Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Swapping Bosch wet flooded battery to Varta AGM Battery (No BEM)
    Jan 2020
    Hi all, newbie here looking to replace my current wet flooded battery which has come to the end of it's days with a new Varta AGM battery. Unfortunately there is no BEM sticker on the battery and i am unsure how to code this battery in. Does anyone have experience with changing the battery from wet flooded to AGM? I will get an Auto Scan uploaded asap as not with the vehicle at the min, this is in a 2006 Audi Q7 4.2 fsi. Any help would be gratefully received, thanks.
    IIRC, the Q7 of that vintage doesn't have much accommodation for different battery types.
    But please do post an Auto-Scan so we can see exactly what kind of battery management this vehicle is equipped with.
    Jan 2020
    Wednesday,22,January,2020,10:58:43:34002
    VIN: WAUZZZ4L07D045588   License Plate:
    Mileage: 225820km-140318mi   Repair Order:
    Chassis Type: 4L (4L0)
    Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 34 37 3C 42 46 47 4F 52
              55 56 57 61 62 65 6C 6D 6F 72 76 77
    VIN: WAUZZZ4L07D045588   Mileage: 225820km-140318miles
    0E-Media Player 1 -- Status: Malfunction 0010
    57-TV Tuner -- Status: Malfunction 0010
    Address 01: Engine        Labels:. 079-907-560-BAR.clb
       Part No SW: 4L0 910 560 B    HW: 4L0 907 560 A
       Component: 4.2l V8/4V FSI      0070
       Revision: 71H16---    Serial number:
       Coding: 01210003190F0560
       Shop #: WSC 00426 210 85987
       VCID: 270BFCEF93E5591FA8D-8072
    002129 - Park/Neutral Switch Input Circuit
                   P0851 - 004 - Short to GND - Intermittent
                        Fault Status: 00110100
                        Mileage: 225779 km
                        Load: 0.0 %
                        Temperature: 78.0°C
                        Temperature: 58.0°C
                        Absolute Pres.: 960.0 mbar
                        Voltage: 7.874 V
    000048 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit
                   P0030 - 004 - Malfunction / Open Circuit
                        Mileage: 225779 km
                        Date: 2019.12.13
                        Time: 13:19:40
                        RPM: 1284 /min
                        Load: 45.5 %
                        Temperature: 3.0°C
                        Temperature: 6.0°C
                        Absolute Pres.: 1010.0 mbar
                        Voltage: 13.335 V
    008196 - Intake Manifold Flap; Bank 1
                   P2004 - 002 - Stuck Open - Intermittent
                        Mileage: 225780 km
                        Date: 2019.12.13
                        Time: 13:35:39
                        RPM: 819 /min
                        Load: 16.5 %
                        Temperature: 83.0°C
                        Temperature: 27.0°C
                        Voltage: 12.700 V
    008197 - Intake Manifold Flap; Bank 2
                   P2005 - 002 - Stuck Open - Intermittent
                        Mileage: 225780 km
                        Date: 2019.12.13
                        Time: 13:35:39
                        RPM: 819 /min
                        Load: 16.5 %
                        Temperature: 83.0°C
                        Temperature: 27.0°C
                        Voltage: 12.700 V
                        Load: 0.0 %
                        Temperature: -40.0°C
                        Absolute Pres.: 0.0 mbar
                        Voltage: 0.000 V
    Readiness: 0110 1101
    Address 02: Auto Trans        Labels: 09D-927-750.clb
       Part No SW: 09D 927 750 FJ    HW: 09D 927 750 FJ
       Component: AL 750 6A           0938
       Revision: 00H52000    Serial number:
       Coding: 0000504
       Shop #: WSC 31414 790 00001
       VCID: 7BA3F09F3FED2DFF9C5-802E
    Address 03: ABS Brakes        Labels:. 4L0-910-517-V1.clb
       Part No SW: 4L0 910 517 A    HW: 4L0 614 517 A
       Component: ESP ALLRAD MK25E1   0130
       Revision: 00H21001
       Coding: 0021553
       VCID: 2809FFD39EFB5667A17-807C
                        Reset counter: 81
                        Mileage: 225779 km
                        Date: 2019.12.13
                        Time: 12:58:30
                        Count: 14337
                        Count: 128
                        Count: 34304
                        Reset counter: 0
                        Mileage: 225779 km
                        Count: 128
                        Count: 15105
                        Count: 297
                        Count: 28928
       Part No SW: 4F0 910 852     HW: 4F0 905 852 B
       Component: FBSAUDIC6 ELV   H31 0220
       Revision: 31050601    Serial number: 10601100526558
       Coding: 0000147
       VCID: 6393A8FFA75DF53FB45-8036
       Component: FBSAUDIC6 EZS   H45 0080
       Component: FBSAUDIC6 IDG   H01 0040
    00532 - Supply Voltage B+
                        Reset counter: 83
                        Mileage: 225779 km
                        Date: 2019.12.13
                        Time: 12:59:54
                        Fault Frequency: 10
                        Reset counter: 83
                        Mileage: 225779 km
                        Date: 2019.12.13
                        Time: 12:58:51
    Address 07: Control Head        Labels: 4L0-910-7xx-07-H.clb
       Part No SW: 4L1 910 732 H    HW: 4E0 035 729 A
       Component: Interfacebox    H43 5570
       Revision: 00000000    Serial number: 387IX067522606
       Coding: 0002002
       VCID: 2F3B14CFBB15015F60D-807A
       Subsystem 1 - Part No: 4L0 910 609
       Component: E0380 BedienteilH02 0060
       Subsystem 2 - Serial number: 00000000515490
       Subsystem 3 - Serial number: 0105.09.060000000100010435˙
       Subsystem 4 - Serial number: 010435˙
                        Reset counter: 83
                        Time Indication: 15
       Part No SW: 4L0 910 043     HW: 4L0 820 043 F
       Component: KLIMABETAETIGUNGH05 0060
       Revision: 00---009    Serial number: 00000000064048
       Coding: 0525320
       VCID: 619FA2F7BD41E72FA69-8034
                        Fault Status: 00101110
                        Reset counter: 82
                        Mileage: 225779 km
                        Date: 2019.12.13
                        Time: 12:51:11
                        Temperature: 23.0°C
                        Reset counter: 80
                        Mileage: 225779 km
                        Date: 2019.12.13
                        Time: 12:58:30
                        Voltage: 9.60 V
                        Reset counter: 83
                        Mileage: 225792 km
                        Date: 2020.01.01
                        Time: 03:57:34
                        Temperature: 3.0°C
                        Temperature: 3.0°C
                        Load: 28.8 %
                        Temperature: -4.0°C
                        RPM: 1240 /min
                        Absolute Pres.: 1.0 bar
                        Current: 0.000 A
                        Temperature: 3.0°C
       Part No SW: 4F0 910 279 J    HW: 4F0 907 279 A
       Component: ILM Fahrer      H17 0240
       Coding: 0013121
       VCID: 303917B3A62B1EA7797-8064
       Subsystem 1 - Part No: 4L2 910 113   Labels: 1KX-955-119.CLB
       Component: Wischer AU716   H08 0080
       Coding: 00064792
       Shop #: WSC 31414
       Subsystem 2 - Part No: 4E0 910 557 A  Labels: 8K0-955-559.CLB
       Component: REGENLICHTSENSORH12 0090
       Coding: 00150059
       Shop #: WSC 31414
    02385 - Rain / Light Recognition Sensor Function Restricted due to Under-Voltage
                        Reset counter: 82
                        Mileage: 225784 km
                        Date: 2019.12.30
                        Time: 12:49:00
                        Reset counter: 81
                        Mileage: 225776 km
                        Date: 2019.12.13
                        Time: 12:59:00
                        Reset counter: 81
                        Mileage: 225776 km
                        Date: 2019.12.13
                        Time: 12:59:00
       Part No SW: 4L0 910 111 A    HW: 4L0 035 111
       Component: CD-Changer      H41 0100
       Revision: 00000000    Serial number: AUZ5ZBF3041880
       VCID: 1E65D90BCCBF98D7DBB-804A
                        Reset counter: 40
                        Mileage: 225779 km
                        Date: 2019.12.13
                        Time: 13:15:41
    02261 - Data Medium
                        Reset counter: 82
                        Mileage: 225792 km
                        Date: 2020.01.01
                        Time: 03:39:45
                        Text: 00000000
                        Reset counter: 80
                        Mileage: 225779 km
                        Date: 2019.12.13
                        Time: 13:00:03
       Part No SW: 4L0 910 655 B    HW: 4L0 959 655
       Component: 31 AIRBAG AUDI8RH38 0120
       Revision: 05H38000    Serial number: 0037GD06M2N6
       Coding: 0013105
       VCID: 2C0103C38A037A4745F-8078
       Subsystem 1 - Serial number: 6332QSME114F2219A
       Subsystem 2 - Serial number: 6342QSME140D1B29H
       Subsystem 3 - Serial number: 6352QSME13613E7FR
       Subsystem 4 - Serial number: 6362QSME126C4459L
       Subsystem 5 - Serial number: 63734SME1532085B-
       Subsystem 6 - Serial number: 63834SME152C1865%
       Part No SW: 4F0 910 549     HW: 4F0 953 549 A
       Component: Lenksäulenmodul H08 0230
       Revision: 00H08000    Serial number: 90025062340199
       Coding: 0112142
       VCID: 6695B1EB546F801753B-8032
       Component: Lenkradmodul    H07 0090
                        Fault Frequency: 7
                        Reset counter: 83
                        Reset counter: 83
                        Mileage: 225779 km
                        Date: 2019.12.13
                        Time: 13:01:55
    Address 17: Instruments        Labels: 4L0-910-xxx-17.lbl
       Part No SW: 4F0 910 930 C    HW: 4L0 920 980 F
       Component: KOMBIINSTR. M73 H17 0110
       Revision: 00400000    Serial number: 5HI56YZ76
       Coding: 2673443
       Shop #: WSC 40568 067 57207
       VCID: 2313E8FFE7DDB53FF45-8076
    Address 19: CAN Gateway        Labels:. 4L0-910-468.clb
       Part No SW: 4L0 910 468     HW: 4L0 907 468 A
       Component: J533__Gateway   H06 0040
       Revision: 00H06000    Serial number: 0800D0682281BD
       Coding: F557FE7F343602
       Shop #: WSC 00583 210 88973
       VCID: 6C81C3C34A83BA4705F-8038
                        Reset counter: 83
                        Mileage: 225779 km
                        Date: 2019.12.13
                        Time: 13:15:43
    Address 34: Level Control        Labels: 4L0-910-553.lbl
       Part No SW: 4L0 910 553 B    HW: 4L0 907 553
       Component: LUFTFDR.-CDC    H03 7550
       Revision: --H03001    Serial number: 15.1528-0095.2
       Coding: 0015510
       Shop #: WSC 00583 210 64613
       VCID: 290FFAD785F16F6FBE9-807C
                        Fault Frequency: 7
                        Reset counter: 168
                        Mileage: 225779 km
                        Date: 2019.12.13
                        Time: 12:59:03
                        Error Code: 13
                        Reset counter: 80
                        Mileage: 225779 km
                        Date: 2019.12.13
                        Time: 13:00:03
                        Error Code: 64
    01577 - Turn-Off due to Over-Temp
                        Fault Status: 00100001
                        Reset counter: 83
                        Mileage: 225781 km
                        Date: 2019.12.13
                        Time: 13:36:35
                        Error Code: 68
       Part No SW: 4E0 910 887 Q    HW: 4E0 919 887 D
       Component: MNS ECE         H48 0850
       Revision: 00000000    Serial number: 399H1067535890
       VCID: 3B23309F7F6DEDFFDC5-806E
                        Reset counter: 83
                        Mileage: 225779 km
                        Date: 2019.12.13
                        Time: 13:00:31
    02261 - Data Medium
                        Reset counter: 83
                        Mileage: 225792 km
                        Date: 2020.01.01
                        Time: 03:56:47
                        Hex Value: 0x0000
                        Raw, Form. N/A: 000 045 048
                        Fault Frequency: 13
                        Reset counter: 82
                        Mileage: 225779 km
                        Date: 2019.12.13
                        Time: 13:13:36
                        Reset counter: 80
                        Mileage: 225779 km
                        Date: 2019.12.13
                        Time: 13:00:10
    Address 3C: Lane Change        Labels: None
       Part No SW: 4L0 910 566 A    HW: 4L0 907 566 A
       Component: J0769_SWA_MasterH06 0060
       Revision: 00H06000    Serial number: 6PZ 009 014-00
       Coding: 0001101
       Subsystem 1 - Part No: 4L0 910 568 A
       Component: J0770_SWA_Slave_H05 0060
       Subsystem 2 - Serial number: 6PZ 009 014-20
       Subsystem 3 - Serial number: 3F30.08.0600H0500000010219˙
       Subsystem 4 - Serial number: 010219˙
    Address 42: Door Elect, Driver        Labels: 4L0-910-793-42.lbl
       Part No SW: 4L0 910 793 B    HW: 4L0 959 793 B
       Component: TSG FA          H12 0130
       Revision: 00-00000
       Coding: 0002651
                        Reset counter: 80
                        Mileage: 225779 km
                        Date: 2019.12.13
                        Time: 13:15:43
       Part No SW: 4L0 910 289 D    HW: 4L0 907 289 A
       Component: Komfortgeraet   H05 0020
       Revision: 0020 ---    Serial number: 01018817190000
       Coding: 7610619
       VCID: 313F12B7AD2117AF769-8064
    01699 - Motor for Central Locking; Hatch/Trunk (V53)
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 42
                        Mileage: 203836 km
                        Date: 2018.03.19
                        Time: 12:38:12
                        Reset counter: 80
                        Mileage: 225779 km
                        Date: 2019.12.13
                        Time: 13:03:58
    Address 47: Sound System        Labels: 4L0-910-223-BO.lbl
       Part No SW: 4L0 910 223 G    HW: 4L0 035 223 D
       Component: DSP-High AU716  H02 0150
       Revision: PROD_01     Serial number: 00000000015745
       Coding: 0000017
                        Reset counter: 83
                        Voltage: 8.00 V
                        Reset counter: 83
                        Mileage: 225787 km
                        Date: 2019.12.30
                        Time: 12:49:57
                        Voltage: 8.30 V
       Part No SW: 4F0 910 280     HW: 4F0 907 280 E
       Component: ILM Beifahrer   H10 0080
       Revision:             Serial number: 00000000008708
       Coding: 0011101
       VCID: 5EE5990B8C3FD8D79BB-800A
                        Reset counter: 83
                        Mileage: 225776 km
                        Date: 2019.12.13
                        Time: 13:00:00
                        Voltage: 6.700 V
                        Temperature: 23.0°C
                        Reset counter: 83
                        Mileage: 225776 km
                        Date: 2019.12.13
                        Time: 12:59:00
                        Voltage: 8.000 V
                        Temperature: 22.0°C
    Address 52: Door Elect, Pass.        Labels: 4L0-910-793-52.lbl
       Part No SW: 4L0 910 793 B    HW: 4L0 959 792 B
       Component: TSG BF          H12 0130
       Revision: 00-00000
       Coding: 0002651
                        Reset counter: 80
                        Mileage: 225779 km
                        Date: 2019.12.13
                        Time: 13:15:43
       Part No SW: 4F0 910 357 F    HW: 4F0 907 357 F
       Coding: 0000022
       Component: AFS-Modul links H06 0002
       Subsystem 2 - Part No: 7L6 941 329 A
       Component: AFS-Modul rechtsH06 0002
                        Reset counter: 40
                        Mileage: 225784 km
                        Date: 2019.12.13
                        Time: 12:59:53
       Part No SW: 4E0 910 541 T    HW: 4E0 035 541 P
       Revision: 00000000    Serial number: 388H$067550845
       Coding: 0000001
                        Reset counter: 83
                        Mileage: 225779 km
                        Date: 2019.12.13
                        Time: 13:15:43
                        Fault Frequency: 229
                        Reset counter: 83
                        Mileage: 225779 km
                        Date: 2019.12.13
                        Time: 12:58:50
    Address 57: TV Tuner        Labels: None
       Part No SW: 4E0 910 148 E    HW: 4E0 919 148
       Component: R0078 TVhybridT     0470
       Revision: R0H05000    Serial number: 76300700558602
       Coding: 0000303
       VCID: 2517F6E7E9E94B0F9A1-8070
                        Reset counter: 83
                        Mileage: 225779 km
                        Date: 2019.12.13
                        Time: 12:59:34
    00863 - Antenna 1 for TV (R55)
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 40
                        Mileage: 225779 km
                        Date: 2019.12.13
                        Time: 12:50:50
    Address 61: Battery Regul.        Labels: 4F0-910-181.lbl
       Part No SW: 4L0 910 181     HW: 4L0 915 181
       Component: J0644 BEM       H12 0530
       Revision: --------    Serial number: 00000000040765
       Shop #: WSC 00426 210 85279
       VCID: 6491ABE3A253F2074DF-8030
       Component: von VA0  2609010410
       Coding: 344630393135313035442056413032363039303130343130
                        Reset counter: 83
                        Mileage: 225779 km
                        Date: 2019.12.13
                        Time: 13:00:31
                        Fault Frequency: 16
                        Date: 2019.12.13
                        Time: 13:11:34
    Address 62: Door, Rear Left        Labels: 4L0-910-795.lbl
       Part No SW: 4L0 910 795 B    HW: 4L0 959 795 B
       Component: TSG HL          H21 0050
       Coding: 0002058
                        Reset counter: 80
                        Mileage: 225779 km
                        Date: 2019.12.13
                        Time: 13:15:43
    Address 65: Tire Pressure        Labels: 4F0-910-273-HI.lbl
       Part No SW: 4F0 910 273 C    HW: 4F0 907 273 A
       Component: Reifendruck 3   H05 0100
       Revision: 00050100    Serial number: 00000700017713
       Coding: 0222424
                002 - Lower Limit Exceeded - Intermittent - MIL ON
                        Fault Status: 10100010
                        Reset counter: 80
                        Mileage: 225779 km
                        Date: 2019.12.13
                        Time: 13:00:31
                        (no units): 255.0
                        Voltage: 6.60 V
                        (no units): 42.0
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
    01467 - Front Left Tire Pressure Sensor (G222)
                        Fault Status: 11100100
                        Reset counter: 43
                        Mileage: 225798 km
                        Date: 2020.01.01
                        Time: 04:38:01
                        (no units): 21.0
                        Voltage: 13.70 V
                        (no units): 46.0
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
    01468 - Front Right Tire Pressure Sensor (G223)
                        Reset counter: 43
                        Mileage: 225798 km
                        Date: 2020.01.01
                        Time: 04:38:01
                        (no units): 21.0
                        Voltage: 13.70 V
                        (no units): 49.0
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
    01469 - Rear Left Tire Pressure Sensor (G224)
                        Reset counter: 43
                        Mileage: 225798 km
                        Date: 2020.01.01
                        Time: 04:38:01
                        (no units): 21.0
                        Voltage: 13.70 V
                        (no units): 52.0
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
    01470 - Rear Right Tire Pressure Sensor (G225)
                        Reset counter: 43
                        Mileage: 225798 km
                        Date: 2020.01.01
                        Time: 04:38:01
                        (no units): 21.0
                        Voltage: 13.70 V
                        (no units): 55.0
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
                            Not Recogn.
       Part No SW: 4L0 910 441 A    HW: 4L0 907 441 A
       Component: J772__Rearview      0050
       Revision: --H12---    Serial number: 525PA8-J6840ZY
       Coding: 1021001
       VCID: 2411EBE3E2D3B2078DF-8070
                        Fault Frequency: 7
                        Reset counter: 83
                        Mileage: 225779 km
                        Date: 2019.12.13
                        Time: 12:58:51
                            Term 15 On
                            Reverse OFF
                        Count: 3
                        Reset counter: 43
                        Mileage: 225779 km
                        Date: 2019.12.13
                        Time: 12:59:04
                            Term 15 On
                            Reverse OFF
                        Count: 3
                013 - Check DTC Memory
                        Fault Status: 01101101
                        Reset counter: 43
                        Mileage: 225828 km
                        Date: 2006.03.15
                        Time: 12:07:48
                            Term 15 On
                            Reverse OFF
                        Count: 3
       Part No SW: 4L0 910 945     HW: 4L0 827 851 B
       Component: ValeoHeckdeckel H21 0280
       Revision: --H21001    Serial number: E5030000B
       Shop #: WSC 98765 666 38354
       Subsystem 3 - Serial number: RD09.09.06--H21001000A0050˙
       Subsystem 4 - Serial number: 0A0050˙
       Component: ILM HINTEN 2    H05 0060
       Revision: AAH05061    Serial number: 001951261-----
       Coding: 0003587
       VCID: 2615F1EB94EF401793B-8072
       Subsystem 1 - Part No: 4L0 910 591
       Component: J_245_EE15_SKB09H10 0180
       Subsystem 2 - Part No: 4L0 910 591
       Component: J_394_EE15_SKB09H10 0180
       Subsystem 3 - Part No: 4L0 910 591
       Component: J_392_EE15_SKB09H10 0180
                        Fault Frequency: 11
                        Reset counter: 83
                        Mileage: 225779 km
                        Date: 2019.12.13
                        Time: 12:59:54
    Address 72: Door, Rear Right        Labels: 4L0-910-795.lbl
       Part No SW: 4L0 910 795 B    HW: 4L0 959 794 B
       Component: TSG HR          H21 0050
       Coding: 0002058
                        Reset counter: 80
                        Mileage: 225779 km
                        Date: 2019.12.13
                        Time: 13:15:43
       Part No SW: 4F0 910 283 G    HW: 4F0 919 283 G
       Component: Parkhilfe 8-Kan H12 0060
       Revision: 00H12000    Serial number: 06330624005744
       Coding: 0221146
                        Reset counter: 80
                        Mileage: 225779 km
                        Date: 2019.12.13
                        Time: 13:00:04
                        Reset counter: 80
                        Mileage: 225779 km
                        Date: 2019.12.13
                        Time: 12:59:06
    Address 77: Telephone        Labels: 4E0-910-336.lbl
       Part No SW: 4E0 910 336 M    HW: 4E0 862 335
       Component: Handyvorb2      H18 1130
       Revision: 00000000    Serial number: 00000005101268
       Coding: 0010920
       Shop #: WSC 00583 210 82263
                        Reset counter: 83
                        Mileage: 225779 km
                        Date: 2019.12.13
                        Time: 12:59:56
    End----(Elapsed Time: 02:29, VBatt start/end: 11.8V/11.9V. VIgn 11.9V)-----
                    Address 19: CAN Gateway       Labels: 4L0-910-468.clb
    Control Module Part Number: 4L0 910 468     HW: 4L0 907 468 A
      Component and/or Version: J533__Gateway   H06 0040
               Software Coding: F557FE7F343602
                Work Shop Code: WSC 00583 210 88973
                        Reset counter: 83
                        Mileage: 225779 km
                        Date: 2019.12.13
                        Time: 13:15:43
    Jan 2020
    Thanks Uwe.
    OK, that's what I thought. It's got the old-school, 4F-style battery manager. I'm pretty sure it expects a flooded battery. That said, I've had nothing but positive experiences with installing AGM batteries in cars that don't have a battery manager at all, so if you've already got the new AGM and can't return it for the "right" battery, I'd go ahead and install it and just change the serial number of the battery in the battery manager. Doing so tells it you've installed a new battery.
  6. Likes PetrolDave, Boki Ar liked this post
    +1
    When the battery died on my B7 RS4 (no battery manager on the 8E platform!) I replaced it with an AGM battery of the same physical size with no issues, in fact it made starting much easier because of the higher CCA rating.
  8. Likes Nic_V8, Boki Ar liked this post
    Jan 2020
    Hi Uwe should i be using CAN 19 then coding 07 or 61 Battery Regulator? These are the numbers i have in each:
    CAN 19, Coding 07 - F557FE7F343602
    61 Battery Regulator - 344630393135313035442056413032363039303130343130
    Sorry for the silly questions it's my first time using VCDS. Thanks for your help.
  10. #8
    Jan 2020
    Which one contains the serial number?
  11. #9
    61-Battery Regulation. In coding, there should be drop-down, the first is for the module itself, and the second is for a virtual sub-system, the battery. Then you can use the battery coding assistant to change the serial number:
  12. #10
    Quote Originally Posted by Nic_V8 View Post
    Neither of those looks like a serial number to me. Just change the existing serial number. Change the last digit by one.
  13. Likes PetrolDave, Boki Ar liked this post
