VW Polo 2011 with s/hand engine ecu faults in ecu
J2 auto
South Africa
C?ID=372869
hi good day i hope i am posting this in the correct place
i have a polo vivo 2011>
car arrived @ my work shop with out a ecu .so we fitted a used ECU
and we currently have 3 dtc in the engine ecu
i need help to to configure the new long coding for the ecu can someone please assist me
Thursday,23,January,2020,16:36:11:49237
VIN: AAVZZZ6SZBU024930   License Plate:
Chassis Type: 6S (6S - VW Polo Vivo (2010 >))
Scan: 01 02 03 08 09 15 17 19 25 44 46 56
VIN: AAVZZZ6SZBU024930   Mileage: 110450km-68630miles
Address 01: Engine (J623-CLPB)       Labels: Redir Fail!
   Part No SW: 03C 906 014 FK    HW: 03C 906 014 L
   Component: CLPB-MM7GV    H02 6848
   Revision: --H02---    Serial number: VWZ7Z0L0161592
   Coding: 00110014020400000000
   Shop #: WSC 12345 123 12345
   VCID: 6B823C42A399F50F0C5-51CE
000115 - Sensor for Ambient Air Temperature (G17)
               P0073 - 000 - Signal too High
                    Reset counter: 0
                    Bin. Bits: 00000000
                    Load: 0.0 %
                    Lambda: 0.0 %
                    Temperature: 46.0°C
                    Absolute Pres.: 999.6 mbar
001153 - Coolant Fan Control Circuit 2
               P0481 - 000 - Electrical Malfunction
                    Reset counter: 0
                    Bin. Bits: 00000000
                    Load: 0.0 %
                    Lambda: 0.0 %
                    Temperature: 46.0°C
005746 - Coolant Fan Control 1
               P1672 - 000 - Open or Short to Ground
                    Reset counter: 0
                    Bin. Bits: 00000000
                    Load: 0.0 %
                    Lambda: 0.0 %
                    Temperature: 46.0°C
Address 03: ABS Brakes        Labels: 6R0-907-37x-ABS80.clb
   Part No SW: 6Q0 907 379 BC    HW: 6Q0 907 379 BC
   Component: ABS 8.0 front   H06 0003
   Coding: 0002070
   Shop #: WSC 31414 000 00000
   VCID: 7F5AF812CBE179AFB0D-50D0
                    Reset counter: 54
                    Mileage: 110454 km
   Part No: 6QS 820 045 C
   Component: Klimaanlage         00.9
   VCID: 50F88BAE23FF36D7197-50D0
Address 09: Cent. Elect.        Labels:. 6Qx-937-049-C.lbl
   Part No: 6Q2 937 049 F
   Component: 000G BN-SG.         2S36
   Coding: 17422
   Shop #: WSC 31414
   VCID: 3FDAB8128E61B9AFF0D-50D0
   Part No: 1C0 909 601 C
   Component: 1N AIRBAG VW51      0011
   Coding: 12622
   Shop #: WSC 31414
   VCID: 20181B6E13DFE657E97-50D0
Address 17: Instruments        Labels: 6Q0-920-xxx-17.lbl
   Part No: 6QS 920 803
   Component: KOMBIINSTRUMENT VDO V08
   Coding: 00141
   VCID: 10784BAEE37F76D7597-50D0
   Part No: 6N0 909 901
   Component: 02VF GATEWAY CAN    2S36
   Coding: 00014
   Shop #: WSC 31414
   VCID: 70B82B2E83BF16D7397-50D0
Address 25: Immobilizer        Labels: 5J0-920-xxx-25.clb
   Component: IMMOBILIZER VDO V08
   Coding: 00141
   AAVZZZ6SZBU024930     VWZ7Z0L0161592
   Part No: 6R0 423 156 B
   Coding: 10150
   Shop #: WSC 31414
   VCID: 2F3AE8525E01492F60D-50D0
Address 46: Central Conv.        Labels:. 6Q0-959-433.clb
   Part No: 6Q0 959 433 E
   Component: 6U Komfortgerát     0002
   Coding: 00018
   Shop #: WSC 31414
   VCID: 3D26C21A846DABBFE21-4B1E
Address 56: Radio        Labels: None
   Part No: 6QS 035 182 A
   Component:  RADIO 9NK         0001
   Coding: 18415
   Shop #: WSC 31414
   VCID: 4EC495D639CB20270BB-5118
End----(Elapsed Time: 01:47, VBatt start/end: 12.5V/12.4V. VIgn 0.0V)------
What makes you think the ECU's coding is incorrect?
I would clear those intermittent faults, that would make it obvious whether the engine ECU is communicating or whether those are "historical" faults.
J2 auto
South Africa
C?ID=372869
megneti marelli ecu
the long coding is incorrect as the computer box comes from a different model and different year that uses a different fan set up
J2 auto
South Africa
C?ID=372869
all the faults have been cleared the current code are always returning
J2 auto
South Africa
C?ID=372869
SO THIS IS THE LATEST DTC ONLY 1 LEFT
Friday,24,January,2020,11:16:37:49237
   Coding: 00110014000400000000
                    Reset counter: 0
                    Bin. Bits: 00000001
                    Load: 30.0 %
                    Lambda: 0.0 %
                    Temperature: 52.0°C
                    Absolute Pres.: 365.8 mbar
                    RPM: 683 /min
   Coding: 0002070
   Coding: 17422
   Shop #: WSC 31414
   Coding: 12622
   Shop #: WSC 31414
   Coding: 00141
   Coding: 00014
   Shop #: WSC 31414
   Coding: 00141
   Coding: 10150
   Shop #: WSC 31414
   Coding: 00018
   Shop #: WSC 31414
   Coding: 18415
   Shop #: WSC 31414
   VCID: 4EC495D639CB20270BB-513C
End----(Elapsed Time: 01:44, VBatt start/end: 13.9V/13.9V. VIgn 0.0V)------
NEtech
C?ID=56995
Are you sure, G17 fault was not present in the old ECU ?
Check MWB 008.1 in [08] if there are problems, that is (G17) .
J2 auto
South Africa
C?ID=372869
SO WHEN CAR CAME TO ME THEY WAS NO ECU IN CAR
Is G17 standard equipment or is bay empty in ecu plug when compare to WD takes place?
Dana
Western PA, USA
Hi guys,
Lots of good suggestions here. The support crew at HEX Microsystems contacted us via e-mail on behalf of the OP and I replied however I'll paste the bulk of that reply below in the event the final feedback ends up here.
I agree with the G17 suggestions in forum.  G17 is standard equipment in
most parts of the world and address 17-Instruments relays the
information over the databus so modules such as 01-Engine, 03-ABS and
similar have the outside air temp information.
I didn't dig into wiring diagrams, and that's not a bad idea per Jack's
suggestion to make sure the wiring is present and connected to the
proper component, however PartsLink24 shows a factory fitted ambient
temperature sensor.  Temp screen shot link:
https://media.trillian.im/media/?m=aW1hZ2UvcG5nLDEyOTEsNzkzLIENjhJQUaHkOnNzlgNiqSZwHSST2g9TUV4NJeui%2BPQR
I'd make sure 1J0 919 379 A is both installed and that the wiring
diagram matches the terminal arrangements/wire colors at the sensor itself.
If that doesn't shed any light I suppose it might not hurt to verify the
instrument cluster or the wiring at it wasn't modified.  Also, measuring
block group 002 in address 17 contains useful info:
002,0,General
002,1,Odometer
002,2,Fuel Level
002,3,Fuel Sender,Resistance
002,4,Ambient,Temperature
You might want to compare that data to MVB 008.1 (per NEtech) in address 08.
Best,
Dana
