       VCID: 45C2714F0CAD8D67D4-8010
       Subsystem 1 - Part No: 8J1 955 119 A  Labels: 1KX-955-119.CLB
       Component: Wischer AU354   H07 0070
       Coding: 00064784
       Shop #: WSC 01236
       Coding: 00149804
       Shop #: WSC 01236
       Part No SW: 8E0 035 593 N    HW: 8E0 035 593 N
       Component: SDAR SIRIUS     H08 0150
       Revision: 00000000    Serial number: AUZ4Z7H0355084
       Coding: 0000000
       VCID: 34243C8B573704EF73-8060
                        Reset counter: 3
                        Mileage: 266709 km
                        Date: 2020.01.14
                        Time: 21:05:08
    Address 15: Airbags        Labels: 8J0-959-655.lbl
       Part No SW: 8J0 959 655     HW: 8J0 959 655
       Component: -E Airbag 9.43  H02 0020
       Revision: 93H02002    Serial number: 0036K002LP1Z
       Coding: 0011589
       VCID: 79BACDBF30D53987E0-802C
       Subsystem 1 - Part No: 8J0 910 339 A
       Component: BF-Gewichtsens. H02 0030
       Subsystem 2 - Serial number: 0237X
       Subsystem 3 - Serial number: 0001.01.0000H020000000000063
       Subsystem 4 - Serial number: 0000006332DRB4072045A9K63
       Subsystem 5 - Serial number: 045A9K6342DRB407210E10963
       Subsystem 6 - Serial number: 10E10963747RB40369C242L63
       Subsystem 7 - Serial number: 9C242L63847RB403698214H
       Subsystem 8 - Serial number: 98214H
    Address 16: Steering wheel        Labels: 8P0-953-549-F.lbl
       Part No SW: 8P0 953 549 F    HW: 8P0 953 549 F
       Component: J0527           H36 0070
       Coding: 0014141
       VCID: 41CA655F1885A147E8-8014
       Component: E0221           H06 0030
    Address 17: Instruments        Labels: 8J0-920-xxx-17-MY8.clb
       Part No SW: 8J0 920 990 E    HW: 8J0 920 990 E
       Component: KOMBIINSTR. VDO H23 0150
       Revision: D0H23003    Serial number: 2243H003102924
       Coding: 0016288
       Part No SW: 1K0 907 530 P    HW: 1K0 907 951
       Component: J533__Gateway   H16 0192
       Revision:   H16       Serial number: 2500K083278118
       Coding: ED801F075007024100
       Shop #: WSC 05111 444 52605
                        Reset counter: 29
                        Mileage: 266586 km
                        Date: 2019.12.26
                        Time: 04:13:25
                        Reset counter: 35
                        Time Indication: 15
       Revision: D0H23003    Serial number: AUX7Z0H3FNB0NB
    Address 37: Navigation        Labels: 8E0-035-192-RNSE.clb
       Part No SW: 8J0 035 192 P    HW: 8J0 035 192 P
       Component: RNS-E US        H14 0250
       Revision:      04S    Serial number: AUZBZ7H4501044
       Coding: 0610657
       VCID: 36200683414B16FF4D-8062
    Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN3.lbl
       Part No SW: 8J8 959 801 E    HW: 8J8 959 801 E
       Component: Tuer-SG         H02 0060
       Coding: 0001077
       VCID: 3FCE63A76E71D7B79E-806A
       Part No: 8J1 909 143 C
       Component: EPS_ZFLS Kl.157 H08 1903
       VCID: 302C309BA32F38CF17-8064
    Address 46: Central Conv.        Labels:. 8J0-959-433.lbl
       Part No: 8J0 959 433 C
       Component:    KSG          H11 0080
       Coding: 1B90328201382D290F0FC88A0477
    01134 - Alarm Horn (H12)
    Address 47: Sound System        Labels: 8J0-035-223.lbl
       Part No SW: 8J0 035 223 B    HW: 8J0 035 223 B
       Component: J525 Amp Std    H03 0120
       Revision: 00H03001    Serial number: 93802005172706
       Coding: 0206116
       VCID: 2306CFD7E2D993579A-8076
       Part No SW: 8J8 959 802 E    HW: 8J8 959 802 E
       Coding: 0001076
       VCID: 40CC605B138FA84FE7-8014
    Address 56: Radio        Labels: 8E0-035-192-RNSE.clb
       Coding: 0610657
    Address 65: Tire Pressure        Labels: 8J0-907-273.lbl
       Part No SW: 8J0 907 273 A    HW: 8J0 907 273 A
       Component: J502-RDK        H03 0370
       Revision: --H03-D0    Serial number: 12956780526418
       Coding: 0840019
       VCID: 2F2E33E7BE1127370E-807A
       Part No SW: 8P0 862 335 R    HW: 8P0 862 335 R
       Component: FSE_255x BT     H26 0350
       Revision: 00000000    Serial number: 00000005074990
       Coding: 0011477
    End----------(Elapsed Time: 01:18, VBatt start/end: 14.2V/13.9V)-----------
    :confused::thumbs::thumbs::thumbs:
    Did you attempt the adaption by driving yet or RTFB?
    HQ
    http://wiki.ross-tech.com/wiki/index...ctronics_(MK60)
    Basic Settings for G200 and G201 listed there for the Golf are the same for your TT.
    Jef
  4. Likes Uwe, Jack@European_Parts liked this post
    Jun 2014
    Link doesn't show a lot Jef... Forum breaks the URL just before the ")"... Manualy edited URL...
    http://wiki.ross-tech.com/wiki/index...tronics_(MK60)
    Golf VII, 1.6TDI BM Ed. 40 - 110 PK
  6. Likes Uwe, Jef liked this post
