Sharan mk1 1998 hazard lights
Sharan1998
Verified VCDS-Lite User
Estonia
C?ID=330344
Hazard lights of mk1 Sharan 1998 starts flashing, hazard switch position OFF. Switch is not blinking.
ABS and low beam codes are "normal".
Cant find 00626, 00945, 00966 and 00975 codes from list.
VCDS-Lite Version: Release 1.2
Tuesday, 21 January 2020, 16:54:35:32725
Chassis Type: 7M - VW Sharan I
Scan: 25,01,02,03,08,09,15,16,17,18,19,22,29,35,36,37,39,45,55,56,76
Address 25: Immobilizer       Labels: 7M0-953-257.LBL
   Controller: 7M0 953 257 M
   Component: IMMO VWZ3Z0V7025858 V64
   Coding: 09600
   VCID: 40F3BCD6539B
Address 01: Engine       Labels: 028-906-021-AHU.LBL
   Controller: 028 906 021 GS
   Component: 1,9l R4 EDC   00SG  1904
   Coding: 00002
   Shop #: WSC 00020
   VCID: 66BF4A4E117F
00626 -  Glow Plug Indicator Light (K29)
            31-10 -  Open or Short to Ground - Intermittent
Readiness: N/A
Address 03: ABS Brakes       Labels: 1J0-907-37x-ABS.LBL
   Controller: 1J0 907 379 D
   Component: ABS     20 IE CAN  0001
   Coding: 12812
   Shop #: WSC 00020
   VCID: 3217E61EED37
00285 -  ABS Wheel Speed Sensor; Front Right (G45)
            35-00 -   -
00283 -  ABS Wheel Speed Sensor; Front Left (G47)
            16-10 -  Signal Outside Specifications - Intermittent
            04-10 -  Mechanical Malfunction - Intermittent
Address 09: Cent. Elect.       Labels: None
   Controller: 7M0 962 258
   Component: Multifunkt.Einheit 0001
   Coding: 00005
   Shop #: WSC 00020
   VCID: F49BA006D7A3
00966 -  Fuse for Blinkers (S151)
            37-10 -  Faulty - Intermittent
00977 -  Low Beams; Left & Right
            28-10 -  Short to Plus - Intermittent
00945 -  Crash Sensor (G190)
            29-10 -  Short to Ground - Intermittent
00975 -  Heated Rear Window (Z1)
            36-10 -  Open Circuit - Intermittent
Address 17: Instruments       Labels: 7Mx-919-xxx-17.LBL
   Controller: 7MO 919 862 S
   Component: Kombiinstrument     064g
   Coding: 00124
   Shop #: WSC 52202
   VCID: 69A541720061
End   --------------------------------------------------------------------------------------------------
It looks like the codes you mention are explained in the scan?
Sharan1998
Estonia
C?ID=330344
But ther is no problems with blinkers nor rear window heater. And the glow plug indicator light is OK too.
Bruce
Near Philadelphia, PA, USA
They are intermittent faults. This means that the fault was set but it was not present at the time the auto-scan was performed. They had been set previously.
This happens from time to time.
You could try clearing them and then see if they return. If they do, then you have a problem which you need to sort.
Sharan1998
Estonia
C?ID=330344
Cleared. They returned. Comfort module?
HMC
C?ID=28246
Hi Sharan1998,
Is the floor wet? Convenience Module pretending to be a fish?
Regards HMC
