Results 1 to 5 of 5
Thread: Audi a3 8p ABS headache
    New User
    Jan 2020
    Australia
    hey im having a bit of trouble and hoping someone can help i have a audi a3 8p i have replaced the modual but did not get the codes from the old modual now im having issues. im using vag com interference when i go into long coding to code it it says out of range what do i do please help
    You need to post a full unedited VCDS Auto-Scan (including the VIN) then someone here will be able to suggest long coding that should work.
  3. Likes Uwe liked this post
    New User
    Jan 2020
    Australia
    OK will do thank you
    New User
    Jan 2020
    Australia
    a3 8p abs coding
    Thursday,23,January,2020,22:29:38:42876
    VCDS Version: 19.6.2.0 (x64)
    VIN: WAUZZZ8PX6A064761   License Plate:
    Chassis Type: 8P (1K0)
    Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 47 52 56 62 72
    VIN: WAUZZZ8PX6A064761   Mileage: 163500km-101594miles
    15-Airbags -- Status: Cannot be reached 1100
    52-Door Elect, Pass. -- Status: Cannot be reached 1100
    62-Door, Rear Left -- Status: Cannot be reached 1100
    72-Door, Rear Right -- Status: Cannot be reached 1100
       Part No SW: 8P0 907 115     HW: 8P0 907 115
       Component: 2.0l R4/4V TFSI G00 0130
       Revision: --H01---    Serial number: AUX7Z0E8FN80F6
       Coding: 01030003180F0160
       Shop #: WSC 06314 000 00000
       VCID: 6FC32ACC7E3A70374E-803A
    012691 - Intake Manifold Runner Control
                   P3193 - 002 - Open Stop outside of Valid Range
                        Fault Status: 01100010
                        Mileage: 163504 km
                        Date: 2019.04.30
                        Time: 00:09:39
                        Temperature: 27.0°C
                        Temperature: 28.0°C
                        Absolute Pres.: 990.0 mbar
                        Voltage: 12.573 V
    049489 - No Communications with Airbag Control Module
                   U0151 - 008 -
                        Mileage: 163504 km
                        Date: 2019.04.30
                        Time: 00:09:39
                        Temperature: 27.0°C
                        Temperature: 28.0°C
                        Voltage: 12.573 V
                   P1602 - 002 - Voltage too Low
                        Temperature: -40.0°C
                        Absolute Pres.: 0.0 mbar
                        Voltage: 0.000 V
    Readiness: 0110 0101
    Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-A.lbl
       Part No SW: 1K0 907 379 R    HW: 1K0 907 379 R
       Component: ESP 4MOTION MK60    0102
       Revision: 00T12001
       Coding: 0021122
       VCID: 41A7BC74182EB647E8-8014
    02085 - Incorrect Control Module Installed
    00493 - ESP-Sensor Unit (G419)
       Part No SW: 8P0 820 043 BG    HW: 8P0 820 043 BG
       Component: KlimavollautomatH09 0100
       Revision: 000160      Serial number: 8P0820043BG
       VCID: 72C523B86D085DDFA1-8026
                        Reset counter: 232
                        Mileage: 163504 km
                        Date: 2019.04.30
                        Time: 00:02:39
                        Reset counter: 232
                        Mileage: 163504 km
                        Date: 2019.04.30
                        Time: 00:02:39
                        Reset counter: 232
                        Mileage: 163504 km
                        Date: 2019.04.30
                        Time: 00:00:48
                        Reset counter: 67
                        Mileage: 163504 km
                        Date: 2019.04.30
                        Time: 00:01:21
    Address 09: Cent. Elect.        Labels:. 8P0-907-279-23-H.lbl
       Part No SW: 8P0 907 279 F    HW: 8P0 907 279 F
       Component: Bordnetz-SG     H36 1201
       Revision: 00H36000    Serial number: 00000002176987
       Coding: 018C4F00B014100000160000160000000008FE175C0100
       Shop #: WSC 06314 000 08192
       VCID: 40A1B9701324BF4FE7-8014
       Subsystem 1 - Part No: 8P2 955 119 F  Labels: 1KX-955-119.CLB
       Component: Wischer AU350   H10 0040
       Coding: 00056595
       Shop #: WSC 06314
    10 Faults Found:
                        Reset counter: 67
                        Mileage: 163504 km
                        Date: 2019.04.30
                        Time: 00:01:00
                        Voltage: 12.45 V
    01834 - Bulb for Side-Blinkers; Left (M18)
                        Reset counter: 67
                        Mileage: 163504 km
                        Date: 2019.04.30
                        Time: 00:01:00
                        Voltage: 12.45 V
    01835 - Bulb for Side-Blinkers; Right (M19)
                        Reset counter: 67
                        Mileage: 163504 km
                        Date: 2019.04.30
                        Time: 00:01:00
                        Voltage: 12.45 V
                        Reset counter: 67
                        Mileage: 163504 km
                        Date: 2019.04.30
                        Time: 00:01:00
                        Voltage: 12.30 V
                        Reset counter: 67
                        Mileage: 163504 km
                        Date: 2019.04.30
                        Time: 00:01:00
                        Voltage: 12.30 V
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 67
                        Mileage: 163504 km
                        Date: 2019.04.30
                        Time: 00:01:00
                        Voltage: 12.30 V
                        Reset counter: 67
                        Mileage: 163504 km
                        Date: 2019.04.30
                        Time: 00:25:00
                        Voltage: 12.15 V
                        Reset counter: 67
                        Mileage: 163504 km
                        Date: 2019.04.30
                        Time: 00:25:00
                        Voltage: 12.15 V
                        Reset counter: 67
                        Mileage: 163504 km
                        Date: 2019.04.30
                        Time: 00:01:00
                        Voltage: 12.45 V
                        Reset counter: 67
                        Voltage: 12.60 V
    Address 15: Airbags
       Part No SW: 8P0 953 549 E    HW: 8P0 953 549 E
       Component: Lenksäulenmodul H34 0070
       Coding: 0002042
       Component: Lenkradmodul    H06 0030
    01304 - Radio
    00895 - Cruise Control Switch (E45)
       Part No SW: 8P0 920 930 T    HW: 8P0 920 930 T
       Component: KOMBIINSTR. VDO H80 0410
       Revision: D03         Serial number: 2248ED03005703
       Coding: 0005743
       Shop #: WSC 60589 067 57207
       VCID: 43ABB67C0232A457FA-8016
                        Fault Status: 00000011
                        Reset counter: 232
                        Mileage: 163504 km
                        Date: 2019.04.30
                        Time: 00:01:14
                        Reset counter: 17
                        Mileage: 163504 km
                        Date: 2019.04.30
                        Time: 00:02:15
       Part No SW: 1K0 907 530 F    HW: 1K0 907 951
       Component: Gateway         H10 0120
       Revision:   H10       Serial number: 2800105819848D
       Coding: BD3F0342072103
       VCID: 2A75FBD88558551FD9-807E
                        Reset counter: 67
                        Reset counter: 67
                        Reset counter: 67
    01304 - Radio
                        Reset counter: 67
                        Mileage: 163504 km
                        Date: 2019.04.30
                        Time: 00:00:01
                        Reset counter: 67
                        Mileage: 163504 km
    Address 22: AWD        Labels: 1K0-907-554.lbl
       Part No: 1K0 907 554 B
       Component: HALDEX 4Motion      0107
       VCID: 2C79FDC08FAC4B2F2B-8078
       Revision: D03         Serial number: AUX7Z0E8FN80F6
    Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN2.lbl
       Part No: 8P0 959 801 H
       Component: Tuer-SG         020 0090
       Coding: 0000688
                002 - Lower Limit Exceeded
       Part No: 1K2 909 144 J
       Component: EPS_ZFLS Kl.5   D04 1606
       VCID: 334BE6BC529214D76A-8066
       Part No: 8P0 959 433 E
       Component:    KSG          H04 0050
       Coding: 188000186D2D8504488F010000
       Shop #: WSC 50620 812 05309
       VCID: 3E5DC78869D0C9BF95-806A
       Part No SW: 8P4 035 382 D    HW: 8P4 035 382 D
       Component: AB2 SUBWOOFERBOXH06 0180
       Revision: 00005       Serial number: 30674802646967
       VCID: 354FD8A45CE60AE744-8060
    Address 52: Door Elect, Pass.
    Address 56: Radio
    Address 62: Door, Rear Left
    Address 72: Door, Rear Right
    End-------------------------(Elapsed Time: 01:14)--------------------------
    Quote Originally Posted by dee81 View Post
    I don't think this is a problem that can be fixed via coding.
    The MK60 has a separate sensor unit for the accelerometers. Get wiring diagrams, verify the relevant wiring, power and grounds, and if all that is OK, replace the ESP sensor unit.
    PS: Threads merged.
