Results 1 to 4 of 4
Thread: Looking for fuel trim parameters
    New User
    Jan 2020
    Sweden
    I've borrowed a HEX+CAN interface from a friend in order to troubleshoot on my Polo.
    The car is running really fat and thick diesel fumes coming out from the exhaust.
    Just as test I unplugged the MAF-sensor and suddenly the car runs perfectly. Of course with engine light on.
    I searched the web and wanted to check the fuel trim parameters, but I can't find them when I use the interface.
    Can anyone of you please lead me in the correct direction?
    This is the error log from the car. The MAF-sensor fault was not there before I unplugged it.
    VCDS Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: Release 19.6.2(x64) Data version: 20190930 DS308.0 www.Ross-Tech.com
    Dealer/Shop Name: Workshop Code: 000 00000 000000
    Self-Diagnosis Log Sunday,15,December,2019,10:44:59:11039
    VIN: WVWZZZ6RZAY293808 License Plate: Mileage: Repair Order:
    Chassis Type: 6R-VW25 (6N0) Scan: 01 02 03 04 08 09 10 15 17 19 25 44 56
    VIN: WVWZZZ6RZAY293808 Mileage: 136330km-84711miles
    01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: Malfunction 0010 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: OK 0000 10-Park/Steer Assist -- Status: OK 0000 15-Airbags -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 56-Radio -- Status: OK 0000
    VCDS Self-Diagnosis Log Sunday,15,December,2019,10:44:59:11039 Page 2
    Address 01: Engine (J623-CAYB) Labels:. 03L-906-023-CAY.clb
    Part No SW: 03L 906 023 AH HW: 03L 906 023 D Component: 1,6l R4 CR td H13 5692 Revision: -------- Serial number: Coding: 00254014002400080000 Shop #: WSC 124697 483 00190 ASAM Dataset: EV_ECM16TDI02103L906023AH 001004 ROD: EV_ECM16TDI02103L906023AH_001.rod VCID: 6CDC75FA87A0E82F6B-8038
    1 Fault Found: 7332 - Mass Air Flow Sensor (G70)
    P0103 00 [036] - Signal too High Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame:
    Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 0 km Date: 2000.00.00 Time: 00:00:00
    Engine speed: 0.00 /min Normed load value: 0.0 % Vehicle speed: 0 km/h Coolant temperature: 2 C Intake air temperature: 3 C Ambient air pressure: 980 mbar Voltage terminal 30: 11.068 V Unlearning counter according OBD: 40 Environmental conditions-Battery voltage: 11.9 V Environmental conditions-ANG_SP_EGRV_ENVD: 0.0 % Environmental conditions-ANG_SP_THR_ENVD: 95.7 % Environmental conditions-MAF_SP_ENVD: 239.671 mg/stroke Environmental conditions-MAF_ENVD: 0 mg/stroke
    Readiness: 1010 0000
    ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 0AM-927-769.clb Part No SW: 0AM 300 049 HW: 0AM 927 769 D Component: GSG DSG AG7 403 9030 Revision: 00040034 Serial number: TFK01005030386 Coding: 0000020 Shop #: WSC 05699 001 1048576 VCID: 6ED87FF27ABC1A3F45-5102
    VCDS Self-Diagnosis Log Sunday,15,December,2019,10:44:59:11039 Page 3
    Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
    Part No SW: 6R0 907 379 AF HW: 6R0 907 379 AF Component: ESP8.2i front H05 0005 Revision: -------- Coding: 210228E3417600B5842D14E282D900421300 Shop #: WSC 02069 000 00000 VCID: 02003B4299240E5FB1-8056
    1 Fault Found: 01314 - Engine Control Module
    Fault Status: 00101101 Fault Priority: 0 Fault Frequency: 5 Reset counter: 134 Mileage: 136320 km Time Indication: 0 Date: 2014.04.17 Time: 13:01:47
    Hex Value: 0x4007 Hex Value: 0x0000 Hex Value: 0x3107 Hex Value: 0x1395 Hex Value: 0x0069 Hex Value: 0x7F7F Hex Value: 0x7C2F
    VCDS Self-Diagnosis Log Sunday,15,December,2019,10:44:59:11039 Page 4
    Address 08: Auto HVAC (J301) Labels: 6R0-820-045-9AP.clb
    Part No SW: 6R0 820 045 J HW: 6R0 820 045 J Component: Climatic 24 0660 Revision: 00 10 24 VCID: 356A909E9C6A69E744-8060
    1 Fault Found: 16350 - Control Module - Self-Test Error
    Fault Status: 00100011 Fault Priority: 2 Fault Frequency: 254 Reset counter: 134 Mileage: 96196 km Time Indication: 0 Date: 2011.12.23 Time: 19:47:41
    ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
    Part No SW: 6R0 937 087 D HW: 6R0 937 087 D Component: BCM PQ25 H+4 H46 0207 Revision: BF046001 Serial number: 0147 126101244 Coding: 24B02BBF08A10000003000003D2B0DD00080410F60040000200000000000 Shop #: WSC 124697 483 00190 VCID: 3E788FB2A95CAABF95-806A
    Subsystem 1 - Part No SW: 6R0 959 801 R HW: 6R0 959 801 R Labels: 6R0-959-801.CLB Component: J386__TSG_FT 006 0903 Serial number: KU0-KU029.04.1011192 Coding: 18BC30
    Subsystem 2 - Part No SW: 6R0 959 802 T HW: 6R0 959 802 T Labels: 6R0-959-802.CLB Component: J387__TSG_BT 006 0902 Serial number: KU0-KU030.04.1013750 Coding: 08BC30
    Subsystem 3 - Part No SW: 6R0 959 811 F HW: 6R0 959 811 F Component: J388__TSG_HL 006 0902 Serial number: KU0-KU027.04.1017893 Coding: 08BC32
    Subsystem 4 - Part No SW: 6R0 959 812 F HW: 6R0 959 812 F Component: J389__TSG_HR 006 0902 Serial number: KU0-KU028.04.1011432 Coding: 08BC32
    VCDS Self-Diagnosis Log Sunday,15,December,2019,10:44:59:11039 Page 5
    Address 10: Park/Steer Assist (J446) Labels:| 6R0-919-475.clb
    Part No SW: 6R0 919 475 HW: 6R0 919 475 Component: PARKHILFE 4K H07 0008 Revision: -------- Serial number: 71391010646886 Coding: 100101 Shop #: WSC 124697 483 00190 ASAM Dataset: EV_VW250ParkiAssis2 S01006 ROD: EV_VW250ParkiAssis2.rod VCID: 7BFE46A6F2CE7F97F2-802E
    ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
    Part No SW: 6R0 959 655 D HW: 6R0 959 655 D Component: VW10Airbag008 H09 0018 Revision: -------- Serial number: 003DX0012BAU Coding: 003038 Shop #: WSC 124697 483 00190 ASAM Dataset: EV_AirbaVW10BPAVW250 A01001 ROD: EV_AirbaVW10BPAVW250.rod VCID: 438EFE46CABEC757FA-8016
    Crash sensor for side airbag: driver side: Serial number: 3572SRB40000B7D48179
    Crash sensor for side airbag: front passenger side: Serial number: 3582SRB40000B7B47AFO
    Crash sensor for side airbag: rear: driver side: Serial number: 3516GRB402VET2JSM3U
    Crash sensor for side airbag: rear: passenger side: Serial number: 3526GRB402VET2JTAC8F
    ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
    Part No SW: 6R0 920 861 D HW: 6R0 920 861 D Component: KOMBI H13 0024 Serial number: 00000002321846 Coding: 140E00 Shop #: WSC 124697 483 00190 ASAM Dataset: EV_DashBoardUDSJCIPQ25 A01004 ROD: EV_DashBoardUDSJCIPQ25_A01.rod VCID: 36689792896C62FF4D-8062
    VCDS Self-Diagnosis Log Sunday,15,December,2019,10:44:59:11039 Page 6
    Part No SW: 6N0 909 901 HW: 6R0 937 087 D Component: GW-K-CAN TP20 0207 Coding: 002200 Shop #: WSC 124697 483 00190 VCID: 70E4618AA3880CCF57-8024
    ------------------------------------------------------------------------------- Address 25: Immobilizer (J285) Labels:. 5K0-920-xxx-25.clb
    Part No SW: 6R0 920 861 D HW: 6R0 920 861 D Component: IMMO H13 X005 Serial number: ASAM Dataset: EV_ImmobUDSJCIPQ25 A01001 ROD: EV_ImmobUDSJCIPQ25.rod VCID: 36689792896C62FF4D-8062
    ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 6Q0-423-156.clb
    Part No: 6R0 423 156 B Component: LenkhilfeTRW V277 Coding: 11230 Shop #: WSC 00000 VCID: 2F66A2F6EA3653370E-807A
    ------------------------------------------------------------------------------- Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb Part No SW: 5M0 035 186 AA HW: 5M0 035 186 AA Component: Radio RCD310 016 0049 Revision: 00000000 Serial number: VWZ1Z2K7105020 Coding: 0500040002 Shop #: WSC 124697 483 00190 VCID: 6BDE76E68AAEEF1762-803E
    End-------------------------(Elapsed Time: 02:46)--------------------------
    I'm not sure what you did that stripped most of the Newline characters from that text, but the above is basically illegible.
    New User
    Jan 2020
    Sweden
    Hi again,
    and sorry for the late reply.
    I had to borrow the interface again since I couldn't get the report printed properly.
    So this is how it looks. The first part is a dump directly from the car, after that I erased DTC's and created another report, which is the second part.
    The MAF has been replaced and the error it is given below is because I had it unplugged when I went for a testrun. The car runs really good without it connected.
    Sunday,15,December,2019,10:51:33:11039
    VCDS Version: 19.6.2.0 (x64)
    Mileage: 136330km-84711mi   Repair Order:
    Readiness Status: 1010 0000
    Exhaust Gas Recirculation: Failed or Incomplete
    Oxygen Sensor Heating: Passed
    Oxygen Sensor(s): Failed or Incomplete
    Air Conditioning: Passed
    Secondary Air Injection: Passed
    Evaporative Emissions: Passed
    Catalyst Heating: Passed
    Catalytic Converter(s): Passed
    Monday,17,February,2020,12:05:53:11039
    VCDS Version: 19.6.2.2 (x64)
       VCID: 6CDC75FA87A0E82F69-8038
                        Mileage: 136334 km
                        Date: 2020.01.15
                        Time: 10:40:37
                        Engine speed: 900.00 /min
                        Normed load value: 43.9 %
                        Coolant temperature: 10 C
                        Intake air temperature: 8 C
                        Voltage terminal 30: 14.118 V
                        Environmental conditions-Battery voltage: 10.6 V
                        Environmental conditions-MAF_SP_ENVD: 234.224 mg/stroke
    Readiness: 0010 0000
       VCID: 6ED87FF27ABC1A3F47-5102
       Revision: --------
       VCID: 02003B4299240E5FB3-8056
                        Reset counter: 135
                        Mileage: 136334 km
                        Date: 2014.06.07
                        Time: 10:40:38
                        Hex Value: 0x0000
                        Hex Value: 0x0000
                        Hex Value: 0x3207
                        Hex Value: 0x13B5
                        Hex Value: 0x007D
                        Hex Value: 0x7F7F
                        Hex Value: 0x7F00
       Revision: 00 10 24
       VCID: 356A909E9C6A69E746-8060
                        Fault Frequency: 58
                        Reset counter: 135
                        Mileage: 136334 km
                        Date: 2014.05.07
                        Time: 11:50:49
       VCID: 3E788FB2A95CAABF97-806A
       Coding: 18BC30
       Coding: 08BC30
       Coding: 08BC32
       Coding: 08BC32
       Coding: 100101
       VCID: 7BFE46A6F2CE7F97F0-802E
       Coding: 003038
       VCID: 438EFE46CABEC757F8-8016
       Coding: 140E00
       VCID: 36689792896C62FF4F-8062
       Coding: 002200
       VCID: 70E4618AA3880CCF55-8024
       Coding: 11230
       VCID: 2F66A2F6EA3653370C-807A
       Coding: 0500040002
       VCID: 6BDE76E68AAEEF1760-803E
    03138 - Input AUX IN
                        Reset counter: 94
                        Mileage: 136334 km
                        Date: 2014.05.07
                        Time: 11:52:21
    End-------------------------(Elapsed Time: 02:52)--------------------------
    Monday,17,February,2020,12:20:53:11039
       VCID: 6ED87FF27ABC1A3F47-50E6
       Revision: --------
                        Reset counter: 135
                        Mileage: 136334 km
                        Date: 2014.06.07
                        Time: 10:40:38
                        Hex Value: 0x0000
                        Hex Value: 0x0000
                        Hex Value: 0x3207
                        Hex Value: 0x13B5
                        Hex Value: 0x007D
                        Hex Value: 0x7F7F
                        Hex Value: 0x7F00
       Revision: 00 10 24
                        Fault Frequency: 58
                        Reset counter: 135
                        Mileage: 136334 km
                        Date: 2014.05.07
                        Time: 11:50:49
       Coding: 18BC30
       Coding: 08BC30
       Coding: 08BC32
       Coding: 08BC32
       Coding: 100101
       Coding: 003038
       Coding: 140E00
       Coding: 002200
       Coding: 11230
       Coding: 0500040002
                        Reset counter: 94
                        Mileage: 136334 km
                        Date: 2014.05.07
                        Time: 11:52:21
    End-------------------------(Elapsed Time: 02:42)--------------------------
    This being a diesel, the concept of fuel trim doesn't really apply. A gasoline engine controls power based on the amount of air allowed into the engine via the throttle. The engine management measures airflow directly, or calculates it indirectly, and supplies an what it thinks is an appropriate amount of fuel. It then measures the amount of oxygen in the exhaust and "trims" the amount of fuel being supplied to maintain the correct fuel/air mixture.
    A diesel works differently. Traditionally, they ran completely un-throttled, getting full airflow at all times, and the amount of power they produced was controlled by fuel flow. The problem with this is that it results in a very lean mixture under all conditions except full power output, and this produces lots of NOx emissions. The "fix" for that is to replace a good bit of the air that the engine would normally pull in with recirculated exhaust gas. In order to control this precisely, "throttles" we added to diesel engines as well, but they don't perform the same function in a diesel; they still don't control the power output; they just control (restrict) the amount of excess oxygen present during combustion. Thus a diesel trims air, not fuel.
  5. Likes PetrolDave, Bruce liked this post
