Results 1 to 2 of 2
Thread: Skoda octavia with Dq250 basic settings please help
    Sep 2019
    IN
    Hello friends.
    I have done basic settings on numerous dsg units with help from wiki Ross-tech.
    I now have a new model Octavia and the meny has no blocks to select like the 060 in others.
    Instead it has a drop down menu.
    Please help.
    The car had no errors just the second gear is slipping and i am sure basic settings shall fix it.
    Thanks in advance.
    Please help.
     Monday,20,January,2020,19:47:06:02918
    VIN: TMBBJKNE8FA008775   License Plate: NEW OCTAVIA
    Mileage: 116613km-72459mi   Repair Order:
    Chassis Type: NE-SK37 (5Q0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 2B 36 42 44 52 55 5F
    VIN: TMBBJKNE8FA008775   Mileage: 116613km-72459miles
    Address 01: Engine (J623-CRVC)       Labels: None
       Part No SW: 04L 906 021 EB    HW: 04L 907 309 C
       Component: R4 2,0L EDC   H22 7183
       Revision: 82H22---
       Coding: 011D0112032500011000
       Shop #: WSC 73430 031 00063
       ASAM Dataset: EV_ECM20TDI01104L906021EB 002007
       ROD: EV_ECM20TDI01104L906021EB.rod
       VCID: 699AAA748872840710-803C
    20557 - Heater support pump
              P16C7 00 [032] - locked
       Part No SW: 0D9 300 042 B    HW: 02E 927 770 AQ
       Component: DQ250-6F MQB  H53 4902
       Revision: 06253104    Serial number: TFK01507221827
       Shop #: WSC 73430 031 00000
       ROD: EV_TCMDQ250021.rod
       VCID: 187CDFB0E398CD8F7F-804C
       Part No SW: 3Q0 907 379 T    HW: 3Q0 907 379 C
       Component: ESC           H32 0393
       Revision: 00000000    Serial number: 51965000002303
       Coding: 1A078A9124200974007E060741C8245851249000608224B200630030C002
       ROD: EV_Brake1UDSContiMK100ESP_034_SK37.rod
       VCID: 4BD670FCE2CE761702-801E
    16401 - Tire Pressure Warning
              C102D 00 [008] - -
                        Reset counter: 70
                        Mileage: 114631 km
                        Date: 2019.12.04
                        Time: 22:51:14
       Revision: 00021000    Serial number: 0374146709
       Coding: 030C0C
       Shop #: WSC 73430 790 00063
       VCID: 3A382538BD54FF9FA9-806E
       Part No SW: 5E0 907 044 Q    HW: 5E0 907 044 Q
       Component: Climatronic   H04 1002
       Revision: 00001K07
       Coding: 01110104100100010000000012001400
       VCID: 3326081C9A3E0ED76A-8066
       Geber f黵 K鋖temitteldruck/K鋖temitteltemperatur:
    262914 - Refrigerant Pressure
              B10AB F0 [008] - Too Low
                        Reset counter: 134
                        Mileage: 116405 km
                        Date: 2020.01.17
                        Time: 18:17:42
                        Outside air temperature: 21.0 癈
                        Engine speed: 0 /min
                        Temperature after evaporator: 31.0 癈
                        System run time-Terminal 15 on: 72 s
       Part No SW: 5Q0 937 084 AS    HW: 5Q0 937 084 AN
       Serial number: 01061519702161
       Coding: 0F111A424047227B47E04000000807000800000000000000000000000000
       ROD: EV_BCMBOSCH_015.rod
       VCID: 095A8AF4A8322407F0-805C
       Subsystem 1 - Part No SW: 5E2 955 119     HW: 5E2 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS371 150606  041 0570
       Serial number:         150618215516
       Coding: 065DDD
       Subsystem 2 - Part No SW: 5Q0 955 559 A    HW: 5Q0 955 559 A  Labels: 5Q0-955-547.CLB
       Component: RLS  037 0059
       Serial number: S4Y15M07D23H19M03S41
       Coding: 00885D
       Sun Roof:
       Subsystem 3 - Part No SW: 6R0 959 591 D    HW: 6R0 959 591 D
       Component: J245 PS72.403  H03 0004
       Serial number: 0000FST000GNMB000000
       Coding: 981803
    12298 - License Plate Light
              B12CA 15 [008] - Open or Short to Plus
                        Fault Frequency: 24
                        Reset counter: 140
                        Mileage: 113869 km
                        Date: 2019.11.25
                        Time: 15:08:43
    12307 - License Plate Light
              B12CA 01 [008] - Electrical Failure
                        Fault Frequency: 44
                        Reset counter: 141
                        Mileage: 113908 km
                        Date: 2019.11.25
                        Time: 18:05:01
    204290 - Remote key 1
              B1479 18 [008] - Current Too Low
                        Reset counter: 140
                        Mileage: 116573 km
                        Date: 2020.01.20
                        Time: 13:47:54
    204546 - Remote key 2
                        Reset counter: 13
                        Mileage: 113919 km
                        Date: 2019.11.25
                        Time: 18:17:29
       Revision: --------    Serial number: 39311521601870
       Coding: 0031151011
       VCID: 43C658DCCA9EBE57FA-8016
       Part No SW: 3Q0 959 655 AR    HW: 3Q0 959 655 AR
       Component: Airbag VW20   013 0200
       Revision: --------    Serial number: 003SPPFRKH3Y
       Coding: 88FCC0000000000040000000008800000065
       ROD: EV_AirbaVW20TS6VW48X.rod
       VCID: 0E50B9E8D15C033F25-805A
       Subsystem 1 - Part No SW: -----------    HW: 454 001 807 15
       Serial number: 3576U000000696159517
       Subsystem 2 - Part No SW: -----------    HW: 454 001 807 15
       Serial number: 3586U00000099615951B
       Subsystem 3 - Part No SW: -----------    HW: 454 801 107 15
       Serial number: 3516R7C3CA307000000A
       Subsystem 4 - Part No SW: -----------    HW: 454 802 206 15
       Serial number: 3526RC0A52E070000007
       Subsystem 5 - Part No SW: -----------    HW: 454 800 806 15
       Serial number: 3556V9CF32207000000E
       Part No SW: 5Q0 953 507 HG    HW: 5Q0 953 549 E
       Component: Lenks. Modul  003 0110
       Revision: --------    Serial number: 06081504220657
       Coding: 1010
       VCID: 02489DD89504775FB1-8056
       Part No SW: 5E0 920 741 B    HW: 5E0 920 741 B
       Component: KOMBI         223 6422
       Coding: 27A402182980000801082A001000000000000000
       VCID: 2306F85C2ADE9E579A-8076
       Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 F
       Component: GW MQB High   128 1223
       Revision: --------    Serial number: 0003770874
       Coding: 010100080008730000000000000F00000000000000000000000000000000
       ROD: EV_GatewLear_013.rod
       VCID: 75A2F604D4CA50E784-8020
       Subsystem 2 - Part No SW: 3V0 919 719 B    HW: 3V0 919 719 B
       Component: E221__MFL-PR6  H02 0150
       Serial number: 000000000B0498220715
       Revision: 00000000    Serial number: 15000177758010
       Coding: 5D00000000000000
       ROD: EV_ELVMarquMQB.rod
       VCID: 34240B009F3009EF73-8060
       Part No SW: 5Q0 959 760 A    HW: 5Q0 959 760 A
       Component: Sitzmemory    H06 0009
       Serial number: Y0006OFJ17160
       Coding: 001400000000000001A081808080000000008181000000D4
       ASAM Dataset: EV_SeatMemorDriveSide 001015
       ROD: EV_SeatMemorDriveSide_001.rod
       VCID: 3B36203CB26EC697B2-806E
       Serial number: 0000162810502
       Coding: 00150120DE01040000001100
       VCID: 47DE4CCCFEA6927726-8012
       Serial number: 00000000000006793899
       Coding: 1D0200
       Component: EPS_MQB_ZFLS  125 1061
       Coding: 0102
       Serial number: 0000162830922
       VCID: 46C041C8F9AC8B7FDD-8012
       Serial number: 00000000000006658468
       Coding: 050200
       Coding: 034E02003F000000
       VCID: 40CC57D0DB88A54FE7-8014
       Coding: 3E0000
       Coding: 3E0000
    Address 5F: Information Electr. (J794)       Labels:| 3V0-035-MIB-STD2.clb
       Part No SW: 5Q0 035 840 A    HW: 5Q0 035 840 A
       Component: MU-S--ER      H24 0241
       Serial number: SKZAZ2R8730257
       Coding: 03730100FF00000011110001001100002F0000D60100010000
       ROD: EV_MUStd4CTSAT_VW41.rod
       VCID: 2B16107C420E561722-807E
       Subsystem 1 - Part No SW: 5E0 919 605 H    HW: 5E0 919 605 H
       Component: ABT_Std-2  H41 1028
       Serial number: SKZ8Z9RBS00KFA
              U11B8 00 [008] - No Communications
              [USB - communication error]
                        Reset counter: 127
                        Mileage: 116271 km
                        Date: 2019.12.28
                        Time: 09:38:53
                        Voltage terminal 30: 14.1 V
                        Interface for external media: status-Status: Open circuit
    End----------(Elapsed Time: 01:41, VBatt start/end: 12.4V/12.3V)-----------
    16.4905° S, 151.7375° W
    Have a look at the Ross-Tech forum post, linked below.
    The transmission in this post appears to be very similar to the one installed on your vehicle, "Component: DQ250-6F MQB".
    Ross-Tech forum post: DSG VW Golf GTI MK7 - Grateful for some help
    This wiki page linked below is for the 0B5 transmission, however this page maybe helpful to 'see' the procedure written out.
    ref:
    7-Speed S-Tronic Direct-Shift Gearbox (DSG/0B5)
    Hope this helps and please post your results here so others may be learn,
    drpeter
  3. Likes Uwe liked this post
