Results 1 to 6 of 6
Thread: Sharan mk1 1998 hazard lights
    Verified VCDS-Lite User
    Feb 2018
    Estonia
    Hazard lights of mk1 Sharan 1998 starts flashing, hazard switch position OFF. Switch is not blinking.
    ABS and low beam codes are "normal".
    Cant find 00626, 00945, 00966 and 00975 codes from list.
    Tuesday, 21 January 2020, 16:54:35:32725
    Chassis Type: 7M - VW Sharan I
    Scan: 25,01,02,03,08,09,15,16,17,18,19,22,29,35,36,37,39,45,55,56,76
    Address 25: Immobilizer       Labels: 7M0-953-257.LBL
       Controller: 7M0 953 257 M
       Component: IMMO VWZ3Z0V7025858 V64
       Coding: 09600
       VCID: 40F3BCD6539B
    Address 01: Engine       Labels: 028-906-021-AHU.LBL
       Controller: 028 906 021 GS
       Component: 1,9l R4 EDC   00SG  1904
       Coding: 00002
       Shop #: WSC 00020
       VCID: 66BF4A4E117F
    00626 -  Glow Plug Indicator Light (K29)
                31-10 -  Open or Short to Ground - Intermittent
    Readiness: N/A
    Address 03: ABS Brakes       Labels: 1J0-907-37x-ABS.LBL
       Controller: 1J0 907 379 D
       Component: ABS     20 IE CAN  0001
       Coding: 12812
       Shop #: WSC 00020
       VCID: 3217E61EED37
    00285 -  ABS Wheel Speed Sensor; Front Right (G45)
                35-00 -   -
    00283 -  ABS Wheel Speed Sensor; Front Left (G47)
                16-10 -  Signal Outside Specifications - Intermittent
                04-10 -  Mechanical Malfunction - Intermittent
    Address 09: Cent. Elect.       Labels: None
       Controller: 7M0 962 258
       Component: Multifunkt.Einheit 0001
       Coding: 00005
       Shop #: WSC 00020
       VCID: F49BA006D7A3
    00966 -  Fuse for Blinkers (S151)
                37-10 -  Faulty - Intermittent
    00977 -  Low Beams; Left & Right
                28-10 -  Short to Plus - Intermittent
    00945 -  Crash Sensor (G190)
                29-10 -  Short to Ground - Intermittent
    00975 -  Heated Rear Window (Z1)
                36-10 -  Open Circuit - Intermittent
    Address 17: Instruments       Labels: 7Mx-919-xxx-17.LBL
       Controller: 7MO 919 862 S
       Component: Kombiinstrument     064g
       Coding: 00124
       Shop #: WSC 52202
       VCID: 69A541720061
    End   --------------------------------------------------------------------------------------------------
    Quote Originally Posted by Sharan1998 View Post
    It looks like the codes you mention are explained in the scan?
    Feb 2018
    Estonia
    But ther is no problems with blinkers nor rear window heater. And the glow plug indicator light is OK too.
    Near Philadelphia, PA, USA
    They are intermittent faults. This means that the fault was set but it was not present at the time the auto-scan was performed. They had been set previously.
    This happens from time to time.
    You could try clearing them and then see if they return. If they do, then you have a problem which you need to sort.
    Feb 2018
    Estonia
    Cleared. They returned. Comfort module?
    Jul 2014
    Hi Sharan1998,
    Is the floor wet? Convenience Module pretending to be a fish?
    Regards HMC
  7. Likes PetrolDave, Uwe liked this post
