Results 1 to 10 of 10
Thread: 2013 Audi Q7 Optical ring broken. Amp or Radio?
    Jan 2020
    OKC, OK, USA
    Monday,20,January,2020,19:31:51:53967
    VCDS Version: Release 19.6.2 (x64)
    Control Module Part Number: 4F0 907 468 S
      Component and/or Version: GW-BEM 5CAN-M H06 0058
    Optical Bus Diagnostic : Standard
    Controller          	Electrical          	Optical
    19-CAN Gateway      	OK                  	OK
    5F-Information Electr.(High/D3)	OK                  	OK
    47-Sound System     	OK                  	ERROR
    56-Radio            	ERROR               	ERROR
    Looking at this is the Amp whats bad? My car shows all signs of a bad amp but after seeing this i wasnt sure if its maybe the amp or if its the radio module?
    You need to replace one module at a time in the optical ring with an optical link to diagnose problems in the optical ring.
    I'd also be concerned about the 56 showing an electrical error, please post an unedited VCDS Auto-Scan.
    Near Philadelphia, PA, USA
    Tutorial for diagnosing MOST Bus problems:
    https://www.ross-tech.com/vcds/tour/optical-bus.php
  4. Likes Jack@European_Parts, Uwe, PetrolDave liked this post
    Jan 2020
    OKC, OK, USA
    That was the concern i had when i saw that all the signs before scan point at the AMP but after running this the radio part had me concerned if it wasnt for that error i would go straight to the amp. I had to leave town for work but ill be back tonight and will post a full scan.
    Jan 2020
    OKC, OK, USA
    Here is the full scan.... Holy hell.... No blow fuses i've checked everyone of them in all 3 fuse blocks.
    Still haven't fixed the Optical ring issue yet i need to get the tools to remove the radio. I tested the amp and it was fine.
    Is it possible that one issue is causing all of these other issues?
    Saturday,25,January,2020,23:34:17:53967
    VIN: WA1DGAFE8DD013495   License Plate: STEPH2
    Mileage: 131030km-81418mi   Repair Order:
    Chassis Type: FE-AU56 (4F0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 28 36 3C 42 46 47 4C 4F 52
              55 56 5F 62 69 6C 6D 6F 72
    VIN: WA1DGAFE8DD013495   Mileage: 131030km-81418miles
    05-Acc/Start Auth. -- Status: Sporadic communication error 1000
    08-Auto HVAC -- Status: Sporadic communication error 1000
    4C-Tire Pressure II -- Status: Malfunction 0010
    Address 01: Engine (CTW)       Labels:. 06E-907-551-CAJ.clb
       Part No SW: 4L0 910 551 Q    HW: 4L0 907 551 A
       Component: 3.0l V6 TFSI        0030
       Revision: --H08---    Serial number:
       Coding: 0121000A290F0928
       Shop #: WSC 31414 790 00001
       VCID: 363521B8F44A514723B-8062
                   U1017 - 000 -  - Intermittent
                        Mileage: 131003 km
                        Date: 2020.01.25
                        Time: 14:42:25
                        RPM: 1504 /min
                        Mass Air / Rev.: 218.0 mg/str
                        Temperature: 12.0°C
                        Bin. Bits: 00000010
                        Load: 17.6 %
       Part No SW: 0C8 927 750 Q    HW: 0C8 927 750 Q
       Component: AL1000 AISIN  002 2090
       Coding: 001378
       Shop #: WSC 99999 999 83333
       ROD: EV_TCMAL991031_002.rod
       VCID: 3A2D3588CCD2B527C73-806E
       Revision: 00H02001
       Coding: 0099409
       VCID: 34311BB0E23643571DF-8060
                        Reset counter: 175
                        Mileage: 131003 km
                        Count: 192
                        Count: 2881
                        Count: 297
                        Count: 33792
       Part No SW: 4F0 910 852 B    HW: 4F0 905 852 H
       Component: FBSAUDIC6 ELV   H08 0200
       Revision: 00H08000    Serial number: 10603702051700
       Coding: 0000135
       VCID: 2517F6F459EC2ADF9A1-8070
       Component: FBSAUDIC6 EZS   H04 0020
       Part No SW: 4L0 910 043 D    HW: 4L0 820 043 AQ
       Revision: 00---031    Serial number: 00000000366298
       Coding: 000CC026
       VCID: 2517F6F455EC2ADF9A1-8070
       Subsystem 1 - Part No SW: 8K0 959 772 F    HW: 8K0 959 772
       Component: SLR-B8  H06 0007
       Serial number:           0053266859
       Coding: 070000
       Part No SW: 4F0 910 279 AG    HW: 4F0 907 279 C
       Component: ILM Fahrer      H31 0400
       Coding: 0133123
       VCID: 6E85C9D8CC9A29872BB-803A
       Component: Wischer AU716   H18 0110
       Coding: 00064792
       Shop #: WSC 31414
       Coding: 00150059
       Shop #: WSC 31414
    00456 - Control Module for Access and Start Control (J518)
                        Reset counter: 174
                        Mileage: 131000 km
                        Date: 2020.01.25
                        Time: 12:33:00
    00061 - Footwell Lights
                        Fault Status: 00110111
                        Reset counter: 174
                        Mileage: 131000 km
                        Date: 2020.01.25
                        Time: 12:30:00
    Address 10: Park/Steer Assist (J446)       Labels:| 4L0-919-475-7X2.clb
       Part No SW: 4L0 919 475 A    HW: 4H0 919 475 C
       Component: PARKHILFE 8K  H07 0011
       Revision: 11001001    Serial number: 55961306500143
       Coding: 25011F
       ASAM Dataset: EV_EPHVA18AU7160000 001001
       ROD: EV_EPHVA18AU7160000.rod
       VCID: 34311BB0EEB643571DF-8060
       Component: 73 AIRBAG AUDI8RH44 0230
       Revision: 08H44000    Serial number: 0038QD0C34B.
       Coding: 0014131
       VCID: 2B0300CC3F081CAF4C5-807E
       Subsystem 1 - Part No: 4L0 959 339 C
       Component: BF-Gewichtsens. H05 0040
       Subsystem 2 - Serial number: 6332QSME662C4D52P
       Subsystem 3 - Serial number: 6342QSME662C174ES
       Subsystem 4 - Serial number: 6352QSME3C2B4158N
       Subsystem 5 - Serial number: 6362QSME2B2B0F60P
       Subsystem 6 - Serial number: 63734SME692C4E68J
       Subsystem 7 - Serial number: 63834SME672C4768B
       Part No SW: 4F0 910 549 B    HW: 4F0 953 549 E
       Component: J0527               0830
       Revision: 00H08000    Serial number: 90026130170350
       Coding: 0012142
       VCID: 2809FFC02EFE37B7A17-807C
       Component: E0221           H03 0040
                        Reset counter: 174
                        Mileage: 131003 km
                        Date: 2020.01.25
                        Time: 12:33:31
       Part No SW: 4L0 920 985 S    HW: 4L0 920 985 S
       Component: KOMBIINSTR.   H35 0317
       Revision: 00000000    Serial number: VJ342HA3E
       Coding: 8BD663040900CF05020205
       VCID: 44D14B70BE96F3D7ADF-8010
       Part No SW: 4F0 907 468 S    HW: 4F0 907 468 G
       Component: GW-BEM 5CAN-M H06 0058
       Revision: MB700037    Serial number: 3700M1330201D9
       Coding: 00C303
       VCID: 3FDB449CD770900FF0D-806A
       Component: J367-BDM  H07 0125
       Serial number: 40060K58094120271281
    00384 - Optical Databus
                        Reset counter: 126
                        Mileage: 130761 km
                        Date: 2020.01.20
                        Time: 19:02:32
                        Bin. Bits:    10111
                        Voltage: 11.90 V
                        Count: 7
                        Bin. Bits:    00000
    02256 - Quiescent Current
                        Fault Status: 00100001
                        Reset counter: 176
                        Mileage: 130790 km
                        Date: 2020.01.21
                        Time: 10:12:00
                        Fault Frequency: 7
                        Reset counter: 176
                        Mileage: 130790 km
                        Date: 2020.01.21
                        Time: 13:12:00
                        Bin. Bits:    00000
                        Voltage: 12.20 V
                        Count: 18
                        Reset counter: 174
                        Mileage: 131003 km
                        Date: 2020.01.25
                        Time: 12:33:31
                        Bin. Bits:    00000
                        Voltage: 11.50 V
                        Count: 8
                        Bin. Bits:    00000
                        Time: 1.70 s
                        Reset counter: 174
                        Mileage: 131003 km
                        Date: 2020.01.25
                        Time: 12:37:28
                        Bin. Bits:    00000
                        Voltage: 11.50 V
                        Count: 11
                        Bin. Bits:    00000
                        Time: 11.30 s
       Part No SW: 4L0 910 158     HW: 4L0 919 158 AE
       Revision: 00---011    Serial number: 00000030275468
       Coding: 0000006
       VCID: 6889BFC0EE7EF7B7617-803C
       Part No SW: 4F0 959 760 D    HW: 4F0 959 760 D
       Component: MEM-FS        H08 0064
       Revision: AA000000    Serial number: 00000053227558
       Coding: 00581B00000011110000
       VCID: 323D1DA814224D670F3-8066
       Component: J0769_SWA_MasterH02 0050
       Revision: 00H02000    Serial number: 6PZ 009 014-10
       Coding: 0010001
       VCID: 2E0509D80C1A69876BB-807A
       Component: J0770_SWA_Slave_H02 0050
       Subsystem 3 - Serial number: 5F28.02.1300H02000AMS15709˙
       Subsystem 4 - Serial number: S15709˙
       Component: TSG FA        H12 0362
       Revision:             Serial number: 0000054976525
       Coding: 011F57205E40440004
       VCID: 48C95F4082BED7B7417-801C
                        Reset counter: 174
                        Mileage: 131003 km
                        Date: 2020.01.25
                        Time: 12:33:42
       Part No SW: 4L0 910 289 K    HW: 4L0 907 289 K
       Component: Komfortgeraet   H12 0130
       Revision: 0130 ---    Serial number: 01923060450000
       Coding: 3569949
       VCID: 38292F80FE5EA737317-806C
    Address 47: Sound System
       Part No SW: 4F0 910 274 B    HW: 4F0 907 274
       Component: J793  RKA+      H04 0110
       Revision: 00000519    Serial number: 00005191001626
       Coding: 0693965
       VCID: 2313E8EC57D8D4EFF45-8076
                        Fault Status: 00101101
                        Reset counter: 174
                        Mileage: 131003 km
                        Date: 2020.01.25
                        Time: 14:42:25
                        Hex Value: 0x0000
                        Hex Value: 0x0000
                        Hex Value: 0x0005
                        Voltage: 10.70 V
                        Temperature: 17.0°C
                        (no units): 0.0
                        Reset counter: 174
                        Mileage: 131003 km
                        Date: 2020.01.25
                        Time: 14:42:25
                        Hex Value: 0x0000
                        Hex Value: 0x0000
                        Hex Value: 0x0005
                        Voltage: 10.70 V
                        Temperature: 17.0°C
                        (no units): 0.0
       Component: ILM Beifahrer   H16 0100
       Revision:             Serial number: 00000000136329
       Coding: 0012001
       VCID: 5EE599183C3AB9079BB-800A
                        Reset counter: 174
                        Mileage: 131000 km
                        Date: 2020.01.25
                        Time: 12:33:00
                        Voltage: 11.700 V
                        Temperature: 77.0°C
                        Reset counter: 174
                        Mileage: 131000 km
                        Date: 2020.01.25
                        Time: 12:37:00
                        Voltage: 11.700 V
                        Temperature: 20.0°C
       Component: TSG BF        H12 0362
       Revision:             Serial number: 0000054987468
       VCID: 47CB5C7C8FA0D8CF48D-8012
                        Reset counter: 174
       Part No SW: 4L0 910 357 B    HW: 4L0 907 357 B
       Component: AFS 1           H01 0010
       Coding: 0000031
       Component: AFS-Modul links H07 0004
       Component: AFS-Modul rechtsH07 0004
    Address 56: Radio
       Part No SW: 4F0 959 795 P    HW: 4F0 959 795 P
       Component: TSG HL        H11 0362
       Revision:             Serial number: 0000055001172
       Coding: 010E57204040230004
       VCID: 46D5517888AAC1C7B3B-8012
                        Reset counter: 174
                        Mileage: 131003 km
                        Date: 2020.01.25
                        Time: 12:33:42
    Address 69: Trailer (J345)       Labels:. 4E0-907-383.clb
       Part No SW: 4E0 907 383 J    HW: 4E0 907 383 J
       Revision: 2A001001    Serial number: 00000193095646
       Coding: 0200000000000000
       VCID: 313F12A41124767F769-8064
       Revision: --H07---    Serial number: 525PA8-J32414U
       Coding: 1021201
       Part No SW: 4L0 910 945     HW: 4L0 827 851 E
       Component: ValeoHeckdeckel H57 0500
       Revision: --H57001    Serial number: E5030000B
       Shop #: WSC 98765 666 38354
       VCID: 6C81C3D0FA86DB9705F-8038
    ó
       Subsystem 3 - Serial number: RD08.03.13--H57001002F0125˙
       Subsystem 4 - Serial number: 2F0125˙
       Component: ILM HINTEN 2    H08 0080
       Revision: AAH08080    Serial number: 132362311-----
       Coding: 0003595
       VCID: 2615F1F824EA21C793B-8072
       Component: J_245_EE16_SKB10H14 0220
       Component: J_394_EE16_SKB10H14 0220
       Component: J_392_EE16_SKB10H14 0220
                        Reset counter: 174
                        Mileage: 131003 km
                        Date: 2020.01.25
                        Time: 12:37:28
       Component: TSG HR        H11 0362
       Revision:             Serial number: 0000055015644
                        Reset counter: 174
    End----------(Elapsed Time: 01:59, VBatt start/end: 14.4V/14.4V)-----------
    VCDS Distributor AIB Wolfgang's Avatar
    Sep 2014
    Hello
    disconnect the optical bus on the sound system and bridge with a "loopback" 4E0-973-802 for Most-Bus
    will bring you the best result
    -Wolfgang
    Drive more talk less
  8. Likes Uwe liked this post
    Quote Originally Posted by AIB Wolfgang View Post
    Hello
    It seems to me the fault is most likely in the Radio, no?
  10. #8
    Jan 2020
    OKC, OK, USA
    Hello
    I have the loopback tool and tested the amp. I am going to test what i think is the radio module tonight. Im having a hard time finding a diagram that shows me where each one of the modules are at to be able to test them. Had to get radio removal tools for this one tonight and they came in the mail today.
  11. #9
    Jan 2020
    OKC, OK, USA
    Well that wasnt the radio module it was the MMI module or in the optical ring test 5F - Information Elec.
    Now to track down the Radio module....
  12. #10
    Jan 2020
    OKC, OK, USA
    If anyone runs across this in the future these Bypass loops work perfect. I put them inline while i am waiting on the new radio module and everything in the car works again. I hjave absolutely nothing to do with this company just posting them up because i have tested this exact one and it works.
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
  13. Likes Uwe liked this post
