Mk60EC1 abs module long coding
TeeleCymn
Pirate
Walking the Plank
Lesotho
Can someone please help me with Mk60EC1 abs module long coding, for MKV GTI Pirelli 2009 model. I recently changed the module but when i paste the old module long coding, it rejects it. The module part no is 1K0907379AE hardware version H35. Vin WVWZZZ1KZ9W143226. Its a 4cylinder gasoline, RHD, FWD, its 2.0TFSI BYD, with no start-stop and has TPMC.
TeeleCymn
Pirate
Walking the Plank
Lesotho
Removed.   Data from a clone/pirate copy of VCDS is not acceptable here.
PetrolDave
Westbury, UK
C?ID=1423
VCDS Version: 18.9.0.2 (x64)
Please update to the latest VCDS version (currently 19.6.2) which is a free download, and post an updated scan.
Ashley SA
New Member
South Africa
Hi Guys, can someone assist, my abs pump failed, cannot retrieve old long coding, its a 2009 golf 5 gti, right hand drive in SA, old controller module 1K0907379AD, ive replaced it with controller module 1K0907379BJ, I need long coding,
Vin AAVZZZ1KZ9U009466
In this section of the forum? Almost certainly not. ;)
busterboy
C?ID=383133
Newer software versions are getting cloned, not just the old chestnut of 12.12 :banghead:
Sadly still happening all over the Facebook Market Place.
AINils
Germany (AIB)
C?ID=56975
I'll get eye cancer if I see this bad quality clones......... :banghead:
Is it possible that people are stupid enough to buy this.....
I think there are very few cases where people buy something like this and they don't know it's pirated clone. If you watch eBay at all, it's clear that most people understand the difference between a clone and a legitimate interface. Legitimate interfaces bring good money, even the older, quasi-obsolete ones. But clones only sell if they're cheap.
PetrolDave
Westbury, UK
C?ID=1423
Sadly, yes. There are still people who don't understand that if something looks to good/cheap to be true it IS too good to be true :facepalm:
NZDubNurd
New Zealand
C?ID=230482
I like the clones that put extra 0's in the BCM coding :D The more you try to "fix" it - the worse it gets ;)
I suspect that a chunk of the people who buy the clones are the same ones that get codes for O2 sensors and MAF's, so replace all the sensors and MAF; only to have the same issue, so replace the ECU (it MUST be faulty! Right?) and then send it away for immo off so it will run, replace it, only to find it still has the problem... but don't notice there is a cracked $20 breather hose :thumbs:
Then try to change the BCM coding ;)
Bruce
Near Philadelphia, PA, USA
I like that clones mess up cars... I like that clone users spend more to fix their cars... it creates market value for the real product. Eventually I think the more serious clone users get tired of the shenanigans and they come around and say, "Hmm... maybe there is something to that legitimate Ross-Tech device..." Then they are ready to plop down the real coin for the real value. Its a longer road to RT success but it's still a road.
AINils
Germany (AIB)
C?ID=56975
Sometimes Iam a little bit happy of clone.... More Customer for me..... :rolleyes: I told a lot of clone user to buy a new one after BCM or ABS restore Coding, most of them understand it
