Results 1 to 4 of 4
Thread: Audi a6 Allroad problem coding
Hybrid View
    Sep 2018
    Bulgaria
    hi, i have here audi a6 2006 allroad. In the menu for Level Control is only 4 options not like allroad suspension with 5 position. I cant find what is changed to miss the 5 position in the menu. any ideas will be great
    Thursday,03,October,2019,16:32:20:55583
    VCDS Version: 19.6.1.0  HEX-NET CB: 0.4513.4
    VIN: WAUZZZ4F96N111106   License Plate:
    Mileage: 212330km-131935mi   Repair Order:
    Gateway Installation List:  4F0 910 468 A
    55-Headlight Range -- Status: Not registered 0001
    Thursday,03,October,2019,16:53:48:55583
    Chassis Type: 4F (4F0)
    Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 34 37 42 46 47 4F 52 53
              55 56 61 62 69 6D 72 77
    VIN: WAUZZZ4F96N111106   Mileage: 212330km-131935miles
       Part No SW: 4F0 910 402 N    HW: 4F0 907 401 B
       Component: 3.0L V6TDI  G000AG  0020
       Revision: --H01---    Serial number:
       Coding: 0011372
       Shop #: WSC 66565 257 00032
       VCID: 281C01969B2A040FF1-807C
                   P1653 - 002 -
                        Fault Status: 01100010
                        Mileage: 211914 km
                        Date: 2020.01.15
                        Time: 14:00:03
                        RPM: 756 /min
                        Torque: 66.3 Nm
                        Duty Cycle: 1.0 %
                        Voltage: 13.98 V
                        Bin. Bits: 00001100
                        Torque: 179.4 Nm
    006217 - Please check DTC Memory of Transmission Controller
                   P1849 - 008 -  - Intermittent
                        RPM: 63 /min
                        Torque: 226.2 Nm
                        (no units): 0.0
                        Voltage: 5.93 V
                        Torque: 581.4 Nm
       Part No SW: 4F1 910 156 B    HW: 09L 927 156 A
       Component: AG6 09L 3,0 TDI RdW 0050
       Revision: --H01---    Serial number:        4110781
       Coding: 0000001
       Shop #: WSC 19460 666 12345
       VCID: 230616BAE20CE757A4-8076
    Address 03: ABS Brakes        Labels: 4F0-910-517.clb
       Part No SW: 4F0 910 517 L    HW: 4F0 614 517 L
       Component: ESP 8.0 quattro H04 0090
       Coding: 0000396
       Shop #: WSC 02325 785 00200
       VCID: 2D12F082B4C8212702-8078
                        Reset counter: 3
                        Mileage: 212332 km
                        Date: 2020.01.22
                        Time: 14:50:08
                        Hex Value: 0x0000
                        Hex Value: 0x4282
                        Hex Value: 0x0024
                        Hex Value: 0x01AD
                        Hex Value: 0x00FF
       Part No SW: 4F0 910 852 B    HW: 4F0 905 852 E
       Component: FBSAUDIC6 ELV   H08 0210
       Revision: 00H08000    Serial number: 10604102225377
       Coding: 0000131
       Shop #: WSC 01114 002 1048576
       VCID: 250208A2EC381967CA-8070
       Component: FBSAUDIC6 EZS   H45 0070
       Component: FBSAUDIC6 IDG   H39 0040
    Address 07: Control Head        Labels: 4F0-910-7xx-07-H.clb
       Part No SW: 4F0 910 730 F    HW: 4E0 035 729
       Component: Interfacebox    H43 2120
       Revision: 00000000    Serial number: 350K-057617955
       Coding: 0012002
       Shop #: WSC 95417 954 999999
       VCID: 240415A6E702E06FDD-8070
       Component: Bedienteil MMIC6H08 0050
       Subsystem 2 - Serial number: 00000000273784
       Subsystem 3 - Serial number: 0109.11.050000000100010659˙
       Subsystem 4 - Serial number: 010659˙
    Address 08: Auto HVAC        Labels: 4F0-910-043.clb
       Part No SW: 4F0 910 043     HW: 4F1 820 043 S
       Component: KLIMABETAETIGUNGH12 0160
       Revision: 00000027    Serial number: 00000000204048
       Coding: 0000374
       VCID: 5BF66E5A9AFC9F97AC-800E
       Part No SW: 4F0 910 279 D    HW: 4F0 907 279
       Component: ILM Fahrer      H15 0190
       Coding: 0012121
       Shop #: WSC 02335 785 00200
       VCID: 2A18FB9E8526361FE7-807E
       Subsystem 1 - Part No: 4F1 910 113   Labels: 1KX-955-119.CLB
       Component: Wischer AudiC6  H05 0150
       Coding: 00062736
       Shop #: WSC 02335
       Subsystem 2 - Part No: 4E0 910 557   Labels: 8K0-955-559.CLB
       Coding: 00141886
       Shop #: WSC 02335
       Part No SW: 4E0 910 111 F    HW: 4E0 035 111 A
       Component: CD-Changer      H44 0470
       Revision: 00000000    Serial number: AUZ5ZBE8015649
       VCID: 1C742D46DF72D8AF65-8048
    Address 15: Airbags        Labels: 4F0-910-655-8R.clb
       Part No SW: 4F0 910 655 E    HW: 4F0 959 655 B
       Component: 43 AIRBAG AUDI8RH29 0260
       Revision: 07H29000    Serial number: 0037LD0B0E3T
       Coding: 0013363
       VCID: 291A049280203D07EE-807C
       Subsystem 1 - Serial number: 6332CSME0C6464575
       Subsystem 2 - Serial number: 6342CSME0C644D2DG
       Subsystem 3 - Serial number: 6352QSME0250161F7
       Subsystem 4 - Serial number: 6362QSME06371D0BJ
       Subsystem 5 - Serial number: 63734SME024E0729$
       Subsystem 6 - Serial number: 63834SME024E77171
       Part No SW: 4F0 910 549     HW: 4F0 953 549 A
       Component: Lenksäulenmodul H07 0230
       Revision: 00H07000    Serial number: 90026053090227
       Coding: 0002142
       Shop #: WSC 02323 785 00200
       VCID: 66804FAE51BED27F03-8032
       Component: Lenkradmodul    H07 0090
    Address 17: Instruments        Labels: 4F0-910-xxx-17.lbl
       Part No SW: 4F0 910 930 A    HW: 4F0 920 931 F
       Component: KOMBIINSTR. M73 H16 0670
       Revision: 00200000    Serial number: 4PV7149C5
       Coding: 2081003
       VCID: 210A1CB2F810F547B6-8074
    Address 19: CAN Gateway        Labels:. 4F0-910-468.clb
       Part No SW: 4F0 910 468 A    HW: 4F0 907 468 D
       Component: Gateway         H11 0070
       Revision: 11          Serial number: 1300805B13012F
       Coding: 6DFE5BC41B3106
       VCID: 271E02AA96340B77F8-8072
                        Reset counter: 3
                        Mileage: 212332 km
                        Date: 2020.01.22
                        Time: 14:35:16
    Address 34: Level Control        Labels: 4F0-910-553.clb
       Part No SW: 4F0 910 553     HW: 4F0 907 553
       Component: J197 LUFTFEDER  H15 0040
       Serial number: 006280018540
       Coding: 0000220
       VCID: 618A5CB2B890B547F6-8034
    01316 - ABS Control Module
                        Fault Status: 11101101
                        Reset counter: 3
                        Mileage: 212332 km
                        Date: 2020.01.22
                        Time: 14:35:11
       Part No SW: 4E0 910 888 P    HW: 4E0 919 887 D
       Component: MNS ECE         H48 1060
       Revision: 00000000    Serial number: 364GT067576303
       Shop #: WSC 08744 264 88789
       VCID: 3B36CEDA7ABCBF978C-806E
    02927 - DVD Read Error
                        Reset counter: 42
                        Mileage: 212319 km
                        Date: 2020.01.21
                        Time: 11:12:51
                        Hex Value: 0x5E26
                        Hex Value: 0xDCEE
                        Hex Value: 0x0401
                        Hex Value: 0x0000
    Address 42: Door Elect, Driver        Labels: 4F0-910-793-42.lbl
       Part No SW: 4F0 910 793 E    HW: 4F0 959 793 E
       Component: TSG FA          H12 0080
       Revision: 00-00000
       Coding: 0001642
       Shop #: WSC 02327 785 00200
       VCID: 2C14FD868FD2282F15-8078
    Address 46: Central Conv.        Labels:. 4F0-910-289.lbl
       Part No SW: 4F0 910 289 B    HW: 4F0 907 289 B
       Component: Komfortgeraet   H18 0130
       Revision: 01300018    Serial number: 01007823600000
       Coding: 3285637
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 2
                        Mileage: 212120 km
    Address 47: Sound System        Labels: 4F0-910-223-AS.lbl
       Part No SW: 4F0 910 223 C    HW: 4F0 035 223
       Component: Amp.-ASK        H10 0320
       Revision: 34S00001    Serial number: 00404060251551
       Coding: 0000102
       Shop #: WSC 20995 000 1048576
       VCID: 1E70274EC96ECABF8B-804A
       Part No SW: 4F0 910 280     HW: 4F0 907 280
       Component: ILM Beifahrer   H10 0080
       Revision:             Serial number: 00000000099314
       Coding: 0001003
       VCID: 5EF0674E89EE8ABFCB-800A
    Address 52: Door Elect, Pass.        Labels: 4F0-910-793-52.lbl
       Part No SW: 4F0 910 793 E    HW: 4F0 959 792 E
       Component: TSG BF          H12 0080
       Revision: 00-00000
       Coding: 0001642
       Part No SW: 4F0 910 801     HW: 4F0 907 801
       Component: EPB  C63C0030   H03 0030
       Revision: C63C0030
       Coding: 0000321
       Shop #: WSC 02334 785 00200
       VCID: 5DF2604284E891A7D2-8008
       Part No: 8P0 907 357 F
       Coding: 0000004
       VCID: 3D32C0C264A8B1A7B2-8068
                        Fault Status: 11101010
                        Reset counter: 3
                        Mileage: 212328 km
                        Date: 2020.01.22
                        Time: 14:35:12
                        Reset counter: 3
                        Mileage: 212328 km
                        Date: 2020.01.22
                        Time: 14:35:12
       Part No SW: 4E0 910 541 L    HW: 4F0 035 541 E
       Component: TUNER EU/US/RDW H42 0560
       Revision: 00000000    Serial number: 352K 057596931
       Coding: 0000001
    Address 61: Battery Regul.        Labels: 4F0-910-181.lbl
       Part No SW: 4F0 910 181 E    HW: 4F0 915 181 A
       Component: J0644 BEM       H12 0590
       Revision: 00000000    Serial number: 00000000153713
       Shop #: WSC 06348 116 57033
       Component: von TU3  2511070827
       Coding: 344630393135313035442054553332353131303730383237
       Shop #: WSC 12345 384 00290
    Address 62: Door, Rear Left        Labels: 4F0-910-795.lbl
       Part No SW: 4F0 910 795 E    HW: 4F0 959 795 E
       Component: TSG HL          H21 0050
       Coding: 0001066
       VCID: 2E10F78EB9CE5A3F3B-807A
    Address 69: Trailer        Labels: 4F0-910-383.lbl
       Part No SW: 4F0 910 383     HW: 4F0 907 383
       Component: ANHAENGERELEKTR H02 0020
       Coding: 0000331
       VCID: 628853BEBD96AE5FEF-8036
    Address 6D: Trunk Elect.        Labels: Redir Fail!
       Part No SW: 4F9 910 591     HW: 4F9 827 851 F
       Component: ValeoHeckdeckel H25 0290
       Revision: --H25001    Serial number: E5030000B
       VCID: 6C943D864F52E82F55-8038
       Subsystem 1 - Part No: 4F9 910 592
       Component: ValeoHeckdeckel H18 0280
       Subsystem 3 - Serial number: RD08.11.05--H18001001A0043˙
       Subsystem 4 - Serial number: 1A0043˙
    00317 - Rear Lid Control Module (J605)
                        Reset counter: 23
                        Mileage: 207396 km
    Address 72: Door, Rear Right        Labels: 4F0-910-795.lbl
       Part No SW: 4F0 910 795 E    HW: 4F0 959 794 E
       Component: TSG HR          H21 0050
       Coding: 0001066
    Address 77: Telephone        Labels: 4E0-910-336.lbl
       Part No SW: 4E0 910 336 L    HW: 4E0 862 335
       Component: Handyvorb2      H20 1120
       Revision: 00000000    Serial number: 00000005194401
       Coding: 0010930
       Shop #: WSC 00316 223 90254
       VCID: 2B16FE9A8ADC2F171C-807E
    End----------(Elapsed Time: 01:49, VBatt start/end: 14.0V/14.0V)-----------
    Moving to Tweaks.
    Dec 2016
    DE
    Does the car have the Allroad parameters? If not, there is no way to enable the Allroad suspension mode.
    You can test incrementing apk 66 in module 09 by 32 and see if this changes anything.
    Sep 2018
    Bulgaria
    All is ok the car is like s6 with air suspension, it move up and down ok. But the highest position is missing from the menu
