Page 9 of 9 FirstFirst ... 789
Results 81 to 89 of 89
Thread: need a little help or a lot i mean
  1. #81
    United States
    Hi John,
    The brake issue sounds mechanical but after digging in the parts catalog for an unrelated 2011/2012 S3 inquiry it looks like the molded brake vacuum hoses with check valves, brake boosters and master cylinders vary wildly. My recommendation would be using a VIN based parts resource such as PartsLink24 to compare PR Codes and part numbers with the parts on the car.
    I would run the VIN from this car, the donor car and in addition to similar vehicles you may find online with complete scans for comparison. On that note I would do the same with the wiring research related to the start/stop issue. erWin Audi would be your best bet for the wiring diagrams however VW/Audi SSP (s) may be helpful for the Start/Stop system concepts and involved controllers.
  2. Likes Uwe liked this post
  3. #82
    Jan 2015
    Thanks Dana, I've got another issue that is driving me made,
    I have a fault code 008852 fuel pressure regulator valve ( N276) p2294-004-open curcuit
    This I'd really getting to me, as I want to drive the thing for a test drive, but it just go's into limp, I'm trying to figure this out, can anyone help in tracing this fault, and can anyone tell me where the 2 wires go I no one go's to the ecu , can remember which pin but can't find where the other wire go's so I can see if the is a break in one of the wire, for there to be an open circuit, I've tried and changed over the HPFP with n276 on it but no help at all, please can someone point me in the right direction and also can anyone tell me if there is a relay or fuse that runs this N276" I can't understand the wire diagrams really if I'm honest, thanks guy's O and are there other things that could cause this open circuit , thanks
  4. #83
    Jan 2015
    Found my latest problem turns out I had moved a fuse under bonnet into wrong place
  5. Likes Dana liked this post
  6. #84
    United States
    Quote Originally Posted by John ler View Post
    Sounds like you got it sorted but this should help http://forums.ross-tech.com/showthre...eo-%28draft%29
    Edit, Whoops! I didn't realize both were removed so those you tube links won't work ATM .. but feel free to post in that thread if you want an update from Jef on the status.
  7. Likes Uwe liked this post
  8. #85
    Jan 2015
    Had the car out for a drive, I forgot how nice they are, is there any way of finding out if the car has been mapped or had any stage tune on it, ?.thanks
  9. #86
    Check how much manifold pressure it's requesting -- MVB 115 should have both requested and actual.
  10. Likes Dana liked this post
  11. #87
    Jan 2015
    Hi still got this car, and still got faults, need some help, I have airbag faults drivers and passengers side crash sensors open circuit, my quest is dose anyone no if there are and sensors in the doors on my 3 doors Audi s3, I've kind of tested some semsors , by moving and swapping around, as 4 semsors have same part number, I just can not find this fault and I've put about 20years on from buying this car, many thanks, I no you'll sak for another auto scan, that I'll add a bit later, as car battery have now gone flat, thanks agin please help
  12. #88
    Jan 2015
    Sunday,14,August,2016,12:30:41:38444
    VCDS Version: 16.8.0.3 (x64)
    Data version: 20160803 DS255
    VIN: WAUZZZ8P   License Plate: 1ST
                    Address 15: Airbags       Labels: 8P0-959-655-10.clb
    Control Module Part Number: 8P0 959 655 S    HW: 8P0 959 655 S
      Component and/or Version: Airbag AU1042 H10 0250
               Software Coding: 30314238303830303037554A305238503053
                Work Shop Code: WSC 06314 000 00000
                  ASAM Dataset: EV_Airba10AURB4 001001 (AU35)
                           ROD: EV_Airba10AURB4.rod
                          VCID: 52A1624C05796DD246-8006
    9443093 - Driver's Side Airbag Crash Sensor
                 B1017 15 [137] - Open or Short to Plus
                        Mileage: 60694 km
                        Date: 2015.02.11
                        Time: 00:26:02
    9451029 - Crash sensor side airbag; passenger side
                 B1036 15 [137] - Open or Short to Plus
    can anyone point me in the right direction to what my problem is, and where to look check thanks where is the drivers side crash sensor please on audi a3
  13. #89
    Jan 2015
    Bosnia and Herzegovina
    i think that crash sensor is under door card, but i would also check wires in grommet coming from a pillar to door, most of the time they break
  14. Likes Uwe liked this post
