Results 1 to 3 of 3
Thread: Reported ROD file missing
    Aug 2018
    Ireland
    Per title,
    Wednesday,22,January,2020,20:12:32:34893
    VCDS Version: 19.6.2.0 (x64)  HEX-V2 CB: 0.4513.4
    VIN: WV1ZZZ2HZCA072939   License Plate: 12MO2775
    Chassis Type: 2H-VN81 (6N0)
    Scan: 01 03 08 09 10 15 17 19 22 25 37 56 69
    Address 01: Engine (J623-CDCA)       Labels:. 03L-906-022-CAA.clb
       Part No SW: 03L 906 019 FA    HW: 03L 907 309 K
       Component: R4 2,0L EDC   H43 9745
       Revision: 26H43---    Serial number: 00000000000000
       Coding: 01194012232600080000
       Shop #: WSC 65535 000 00000
       ASAM Dataset: EV_ECM20BTD01103L906019FA 002005
       ROD: EV_ECM20BTD_002_VN81.rod
       VCID: 6FBBD185B71588AF20D-803A
    4875 - Coolant Pump 2
              P261A 00 [032] - Open circuit
                        Mileage: 255859 km
                        Date: 2085.14.15
                        Time: 14:21:01
                        Engine speed: 873.00 /min
                        Normed load value: 38.8 %
                        Vehicle speed: 1 km/h
                        Coolant temperature: 39 °C
                        Intake air temperature: 10 °C
                        Ambient air pressure: 1030 mbar
                        Voltage terminal 30: 14.200 V
                        Unlearning counter according OBD: 33
                        Coolant temperature at radiator outlet: actual value: 5.7 °C
                        Bypass valve for EGR cooler: status-Bits 0-7: 00000000
                        exh.gas recirc.: shut-off conditions-Bits 0-7: 00000000
                        EGR cooling function: status-Bits 0-7: 00000000
                        exh.gas recirc. (EGR) cooler pump: specified value: 69.32 %
                        Temp sensor for EGR after cooler: raw value: -270.6 °C
                        Exh.gas temp.sen 1: 91.8 °C
    Readiness: 0 0 0 0 X
    Address 03: ABS Brakes (-----)       Labels: 2H0-907-37x-ESP.clb
       Part No SW: 2H0 907 379 J    HW: 2H0 907 379 D
       Component: ESP MK25A XT  H44 0109
       Revision: 00H44001
       Coding: C07324B6919B039724AB89A6AF5990
       Shop #: WSC 07456 790 49164
       VCID: 372B29E58F45006F38D-8062
                        Reset counter: 100
                        Mileage: 249208 km
                        Date: 2018.14.31
                        Time: 17:22:37
                        Count: 16384
                        Count: 4097
                        Count: 8239
                        Count: 1022
    Address 08: Auto HVAC (J255)       Labels:| 7E5-907-040.clb
       Part No SW: 2H0 907 040 C    HW: 2H0 907 040 C
       Component: ClimatronicT5 H18 0404
       Revision: 00001002
       Coding: 0000000002
       Shop #: WSC 07456 790 50316
       ASAM Dataset: EV_ClimatronicT5 A01003
       ROD: EV_ClimaAutoT5Basis.rod
       VCID: 211FE7BD31416EDFE69-8074
              U1111 00 [008] - -
              [Motorsteuergerät - kein Signal/Kommunikation]
                        Reset counter: 100
                        Mileage: 249208 km
                        Date: 2082.14.31
                        Time: 17:31:06
    9481988 - Air Quality Sensor
              B10AF 04 [008] - Internal System Fault
                        Reset counter: 69
                        Mileage: 255214 km
                        Date: 2084.14.20
                        Time: 19:11:39
    9477872 - AC Compressor First Run-In
              B109E F0 [009] - Not Performed
                        Reset counter: 60
                        Mileage: 249208 km
                        Date: 2082.14.31
                        Time: 17:31:06
       Part No SW: 6R7 937 087 K    HW: 6R7 937 087 K
       Component: PQ25 BCM      H27 0532
       Revision: -1------    Serial number: 1009009900
       Coding: 3D0002380C410400923808100C4B84D50080410E60000000300000000000
       Shop #: WSC 22002 758 00808
       VCID: 4CC16609E6C393B765F-8018
       Subsystem 1 - Part No SW: 6R0 959 802 M    HW: 6R0 959 802 M  Labels: 6R0-959-802.CLB
       Component: J386__TSG_FT  002 3321
       Coding: 110000
       Subsystem 2 - Part No SW: 6R0 959 801 P    HW: 6R0 959 801 P  Labels: 6R0-959-801.CLB
       Component: J387__TSG_BT  002 3321
       Coding: 110000
       Subsystem 3 - Part No: 1K8 951 171 A
       Component: DWA-Sensor      001  001 0103
       Component: LIN BACKUP HORN H11  H11 9005
       Subsystem 5 - Part No: 1K8 951 171 A
       Subsystem 6 - Part No SW: 5K0 959 542 C    HW: 5K0 959 542 C
       Component: E221__MFL-TAS  H31 0033
       Serial number: 0083985
       Coding: 020000
       Subsystem 7 - Part No SW: 6R0 959 811 D    HW: 6R0 959 811 D
       Component: J388__TSG_HL  002 3321
       Coding: 100000
       Subsystem 8 - Part No SW: 6R0 959 812 D    HW: 6R0 959 812 D
       Component: J389__TSG_HR  002 3321
       Coding: 100000
                        Fault Frequency: 11
                        Reset counter: 41
                        Mileage: 255724 km
                        Date: 2020.14.27
                        Time: 10:35:30
    03302 - Response Closing Status of Passenger's Door
                        Reset counter: 45
                        Mileage: 256122 km
                        Date: 2021.14.18
                        Time: 09:21:13
    Address 10: Park/Steer Assist (J446)       Labels:| 7E0-919-475.clb
       Part No SW: 7E0 919 475 D    HW: 7E0 919 475
       Component: PARKHILFE 4K  H11 0013
       Revision: --------    Serial number: 47361206901440
       Coding: 118003
       Shop #: WSC 53863 115 183226
       ASAM Dataset: EV_VW75XParkAssis4K A01006
       ROD: EV_VW75XParkAssis4K_A01.rod
       VCID: 33331DF59BBDEC4F045-8066
    1079572 - Rear Right Parking Aid Sensors
              B1079 14 [009] - Open or Short to Ground
                        Reset counter: 60
                        Mileage: 249208 km
                        Date: 2082.14.31
                        Time: 17:47:46
       Part No SW: 2H0 959 655 B    HW: 2H0 959 655 B
       Component: VW10Airbag00M H07 0013
       Revision: --------    Serial number: 003HN007ZWVJ
       Coding: 00000000000000000000000000000000304D
       Shop #: WSC 07446 790 50316
       Serial number: 3495RRB404P126SE8OH4
       Serial number: 3505RRB404P126SEFGS6
       Serial number: 3555YRB405D15A9MC94C
       Serial number: 3565YRB405B14E7CB8LH
    Address 17: Instruments (J285)       Labels:. 5K0-920-xxx-17.clb
       Part No SW: 2H0 920 963 B    HW: 2H0 920 963 B
       Component: KOMBI         H02 0505
       Coding: 450A00
       ASAM Dataset: EV_Kombi_c˙_VDD_RM09 A04114
       ROD: N/A
       VCID: 290FFF9D4971A69FBE9-807C
    No ASAM data for: "EV_Kombi_c˙_VDD_RM09" (VW36 *)
       Part No SW: 6N0 909 901     HW: 6R7 937 087 K
       Component: GW-K-CAN TP20 H27 0532
       Revision: -1------
       Coding: 742300
       Shop #: WSC 07462 790 50316
       VCID: 70B9D2F9AAAB9757397-8024
       Part No SW: 2H0 927 755 C    HW: 2H0 927 755 C
       Component: SG offroad VTG      0155
       Revision: 00H07000    Serial number: T1IYC114213K1X
       Coding: 0000013
       VCID: 303912F9662BD757797-8064
       Component: IMMO          H02 0505
       Shop #: WSC 00078 790 12345
       VCID: 6A8DC0918CF76D87773-803E
       Part No SW: 3C0 035 279 H    HW: 3C0 035 279 H
       Component: RNS315-EU   H36 0263
       Serial number: VWZAZ2M3977476
       Coding: 000004110200160000031002
       ASAM Dataset: EV_RNS315EUV2UDS A01004
       ROD: EV_RNS315EUV2UDS.rod
       VCID: 2809FA99527B9F97A17-807C
       Component: EUR_W_0038  0038
       Revision: 3A001001    Serial number: 00008030130770
       Coding: 0100000100000000
       VCID: 303912F96A2BD757797-8064
    02562 - Trailer; Brake Lamps
                        Fault Status: 11101010
                        Reset counter: 252
                        Mileage: 255950 km
                        Date: 2021.14.16
                        Time: 18:08:10
    02563 - Trailer; Right Tail Lamps (M61)
                010 - Open or Short to Plus - Intermittent - MIL ON
                        Fault Status: 10101010
                        Reset counter: 37
                        Mileage: 255950 km
                        Date: 2021.14.16
                        Time: 18:08:10
    02564 - Trailer; Left Tail Lamps (M60)
                        Reset counter: 252
                        Mileage: 255950 km
                        Date: 2021.14.16
                        Time: 18:08:11
    End----------(Elapsed Time: 01:02, VBatt start/end: 13.7V/13.6V)-----------
    No, sorry, "EV_Kombi_c˙_VDD_RM09" is not a valid ASAM Dataset name. We've seen this before. It seems to be a prank that the VDO programmers played on people who "manipulate" these clusters using certain back-door techniques.
  3. Likes PetrolDave, Eric, BavarianCare liked this post
    Aug 2018
    Ireland
    Interesting.
    It is very possible this Amarok was 'clocked'. He has nothing but problems with it for past year.
