Page 4 of 9 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 89
Thread: need a little help or a lot i mean
  1. #31
    Feb 2015
    Quote Originally Posted by John ler
    [...]the ones I needed to connect to for the dsg was one orange and brown and the other orange and black[...]
    It's best if you double check which pin numbers you connected to and in which location. On newer vehicles, the Drive CAN is green/yellow and white/yellow, and when the colours you told above are used (they are ok, made so by factory), we need to be aware that the Drive CAN and Diagnostic CAN use the same colours.
    If placed on the diagnostic bus, you can talk to the control unit via VCDS, but the car can't nessacarely talk to the module.
    When I go isn't gearbox I can see its in P and that's what the clusters say, it's in park, and when pressing the paddles it shows them activated when pressing, dose this mean there is something communicating somewhere along the lines,[...]
    This points to the module being wired and coded correctly. The paddles are connected through the steering column electronics control module, so if you can read those from the 02 AutoTrans module measuring blocks, and if the instrument cluster (17) receives and displays the correct position, then it would indicate that the control module is wired correctly in terms of CAN.
    I don't think the ABS module would prevent the engine from cranking, but as you sort these wiring and communication issues, less possible error origins are possible, and you should also be able to communicate with more and more modules correctly to get maybe more information on what's wrong.
    We also have to remember, that the missing engine crank could result from psysical problems rather than coding, but with coding and issues solved, we should get more information. *
  2. #32
    United States
    Great. Please post that scan and this may be helpful for posting pics:
    http://forums.ross-tech.com/showthre...-Post-Pictures
  3. #33
    Jan 2015
    Many thanks for your help guys. I'll post the scan tomorrow . I really do appreciate your time and advice, John
    With a direct feed to starter. The car will crank fine. But not by using the key,
  4. #34
    Jan 2015
    Thursday,19,February,2015,17:31:20:38444
    VCDS Version: 14.10.1.1 (x64)
    Data version: 20150130
    VIN: WAUZZZ8P4AA151399   License Plate: NEW 19TH
    Mileage: 75370km-46832mi   Repair Order:
    Chassis Type: 8P (1K0)
    Scan: 01 02 03 08 09 15 16 17 19 22 25 2E 37 42 44 46 47 52 55 56
              77 A6
    VIN: WAUZZZ8P4AA151399   Mileage: 75370km-46832miles
    2E-Media Player 3 -- Status: Cannot be reached 1100
    A6-Microphone -- Status: Cannot be reached 1100
    Address 01: Engine (CDL)       Labels: 06F-907-115-CDL.clb
       Part No SW: 8P0 907 115 AP    HW: 8P0 907 115 B
       Component: 2.0l R4/4V TFSI     0010
       Revision: 5BH19---    Serial number: AUX7Z0J2FNC0JK
       Coding: 0103000C1C0F0060
       Shop #: WSC 00024 000 00000
       VCID: 0005980453952F216E0-8055
    Readiness: 0110 0101
       Part No SW: 02E 300 012 N    HW: 02E 927 770 AL
       Component: GSG DSG AG6     511 2115
       Revision:    51112    Serial number: 00001003050064
       Shop #: WSC 06314 000 00000
       VCID: 1B3FCF68DA33ECF99B2-804E
       Part No SW: 1K0 907 379 AJ    HW: 1K0 907 379 AJ
       Revision: 00H30001
       VCID: 7AF1EAECF54975F1204-802F
                        Reset counter: 69
                        Mileage: 75378 km
                        Date: 2013.12.05
                        Time: 00:19:02
                        Count: 3
                        Count: 14
                        Count: 12800
                        Count: 320
                        Count: 42496
                        Reset counter: 69
                        Mileage: 75378 km
                        Date: 2013.12.05
                        Time: 00:21:02
                        Count: 7
                        Count: 14
                        Count: 29184
                        Count: 195
                        Count: 42496
                        Fault Status: 01100101
                        Reset counter: 69
                        Mileage: 75378 km
                        Date: 2013.12.05
                        Time: 00:19:02
                        Count: 3
                        Count: 14
                        Count: 12800
                        Count: 279
                        Count: 42496
                        Reset counter: 69
                        Mileage: 75378 km
                        Date: 2013.12.05
                        Time: 00:19:02
                        Count: 3
                        Count: 14
                        Count: 12800
                        Count: 295
                        Count: 42496
                        Reset counter: 69
                        Mileage: 75378 km
                        Date: 2013.12.05
                        Time: 00:19:02
                        Count: 3
                        Count: 14
                        Count: 12800
                        Count: 270
                        Count: 42496
       Part No SW: 8P0 820 043 BN    HW: 8P0 820 043 BN
       Component: KlimavollautomatH09 0180
       Revision: 000214      Serial number: 8P0820043BN
       VCID: 79F3F5E0304F7EE929E-802C
                        Reset counter: 69
                        Mileage: 75378 km
                        Date: 2013.12.04
                        Time: 00:00:52
    Address 09: Cent. Elect. (J519)       Labels: 8P0-907-063.clb
       Part No SW: 8P0 907 063 A    HW: 8P0 907 063 A
       Component: BCM PQ35  M   105 0575
       Revision: 00105 AK
       Coding: 06000A2FB005F200207241E00000094C431E25AA304DD929E40008840040
       VCID: 326102CC6DB94DB1A84-8067
       Subsystem 1 - Part No SW: 8P2 955 119 F    HW: 8P2 955 119 F  Labels: 1KX-955-119.CLB
       Component: Wischer AU350  H11 0050
       Coding: 00DD13
       Subsystem 4 - Part No: 1K0 907 719 C
       Component: Neigungssenso  005 0003
                        Reset counter: 69
                        Mileage: 75378 km
                        Date: 2013.12.05
                        Time: 00:16:38
                        Voltage: 11.85 V
                            Term 50 Off
    00323 - Vehicle Inclination Sensor (G384)
                        Reset counter: 69
                        Mileage: 75378 km
                        Date: 2013.12.05
                        Time: 00:22:42
                        Voltage: 11.90 V
                            Term 50 Off
    Address 15: Airbags (J234)       Labels: 8P0-959-655-10.clb
       Part No SW: 8P0 959 655 S    HW: 8P0 959 655 S
       Component: Airbag AU1042 H10 0250
       Revision: --------    Serial number: 003JU0085SAH
       Coding: 30314238303830303037554A305238503053
       ROD: EV_Airba10AURB4.rod
       VCID: 52A1624C05796DB1884-8007
       Serial number: 35128RB4000056DDD34W
       Serial number: 35228RB4000056DEEFFF
       Serial number: 35547RB4000057B42AEX
       Serial number: 35647RB4000057B432DQ
    9443093 - Driver's Side Airbag Crash Sensor
                 B1017 15 [137] - Open or Short to Plus
                        Mileage: 75378 km
                        Date: 2013.12.04
                        Time: 03:03:18
    9451029 - Crash sensor side airbag; passenger side
                 B1036 15 [137] - Open or Short to Plus
                        Mileage: 75378 km
                        Date: 2013.12.04
                        Time: 03:03:18
    9445397 - Key switch for deactivation of passenger-side airbag
                 B1020 15 [137] - Open or Short to Plus
                        Mileage: 75378 km
                        Date: 2013.12.04
                        Time: 03:03:19
    9446677 - Redundant signal path for airbag shut-off; passenger side
                 B1025 15 [137] - Open or Short to Plus
                        Mileage: 75378 km
                        Date: 2013.12.04
                        Time: 03:03:19
       Part No SW: 8P0 953 549 K    HW: 8P0 953 549 K
       Coding: 0012112
       VCID: 46894E1C3131C11114C-8013
       Component: E0221           H06 0030
    Address 17: Instruments        Labels: 8P0-920-xxx-17-MY8.clb
       Part No SW: 8P0 920 932 E    HW: 8P0 920 932 E
       Component: KOMBIINSTR. VDO H03 0990
       Revision: D0H03005    Serial number: 2242J005003844
       Coding: 0001128
       Shop #: WSC 00288 264 135309
       VCID: 36693EDC41D1519184C-8063
    00003 - Control Module
                014 - Defective
                        Fault Status: 01101110
                        Mileage: 75378 km
                        Date: 2013.12.03
                        Time: 00:00:03
    00771 - Fuel Level Sensor (G)
                007 - Short to Ground
                        Fault Status: 01100111
                        Reset counter: 69
                        Mileage: 75378 km
                        Date: 2013.12.04
                        Time: 03:03:16
                014 - Defective
                        Reset counter: 69
                        Mileage: 75378 km
                        Date: 2013.12.05
                        Time: 00:15:13
    Address 19: CAN Gateway        Labels: 1K0-907-530-V4.clb
       Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
       Component: J533  Gateway   H16 0233
       Revision:   H16       Serial number: 4520K103150268
       Coding: ED831F06500612080100
       Shop #: WSC 06314 123 12345
       VCID: 69D3A5A040EFCE69D9E-803C
                        Reset counter: 69
                        Mileage: 75378 km
    03272 - Control Module for Audio Interface
                        Reset counter: 69
                        Mileage: 75378 km
    03753 - Control Module for Microphone
                        Reset counter: 69
                        Mileage: 75378 km
    Address 22: AWD        Labels: Redir Fail!
       Part No SW: 0BR 907 554 A    HW: 0BR 907 554 A
       Component: Haldex 4Motion      3016
       Coding: 0000005
       VCID: 438F57080203F439332-8016
       Revision: D0H03005    Serial number: AUX7Z0J2FNC0JK
       Shop #: WSC 00288 264 182592
    Address 2E: Media Player 3
    Address 37: Navigation        Labels: 8E0-035-192-RNSE.lbl
       Part No SW: 8P0 035 193 G    HW: 8P0 035 193 G
       Component: RNS-E PU EU     H06 0200
       Revision: 0000012S    Serial number: AUZBZ7MD207074
       Coding: 0209725
       Shop #: WSC 00762 210 97024
       VCID: 346D04D457AD4381BA8-8061
                        Reset counter: 69
                        Mileage: 75378 km
                        Date: 2013.12.05
                        Time: 00:16:35
                        Mileage: 75370 km
                        Count: 512
                        Clock: 00:16
                        Reset counter: 69
                        Mileage: 75378 km
                        Date: 2013.12.05
                        Time: 00:16:18
                        Bin. Bits: 00000000 00000000
                        Bin. Bits: 10000000 00000000
    Address 42: Door Elect, Driver        Labels: 8P0-959-801-MAX3.lbl
       Part No SW: 8P0 959 801 M    HW: 8P0 959 801 M
       Component: Tuer-SG         H04 0100
       Coding: 0004148
       VCID: 458B49100C37CA091D6-8010
    00096 - Drivers Door Central Locking (Safe) Motor (V161)
       Part No: 1K0 909 144 P
       Component: EPS_ZFLS Kl. 233    3305
       Revision: 00H22000
       VCID: 377733D846DBA8999FA-8062
                        Fault Status: 11100101
                        Mileage: 75378 km
                        Date: 2013.12.04
                        Time: 03:03:16
                        Battery Volts: 12.0 V
                            DD
                        Temperature: 14.0*C
                        Count: 3
                        Steering Angle: 0.00*
                            SteerAng n.Init
    Address 47: Sound System
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.lbl
       Part No SW: 8P0 959 802 M    HW: 8P0 959 802 M
       Coding: 0004148
    01553 - Motor for Central Locking; Passenger Door (V57); Lock
    00097 - Front Passengers Central Locking (Safe) Motor (V162)
       Part No: 8P3 907 357
       Coding: 0000013
       VCID: 7AF1EAEC354975F1204-802F
    00497 - Sensor for Vehicle Leveling; Rear
                        Fault Status: 11101010
                        Reset counter: 69
                        Mileage: 75384 km
                        Date: 2013.12.04
                        Time: 03:03:16
    Address 56: Radio        Labels: 8E0-035-192-RNSE.lbl
       Coding: 0209725
                        Reset counter: 69
                        Mileage: 75378 km
                        Date: 2013.12.05
                        Time: 00:16:35
                        Mileage: 75370 km
                        Count: 512
                        Clock: 00:16
                        Reset counter: 69
                        Mileage: 75378 km
                        Date: 2013.12.05
                        Time: 00:16:18
       Part No SW: 8P1 862 335 A    HW: 8P1 862 335
       Component: FSE_256x BT     H44 0660
       Revision: 00000000    Serial number: 00000005522442
       Coding: 0011422
       VCID: 356B39D05CD75A898D6-8060
    Address A6: Microphone
    End-------------------------(Elapsed Time: 02:48)--------------------------
  5. #35
    Feb 2015
    Quote Originally Posted by John ler View Post
       Revision: 00H30001
    You got communication working to the ABS controller - great job. I see a few faults have changed in your scan, but most are the same. There are plenty of these faults that will either resolve themselves, or that we can probably easily help you resolve, but for now, let's focus on the faults keeping the car from being driveable.
    You need to code the ABS module, but this is not a task I can help you with. Part of the vehicle VIN is entered into the coding along with a range of other things, that I don't know about. I will suggest that you wait for Dana to reply, as I'm sure she can assist better than I with this, but to prepare (so she can help you better), I think it will be good if you post the VIN (Vehicle Identification Number) of both the vehicle that the unit is currently installed into, as well as the VIN of the donor vehicle it came from, if applicable. Maybe Dana will need other informations, but my guess is that those would be the bare minimum in combination with the autoscan you posted.
    I'll keep an eye on this thread as well, so I can pitch in once again when the ABS is sorted and we may be moving on to other solutions.
    Kind regards,
    Nicolai
  6. Likes Uwe liked this post
  7. #36
    Jan 2015
    Thanks, I think the vin shows on the scan?, all the controllers and moduels belong to this vin/car that I'm scanning, there is only the loom that is from the cashed car, everything is original from factory,
  8. #37
    Jan 2015
    One other thing can you see anything on the scan that would stop the car from starting / cranking
  9. #38
    Feb 2015
       Revision: 00H30001
                        Reset counter: 69
                        Mileage: 75378 km
                        Date: 2013.12.05
                        Time: 00:19:02
                        Count: 3
                        Count: 14
                        Count: 12800
                        Count: 279
                        Count: 42496
    I think that the lack of adaptation for the G201 sensor means, that it does not send any value to the ABS (and other) control modules. This sensor determines how hard the driver depresses the brake pedal. This information is used by the DSG to determine when to disengage the clutch (amongst other things), since the DSG (unlike a traditional automatic transmission) doesn't just stupidly apply power to a fully braked vehicle, but rather waits untill the brake is eased before applying power to the transmission.
    I believe this sensor could also be used to determine if the driver depresses the brake pedal far enough to allow engine start/gear selector lever release. Like I mentioned earlier in the thread, I had the impression that I needed to depress the brake pedal semi firmly to be allowed to move the gear lever, and I believe it might only allow (unlock) movement of the gear selector (and possibly start condition for the engine), when the applied braking pressure is high enough to disengage the clutch packs in the gear box.
    The sensor will most likely not be able to complete adaptation, untill the control module is properly coded. Once coded, the adaptation can be reset, and then the proper adaptation can be followed (Google G201 adaptation).
  10. #39
    Jan 2015
    Ok thanks, I'll carry on and wait to see if anyone else can help with abs. Many thanks
  11. #40
    United States
    I may need Sebastian and/or Niels in on this MK60EC1 coding .. because we can so some of them but it is possible that this car will need to go to the dealer for SVM if we can't.
    Just to be 100% crystal clear. Is the VIN on the windshield/door jamb WAUZZZ8P4AA151399 and was this car born with that 1K0 907 379 AJ controller?
  12. Likes Uwe liked this post
