Results 1 to 10 of 17
Thread: Q7 4L 3.0TDI not starting after high pressure pump change
    Jan 2020
    NO
    We got in a Q7 3.0tdi year 2011 that was running but with fault low fuel pressure.
    Local VW dealer changed High pressure pump, and after that they could not get it running. They don`t have Audi license anymore so they could not do any adaptations on it they said, so they have given up get it running after one week...
    I have now updated it to the newest Audi SW version, can clear fault codes on engine, but once I try to start it they come back, also not starting either.
    Fault codes are no power to injector bank A and B, P2146 and P2149. They are cleared in the autoscan, but attached after that.
    Anyone know what next step is to try? Or what could cause this? Car was running after all before they changed the pump.
    Thanks in advance if anyone could help here.
    Tuesday,21,January,2020,17:46:29:37173
    VCDS Version: 19.6.2.0 (x64)
    Dealer/Shop Name: ES Tuning
    Workshop Code: 123 00123 012345
    VIN: WAUZZZ4L3BD009290   License Plate: Q7
    Mileage:    Repair Order: etter0009
                    Address 01: Engine       Labels: 059-907-401-V2.clb
    Control Module Part Number: 4L1 910 401 H    HW: 4L0 907 401 C
      Component and/or Version: 3.0TDI EDC17  H37 0009
               Software Coding: 2A2A4012A57601020000
                Work Shop Code: WSC 31414 790 00001
                  ASAM Dataset: EV_ECM30TDI0114L1910401H 001014 (AU56)
                           ROD: EV_ECM30TDI0114L1910401H.rod
                          VCID: 2854453853622E0FCF-807C
    5060 - Supply Voltage for Fuel Injector Group A
              P2146 00 [101] - Open Circuit
                        Mileage: 180436 km
                        Date: 2020.01.19
                        Time: 20:49:41
                        Engine speed: 195.00 /min
                        Normed load value: 100.0 %
                        Coolant temperature: 1 °C
                        Intake air temperature: 2 °C
                        Voltage terminal 30: 9.540 V
                        Allowed number of injections-Bits 0-7: 3
                        Injection release status-Bits 0-7: 56
                        Desired injection characteristic-Bits 0-7: 56
                        Mean injection quantity: 39.31 mg/stroke
                        Rail pressure regulation: status-Bits 0-7: 5
                        Fuel high pressure: actual value: 346300 hPa
                        Control Module temperature: 21.6 °C
    5061 - Supply Voltage for Fuel Injector Group B
              P2149 00 [101] - Open Circuit
                        Mileage: 180436 km
                        Date: 2020.01.19
                        Time: 20:49:41
                        Engine speed: 193.50 /min
                        Voltage terminal 30: 9.600 V
                        Fuel high pressure: actual value: 574600 hPa
                        Control Module temperature: 20.4 °C
    Welcome OP
    Please post a compete auto-scan!
    Did you check wiring and supply bus + fuses yet?
    Well, if there's no supply voltage to the fuel injectors, that certainly could keep it from starting, no?
    If I were chasing this, I'd get wiring diagrams and check things out with a multimiter.
  4. Likes Jack@European_Parts, PetrolDave liked this post
    And in addition to what Uwe aforementioned you check with DVOM, you know you must qualify the amperage in series with multi meter, not just voltage to circuit, right?
    Jan 2020
    NO
    Thanks for your reply.
    Here complete autoscan.
    I haven’t started checked the wiring yet, that will be the next thing I figure.
    But as they said at the VW shop who replaced the part, they didnt have access to the ecu because of the license.
    Is there anything that need adapation to Get it running after high pressure pump? N276 basic settings?
    Also, if I clear the fault codes when I crank the engine it tries to start for a very short time and then the fault codes comes again. As is it gets spray from the injectors for a short time.
    Any clues from this?
    Thanks,
     Chassis Type: 4L-AU56 (4F0)
    Scan: 01 02 03 05 08 09 0E 13 15 16 17 18 19 20 34 3C 42 46 4F 52
              55 56 5F 62 69 6C 6D 6F 72 76
    VIN: WAUZZZ4L3BD009290   Mileage: 180430km-112114miles
    Address 01: Engine (J623-CJGA)       Labels:. 059-907-401-V2.clb
       Part No SW: 4L1 910 401 H    HW: 4L0 907 401 C
       Component: 3.0TDI EDC17  H37 0003
       Revision: 53H37---    Serial number:
       Shop #: WSC 31414 790 00001
       ASAM Dataset: EV_ECM30TDI0114L1910401H 001008
       Part No SW: 0C8 927 750 AE    HW: 0C8 927 750 AE
       Component: AL1000 AISIN  001 1783
       Coding: 001578
       Shop #: WSC 19081 001 1048576
       ASAM Dataset: EV_TCMAL991031 001001
       ROD: EV_TCMAL991031_001_AU56.rod
       VCID: 6FE66E24B60C39374E-803A
       Revision: 00H02001
       Coding: 2724961
       VCID: 346CA14857AA5AEF73-8060
                        Reset counter: 21
                        Mileage: 180435 km
                        Date: 2020.01.14
                        Time: 19:47:23
                        Count: 321
                        Count: 297
                        Count: 50432
                        Reset counter: 21
                        Mileage: 180435 km
                        Date: 2020.01.17
                        Time: 21:39:50
                        Count: 64
                        Count: 2113
                        Count: 128
                        Count: 33792
       Part No SW: 4F0 910 852 B    HW: 4F0 905 852 F
       Component: FBSAUDIC6 ELV   H05 0130
       Revision: 00H05000    Serial number: 10602901655846
       Coding: 0000131
       VCID: 254A4C0CEC703367F4-8070
       Subsystem 1 - Part No: 4F0 910 132 E
       Component: FBSAUDIC6 IDG   H01 0054
       Part No SW: 4L0 910 043 D    HW: 4L0 820 043 AE
       Component: KLIMA 4 ZONEN H13 0060
       Revision: 00---022    Serial number: 00000000246955
       Coding: 01009016
       VCID: 254A4C0C2C703367F4-8070
                        Fault Frequency: 9
                        Reset counter: 21
                        Mileage: 180435 km
                        Date: 2020.01.17
                        Time: 21:39:52
                        Voltage: 9.40 V
       Part No SW: 4F0 910 279 AH    HW: 4F0 907 279 D
       Component: ILM Fahrer      H29 0390
       Coding: 0023221
       VCID: 6FE66E247E0C39374E-803A
       Component: Wischer AU716   H17 0100
       Coding: 00064792
       Shop #: WSC 31414
       Coding: 00150059
       Shop #: WSC 31414
                014 - Defective
                        Fault Status: 01101110
                        Reset counter: 236
                        Mileage: 180432 km
                        Date: 2020.01.14
                        Time: 19:47:00
    Address 0E: Media Player 1 (R41)       Labels: 4E0-910-111.lbl
       Part No SW: 4F0 035 110 A    HW: 4F0 035 110
       Component: CDC-MP3-Alp   H44 0140
       Revision: AA001001
       VCID: 152A7CCCFC10A3E764-8040
    Address 13: Auto Dist. Reg        Labels: None
       Part No SW: 4L0 910 561 A    HW: 4L0 907 561
       Component: ABSTANDSREGELUNGH06 0160
       Coding: 0031161
       VCID: 27564604967C2177C6-8072
                        Fault Status: 00101101
                        Fault Frequency: 11
                        Reset counter: 21
                        Mileage: 180435 km
                        Date: 2020.01.14
                        Time: 19:47:22
                        Temperature: 22.0°C
                        Voltage: 13.95 V
                        Bin. Bits:    01000
                        Hex Value: 0x0442
                        Hex Value: 0x0002
                        Speed: -3.6 km/h
                        Lateral Accel.: 0.00 m/s^2
       Part No SW: 4L0 910 655 D    HW: 4L0 959 655 C
       Component: 70 AIRBAG AUDI8RH43 0230
       Revision: 04H43000    Serial number: 00399D071W2X
       Coding: 0014128
       VCID: 2E58B320B986703F05-807A
       Subsystem 1 - Serial number: 6332QSME09694608H
       Subsystem 2 - Serial number: 6342QSME0969150AG
       Subsystem 3 - Serial number: 6352QSME116E070CI
       Subsystem 4 - Serial number: 6362QSME3F6D3114O
       Subsystem 5 - Serial number: 63734SME714C4F348
       Subsystem 6 - Serial number: 63834SME584B07284
    00532 - Supply Voltage B+
       Component: J0527               0530
       Revision: 00H05000    Serial number: 90025102360289
       Coding: 0002052
       Component: E0221           H02 0100
       Part No SW: 4L0 920 932 D    HW: 4L0 920 932 D
       Component: KOMBIINSTR.   H10 0209
       Revision: 00000000    Serial number: FLA20HV8A
       Coding: 0F5663040C010008000000
       VCID: 2D5AB42C74800B273C-8078
    Address 18: Aux. Heat        Labels: 4L0-910-105.lbl
       Part No SW: 4L0 910 105     HW: 4L0 815 071 G
       Component: Heizgeraet      H09 0140
       Revision: 0000000C    Serial number: 00000009021078
       Coding: 0000101
       VCID: 60C41D18B3D2964FC7-8034
    00664 - Fuel gauge
       Part No SW: 4F0 907 468 Q    HW: 4F0 907 468 G
       Component: GW-BEM 5CAN-M H06 0047
       Revision: MB300033    Serial number: 3300M10720017E
       Coding: 00CF07
       VCID: 3D7A846CA4E09BA78C-8068
       Component: J367-BDM  H07 0125
       Serial number: 00000000002799187804
       Component: J532_DCDCStab  H16 0038
       Serial number: 10230001370011200180
                        Reset counter: 236
                        Mileage: 180435 km
                        Date: 2020.01.14
                        Time: 19:47:22
                        Bin. Bits:    10111
                        Voltage: 13.80 V
                        Count: 7
    02256 - Quiescent Current
                001 - Upper Limit Exceeded
                        Fault Status: 01100001
                        Reset counter: 236
                        Mileage: 180435 km
                        Date: 2020.01.14
                        Time: 22:37:00
       Part No SW: 4F0 857 511 K    HW: 4F0 857 511 K
       Revision: AA001002
       Coding: 02019064747464545425363E
       VCID: 3064AD5863B266CF17-8064
    Address 34: Level Control        Labels: 4L0-910-553.lbl
       Part No SW: 4L0 910 553 H    HW: 4L0 907 553
       Component: LUFTFDR.-CDC    H03 7870
       Revision: --H03001    Serial number: 15.1528-0123.2
       Coding: 0015520
       VCID: 2F66AE24BE8C79370E-807A
                        Fault Frequency: 10
                        Reset counter: 20
                        Mileage: 180435 km
                        Date: 2020.01.14
                        Time: 19:48:04
                        Error Code: 13
       Component: J0769_SWA_MasterH02 0050
       Revision: 00H02000    Serial number: 6PZ 009 014-10
       Coding: 0010101
       Component: J0770_SWA_Slave_H01 0050
       Subsystem 3 - Serial number: 5F16.08.1000H010003C910691˙
       Subsystem 4 - Serial number: 910691˙
    02857 - Supply Voltage for Lane Change Assistance Control Module 2
                        Reset counter: 21
                        Mileage: 180432 km
                        Date: 2020.01.17
                        Time: 21:56:12
       Component: TSG FA        H12 0361
       Revision:             Serial number: 0008000005527
       Coding: 011C02205040440004
       VCID: 4894E5B8FB22CE0F2F-801C
       Part No SW: 4L0 910 289 H    HW: 4L0 907 289 H
       Component: Komfortgeraet   H10 0110
       Revision: 0110 ---    Serial number: 01345264760000
       Coding: 3539077
       VCID: 356A9C4C5CD043E744-8060
       Part No SW: 4F0 910 280     HW: 4F0 907 280
       Component: ILM Beifahrer   H14 0100
       Revision:             Serial number: 00000000556863
       Coding: 0011001
       VCID: 5EB823E089A6A0BFF5-800A
       Component: TSG BF        H12 0361
       Revision:             Serial number: 0008000003477
       VCID: 4796E684F63CC17726-8012
       Part No SW: 4L0 910 357 B    HW: 4L0 907 357 B
       Component: AFS 1           H01 0010
       Coding: 0000032
       VCID: 2B5EBA348A94051722-807E
       Component: AFS-Modul links H07 0004
       Subsystem 2 - Part No: -----------
       Component: AFS-Modul rechts
                        Fault Status: 11100100
                        Reset counter: 236
                        Mileage: 180435 km
                        Date: 2020.01.14
                        Time: 19:47:22
    03798 - Output Module 2 for Right Headlamp
                        Reset counter: 236
                        Mileage: 180435 km
                        Date: 2020.01.14
                        Time: 19:47:22
       Part No SW: 4G0 035 056     HW: 4G0 035 056
       Component: Radio U STD   H51 0051
       Revision: AB001007    Serial number: 469H40A7559603
       Coding: 010003020100000000
       VCID: 5EB823E049A6A0BFF5-800A
       Part No SW: 4L0 035 666 B    HW: 4L0 035 666 A
       Component: H-BN-EU       H49 0107
       Revision: --------    Serial number: 473I20A7535368
       Coding: 0101000600049BEF31002315EF6300030001
       VCID: 2C5CB9284F9A022F2B-8078
       Subsystem 1 - Part No: 8R0 060 884 R
       Component: EUR 2010  1107
       Subsystem 2 - Part No SW: 8F0 919 604     HW: 8F0 919 604
       Component: DU7 High  H43 0084
       Serial number: 9466G00A0058886
       Subsystem 3 - Part No SW: 4L0 910 609     HW: 4L0 919 611 B
       Component: E0380 Bedient  H05 0060
       Serial number: 00000001669447
       Component: CD-Database  1886
       Part No SW: 4F0 959 795 Q    HW: 8K0 959 795 F
       Component: TSG HL        H11 0357
       Revision:             Serial number: 0000107612432
       Coding: 010800204040230004
                        Reset counter: 236
                        Mileage: 180435 km
                        Date: 2020.01.15
                        Time: 12:49:42
    Address 69: Trailer (J345)       Labels: None
       Part No SW: 4L0 907 383 D    HW: 4L0 907 383 D
       Component: Anhaenger     H08 0072
       Revision: 2C001002    Serial number: 00000133852463
       Coding: 0101010000000000
       VCID: 3260A7506DBE54DF61-8066
    02588 - Swiveling Trailer Hitch
                        Fault Status: 11100101
                        Reset counter: 174
       Revision: --H04---    Serial number: 525PA8-J0742YH
       Coding: 1031001
       Part No SW: 4L0 910 945     HW: 4L0 827 851 E
       Component: ValeoHeckdeckel H55 0500
       Revision: --H55001    Serial number: E5030000B
       Shop #: WSC 98765 666 38354
       VCID: 6CDC79284F1AC22F6B-8038
       Subsystem 3 - Serial number: RD06.09.10--H55001001B0186˙
       Subsystem 4 - Serial number: 1B0186˙
                        Reset counter: 20
                        Mileage: 180435 km
                        Date: 2020.01.06
                        Time: 08:57:28
       Component: ILM HINTEN 2    H05 0070
       Revision: AAH05061    Serial number: 107530114-----
       Coding: 0003587
       VCID: 26484B009176387FFD-8072
       Component: J_245_EE16_SKB10H11 0220
       Component: J_394_EE16_SKB10H11 0220
       Component: J_392_EE16_SKB10H11 0220
    02960 - Lamp in Bumper; Rear Left
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 236
                        Mileage: 180435 km
                        Date: 2020.01.14
                        Time: 19:47:22
                        Bin. Bits:  000 001
       Component: TSG HR        H11 0357
       Revision:             Serial number: 0000107612496
       Part No SW: 4L0 910 283 E    HW: 4L0 919 283 E
       Component: Parkhilfe 8-Kan H02 0100
       Revision: 00H02000    Serial number: 85131024010419
       Coding: 0231066
       VCID: 2C5CB9288F9A022F2B-8078
    End-------------------------(Elapsed Time: 04:02)--------------------------
    Gateway Installation List:  4F0 907 468 Q
    Jan 2020
    NO
    A little update today.
    Have got the car running when I took of power supply for injector 1 and 5. Car starts running, idle but of course rough. When I connect one of the injectors again it stops right away. Without them connected it idles for hours.
    Number 1 injector don`t have right Ohm, it flucting from zero to 185ohm, so this is porobably gone. But number 5 is 187ohm on, so I suspect wiring trouble...
    Or...could it be the ecu that cause this? I took it out now and it is heavy corroded outside, water has been on dripping on this for a long time it looks.Haven`t the ecu yet but will take a look tomorrow.
    Now I have this fault codes.
    5334 - Turbocharger Boost Control Position Sensor Circuit
              P2564 00 [175] - Signal too Low
                        Mileage: 180436 km
                        Date: 2020.01.20
                        Time: 23:27:44
                        Engine speed: 864.50 /min
                        Normed load value: 48.2 %
                        Coolant temperature: 45 °C
                        Intake air temperature: 6 °C
                        Voltage terminal 30: 13.980 V
                        Charge Pressure Actuator: activation: 84.99 %
                        Charge Pressure Actuator: acknowledgment: -4.82 %
                        Turbocharger boost control: offset closed: 0.00 %
                        Turbocharger boost control: offset open: 0.00 %
                        High press turbocharger actuator: actual uncond volt value: 0.0 mV
    5075 - Fuel Injector for Cylinder 1 (N30)
              P1237 00 [175] - Open Circuit
                        Mileage: 180436 km
                        Date: 2020.01.20
                        Time: 23:27:44
                        Engine speed: 849.50 /min
                        Normed load value: 63.5 %
                        Voltage terminal 30: 13.840 V
                        Mean injection quantity: 20.56 mg/stroke
                        Rail pressure regulation: status-Bits 0-7: 15
                        Fuel high pressure: actual value: 330300 hPa
                        Control Module temperature: 12.8 °C
    5433 - Fuel Injector for Cylinder 5 (N83)
              P1241 00 [175] - Open Circuit
                        Mileage: 180436 km
                        Date: 2020.01.20
                        Time: 23:27:44
                        Engine speed: 856.50 /min
                        Normed load value: 49.4 %
                        Voltage terminal 30: 13.880 V
                        Mean injection quantity: 18.63 mg/stroke
                        Fuel high pressure: actual value: 314100 hPa
    5080 - Injector: Cylinder 2 (N31)
              P0202 00 [172] - Circuit Malfunction
                        Mileage: 180436 km
                        Date: 2020.01.20
                        Time: 23:28:25
                        Engine speed: 1270.00 /min
                        Normed load value: 99.6 %
                        Coolant temperature: 48 °C
                        Intake air temperature: 7 °C
                        Voltage terminal 30: 14.160 V
                        Mean injection quantity: 24.27 mg/stroke
                        Fuel high pressure: actual value: 628400 hPa
                        Control Module temperature: 13.2 °C
    Readiness: 1 4 0 0 1
    So when you going to change or swap faulty injector to isolate?
  9. #8
    Jan 2020
    NO
    Have to get my injector extraction tool first, number 1 was really stuck....
    Tried to look in erwin but could not find what tourqe the injector clamp bolt should have.
    Anyone knows it?
  10. #9
    Jan 2020
    NO
    More update.
    Got WD and there is all good from the ecu pin out to the injectors. Took out the ecu last night. It has been opened before I can see, and they have used another sealing than stock. Cant se much error on the pcb, or water, but suspect there is something wrong inside there.
    Have found a used ecu, but is it possible to make clone full ecu on this? Immo problem?
  11. #10
    Data transfer is possible by mail not clone or GeKo FaZit session at dealer or authorized VAG agent?
