Wednesday,07,January,2015,18:07:27:38444
VCDS Version: 14.10.0.0 (x64)
Data version: 20141022
VIN: WAUZZZ8P7CA154302 License Plate: 10 PLATE 1ST
Mileage: 5100km-3168mi Repair Order:
Chassis Type: 8P (7N0)
Scan: 01 02 03 08 09 15 16 17 19 22 25 42 44 46 52 55 56 61 62 72
77
VIN: WAUZZZ8P7CA154302 Mileage: 5100km-3168miles
02-Auto Trans -- Status: Not registered 0011
08-Auto HVAC -- Status: Malfunction 1010
22-AWD -- Status: Not registered 0011
42-Door Elect, Driver -- Status: Malfunction 1010
52-Door Elect, Pass. -- Status: Malfunction 1010
55-Headlight Range -- Status: Malfunction 1010
62-Door, Rear Left -- Status: Cannot be reached 1100
72-Door, Rear Right -- Status: Cannot be reached 1100
Address 01: Engine
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 012 N HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2115
Revision: 51112 Serial number: 00001003050064
Shop #: WSC 06314 000 00000
VCID: 1B3FCF68DA33ECF99A9-804E
8 Faults Found:
18258 - Powertrain Data Bus
P1850 - 000 - Missing Message from ECU
Fault Frequency: 255
Reset counter: 40
18270 - Powertrain Data Bus
P1862 - 000 - Missing Message from Instrument Cluster - Intermittent
Reset counter: 40
28775 - No Communication with Gear Selector Module
U0103 - 000 -
Reset counter: 40
18097 - Powertrain Data Bus
P1689 - 000 - Implausible Message from Elect. Load Controller - Intermittent
Reset counter: 40
18275 - Powertrain Data Bus
P1867 - 000 - Missing Message from Steering Wheel (J527) - Intermittent
Reset counter: 40
01196 - Engine-Transmission Data Bus
Reset counter: 40
18288 - Powertrain Data Bus
P1880 - 000 - Missing Message from Diagnostic Gateway - Intermittent
Reset counter: 40
U0103 - 004 -
Reset counter: 0
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AJ HW: 1K0 907 379 AJ
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
VCID: 7AF1EAECF54975F121F-802F
10 Faults Found:
Reset counter: 101
Mileage: 5102 km
Date: 2014.03.25
Time: 00:00:13
Count: 7
Count: 14
Count: 4608
Count: 8192
Count: 44544
Count: 65024
Reset counter: 101
Mileage: 5102 km
Date: 2014.03.25
Time: 00:00:14
Count: 7
Count: 14
Count: 4608
Count: 8194
Count: 43776
Count: 65279
Fault Status: 00100101
Reset counter: 101
Mileage: 263434 km
Date: 2001.12.04
Time: 16:04:08
Count: 776
Count: 80
Count: 17664
Count: 212
Count: 256
Count: 20481
Count: 64
Count: 17665
Fault Status: 00101100
Reset counter: 69
Count: 7
Count: 12
Count: 512
Count: 80
Count: 45312
Count: 65280
Reset counter: 69
Count: 7
Count: 12
Count: 512
Count: 64
Count: 45312
Count: 65280
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.25
Time: 00:00:19
Count: 3
Count: 2
Count: 4608
Count: 166
Count: 45056
Count: 65024
Reset counter: 101
Mileage: 5102 km
Date: 2014.03.25
Time: 00:00:19
Count: 3
Count: 2
Count: 4608
Count: 195
Count: 45056
Count: 65024
Fault Status: 01100101
Reset counter: 101
Date: 2025.04.00
Time: 16:04:28
Count: 256
Count: 42581
Count: 256
Count: 279
Count: 166
Count: 256
Count: 50021
Count: 256
Reset counter: 101
Mileage: 5102 km
Date: 2014.03.25
Time: 00:00:22
Count: 7
Count: 2
Count: 4608
Count: 295
Count: 44032
Count: 65024
Reset counter: 101
Mileage: 5102 km
Date: 2014.03.25
Time: 00:00:22
Count: 7
Count: 2
Count: 4608
Count: 270
Count: 44032
Count: 65024
Part No SW: 8P0 820 043 BN HW: 8P0 820 043 BN
Component: KlimavollautomatH09 0180
Revision: 000214 Serial number: 8P0820043BN
VCID: 79F3F5E0304F7EE9285-802C
12 Faults Found:
Reset counter: 40
Mileage: 5102 km
Date: 2014.03.19
Time: 19:02:20
Reset counter: 40
Mileage: 5102 km
Date: 2014.03.20
Time: 12:56:58
Fault Status: 00101001
Reset counter: 40
Temperature: -50.0°C
Voltage: 12.90 V
01856 - Temperature Sensor for Heated Seat; Front Right (G345)
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 18
Mileage: 5102 km
Date: 2014.03.25
Time: 14:42:54
Temperature: 12.0°C
01855 - Temperature Sensor for Heated Seat; Left Front (G344)
Reset counter: 18
Mileage: 5102 km
Date: 2014.03.25
Time: 14:52:06
Temperature: 12.0°C
Reset counter: 141
Fault Status: 00101010
Reset counter: 40
Reset counter: 141
Reset counter: 101
Mileage: 5102 km
Date: 2014.03.28
Time: 00:08:45
01301 - Control Module for Voice Recognition (J507)
Reset counter: 141
Reset counter: 101
Mileage: 5102 km
Date: 2014.03.28
Time: 00:01:10
Reset counter: 101
Mileage: 5102 km
Date: 2014.03.28
Time: 00:01:11
Address 09: Cent. Elect. (J519) Labels: 8P0-907-063.clb
Part No SW: 8P0 907 063 A HW: 8P0 907 063 A
Component: BCM PQ35 M 105 0575
Revision: 00105 AK
Coding: 06000A2FB005F200207241E00000094C431E25AA304DD929E40008840040
VCID: 326102CC6DB94DB1A9F-8067
30 Faults Found:
Reset counter: 141
Mileage: 70531 km
Date: 2013.09.16
Time: 17:44:21
Voltage: 14.00 V
Term 50 Off
00910 - Indicator Lamp for Emergency Flashers (K6)
Fault Status: 00100111
Reset counter: 109
Mileage: 75377 km
Date: 2013.12.03
Time: 17:25:23
Term 15 Off
Voltage: 12.55 V
Term 50 Off
Fault Frequency: 26
Reset counter: 101
Mileage: 5102 km
Date: 2014.03.25
Time: 00:00:17
Voltage: 12.90 V
Term 50 Off
01800 - Light Switch (E1)
Fault Frequency: 10
Reset counter: 141
Term 15 Off
Voltage: 12.65 V
Term 50 Off
00887 - Switch for Emergency Flasher (E229)
Reset counter: 141
Term 15 Off
Voltage: 12.70 V
Term 50 Off
00323 - Vehicle Inclination Sensor (G384)
Reset counter: 101
Term 15 Off
Voltage: 12.70 V
Term 50 Off
01134 - Alarm Horn (H12)
Reset counter: 141
Term 15 Off
Voltage: 12.70 V
Term 50 Off
Reset counter: 69
Term 15 Off
Voltage: 12.70 V
Term 50 Off
03020 - Local databus 2
Reset counter: 141
Term 15 Off
Voltage: 12.70 V
Term 50 Off
002 - Lower Limit Exceeded
Fault Status: 01100010
Reset counter: 101
Term 15 Off
Voltage: 12.55 V
Term 50 Off
00153 - Windshield Wiper Motor; Driver Side (V216)
Reset counter: 101
Voltage: 11.85 V
Term 50 Off
01064 - Terminal 58d; Interior Dimming
Reset counter: 141
Voltage: 11.65 V
Term 50 On
01505 - Bulb for Blinkers; Rear Right (M8)
Reset counter: 109
Voltage: 11.70 V
Term 50 Off
00985 - Right Tail Light (M2)
Fault Frequency: 17
Reset counter: 141
Voltage: 11.80 V
Term 50 Off
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
Reset counter: 141
Term 15 Off
Voltage: 12.45 V
Term 50 Off
00834 - Signal for Activation of Heated Rear Window
Reset counter: 141
Mileage: 5102 km
Time: 31:63:63
Term 15 Off
Voltage: 13.45 V
Term 50 Off
Reset counter: 141
Mileage: 5102 km
Time: 31:63:63
Term 15 Off
Voltage: 13.45 V
Term 50 Off
01259 - Fuel Pump Relay (J17)
Reset counter: 141
Mileage: 5102 km
Time: 31:63:63
Term 15 Off
Voltage: 13.45 V
Term 50 Off
03266 - Control Circuit for Signal Horn
Reset counter: 141
Mileage: 5102 km
Time: 31:63:63
Term 15 Off
Voltage: 13.45 V
Term 50 Off
03396 - Supply voltage terminal 30 for central locking
Fault Status: 00101011
Reset counter: 141
Mileage: 5102 km
Date: 2014.03.25
Time: 00:00:01
Term 15 Off
Voltage: 13.45 V
Term 50 Off
Fault Frequency: 26
Reset counter: 101
Mileage: 5102 km
Date: 2014.03.25
Time: 00:00:17
Voltage: 12.90 V
Term 50 Off
00984 - Left Tail Light (M4)
Reset counter: 141
Mileage: 5102 km
Date: 2014.03.25
Time: 00:00:17
Voltage: 12.90 V
Term 50 Off
01403 - Glass-Break Sensors; Rear
Reset counter: 141
Mileage: 5102 km
Date: 2014.03.25
Time: 00:00:19
Voltage: 12.85 V
Term 50 Off
00956 - Key 2
Reset counter: 101
Mileage: 5102 km
Term 15 Off
Voltage: 12.95 V
Term 50 Off
00955 - Key 1
Reset counter: 101
Mileage: 5102 km
Date: 2014.03.25
Time: 00:00:15
Term 15 Off
Voltage: 13.00 V
Term 50 Off
00059 - Terminal 30 for Interior Lighting
Reset counter: 141
Mileage: 5102 km
Date: 2014.03.25
Time: 00:00:09
Term 15 Off
Voltage: 13.40 V
Term 50 Off
00185 - Control Circuit; Relay for Supply Voltage Terminal 15
Reset counter: 141
Mileage: 5102 km
Date: 2014.03.25
Time: 00:00:12
Voltage: 13.15 V
Term 50 Off
Reset counter: 101
Mileage: 5102 km
Date: 2014.03.28
Time: 00:07:51
Term 15 Off
Voltage: 12.75 V
Term 50 Off
Reset counter: 101
Mileage: 5102 km
Date: 2014.03.28
Time: 00:07:51
Term 15 Off
Voltage: 12.75 V
Term 50 Off
Reset counter: 101
Mileage: 5102 km
Date: 2014.03.25
Time: 00:00:15
Voltage: 13.00 V
Term 50 Off
Address 15: Airbags (J234) Labels: 8P0-959-655-10.clb
Part No SW: 8P0 959 655 S HW: 8P0 959 655 S
Component: Airbag AU1042 H10 0250
Revision: -------- Serial number: 003JU0085SAH
Coding: 30314238303830303037554A305238503053
ROD: EV_Airba10AURB4.rod
VCID: 52A1624C05796DB189F-8007
Serial number: 35128RB4000056DDD34W
Serial number: 35228RB4000056DEEFFF
Serial number: 35547RB4000057B42AEX
Serial number: 35647RB4000057B432DQ
15 Faults Found:
9443093 - Driver's Side Airbag Crash Sensor
B1017 15 [137] - Open or Short to Plus
9451029 - Crash sensor side airbag; passenger side
B1036 15 [137] - Open or Short to Plus
9440027 - Driver's side; side-airbag igniter
B100B 1B [137] - Resistance Too High
9438491 - Igniter for Driver head airbag
B1005 1B [136] - Resistance Too High
9439771 - Front Passenger's Side Airbag Igniter
B100A 1B [137] - Resistance Too High
9438235 - Igniter for Front passenger's Head Curtain Airbag
B1004 1B [136] - Resistance Too High
9437723 - Igniter for Passenger's Airbag
B1002 1B [136] - Resistance Too High
B1006 1B [136] - Resistance Too High
9439002 - Igniter for Seat Belt Tensioner; Passenger's Side
B1007 1A [136] - Resistance Too Low
9445376 - Key switch for deactivation of passenger-side airbag
B1020 00 [000] - -
000000 - SAE - Reserved by Document ISO 15031-6
P0000 00 [000] - 2005
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
Component: J0527 H37 0070
Coding: 0012112
VCID: 46894E1C3131C111157-8013
Component: E0221 H06 0030
6 Faults Found:
01304 - Radio
02413 - Switch for Selector Lever Position P Lock (F319)
00194 - Ignition Key Removal Lock
00002 - Transmission Control Unit
Part No SW: 8P0 920 983 A HW: 8P0 920 983 A
Component: KOMBIINSTR. VDO H04 0150
Revision: D0H04003 Serial number: 2243L003000800
Coding: 0261428
Shop #: WSC 00762 210 97024
VCID: 387530E44BC5A7E197B-806D
Reset counter: 40
Mileage: 4978 km
Date: 2013.11.11
Time: 12:26:09
00532 - Supply Voltage B+
Reset counter: 40
Mileage: 4978 km
Date: 2013.11.11
Time: 12:28:16
Reset counter: 141
Mileage: 5102 km
Date: 2014.03.25
Time: 14:11:22
00438 - Fuel Supply Sensor 2 (G169)
Reset counter: 141
Mileage: 5102 km
Date: 2014.03.25
Time: 00:00:32
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 S HW: 7N0 907 530 J
Component: J533 Gateway H43 1632
Revision: H43 Serial number: 130712F2002796
Coding: 352103
VCID: 40855804D315EF212FB-8015
14 Faults Found:
01312 - Powertrain Data Bus
Reset counter: 141
Mileage: 5102 km
Date: 2014.03.25
Time: 00:00:14
Reset counter: 101
Mileage: 5102 km
Date: 2014.03.25
Time: 00:00:13
01771 - Control Module for Headlight Range (J431)
Fault Status: 00110100
Reset counter: 141
Mileage: 5102 km
Date: 2014.03.25
Time: 00:00:15
Fault Frequency: 89
Reset counter: 141
Date: 2014.11.20
Time: 18:30:45
Reset counter: 141
Reset counter: 141
Mileage: 5102 km
Date: 2014.03.25
Time: 00:00:01
Reset counter: 101
Mileage: 5102 km
Date: 2014.03.25
Time: 00:00:01
Reset counter: 101
Reset counter: 141
Reset counter: 141
Reset counter: 141
Mileage: 5102 km
Date: 2014.03.25
Time: 00:00:02
01304 - Radio
Reset counter: 101
Fault Frequency: 16
Mileage: 5102 km
Date: 2014.03.25
Time: 00:00:18
03406 - Control Module for Battery Monitoring
Reset counter: 101
Mileage: 5102 km
Date: 2014.03.25
Time: 00:01:00
Address 22: AWD Labels: Redir Fail!
Part No SW: 0BR 907 554 A HW: 0BR 907 554 A
Component: Haldex 4Motion 3016
Coding: 0000005
VCID: 438F57080203F439329-8016
Subsystem 1 - Part No: 0BR 907 554 A
Revision: D0H04003 Serial number: AUX7Z0L3FNB0FH
01176 - Key
Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX3.lbl
Part No SW: 8P0 959 801 M HW: 8P0 959 801 M
Component: Tuer-SG H04 0100
Coding: 0004148
VCID: 458B49100C37CA091CD-8010
00096 - Drivers Door Central Locking (Safe) Motor (V161)
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 233 3305
Revision: 00H22000
VCID: 377733D846DBA8999E1-8062
Fault Status: 11100101
Battery Volts: 12.8 V
PD
Temperature: 6.0°C
Count: 2
Steering Angle: 0.00°
SteerAng n.Init
Fault Status: 00101101
Reset counter: 141
Mileage: 5102 km
Date: 2014.03.25
Time: 00:00:15
Voltage: 12.38 V
DU
Temperature: 6.0°C
RPM: 1498 /min
Reset counter: 101
Mileage: 5102 km
Date: 2014.03.25
Time: 00:00:15
Voltage: 12.38 V
DU
Temperature: 6.0°C
RPM: 1498 /min
Reset counter: 141
Voltage: 12.50 V
DU
Temperature: 9.0°C
RPM: 1498 /min
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 8P0 959 802 M HW: 8P0 959 802 M
Coding: 0004148
01553 - Motor for Central Locking; Passenger Door (V57); Lock
00097 - Front Passengers Central Locking (Safe) Motor (V162)
Address 55: Headlight Range (J431) Labels: 8X0-907-357.clb
Part No SW: 8X0 907 357 C HW: 8X0 907 357 B
Component: ****LWR12**** H02 0012
Serial number: 120412-0001-025
Coding: 1161A51010000000
ROD: EV_HeadlRegulBasic.rod
VCID: 4281520CD519FD3139F-8017
8 Faults Found:
0068 - Function Restricted due to Missing Message(s)
U1111 00 [137] - -
0080 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 141
0082 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 141
0084 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 141
0086 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 141
127242 - Rear Left Ride-Height Sensor
C1036 15 [137] - Open or Short to Plus
392714 - Positioning Motor for Headlight Range Left
C1085 15 [008] - Open or Short to Plus
Mileage: 5102 km
Date: 2014.03.25
Time: 19:11:40
392970 - Positioning Motor for Headlight Range Right
C1086 15 [008] - Open or Short to Plus
Mileage: 5102 km
Date: 2014.03.25
Time: 19:11:40
Address 56: Radio
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Part No SW: 7N0 907 534 HW: 7N0 907 530 J
Component: Batt.regelung H43 1632
Coding: F30F185A
VCID: 71E3CDC0A83F36A9905-8024
00458 - Control Module for Battery Monitoring (J367)
Reset counter: 101
Mileage: 5102 km
Date: 2014.03.25
Time: 00:01:13
02252 - Generator
Reset counter: 101
Mileage: 5102 km
Date: 2014.03.25
Time: 00:01:13
Address 62: Door, Rear Left
Address 72: Door, Rear Right
Part No SW: 8P1 862 335 A HW: 8P1 862 335
Component: FSE_256x BT H44 0660
Revision: 00000000 Serial number: 00000005522442
Coding: 0011422
VCID: 356B39D05CD75A898CD-8060
02503 - Output Wire to Radio
Reset counter: 18
Mileage: 5102 km
Date: 2014.03.25
Time: 19:10:34
01523 - Microphone for Telephone (R38)
Reset counter: 18
Time Indication: 15
Reset counter: 141
Time Indication: 15
01304 - Radio
Reset counter: 101
Mileage: 5102 km
Date: 2014.03.28
Time: 00:00:37
End-------------------------(Elapsed Time: 03:53)--------------------------
77
Address 01: Engine
8 Faults Found:
Reset counter: 40
U0103 - 000 -
Reset counter: 40
Reset counter: 40
Reset counter: 40
Reset counter: 40
Reset counter: 40
U0103 - 004 -
Reset counter: 0
Component: ESP MK60EC1 H30 ESP MK60EC1 H30 01070107
Revision: 00H30001
10 Faults Found:
Reset counter: 101
Mileage: 5102 km
Date: 2014.03.25
Time: 00:00:13
Raw, Form. N/A: 000 000 000
Reset counter: 101
Mileage: 5102 km
Date: 2014.03.25
Time: 00:00:13
Reset counter: 101
Mileage: 5102 km
Date: 2014.03.25
Time: 00:00:13
Reset counter: 101
Mileage: 5102 km
Date: 2014.03.25
Time: 00:00:13
Reset counter: 101
Mileage: 5102 km
Date: 2014.03.25
Time: 00:00:13
Reset counter: 101
Mileage: 5102 km
Date: 2014.03.25
Time: 00:00:13
Reset counter: 101
Mileage: 5102 km
Date: 2014.03.25
Time: 00:00:13
Reset counter: 101
Mileage: 5102 km
Date: 2014.03.25
Time: 00:00:13
Reset counter: 101
Mileage: 5102 km
Date: 2014.03.25
Time: 00:00:13
Reset counter: 101
Mileage: 5102 km
Date: 2014.03.25
Time: 00:00:13
12 Faults Found:
Reset counter: 40
Mileage: 5102 km
Date: 2014.03.19
Time: 19:02:20
Reset counter: 40
Mileage: 5102 km
Date: 2014.03.20
Time: 12:56:58
Reset counter: 40
Voltage: 12.90 V
Reset counter: 18
Mileage: 5102 km
Date: 2014.03.25
Time: 14:42:54
Temperature: 12.0°C
Reset counter: 18
Mileage: 5102 km
Date: 2014.03.25
Time: 14:52:06
Temperature: 12.0°C
Reset counter: 141
Reset counter: 40
Reset counter: 141
Reset counter: 101
Mileage: 5102 km
Date: 2014.03.28
Time: 00:08:45
Reset counter: 141
Reset counter: 101
Mileage: 5102 km
Date: 2014.03.28
Time: 00:01:10
Reset counter: 101
Mileage: 5102 km
Date: 2014.03.28
Time: 00:01:11
Revision: 00105 AK
30 Faults Found:
Reset counter: 141
Mileage: 70531 km
Date: 2013.09.16
Time: 17:44:21
Voltage: 14.00 V
Term 50 Off
Reset counter: 109
Mileage: 75377 km
Date: 2013.12.03
Time: 17:25:23
Term 15 Off
Voltage: 12.55 V
Term 50 Off
Fault Frequency: 26
Reset counter: 101
Mileage: 5102 km
Date: 2014.03.25
Time: 00:00:17
Voltage: 12.90 V
Term 50 Off
Fault Frequency: 10
Reset counter: 141
Term 15 Off
Voltage: 12.65 V
Term 50 Off
Reset counter: 141
Term 15 Off
Voltage: 12.70 V
Term 50 Off
Reset counter: 101
Term 15 Off
Voltage: 12.70 V
Term 50 Off
Reset counter: 141
Term 15 Off
Voltage: 12.70 V
Term 50 Off
Reset counter: 69
Term 15 Off
Voltage: 12.70 V
Term 50 Off
Reset counter: 141
Term 15 Off
Voltage: 12.70 V
Term 50 Off
Reset counter: 101
Term 15 Off
Voltage: 12.55 V
Term 50 Off
Reset counter: 101
Voltage: 11.85 V
Term 50 Off
Reset counter: 141
Voltage: 11.65 V
Term 50 On
Reset counter: 109
Voltage: 11.70 V
Term 50 Off
Fault Frequency: 17
Reset counter: 141
Voltage: 11.80 V
Term 50 Off
Reset counter: 141
Term 15 Off
Voltage: 12.45 V
Term 50 Off
Reset counter: 141
Mileage: 5102 km
Time: 31:63:63
Term 15 Off
Voltage: 13.45 V
Term 50 Off
Reset counter: 141
Mileage: 5102 km
Time: 31:63:63
Term 15 Off
Voltage: 13.45 V
Term 50 Off
Reset counter: 141
Mileage: 5102 km
Time: 31:63:63
Term 15 Off
Voltage: 13.45 V
Term 50 Off
Reset counter: 141
Mileage: 5102 km
Time: 31:63:63
Term 15 Off
Voltage: 13.45 V
Term 50 Off
Reset counter: 141
Mileage: 5102 km
Date: 2014.03.25
Time: 00:00:01
Term 15 Off
Voltage: 13.45 V
Term 50 Off
Fault Frequency: 26
Reset counter: 101
Mileage: 5102 km
Date: 2014.03.25
Time: 00:00:17
Voltage: 12.90 V
Term 50 Off
Reset counter: 141
Mileage: 5102 km
Date: 2014.03.25
Time: 00:00:17
Voltage: 12.90 V
Term 50 Off
Reset counter: 141
Mileage: 5102 km
Date: 2014.03.25
Time: 00:00:19
Voltage: 12.85 V
Term 50 Off
00956 - Key 2
Reset counter: 101
Mileage: 5102 km
Term 15 Off
Voltage: 12.95 V
Term 50 Off
00955 - Key 1
Reset counter: 101
Mileage: 5102 km
Date: 2014.03.25
Time: 00:00:15
Term 15 Off
Voltage: 13.00 V
Term 50 Off
Reset counter: 141
Mileage: 5102 km
Date: 2014.03.25
Time: 00:00:09
Term 15 Off
Voltage: 13.40 V
Term 50 Off
Reset counter: 141
Mileage: 5102 km
Date: 2014.03.25
Time: 00:00:12
Voltage: 13.15 V
Term 50 Off
Reset counter: 101
Mileage: 5102 km
Date: 2014.03.28
Time: 00:07:51
Term 15 Off
Voltage: 12.75 V
Term 50 Off
Reset counter: 101
Mileage: 5102 km
Date: 2014.03.28
Time: 00:07:51
Term 15 Off
Voltage: 12.75 V
Term 50 Off
Reset counter: 101
Mileage: 5102 km
Date: 2014.03.25
Time: 00:00:15
Voltage: 13.00 V
Term 50 Off
15 Faults Found:
B100B 15 [137] - Open or Short to Plus
B1005 15 [136] - Open or Short to Plus
B100A 15 [137] - Open or Short to Plus
B1004 15 [136] - Open or Short to Plus
B1002 15 [136] - Open or Short to Plus
B1006 15 [136] - Open or Short to Plus
B1007 15 [136] - Open or Short to Plus
B1020 15 [000] - Open or Short to Plus
Coding: 0012112
6 Faults Found:
01304 - Radio
Coding: 0261428
Reset counter: 40
Mileage: 4978 km
Date: 2013.11.11
Time: 12:26:09
Reset counter: 40
Mileage: 4978 km
Date: 2013.11.11
Time: 12:28:16
Reset counter: 141
Mileage: 5102 km
Date: 2014.03.25
Time: 14:11:22
Reset counter: 141
Mileage: 5102 km
Date: 2014.03.25
Time: 00:00:32
Coding: 0261428
Reset counter: 40
Mileage: 4978 km
Date: 2013.11.11
Time: 12:26:09
Reset counter: 40
Mileage: 4978 km
Date: 2013.11.11
Time: 12:28:16
Reset counter: 141
Mileage: 5102 km
Date: 2014.03.25
Time: 14:11:22
Reset counter: 141
Mileage: 5102 km
Date: 2014.03.25
Time: 00:00:32
Coding: 352103
14 Faults Found:
Reset counter: 141
Mileage: 5102 km
Date: 2014.03.25
Time: 00:00:14
Reset counter: 101
Mileage: 5102 km
Date: 2014.03.25
Time: 00:00:13
Reset counter: 141
Mileage: 5102 km
Date: 2014.03.25
Time: 00:00:15
Fault Frequency: 89
Reset counter: 141
Date: 2014.11.20
Time: 18:30:45
Reset counter: 141
Reset counter: 141
Mileage: 5102 km
Date: 2014.03.25
Time: 00:00:01
Reset counter: 101
Mileage: 5102 km
Date: 2014.03.25
Time: 00:00:01
Reset counter: 101
Reset counter: 141
Reset counter: 141
Reset counter: 141
Mileage: 5102 km
Date: 2014.03.25
Time: 00:00:02
01304 - Radio
Reset counter: 101
Fault Frequency: 16
Mileage: 5102 km
Date: 2014.03.25
Time: 00:00:18
Reset counter: 101
Mileage: 5102 km
Date: 2014.03.25
Time: 00:01:00
Coding: 0000005
Fault Status: 00101110
Reset counter: 10
Reset counter: 138
Mileage: 5102 km
Date: 2014.03.25
Time: 00:00:19
Reset counter: 10
Mileage: 5102 km
Date: 2014.03.25
Time: 00:00:19
Reset counter: 10
Mileage: 5102 km
Date: 2014.03.25
Time: 00:00:19
Ign. Timing: 4.6 °BTDC
Fault Status: 00010011
Reset counter: 10
Mileage: 5102 km
Date: 2014.03.25
Time: 00:00:19
01176 - Key
Coding: 0004148
Revision: 00H22000
PD
Temperature: 6.0°C
Count: 2
SteerAng n.Init
Reset counter: 141
Mileage: 5102 km
Date: 2014.03.25
Time: 00:00:15
Voltage: 12.38 V
DU
Temperature: 6.0°C
RPM: 1498 /min
Reset counter: 101
Mileage: 5102 km
Date: 2014.03.25
Time: 00:00:15
Voltage: 12.38 V
DU
Temperature: 6.0°C
RPM: 1498 /min
Reset counter: 141
Voltage: 12.50 V
DU
Temperature: 9.0°C
RPM: 1498 /min
Coding: 0004148
8 Faults Found:
U1111 00 [137] - -
U1111 00 [008] - -
Reset counter: 141
U1111 00 [008] - -
Reset counter: 141
U1111 00 [008] - -
Reset counter: 141
U1111 00 [008] - -
Reset counter: 141
Mileage: 5102 km
Date: 2014.03.25
Time: 19:11:40
Mileage: 5102 km
Date: 2014.03.25
Time: 19:11:40
Address 56: Radio
Coding: F30F185A
Reset counter: 101
Mileage: 5102 km
Date: 2014.03.25
Time: 00:01:13
02252 - Generator
Reset counter: 101
Mileage: 5102 km
Date: 2014.03.25
Time: 00:01:13
Coding: 0011422
Reset counter: 18
Mileage: 5102 km
Date: 2014.03.25
Time: 19:10:34
Reset counter: 18
Time Indication: 15
Reset counter: 141
Time Indication: 15
01304 - Radio
Reset counter: 101
Mileage: 5102 km
Date: 2014.03.28
Time: 00:00:37
End-------------------------(Elapsed Time: 03:34)--------------------------
VCDS Release 14.10.0: SRI Reset
Control Module Part Number: 8P0 920 983 A Labels: 8P0-920-xxx-17-MY8.clb
Component:KOMBIINSTR. VDO H04 0150, Coding:0261428
Channel Description Unit Current val. New val.
02 Service Reminder Status 2 ---
40 Distance since Service km x100 50 ---
41 Time since Service Days 615 ---
42 Minimum Distance to Service km x100 145 ---
43 Maximum Distance to Service km x100 300 ---
44 Maximum Time to Service Days 730 ---
45 Oil Quality 1 ---
47 Soot Quantity km x100 9 ---
48 Thermal Load km x100 202 ---
49 Minimum Time to Service Days 365 ---
50 Basic Distance Value for Oil Change km x100 145 ---
51 Basic Time Value for Oil Change Days 365 ---
52 Basic Distance Value for Inspection km x100 306 ---
53 Distance since Inspection km x100 51 ---
54 Basic Time Value for Inspection Days 730 ---
55 Time since Inspection Days 615 ---
56 Day Counter Days 706 ---
Address 09: DTCs cleared
Address 25: DTCs cleared
Address 19: DTCs cleared
Address 77: DTCs cleared
Address 16: DTCs cleared
Address 08: DTCs cleared
Gateway Installation List: 7N0 907 530 M
2E-Media Player 3 -- Status: Cannot be reached 1100
37-Navigation -- Status: Malfunction 1010
37-Navigation -- Status: Sporadic communication error 1000
56-Radio -- Status: Sporadic communication error 1000
Scan: 01 03 08 09 15 16 17 19 22 25 2E 37 42 44 46 52 55 56 77
Address 01: Engine
Reset counter: 58
Mileage: 5102 km
Date: 2014.03.28
Time: 01:42:18
Reset counter: 58
Mileage: 5102 km
Date: 2014.03.28
Time: 01:42:18
Reset counter: 18
Mileage: 5102 km
Date: 2014.03.25
Time: 14:42:54
Temperature: 12.0°C
Reset counter: 18
Mileage: 5102 km
Date: 2014.03.25
Time: 14:52:06
Temperature: 12.0°C
Reset counter: 18
Mileage: 5102 km
Date: 2014.03.28
Time: 01:50:07
Address 09: Cent. Elect. Labels: 8P0-907-063.clb
VCID: 326102CC6DB94DB1A9F-FFFF
Address 15: Airbags
Coding: 0012112
Coding: 0261428
Coding: 0261428
Part No SW: 7N0 907 530 M HW: 1K0 907 951
Component: J533 Gateway H42 1623
Revision: H42 Serial number: 110312F2000712
Coding: 350101
VCID: 3A712AECB5C9B5F161F-806F
8 Faults Found:
Fault Frequency: 21
Reset counter: 58
Reset counter: 58
Mileage: 5102 km
Date: 2014.03.19
Time: 19:13:00
Reset counter: 58
Mileage: 5102 km
Date: 2014.03.19
Time: 18:54:56
Reset counter: 58
Mileage: 5102 km
Date: 2014.03.25
Time: 15:13:30
Reset counter: 58
Mileage: 5102 km
Date: 2014.03.25
Time: 13:23:50
01304 - Radio
Reset counter: 58
Mileage: 5102 km
Date: 2014.03.25
Time: 13:23:50
Reset counter: 55
Mileage: 4978 km
Date: 2013.11.11
Time: 12:28:17
03272 - Control Module for Audio Interface
Reset counter: 18
Address 22: AWD
Address 2E: Media Player 3
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8P0 035 193 G HW: 8P0 035 193 G
Component: RNS-E PU EU H06 0200
Revision: 0000012S Serial number: AUZBZ7MD207074
Coding: 0209725
VCID: 346D04D457AD4381BB3-8061
Fault Status: 01100111
Reset counter: 18
Mileage: 5102 km
Date: 2014.03.28
Time: 02:16:21
Mileage: 5100 km
Count: 2803
Clock: 02:16
Coding: 0004148
Coding: 0004148
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0209725
Reset counter: 18
Mileage: 5102 km
Date: 2014.03.28
Time: 02:16:21
Mileage: 5100 km
Count: 2803
Clock: 02:16
Coding: 0011422
Reset counter: 18
Mileage: 5102 km
Date: 2014.03.28
Time: 02:00:22
End-------------------------(Elapsed Time: 02:42)--------------------------
Address 37: DTCs cleared
Address 56: DTCs cleared
Address 17: DTCs cleared
Address 42: DTCs cleared
Address 52: DTCs cleared
Control Module Part Number: 8P0 907 063 A HW: 8P0 907 063 A
Component and/or Version: BCM PQ35 M 105 0575
Software Coding: 06000A2FB005F200207241E00000094C431E25AA304DD929E40008840040
Work Shop Code: WSC 06314 000 00000
10 Faults Found:
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:09:35
Voltage: 12.15 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:09:35
Voltage: 12.15 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:09:35
Voltage: 12.15 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:09:35
Voltage: 12.15 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:09:35
Voltage: 12.15 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:09:35
Voltage: 12.15 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:09:35
Voltage: 12.15 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:09:35
Voltage: 12.15 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:09:35
Voltage: 12.15 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:09:35
Voltage: 12.15 V
Term 50 Off
10 Faults Found:
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:09:35
Voltage: 12.15 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:09:35
Voltage: 12.15 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:09:35
Voltage: 12.15 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:09:35
Voltage: 12.15 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:09:35
Voltage: 12.15 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:09:35
Voltage: 12.15 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:09:35
Voltage: 12.15 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:09:35
Voltage: 12.15 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:09:35
Voltage: 12.15 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:09:35
Voltage: 12.15 V
Term 50 Off
Address 19: CAN Gateway Labels: 1K0-907-530-V4.clb
Control Module Part Number: 1K0 907 530 AD HW: 1K0 907 951
Component and/or Version: J533 Gateway H16 0233
Software Coding: ED831F06100202000100
VCID: 69D3A5A040EFCE69D85-803C
Reset counter: 69
Mileage: 5102 km
Reset counter: 69
Mileage: 5102 km
Reset counter: 69
Mileage: 5102 km
Reset counter: 69
Mileage: 5102 km
12 Faults Found:
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:09:35
Voltage: 12.15 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:09:35
Voltage: 12.15 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:09:35
Voltage: 12.15 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:09:35
Voltage: 12.15 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:09:35
Voltage: 12.15 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:09:35
Voltage: 12.15 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:09:35
Voltage: 12.15 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:09:35
Voltage: 12.15 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:09:35
Voltage: 12.15 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:09:35
Voltage: 12.15 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:16:31
Voltage: 12.10 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:16:31
Voltage: 12.10 V
Term 50 Off
12 Faults Found:
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:09:35
Voltage: 12.15 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:09:35
Voltage: 12.15 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:09:35
Voltage: 12.15 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:09:35
Voltage: 12.15 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:09:35
Voltage: 12.15 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:09:35
Voltage: 12.15 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:09:35
Voltage: 12.15 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:09:35
Voltage: 12.15 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:09:35
Voltage: 12.15 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:09:35
Voltage: 12.15 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:16:31
Voltage: 12.10 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:16:31
Voltage: 12.10 V
Term 50 Off
12 Faults Found:
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:09:35
Voltage: 12.15 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:09:35
Voltage: 12.15 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:09:35
Voltage: 12.15 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:09:35
Voltage: 12.15 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:09:35
Voltage: 12.15 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:09:35
Voltage: 12.15 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:09:35
Voltage: 12.15 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:09:35
Voltage: 12.15 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:09:35
Voltage: 12.15 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:09:35
Voltage: 12.15 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:16:31
Voltage: 12.10 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:16:31
Voltage: 12.10 V
Term 50 Off
Fault Codes have been Erased
9 Faults Found:
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:25:07
Voltage: 12.15 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:25:07
Voltage: 12.15 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:25:07
Voltage: 12.15 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:25:07
Voltage: 12.10 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:25:07
Voltage: 12.10 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:25:07
Voltage: 12.10 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:25:07
Voltage: 12.10 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:25:07
Voltage: 12.10 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:25:07
Voltage: 12.10 V
Term 50 Off
12 Faults Found:
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:25:07
Voltage: 12.15 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:25:07
Voltage: 12.15 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:25:07
Voltage: 12.15 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:25:07
Voltage: 12.10 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:25:07
Voltage: 12.10 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:25:07
Voltage: 12.10 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:25:07
Voltage: 12.10 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:25:07
Voltage: 12.10 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:25:07
Voltage: 12.10 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:25:07
Voltage: 12.15 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:28:41
Voltage: 12.05 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:28:41
Voltage: 12.05 V
Term 50 Off
Chassis Type: 8P (1K0)
Scan: 01 02 03 08 09 15 16 17 19 22 25 37 42 44 46 47 52 55 56 77
02-Auto Trans -- Status: Cannot be reached 1100
03-ABS Brakes -- Status: Cannot be reached 1100
04-Steering Angle -- Status: Cannot be reached 1100
15-Airbags -- Status: Cannot be reached 1100
22-AWD -- Status: Cannot be reached 1100
37-Navigation -- Status: Not registered 0011
44-Steering Assist -- Status: Cannot be reached 1100
55-Headlight Range -- Status: Cannot be reached 1100
77-Telephone -- Status: Not registered 0001
Address 01: Engine
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:28:38
Revision: 00105 AK
14 Faults Found:
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:25:07
Voltage: 12.15 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:25:07
Voltage: 12.15 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:25:07
Voltage: 12.15 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:25:07
Voltage: 12.10 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:25:07
Voltage: 12.10 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:25:07
Voltage: 12.10 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:25:07
Voltage: 12.10 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:25:07
Voltage: 12.10 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:25:07
Voltage: 12.10 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:25:07
Voltage: 12.15 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:28:41
Voltage: 12.05 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:28:41
Voltage: 12.05 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:41:59
Voltage: 12.05 V
Term 50 Off
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:41:59
Voltage: 12.05 V
Term 50 Off
Address 15: Airbags
Coding: 0012112
Coding: 0261428
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H16 0233
Revision: H16 Serial number: 4520K103150268
Reset counter: 69
Mileage: 5102 km
Address 22: AWD
01176 - Key
Coding: 0209725
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:11:21
Mileage: 5100 km
Count: 2803
Clock: 04:11
Coding: 0004148
Address 47: Sound System
Coding: 0004148
Coding: 0209725
Reset counter: 69
Mileage: 5102 km
Date: 2014.03.28
Time: 04:11:21
Mileage: 5100 km
Count: 2803
Clock: 04:11
Coding: 0011422
End-------------------------(Elapsed Time: 03:22)--------------------------
