Results 1 to 7 of 7
Thread: VW Tiguan 2014 - ABS-Traction- TPM
    Oct 2019
    Malawi
    Hi Guys,
    i have just received this car into my auto shop, before it came to me it was with the dealers. The ABS, Traction, and TPM lights all showing on the dash. According to the client the dealers REPLACED the ABS CONTROL MODULE and it still showing the warning lights. Any Ideas?
    below is a report generated:
    Wednesday,22,January,2020,11:27:35:13642
    VIN: WVGZZZ5NZFW046220   License Plate: MJ 2715
    Mileage: 81720km-50778mi   Repair Order:
    Chassis Type: 5N-VW36 (7N0)
    Scan: 01 02 03 08 09 10 15 16 17 19 1C 22 25 2E 42 44 46 4C 52 53
              56 62 72
    VIN: WVGZZZ5NZFW046220   Mileage: 81720km-50778miles
    Address 01: Engine (CCZ)       Labels:. 06J-907-115-CCZ.clb
       Part No SW: 06J 906 027 CB    HW: 06J 907 309 A
       Component: MED17.5.2        04 2134
       Revision: P3H07---    Serial number:
       Coding: 04230010240F0060
       VCID: 6D8633929192AACF121-8038
    Readiness: 0000 0001
       Part No SW: 0BH 300 012 B    HW: 0BH 927 711 C
       Component: DSG DQ500-7A  H08 2234
       Revision: 00H08V01
       ROD: EV_TCMDQ500021_VW36.rod
       VCID: 221C10AE144CA5B7FF3-8076
    Address 03: ABS Brakes        Labels: 5N0-614-109-C6.clb
       Part No SW: 5N0 614 109 BN    HW: 5N0 614 109 BN
       Component: J104   C6 450M VDF7 0021
       Revision: --H07---    Serial number: 00000008633922
       Coding: 0007712
       Shop #: WSC 44409 002 1048576
       VCID: 78A812C6EED01F67F17-802C
    01200 - ABS Valves Supply Voltage
                        Fault Frequency: 9
                        Reset counter: 246
                        Mileage: 81717 km
                        Date: 2020.01.10
                        Time: 21:53:10
                        Hex Value: 0x0000
                        Bin. Bits: 00000000 00000000
                        Voltage: 13.75 V
                        Bin. Bits: 00011111
                        Count: 68
                        Hex Value: 0x0000
    00003 - Control Module
                014 - Defective
                        Fault Status: 01101110
                        Fault Frequency: 9
                        Reset counter: 246
                        Mileage: 81717 km
                        Date: 2020.01.10
                        Time: 21:53:10
                        Hex Value: 0x0000
                        Voltage: 13.75 V
                        Bin. Bits: 00011111
                        Count: 113
                        Hex Value: 0x0000
                        Fault Frequency: 12
                        Reset counter: 246
                        Mileage: 81717 km
                        Date: 2020.01.10
                        Time: 21:53:20
                        Hex Value: 0x0000
                        Voltage: 13.75 V
                        Bin. Bits: 00011111
                        Count: 191
                        Hex Value: 0x0000
                        Fault Frequency: 9
                        Reset counter: 246
                        Mileage: 81717 km
                        Date: 2020.01.10
                        Time: 21:53:10
                        Hex Value: 0x0000
                        Voltage: 13.75 V
                        Bin. Bits: 00011111
                        Count: 68
                        Hex Value: 0x0000
    00532 - Supply Voltage B+
                        Reset counter: 31
                        Mileage: 81717 km
                        Date: 2020.01.10
                        Time: 13:16:57
                        Hex Value: 0x0000
                        Voltage: 13.50 V
                        Bin. Bits: 00011111
                        Count: 115
                        Hex Value: 0x0000
    [/B]
       Part No SW: 7N0 907 426 BT    HW: 7N0 907 426 BT
       Component: AC Manuell    H20 0607
       Revision: 00001004
       Coding: 0010002002
       VCID: 074A613A9FAE609F88D-8052
       Part No SW: 5K0 937 084 K    HW: 5K0 937 084 K
       Component: BCM PQ35 B    122 0174
       Revision: BA122001
       Coding: 60180A3B882518C4448800C0340000644B51AA88536D8960648000000040
       VCID: 3A2CC8CE9C5CCD77C73-806E
       Subsystem 1 - Part No SW: 5N2 955 119     HW:              Labels: 1KX-955-119.CLB
       Component: Wischer 11091  013 0204
       Serial number: N2955119   204!
       Coding: 009795
       Component: RLS 151014 05  54  0403
       Coding: 02304D
    Address 10: Park/Steer Assist (J446)       Labels:| 1Q0-919-475.clb
       Part No SW: 5N0 919 475 D    HW: 1Q0 919 475
       Component: PARKHILFE 4K  H03 0045
       Revision: --------    Serial number: 32901426506525
       Coding: 108102
       ASAM Dataset: EV_EPHVA14VW3680000 001005
       ROD: EV_EPHVA14VW3680000.rod
       VCID: 3A2CC8CE9CDCCD77C73-806E
       Part No SW: 5N0 959 655 AA    HW: 5N0 959 655 AA
       Component: J234__20G VW10 HI   2518
       Revision: 28020000    Serial number: 003L7PLAKVAJ
       Coding: 0012359
       VCID: 7CA00ED6DAE8334795F-8028
       Subsystem 1 - Serial number: 6332MTS613382784
       Subsystem 2 - Serial number: 6342MTS686232784
       Subsystem 3 - Serial number: 6351HTS6QISL7DKJ
       Subsystem 4 - Serial number: 6361HTS6DSSL7DKR
       Part No SW: 5K0 953 521 CS    HW: 5K0 953 569 AC
       Revision: FF010042    Serial number: 20140820201110
       Coding: 5880040000
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 7F5AF9DAC77E285FB0D-802A
       Part No SW: 5N0 920 873 D    HW: 5N0 920 873 D
       Component: KOMBI         H03 0905
       Coding: 111F01
       VCID: 3430E6F6BEB83B071DF-8060
       Part No SW: 7N0 907 530 AP    HW: 7N0 907 530 AK
       Component: J533  Gateway H57 1653
       Revision:   H57       Serial number: 130914F1001768
       Coding: 356003
       VCID: 7EA404DEC0F42157BBB-802A
       Part No SW: 5N0 919 879     HW: 5N0 919 879
       Component: Kompass         002 0002
       Revision: 00002000    Serial number: 1225223RQA2Q07
       VCID: 7EA404DECCF42157BBB-802A
       Part No SW: 0AY 907 554 J    HW: 0AY 907 554 J
       Component: Haldex4Motion H52 7522
       Serial number: HA1-00013.08.14
       Coding: 0001
       VCID: 52FC806E246C15372F3-8006
       Component: IMMO          H03 0905
       VCID: 6A8C388EACFCBDF7773-803E
       Revision: A1001003    Serial number: 7666737003
       Coding: 010100
       VCID: 2B02FD8A630664FF4C5-807E
       Part No SW: 5N0 959 701 G    HW: 3C0 959 793 C
       Component: TUER-SG FT    002 0504
       Revision: 12110009    Serial number: 0009074529
       Coding: 0016B6
       VCID: 392ED7C299DAC66FCE9-806C
       Slave Driver:
       Subsystem 1 - Part No SW: 5N0 959 704 F    HW: 3C0 959 795 C  Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  009 1504
       Serial number: 00000009003671
       Coding: 000490
       Part No: 5N0 909 144 R
       Component: EPS_ZFLS Kl. 202    3501
       Revision: 00H22000
       Shop #: WSC 01324 785 00200
       VCID: 40D8BA26F68097A7897-8014
       Part No SW: 5N0 959 702 G    HW: 3C0 959 792 C
       Component: TUER-SG BT    002 0504
       Revision: 14110009    Serial number: 0009076142
       Coding: 0017B6
       Slave Passenger:
       Subsystem 1 - Part No SW: 5N0 959 703 F    HW: 3C0 959 794 C  Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  009 1504
       Serial number: 00000008995642
       Coding: 000490
       Part No SW: 3AA 907 801 J    HW: 3AA 907 801 J
       Component: J540 EPB4  VW-63206 0012
       Revision:   H19       Serial number: 00000000324005
       Coding: 0026157
       VCID: 3828D2C6AE50DF67317-806C
                        Fault Status: 00101101
                        Reset counter: 30
                        Mileage: 81717 km
                        Date: 2020.01.10
                        Time: 21:54:11
                        Voltage: 13.00 V
                        Count: 160
                        Hex Value: 0x1263
                        Hex Value: 0x0001
                        Hex Value: 0x1010
       Part No SW: 5M0 035 186 J    HW: 5M0 035 186 J
       Component: RCD310 EU T   H06 5007
       Revision: -----10S    Serial number: VWZ4Z2P1376898
       Coding: 0100040004000C
       VCID: 3332E5EABB363C3F045-8066
    End----------(Elapsed Time: 01:20, VBatt start/end: 14.1V/14.1V)-----------
    Wednesday,22,January,2020,11:44:12:13642
              56 62 72
       Revision: 00H08V01
       Coding: 0007712
                        Reset counter: 247
                        Mileage: 81720 km
                        Date: 2020.01.22
                        Time: 11:33:19
                        Hex Value: 0x0001
                        Voltage: 13.75 V
                        Bin. Bits: 00011111
                        Count: 191
                        Hex Value: 0x0000
                        Fault Status: 01100010
                        Reset counter: 247
                        Mileage: 81720 km
                        Date: 2020.01.22
                        Time: 11:34:10
                        Hex Value: 0x0001
                        Voltage: 13.75 V
                        Bin. Bits: 00011111
                        Count: 115
                        Hex Value: 0x0000
                        Reset counter: 247
                        Mileage: 81720 km
                        Date: 2020.01.22
                        Time: 11:34:10
       Revision: 00001004
       Coding: 0010002002
       Revision: BA122001
       Coding: 009795
       Coding: 02304D
       Coding: 108102
       Coding: 0012359
       Coding: 5880040000
       Coding: 111F01
       Coding: 356003
       Coding: 0001
       Coding: 010100
       Coding: 0016B6
       Slave Driver:
       Coding: 000490
       Revision: 00H22000
       Coding: 0017B6
       Slave Passenger:
       Coding: 000490
       Coding: 0026157
    End----------(Elapsed Time: 01:18, VBatt start/end: 13.8V/13.9V)-----------
    Just to clarify/confirm: The first scan is as you received it, and the second is after you cleared fault codes?
    Oct 2019
    Malawi
    Correct, 1st Scan when i received it and the 2nd after i cleared DTCs
    Looks like a wiring problem or terminal fault and possibly from faulty ignition switch, how are fuses?
    Oct 2019
    Malawi
    Checked all fuses and they OK... going through the wiring, and will be checking the connector to the Control Unit.
    Vehicle Identification No. WVGZZZ5NZFW046220
    Model Tiguan 4Motion
    TIG
    Date of production 23.10.2014
    Model year 2015
    Sales type 5N21N9
    Engine Code CCZD
    Transmission Code NZT
    Emission standard 0GV Emission standard EU2
    (critical vapor pressure)
    Indeed correct part number............
  7. #7
    Oct 2019
    Malawi
    hi guys,
    so i checked the wiring on the connector to the ABS control module, all looks OK
    I also gave the connector a good air clean and also cleaned the connector pins on the abs control unit.
    connected it all up, and all warning lights have gone .
    i have re run a scan, results below.
    Thursday,23,January,2020,11:30:10:13642
              56 62 72
    Readiness: 1110 0101
       Revision: 00H08V01
       Component: J104   C6 450M VDF9 0021
       Coding: 0007712
       Revision: 00001004
       Coding: 0010002002
       Revision: BA122001
       Coding: 009795
       Coding: 02304D
       Coding: 108102
       Coding: 0012359
       Coding: 5880040000
       Coding: 111F01
       Coding: 356003
       Coding: 0001
       Coding: 010100
       Coding: 0016B6
       Slave Driver:
       Coding: 000490
              B11EC 54 [009] - Missing Calibration / Basic Setting
                        Reset counter: 249
                        Mileage: 81729 km
                        Date: 2020.01.23
                        Time: 00:50:35
       Revision: 00H22000
       Coding: 0017B6
       Slave Passenger:
       Coding: 000490
                        Reset counter: 249
                        Mileage: 81729 km
                        Date: 2020.01.23
                        Time: 00:50:35
       Coding: 0026157
    End----------(Elapsed Time: 01:18, VBatt start/end: 13.8V/13.8V)-----------
