Results 1 to 4 of 4
Thread: 2009 Audi A3 ECM fault codes
    Mar 2014
    United Kingdom
    Hi I have this vehicle in with the EML light on, it only had the fault regards the egr coolant pump but after replacing the pump(genuine pump was fitted) the fault was still present.
    I have then proceeded to check the wiring diagram and supply voltage all ok.
    Cycling the ignition has introduced all the other faults in the ECM, and I cant clear them either.
    Clear faults EML light goes off and cycle the ignition the faults are still present.
    Is there a possibility of ECM fault?
    Thursday,23,January,2020,10:55:19:32967
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x86
    VCDS Version: 19.6.2.0  HEX-NET CB: 0.4508.4
    VIN: WAUZZZ8P6AA024475   License Plate: OU59ZKR
    Mileage: 119320km-74142mi   Repair Order:
    Chassis Type: 8P-AU35 (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 61 62 72 77
    VIN: WAUZZZ8P6AA024475   Mileage: 119320km-74142miles
    Address 01: Engine (J623-CAYC)       Labels:. 03L-906-023-CAY.clb
       Part No SW: 03L 906 023 M    HW: 03L 906 023 L
       Component: R4 1.6l TDI   H23 9979
       Revision: --H23---    Serial number: AUX7Z0I5FNT03N
       Coding: 00114016030501080000
       Shop #: WSC 06314 000 00000
       ASAM Dataset: EV_ECM16TDI02103L906023M 003017
       ROD: EV_ECM16TDI02103L997557R.rod
       VCID: B02C989CEBA314CF97-80E4
    10 Faults Found:
    7300 - Throttle Position Sensor (G69)
              P0123 00 [032] - Signal too High
                        Time: 00:00:00
                        Coolant temperature: 9 C
                        Intake air temperature: 10 C
                        Voltage terminal 30: 12.085 V
                        Throttle valve adapter: actual value-ANG_THR[0]: 99.997 %
                        Throttle_actuator_commanded_value-ANG_SP_THR[0]: 3.999 %
                        Throttle valve: activation-PWM_HBR_THR[0]: 0.000 %
                        Throttle valve adapter: uncond voltage actual value-V_THR[0]: 4.995 V
                        Throttle valve adapter: offset closed-V_THR_BOL[0]: 0.688 V
                        Throttle valve adapter: offset open-V_THR_TOL[0]: 4.600 V
                        Throttle valve adapter: status-LF_STATE_THR_DISP[0]: 0
    7332 - Mass Air Flow Sensor (G70)
              P0103 00 [032] - Signal too High
                        Time: 00:00:00
                        Engine speed: 0 /min
                        Battery voltage: 11.7 V
                        EGR Vacuum Regulator Solen.val.: activation-ANG_SP_EGRV[0]: 0.000 %
                        Air mass: specified value-MAF_SP_MMV: 239.95 mg/stroke
                        Air mass: actual value (mg/stroke)-MAF_MES: 0 mg/stroke
    7411 - Turbocharger Boost Control Position Sensor Circuit
              P2564 00 [032] - Signal too Low
                        Time: 00:00:00
                        Charge Pressure Actuator: acknowledgment-ANG_BPA[0]: -13.025 %
                        Charge Pressure Actuator: activation-ANG_SP_BPA[0]: 20.000 %
                        High press turbocharger actuator: activation-CTL_LIM_BPA[0]: 95.001 %
                        High press turbocharger actuator: actual uncond volt value-V_BPA[0]: 0.000 V
                        Turbocharger boost control: offset open-V_BPA_BOL[0]: 0.498 V
                        Turbocharger boost control: offset closed-V_BPA_TOL[0]: 3.501 V
                        High press turbocharger actuator: status-LF_STATE_BPA_DISP[0]: 0
    10156 - Cylinder 1 Glow Plug Circuit (Q10)
              P0671 00 [100] - Electrical Fault
                        Mileage: 119328 km
                        Date: 2020.08.23
                        Time: 09:36:53
                        Voltage terminal 30: 11.972 V
                        Glow status-STATE_GLOW: 48
                        Fuel temperature-TFU: 10 C
                        Sensor for engine block temperature: raw value-Coolant temperature: 9 C
    10158 - Cylinder 2 Glow Plug Circuit (Q11)
              P0672 00 [100] - Electrical Fault
                        Mileage: 119328 km
                        Date: 2020.08.23
                        Time: 09:36:53
    10131 - Fuel Pressure Sensor (G247)
              P0193 00 [032] - Short to Plus
                        Time: 00:00:00
                        Voltage terminal 30: 11.859 V
                        Supply voltage of analog output 1-VCC_1: 5.00 V
                        Fuel high pressure sensor: unconditioned voltage-VP_PFU: 4.9939 V
                        Fuel pressure: 200000 kPa rel
                        Fuel high pressure: actual value-FUP_FIL: 199.997 MPa
                        Fuel high pressure commanded value_1-FUP_SP_KPA_ENVD: 0.000 kPa
                        ECM system status-Binary 16 Bit: 00000000 00000000
    10113 - Fuel Pressure Regulator Valve (N276)
              P2294 00 [032] - Open Circuit
                        Time: 00:00:00
                        Fuel pressure regulator valve actual value-CFB_PCV_MES: 0.073 A
                        Voltage equiv. current of regulating valve for fuel pressure-VP_CFB_PCV: 3.2877 V
                        Fuel pressure regulator valve: specified value rail pressure-LV_PCV_CTL: 00000000
                        Fuel Pressure Regulator Valve-PCV: 0.000 %
                        Fuel Metering Valve-VCV: 0.000 %
    9867 - Coolant Pump 2
              P261A 00 [168] - Open circuit
                        Fault Frequency: 90
                        Mileage: 116607 km
                        Date: 2020.06.05
                        Time: 21:40:40
                        Engine speed: 2047.50 /min
                        Normed load value: 23.1 %
                        Vehicle speed: 55 km/h
                        Coolant temperature: 54 C
                        Voltage terminal 30: 14.231 V
                        Coolant temperature at radiator outlet: actual value-TCO_2: 14 C
                        Battery voltage: 14.6 V
    9870 - Coolant pump 2
              P261B 00 [237] - Implausible signal
                        Fault Frequency: 41
                        Mileage: 117289 km
                        Date: 2020.06.28
                        Time: 13:06:35
                        Engine speed: 784.50 /min
                        Normed load value: 9.8 %
                        Coolant temperature: 66 C
                        Intake air temperature: 16 C
                        Voltage terminal 30: 14.456 V
                        Coolant temperature at radiator outlet: actual value-TCO_2: 13 C
                        Battery voltage: 14.0 V
    9871 - Exhaust Gas Recirculation Cooling Valve Control
              P2425 00 [032] - Open Circuit
                        Time: 00:00:00
                        Sensor for temp after charge air cooler: raw value-TBA_MES: 10 C
                        Charge air pressure: actual value-MAP_MMV: 200.00 hPa
                        Air mass: actual value:: 0.00 g/s
                        Air mass proportion filtered-FAC_MAF_CYL_KGH_RATIO_FIL: 1.00000
    Readiness: 1 2 0 0 0
       Part No SW: 1K0 907 379 BA    HW: 1K0 907 379 BA
       Component: ESP MK60EC1   H45 0109
       Revision: 00H45001
       Coding: 13422012492400FEC80F04EB921E00913800
       Shop #: WSC 25463 000 1048576
       VCID: F2A852942D2F66DF21-80A6
       Part No SW: 8P0 820 043 BK    HW: 8P0 820 043 BK
       Component: KlimavollautomatH09 0130
       Revision: 000105      Serial number: 8P0820043BK
       VCID: F6A06E8481477AFF0D-80A2
       Part No SW: 8P0 907 063 A    HW: 8P0 907 063 A
       Component: BCM PQ35  M   104 0575
       Revision: 00104 AH
       Coding: 0E000A2CB005F0C0207041E00000015C431A29AA004DC12AE4008F800041
       Shop #: WSC 00751 210 98641
       VCID: B2289294EDAF26DFE1-80E6
       Subsystem 1 - Part No SW: 8P2 955 119 F    HW: 8P2 955 119 F  Labels: 1KX-955-119.CLB
       Component: Wischer AU350  H10 0040
       Coding: 00DD13
       Subsystem 2 - Part No: 8P0 951 177
       Component: Innenraumuebe  H04 0020
       Subsystem 4 - Part No: 1K0 907 719 C
       Component: Neigungssenso  005 0003
    Address 15: Airbags (J234)       Labels:* 8P0-959-655-10.clb
       Part No SW: 8P0 959 655 P    HW: 8P0 959 655 P
       Component: Airbag AU1042 H06 0140
       Revision: --------    Serial number: 003FB001W2XB
       Coding: 30314238303830303037554A305238503053
       ROD: EV_Airba10AURB4.rod
       VCID: CFEEFB60965D6B37EE-809A
       Serial number: 3572DRB40000916069DU
       Serial number: 3582DRB400009160F21L
       Serial number: 35128RB400004E2D41CP
       Serial number: 35228RB400004E275C7R
       Serial number: 35547RB400004DD073AU
       Serial number: 35647RB400004DCF78C9
       Component: J0527           H37 0070
       Coding: 0004012
       VCID: C6C0DE44B127AA7F5D-8092
       Component: E0221           H02 0030
       Part No SW: 8P0 920 982 J    HW: 8P0 920 982 J
       Component: KOMBIINSTR. VDO H02 0980
       Revision: D0H02002    Serial number: 2245I002002972
       Coding: 0004428
       Shop #: WSC 12345 123 12345
       VCID: C0CCC85C9303844F67-8094
       Part No SW: 1K0 907 530 AC    HW: 1K0 907 951
       Component: J533  Gateway   H17 0222
       Revision:   H17       Serial number: 1021J095190695
       Coding: E9807F06000602042103
       VCID: E89C30FCDBF39C0F8F-80BC
       Revision: D0H02002    Serial number: AUX7Z0I5FNT03N
    Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN3.lbl
       Part No SW: 8P0 959 801 N    HW: 8P0 959 801 N
       Component: Tuer-SG         H04 0100
       Coding: 0131764
       Part No: 1K0 909 144 H
       Component: EPS_ZFLS Kl. 232    2901
       Revision: 00H15000
       Shop #: WSC 02069 000 90108
       VCID: AF2E9BE03E9D0B378E-80FA
       Part No SW: 8P0 959 802 N    HW: 8P0 959 802 N
       Coding: 0131764
       VCID: C7DED340B62DB377A6-8092
    Address 56: Radio        Labels: 8J0-035-1xx-56.clb
       Part No SW: 8P0 035 152 E    HW: 8P0 035 152 E
       Component: R Chorus2+      H02 0280
       Revision: 00H02000    Serial number: AUZ1Z2I5214719
       Coding: 0600021
       VCID: AD1281E834917927BC-80F8
       Part No SW: 1K0 907 534     HW: 1K0 907 951
       Component: Batt.regelung H17 0222
       Revision: --------    Serial number: 1021J095190695
       Coding: 0303085A
       VCID: E89C30FC1BF39C0F8F-80BC
       Subsystem 1 - Part No SW: 1K0 915 181 C    HW: 1K0 915 181 A
       Component: J367-BDM  H07 0125
       Serial number: 00000000002790585430
       Part No SW: 8P4 959 801 F    HW: 8P4 959 801 F
       Component: Tuer-SG         H04 0050
       Coding: 0131216
       Shop #: WSC 06314 000 1012544
       VCID: C2C8C2549D0F965F71-8096
       Part No SW: 8P4 959 802 F    HW: 8P4 959 802 F
       Coding: 0131216
       VCID: C3C6C75082159F577A-8096
       Part No SW: 8P0 862 335 AA    HW: 8P0 862 335 S
       Component: FSE_256x BT     H34 0600
       Revision: 00000000    Serial number: 00000005103746
       Coding: 0001222
       VCID: F5A269889C4171E704-80A0
    End----------(Elapsed Time: 01:29, VBatt start/end: 14.3V/14.4V)-----------
    Mar 2014
    United Kingdom
    I don't believe its been in a collision, is there something I'm missing in the autoscan that suggests its been in a collision?
    Nope not sure how this post got here.
    Deleted....was intended for link below so either that was a forum bug maybe or other glitch?
    https://forums.ross-tech.com/showthr...udi-A4-B8-2-0T
    On another note.....
    Did you try unplugging all respective shared sensors and isolating the faults one by one while qualifying the circuit with load light?
    Mar 2014
    United Kingdom
    The old disconnect the battery and discharge system and reconnect has worked and all faults cleared.
