Results 1 to 1 of 1
Thread: Audi E-Tron 55 DAB+ retrofit
    May 2016
    I have an Audi E-Tron 55 Quattro with DAB+ preparation. If I look at the PR codes I get Q0D and that means DAB+ preparation. If I look at the MIB the DAB+ antenne is connected. I have also compared the antennas with a similar car with DAB+ from factory, all are the same. Sharkvin antenna, antenna amplifier all are same. If I look at the coding, I can see that the DAB+ option is already active, but not working at all. Maybe someone can share a scan from E-Tron with OEM DAB+. Below scan of car with DAB+ preparation:
    Thursday,02,January,2020,13:59:21:43540
    VIN: WAUZZZGE9LB011748   License Plate: ETRON
    Mileage: 850km-528mi   Repair Order:
    Chassis Type: GE-AU58 (4KL)
    Scan: 01 03 09 13 15 16 17 19 2B 36 42 44 46 51 52 5F 6C 6D 74 75
              81 8C A5 BB BC C5 C6 CA CE D6 D7 8104
    VIN: WAUZZZGE9LB011748   Mileage: 850km-528miles
    C5-Therm. mgt. -- Status: OK 0000
    C6-Batt. Chrg. -- Status: OK 0000
    CA-Sunroof -- Status: OK 0000
    CE-Drive Motor 2 -- Status: OK 0000
    8104-DC/DC Converter HV -- Status: OK 0000
    Address 01: Engine (J623-    )       Labels: None
       Part No SW: 4KE 907 558 A    HW: 4KE 907 558
       Component: I99 99.9l XXX H02 0001
       Coding: 2A0A0012006E040034080000000000000000000000000000
       ASAM Dataset: EV_VCU00XXX0204KE907558A 001004
       ROD: EV_VCU00XXX0204KE907558A.rod
       VCID: 47CAADB91F27557F48D-8012
       Part No SW: 4KE 909 059 AD    HW: 4KE 909 059 N
       Component: ESC           H11 0231
       Revision: 00000000    Serial number: 62779000003773
       Coding: 008800BA3D950B9A93570875187FD2E025BEA10000BCD0C910184B07A47D85
       Shop #: WSC 00046 412 00046
       ASAM Dataset: EV_BRSContiMKC1AU516 011001
       ROD: EV_BRSContiMKC1AU516_009.rod
       VCID: 094E6B8149B3E30F9E9-805C
       Part No SW: 4N0 907 063 KG    HW: 4N0 907 063 AG
       Component: BCM1 MLBevo   H10 0691
       Coding: 07000143C1F900DD0740870898AF8C68130B33100806009701010A00792216810A4509BB62B62A0B000001000009101A0002800000010000000000000000000000
       ASAM Dataset: EV_BCM1BOSCHAU651 016011
       ROD: EV_BCM1BOSCHAU651_016_AU49.rod
       VCID: 7DA60F510D7BCFAFA21-8028
       Subsystem 1 - Part No SW: 4KL 955 119     HW: 4K1 955 119
       Component: J400FRWISCH  063 0840
       Serial number: 00000001909030402367
       Coding: 7DC727
       Serial number: 23658741X81A955555A0
       Coding: 02005E
       Light switch:
       Subsystem 3 - Part No SW: 4K1 941 501 A    HW: 4K1 941 501 A
       Component: E1 - LTM  H09 0086
       Serial number: 14S14.10.1900690458
       Subsystem 4 - Part No SW: 8W0 857 511     HW: 8W0 857 511
       Serial number: GX1CE116071923611243
       Interior Light Module:
       Subsystem 5 - Part No SW: 4K0 947 135 AL    HW: 4K0 947 135 AL
       Component: Dachmodul  H42 0415
       Serial number: B01435935
       Coding: 0D0104
       Part No SW: 4KE 907 561 C    HW: 4K0 907 561
       Component: LRR4R         H04 0354
       Coding: 7E61FF4358082C00010380200000003A4A1246494401009E01
       ASAM Dataset: EV_ACCBOSCHAU65X 002023
       ROD: EV_ACCBOSCHAU65X_AU58.rod
       VCID: 43D2B9A92B1F795F945-8016
       Part No SW: 4KE 959 655 D    HW: 4KE 959 655 D
       Component: AirbagVW32    H42 3221
       Serial number: 0031NM00NU7N
       Coding: AACCF0C0003000009A5400FFF80D49A800C5
       ASAM Dataset: EV_AirbaVW31SMEAU65x 001034
       ROD: EV_AirbaVW31SMEAU65x_VW53.rod
       VCID: 4FFA8599F7578D3F00D-801A
       Belt Pretensioner left:
       Subsystem 1 - Part No SW: 4N0 980 945 A    HW: 4N0 980 945 A
       Component: BeltPretRevFL  H10 0115
       Serial number: 00AI2019219726900000
       Coding: 03F002
       Belt Pretensioner right:
       Subsystem 2 - Part No SW: 4N0 980 946 A    HW: 4N0 980 946 A
       Component: BeltPretRevFR  H10 0115
       Serial number: 00AI2019239660800000
       Coding: 03F002
       Subsystem 3 - Part No SW: -----------    HW: 480 000 110 19
       Serial number: 357000000004D1293F3M
       Subsystem 4 - Part No SW: -----------    HW: 480 000 810 19
       Serial number: 35800000000910808F3H
       Subsystem 5 - Part No SW: -----------    HW: 480 030 110 19
       Component: SideSensor_Dr  002 0149
       Serial number: 351002C00445C9D01CB8
       Subsystem 6 - Part No SW: -----------    HW: 480 030 110 19
       Component: SideSensor_Pr  002 0149
       Serial number: 352001C2495435A0FE5D
       Subsystem 7 - Part No SW: -----------    HW: 480 021 110 19
       Component: FrontSensor_D  000 0149
       Serial number: 35500010662EBD733294
       Front Sensor Passenger:
       Subsystem 8 - Part No SW: -----------    HW: 480 021 110 19
       Component: FrontSensor_P  000 0149
       Serial number: 35600010662EBD73F66I
       Sensor High Voltage System 1:
       Subsystem 9 - Part No SW: -----------    HW: 480 021 110 19
       Component: HVSensor_gSat  000 0149
       Serial number: I0T00010262EBD7556A0
       Side Sensor B-Pillar Driver Front:
       Subsystem 10 - Part No SW: -----------    HW: 480 021 110 19
       Component: SideSens_B_Df  000 0149
       Serial number: I0P00010262EBD74579
       Side Sensor B-Pillar Passenger Front:
       Subsystem 11 - Part No SW: -----------    HW: 480 020 410 19
       Component: SideSens_B_Pf  000 0149
       Serial number: I0Q00010662F2C63B4B.
       Part No SW: 4N0 907 129 AJ    HW: 4N0 907 129 AJ
       ROD: EV_SMLSKLOAU736_VW53.rod
       VCID: 79AE1B411953F38F8E9-802C
       Part No SW: 4KE 920 795 A    HW: 4KE 920 795 A
       Component: FHybRDWACC--- H13 0105
       Coding: 850400C87C9000080DA6E170B284480008000000
       ASAM Dataset: EV_DashBoardAU65X 001017
       ROD: EV_DashBoardAU65X_VW53.rod
       VCID: 45D6A7B1252B476FBA1-8010
       Part No SW: 4KL 907 468     HW: 4KL 907 468
       Component: Gateway       H04 0362
       Serial number: 14F05089868301
       Coding: 02030005000100C000810000005B01329C8A0047180000000900009E00000000
       ASAM Dataset: EV_Gatew31xAU65x 003190
       ROD: EV_Gatew31xAU65x_AU58.rod
       VCID: 0D465F913DDBFF2FB21-8058
       Subsystem 1 - Part No SW: 4N0 951 523 G    HW: 4N0 951 523 G
       Component: E221__MFL  H06 0003
       Serial number: 00000000000000000000
       Subsystem 2 - Part No SW: 4N0 915 181 D    HW: 4N0 915 181 D
       Component: J367-BDMConti  H03 1051
       Serial number: 7674960200191005000C
       Control module for steering wheel touch recognition:
       Subsystem 3 - Part No SW: 4N0 419 508 A    HW: 4N0 419 508
       Component: J1158 KLR  H46 0041
       Serial number: 19252056110S00414601
       Part No SW: 3Q0 905 861 C    HW: 3Q0 905 861 C
       Component: ELV-MLBevo    H05 0020
       Serial number: 19000264568006
       Coding: 8800000000000000
       ROD: EV_ELVMarqMQBA0_VW41.rod
       VCID: 3430EA757EB1CEE71DF-8060
       Part No SW: 4M4 959 760     HW: 4M4 959 760
       Component: MEM-FS        009 0044
       Serial number: 00000390943019
       Coding: 005812400000B4010003010101010000000000000000000000000000004000
       ROD: EV_SCMDriveSideCONTIAU736_VW38.rod
       Part No SW: 4M0 959 593 M    HW: 4M0 959 593 J
       Component: TSG FS        010 0387
       Serial number: 0000390427868
       Coding: 001FDB0052000480A001B002
       ROD: EV_DCU2DriveSideMAXHCONT_VW38.rod
       VCID: 46D4A0BD182D4C77B3B-8012
    196631 - Remote Rear Lid Unlock Button
              B1210 29 [009] - Signal Implausible
                        Reset counter: 32
                        Mileage: 850 km
                        Date: 2020.01.18
                        Time: 13:56:08
       Part No SW: 4N0 909 144 E    HW: 4N0 909 144 C
       Component: EPS_MLBEVO2BS H22 0505
       Coding: B4110101010000
       ASAM Dataset: EV_EPSVWBSAU426 010017
       ROD: EV_EPSVWBSAU426_010.rod
       VCID: 323CEC6D84A5C0D70F3-8066
       Part No SW: 8W1 907 064 AP    HW: 8W1 907 064 P
       Component: BCM2 MLBevo   044 0530
       Coding: 017400002FB100E16309A0046400880200000000804F06582F04000000040030001F0100010F13
       ASAM Dataset: EV_BCM2HellaAU736 017017
       ROD: EV_BCM2HellaAU736_017_AU58.rod
       VCID: 0B42518943CFF11FAC5-805E
       Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
       Serial number: 000000000ZY1925500GS
       Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
       Serial number: 00000000000047778774
       Rear Light Left 1:
       Subsystem 3 - Part No SW: 4KE 945 423     HW: 4KE 945 423
       Component: T1 LH ECE HD  H10 0403
       Serial number: A1W70000PVY
       Rear Light Left 2:
       Subsystem 4 - Part No SW: 4KE 945 429     HW: 4KE 945 429
       Component: T2 LH ECE HD  H11 0403
       Serial number: A1WK0000T5P
       Rear Light Right 1:
       Subsystem 5 - Part No SW: 4KE 945 424     HW: 4KE 945 424
       Component: T1 RH ECE HD  H10 0403
       Serial number: A1WD0000FJD
       Rear Light Right 2:
       Subsystem 6 - Part No SW: 4KE 945 430     HW: 4KE 945 430
       Component: T2 RH ECE HD  H11 0403
       Serial number: A1WL0000T5Q
    Address 51: Electric Drive (J841)       Labels: None
       Part No SW: 0EF 907 080 E    HW: 0EF 907 080 E
       Component: CUFZD68540AD0 H05 1002
       Revision: --------    Serial number: -00107.07.19000
       Coding: 01000000000000000000
       Shop #: WSC 08845 004 1048576
       ASAM Dataset: EV_DMCMHITACAU516 003009
       ROD: EV_DMCM2HITACAU516_003.rod
       VCID: 3828DE4562D92A87317-806C
       Part No SW: 4M0 959 592 M    HW: 4M0 959 592 J
       Component: TSG BFS       010 0387
       Serial number: 0000391434172
       Coding: 001FDB005E000480A001B000
       ROD: EV_DCU2PasseSideMAXHCONT_VW38.rod
       Part No SW: 4KE 035 063 B    HW: 4KE 035 063
       Component: MU-H-LND-EU   054 2658
       Coding: 01157601FF0A000043111101C00802102F0001E4037008008E
       ASAM Dataset: EV_MUHigGen2pALPI 001001
       ROD: EV_MUHigGen2pALPI_AU27.rod
       VCID: 372ADD796FC725FF38D-8062
       Subsystem 1 - Part No: V03 959 804 LN
       Component: MIB2P_EU_Q219  0371
       Subsystem 2 - Part No SW: 4KE 919 605 C    HW: 4KE 919 605
       Component: DU AU516 High  H41 0147
       Serial number: INX00118081900130408
       Subsystem 3 - Part No: V03 959 800 EG
       Component: Gracenote2  1010
       Volume Control 1:
       Subsystem 4 - Part No SW: 4K1 919 616 B    HW: 4K1 919 616 A
       Component: LSR-D5/C8  H33 0110
       Serial number: 00004419000109892047
       Display Unit 5 For Multimedia System:
       Subsystem 5 - Part No SW: 4KE 919 603 A    HW: 4KE 919 603
       Component: DU AU516 Bot  H41 0147
       Serial number: INX00113071900140592
       Media socket:
       Subsystem 6 - Part No SW: 4N0 035 736 A    HW: 4N0 035 736
       Component: MediaConnectH  014 0133
       Serial number: 051900564889003
    Address 6C: Back-up Cam. (J772)       Labels:* Redir Fail!
       Part No SW: 4M0 980 556 A    HW: 5Q0 980 556 B
       Component: RVC Compact   H18 0240
       Coding: 0237060102002001000040
       ASAM Dataset: EV_CamSysRVRVCPANAMLBEv 005010
       ROD: EV_CamSysRVRVCPANAMLBEv_005_VW53.rod
       VCID: 3332E9697BBFC9DF045-8066
    10489856 - No Basic Setting
              B2010 00 [009] - -
              [RearView system not calibrated]
                        Reset counter: 32
                        Mileage: 850 km
                        Date: 2020.01.18
                        Time: 13:56:07
                        passive
       Part No SW: 8W8 959 107 D    HW: 8W8 959 107
       Component: HDSG-Modul    H13 0171
       Revision: --------    Serial number: A2-C744-8781-2
       Coding: 3310
       ROD: EV_DeckLidCONTIAU736_AU38.rod
       VCID: 4ACC948D0C35A817573-801E
    Address 74: Chassis Control (J775)       Labels:* None
       Part No SW: 4KE 907 777 AM    HW: 4KE 907 777 A
       Component: Fahrwerk-SG   H52 2312
       Serial number: 2909191045
       Coding: 18D8586BDA4030
       ASAM Dataset: EV_ChassContrContiAU651 003018
       ROD: EV_ChassContrContiAU651_003.rod
       VCID: 176A3DF90F0705FF18D-8042
       Air Suspension Compressor:
       Subsystem 1 - Part No SW: 4M0 907 778     HW: 4M0 907 778
       Component: V66LFKompOLV  H06 0013
       Serial number: 00000000004130734434
       Coding: 303030
    Address 75: Telematics (J949)       Labels:* None
       Part No SW: 4K1 035 282 D    HW: 4K1 035 282 B
       Component: ConBox        H09 0232
       Serial number: 005CCA11F120830
       Coding: 01C0E0FFC040800000
       ASAM Dataset: EV_ConBoxAU651 002004
       ROD: EV_ConBoxAU651_002.rod
       VCID: 28080E05B279BA07A17-807C
       Part No SW: 4KL 713 041 A    HW: 4KL 713 041
       Component: GSM-LL H04 0036
       Serial number: 92145SJG00377
       ASAM Dataset: EV_GSMKLOAU516 001008
       ROD: EV_GSMKLOAU516.rod
       VCID: 3C20C25556E106A7D5F-8068
    Address 8C: Hybrid Battery (J840)       Labels: None
       Part No SW: 4KE 915 233 B    HW: 4KE 915 233 B
       Component: BMC_MLBCBEV   H15 0442
       ASAM Dataset: EV_BECM0842071 001004
       ROD: EV_BECM0842071_VW53.rod
       VCID: 3D26CF514DFB0FAFE21-8068
       Battery Junction Box:
       Subsystem 1 - Part No SW: 4KE 915 253 B    HW: 4KE 915 253 B
       Component: BJB_MLBBEV  H05 0444
       Cell module: control module 1:
       Subsystem 2 - Part No SW: 4KE 915 022 A    HW: 4KE 915 022
    H06 0110
       Cell module: control module 2:
       Subsystem 3 - Part No SW: 4KE 915 022 A    HW: 4KE 915 022
    H06 0110
       Cell module: control module 3:
       Subsystem 4 - Part No SW: 4KE 915 022 A    HW: 4KE 915 022
    H06 0110
       Cell module: control module 4:
       Subsystem 5 - Part No SW: 4KE 915 022 A    HW: 4KE 915 022
    H06 0110
       Cell module: control module 5:
       Subsystem 6 - Part No SW: 4KE 915 022 A    HW: 4KE 915 022
    H06 0110
       Cell module: control module 6:
       Subsystem 7 - Part No SW: 4KE 915 022 A    HW: 4KE 915 022
    H06 0110
       Cell module: control module 7:
       Subsystem 8 - Part No SW: 4KE 915 022 A    HW: 4KE 915 022
    H06 0110
       Cell module: control module 8:
       Subsystem 9 - Part No SW: 4KE 915 022 A    HW: 4KE 915 022
    H06 0110
       Cell module: control module 9:
       Subsystem 10 - Part No SW: 4KE 915 022 A    HW: 4KE 915 022
    H06 0110
    Address A5: Frt Sens. Drv. Assist (J1121)       Labels:* None
       Part No SW: 4K4 907 108     HW: 4K4 907 108
       Component: zFAS Var B    H09 0352
       Coding: 04218400000000000008060000D4642E189E57000000008000000000000000000019000000000000000000000000000000000000000000000000400000000000000078D80000009000800080000000000080400000A0
       ASAM Dataset: EV_ZFASAU516 003008
       ROD: EV_ZFASAU516_003.rod
       VCID: 6C8032156601562705F-8038
       Part No SW: 4M0 959 595 M    HW: 4M0 959 595 J
       Component: TSG HFS       010 0387
       Serial number: 0000391099798
       Coding: 000FD90000000480A000B000
       ROD: EV_DCU2RearDriveMAXHCONT_AU58.rod
       VCID: 48C8AE8512395A07417-801C
       Component: TSG HBFS      010 0387
       Serial number: 0000391099797
       ROD: EV_DCU2RearPasseMAXHCONT_AU58.rod
    Address C5: Therm. mgt. (J1024)       Labels:* None
       Part No SW: 4KE 965 429 C    HW: 4KE 965 429
       Component: TME-Max       H08 0312
       Serial number: 0077846
       Coding: 00
       ASAM Dataset: EV_ThermContrVISAU49X 002036
       ROD: EV_ThermContrVISAU49X_002_AU58.rod
       Subsystem 1 - Part No SW: 4M0 959 603 C    HW: 4M0 959 603 C
       Component: G395 pT-Sens1  H11 0010
       Subsystem 2 - Part No SW: 3Q0 963 231 E    HW: 3Q0 963 231 E
       Component: J848 HV-PTC  200 0204
       Serial number: -00104.2W.2B20370813
       Subsystem 3 - Part No SW: 4G0 816 797 C    HW: 4G0 816 797 C
       Component: J842 EKK es33  H03 0015
       Serial number: 00000000019100300705
       Geber für Kältemitteldruck/Kältemitteltemperatur 2:
       Subsystem 4 - Part No SW: 4M0 959 603 C    HW: 4M0 959 603 C
       Component: G826 pT-Sens2  H11 0010
       Refrigerant Expansion Valve 2:
       Subsystem 5 - Part No SW: 4M0 816 682 E    HW: 4M0 816 682 E
       Component: N637 EV2_KaMi  H12 0102
       Serial number: 00000000000151073809
       Refrigerant Shut Off Valve 3:
       Subsystem 6 - Part No SW: 4M0 816 099     HW: 4M0 816 099
       Component: N641 AV3_KaMi  H12 0102
       Serial number: 36000000000000005546
       Refrigerant Shut Off Valve 5:
       Subsystem 7 - Part No SW: 4M0 816 099     HW: 4M0 816 099
       Component: N643 AV5_KaMi  H12 0102
       Serial number: 33000000000000005546
       Radiator shutter:
       Subsystem 8 - Part No SW: 95B 965 501 AA    HW: 95B 965 501 AA
       Component: V544KJS1  H13 0110
       Serial number: 20190919060103050779
       Radiator Shutter 2:
       Subsystem 9 - Part No SW: 95B 965 501 AA    HW: 95B 965 501 AA
       Component: V550KJS2  H13 0110
       Serial number: 20190828060404051658
       Coolant valve 1:
       Subsystem 10 - Part No SW: 4KE 963 375 K    HW: 4KE 963 375 K
       Component: N632 V1_KUEMI  010 0103
       Serial number: 00000000000000396341
       Coolant valve 2:
       Subsystem 11 - Part No SW: 4KE 963 375 J    HW: 4KE 963 375 J
       Component: N633 V2_KUEMI  010 0103
       Serial number: 00000000000000143084
       Coolant valve 3:
       Subsystem 12 - Part No SW: 4KE 963 375 H    HW: 4KE 963 375 H
       Component: N634 V3_KUEMI  010 0103
       Serial number: 00000000000000393351
       Coolant valve 4:
       Subsystem 13 - Part No SW: 4KE 963 375 N    HW: 4KE 963 375 N
       Component: N635 V4_KUEMI  010 0103
       Serial number: 00000000000000388080
    Address C6: Batt. Chrg. (J1050)       Labels:* None
       Part No SW: 5QE 915 684 J    HW: 5QE 915 684 J
       Component: OBC KOSTAL    H24 0020
       Serial number: ---------------
       Coding: 2B48844542080E000000
       ASAM Dataset: EV_OBC3Phase1KLOMLBev14B 002001
       ROD: EV_OBC2PhaseKLOMLBev14P.rod
       VCID: 56F470FDC88DFCF7C3B-8002
       Part No SW: 4K0 907 594 AC    HW: 4K0 907 594
       Component: SAD_STG_1     006 0002
       Coding: 628040051602
       ASAM Dataset: EV_SunRoofCONTIAU736 009011
       ROD: EV_SunRoofCONTIAU736_009_VW27.rod
       VCID: 75B61771354B97EFEA1-8020
    Address CE: Drive Motor 2 (J944)       Labels: None
       Part No SW: 0EF 907 180 F    HW: 0EF 907 180 F
       Component: CUBZE68540AD0 H05 1002
       Revision: --------    Serial number: -00104.07.19000
       ASAM Dataset: EV_DMCM2HITACAU516 003009
       VCID: 3A2CC44D5CD53897C73-806E
    Address D6: Light Ctrl Left 2 (A31)       Labels: None
       Part No SW: 4K0 941 591 BC    HW: 4K0 941 591 B
       Component: LMS_MLBevo    H11 0031
       ASAM Dataset: EV_LMSLeftHELLAAU58X 001013
       ROD: EV_LMSLeftHELLAAU58X_AU38.rod
       VCID: 71BE23614123BBCF369-8024
    Address D7: Light Ctrl Right 2 (A27)       Labels: None
       ASAM Dataset: EV_LMSRightHELLAAU58X 001013
       ROD: EV_LMSRightHELLAAU58X_AU38.rod
    Address 8104: DC/DC Converter HV (A19)       Labels: None
       Part No SW: 4KE 907 171 B    HW: 4KE 907 171 B
       Component: DCDC Wandler H10 0400
       ASAM Dataset: EV_DCDCHVTDKAU516 001004
       ROD: EV_DCDCHVTDKAU516.rod
       VCID: 3FDAB55947F71DBFF0D-806A
    End----------(Elapsed Time: 02:21, VBatt start/end: 13.2V/13.2V)-----------
