Results 1 to 10 of 12
Thread: VW Polo 2011 with s/hand engine ecu faults in ecu
    Jul 2019
    South Africa
    hi good day i hope i am posting this in the correct place
    i have a polo vivo 2011>
    car arrived @ my work shop with out a ecu .so we fitted a used ECU
    and we currently have 3 dtc in the engine ecu
    i need help to to configure the new long coding for the ecu can someone please assist me
    Thursday,23,January,2020,16:36:11:49237
    VIN: AAVZZZ6SZBU024930   License Plate:
    Chassis Type: 6S (6S - VW Polo Vivo (2010 >))
    Scan: 01 02 03 08 09 15 17 19 25 44 46 56
    VIN: AAVZZZ6SZBU024930   Mileage: 110450km-68630miles
    Address 01: Engine (J623-CLPB)       Labels: Redir Fail!
       Part No SW: 03C 906 014 FK    HW: 03C 906 014 L
       Component: CLPB-MM7GV    H02 6848
       Revision: --H02---    Serial number: VWZ7Z0L0161592
       Coding: 00110014020400000000
       VCID: 6B823C42A399F50F0C5-51CE
    000115 - Sensor for Ambient Air Temperature (G17)
                   P0073 - 000 - Signal too High
                        Reset counter: 0
                        Bin. Bits: 00000000
                        Lambda: 0.0 %
                        Temperature: 46.0°C
                        Absolute Pres.: 999.6 mbar
    001153 - Coolant Fan Control Circuit 2
                   P0481 - 000 - Electrical Malfunction
                        Reset counter: 0
                        Bin. Bits: 00000000
                        Lambda: 0.0 %
                        Temperature: 46.0°C
    005746 - Coolant Fan Control 1
                   P1672 - 000 - Open or Short to Ground
                        Reset counter: 0
                        Bin. Bits: 00000000
                        Lambda: 0.0 %
                        Temperature: 46.0°C
    Address 03: ABS Brakes        Labels: 6R0-907-37x-ABS80.clb
       Part No SW: 6Q0 907 379 BC    HW: 6Q0 907 379 BC
       Component: ABS 8.0 front   H06 0003
       Coding: 0002070
       Shop #: WSC 31414 000 00000
       VCID: 7F5AF812CBE179AFB0D-50D0
                        Reset counter: 54
                        Mileage: 110454 km
       Part No: 6QS 820 045 C
       Component: Klimaanlage         00.9
       VCID: 50F88BAE23FF36D7197-50D0
    Address 09: Cent. Elect.        Labels:. 6Qx-937-049-C.lbl
       Part No: 6Q2 937 049 F
       Component: 000G BN-SG.         2S36
       Coding: 17422
       Shop #: WSC 31414
       VCID: 3FDAB8128E61B9AFF0D-50D0
       Part No: 1C0 909 601 C
       Component: 1N AIRBAG VW51      0011
       Coding: 12622
       Shop #: WSC 31414
       VCID: 20181B6E13DFE657E97-50D0
    Address 17: Instruments        Labels: 6Q0-920-xxx-17.lbl
       Part No: 6QS 920 803
       Component: KOMBIINSTRUMENT VDO V08
       Coding: 00141
       VCID: 10784BAEE37F76D7597-50D0
       Part No: 6N0 909 901
       Component: 02VF GATEWAY CAN    2S36
       Coding: 00014
       Shop #: WSC 31414
       VCID: 70B82B2E83BF16D7397-50D0
    Address 25: Immobilizer        Labels: 5J0-920-xxx-25.clb
       Component: IMMOBILIZER VDO V08
       Coding: 00141
       AAVZZZ6SZBU024930     VWZ7Z0L0161592
       Part No: 6R0 423 156 B
       Component: LenkhilfeTRW        V277
       Coding: 10150
       Shop #: WSC 31414
       VCID: 2F3AE8525E01492F60D-50D0
    Address 46: Central Conv.        Labels:. 6Q0-959-433.clb
       Part No: 6Q0 959 433 E
       Component: 6U Komfortgerát     0002
       Coding: 00018
       Shop #: WSC 31414
       VCID: 3D26C21A846DABBFE21-4B1E
    Address 56: Radio        Labels: None
       Part No: 6QS 035 182 A
       Component:  RADIO 9NK         0001
       Coding: 18415
       Shop #: WSC 31414
       VCID: 4EC495D639CB20270BB-5118
    End----(Elapsed Time: 01:47, VBatt start/end: 12.5V/12.4V. VIgn 0.0V)------
    What makes you think the ECU's coding is incorrect?
    I would clear those intermittent faults, that would make it obvious whether the engine ECU is communicating or whether those are "historical" faults.
  4. Likes Uwe, Jack@European_Parts liked this post
    Jul 2019
    South Africa
    megneti marelli ecu
    the long coding is incorrect as the computer box comes from a different model and different year that uses a different fan set up
    Jul 2019
    South Africa
    all the faults have been cleared the current code are always returning
    Try this:
    00110014000400000000
  8. Likes Jack@European_Parts, Uwe, Dana liked this post
    Jul 2019
    South Africa
    Try this:
    HI TRIED ITSTILL 1 DTC
    00110014000400080000 ALSO TRIED THIS STILL 1 DTC
  10. #8
    Jul 2019
    South Africa
    SO THIS IS THE LATEST DTC ONLY 1 LEFT
    Friday,24,January,2020,11:16:37:49237
       Coding: 00110014000400000000
                        Reset counter: 0
                        Bin. Bits: 00000001
                        Load: 30.0 %
                        Lambda: 0.0 %
                        Temperature: 52.0C
                        Absolute Pres.: 365.8 mbar
                        RPM: 683 /min
       Coding: 0002070
       Coding: 17422
       Shop #: WSC 31414
       Coding: 12622
       Shop #: WSC 31414
       Coding: 00141
       Coding: 00014
       Shop #: WSC 31414
       Coding: 00141
       Coding: 10150
       Shop #: WSC 31414
       Component: 6U Komfortgert     0002
       Coding: 00018
       Shop #: WSC 31414
       Coding: 18415
       Shop #: WSC 31414
       VCID: 4EC495D639CB20270BB-513C
    End----(Elapsed Time: 01:44, VBatt start/end: 13.9V/13.9V. VIgn 0.0V)------
  11. #9
    Are you sure, G17 fault was not present in the old ECU ?
    Check MWB 008.1 in [08] if there are problems, that is (G17) .
  12. Likes Jack@European_Parts, Dana liked this post
  13. #10
    Jul 2019
    South Africa
    SO WHEN CAR CAME TO ME THEY WAS NO ECU IN CAR
