Results 1 to 5 of 5
Thread: Passat B8 high beam not working after HBA activation
    Nov 2018
    Europe - Hungary
    I tried to activate high beam assist on a Passat B8 with LED2 headlamps.
    After coding the HBA, the symbol appeared on the instrument cluster.
    During driving the blue high beam symbol appearad on the instrument cluster but the headlamps didn't.
    After driving I tried to switch back the coding from log file.
    Address 09,5Q0 937 086 BD,recoded (Long Coding),from,00071F46C24102FF4BE44004001C070818800 00000000000000000000000,to,00071B46C24102FF4BE4400 4001C07081880000000000000000000000000,(73430/790/00063)
    So I wrote back the 09 long code to original 00071F46C24102FF4BE44004001C0708188000000000000000 0000000000
    The high beam doesn't work.
    If I try to activate the high beam when the light switch is OFF mode (DRL active), only LOW beam activated instead of high beam but the blue symbol appears.
    What can I do?
    Please help.
    Monday,20,January,2020,17:06:35:64377
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(VirtualBox)
    VCDS Version 19.6.2.0 (x64)  HEX-V2 CB: 0.4508.4
    Workshop Code: 790 73430 000063
    VIN: WVWZZZ3CZFP410769   License Plate: RVR-098
    Mileage: 159609km-99176mi   Repair Order:
    Chassis Type: 3C-VW48 (5Q0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 55 5F 69 A5
    VIN: WVWZZZ3CZFP410769   Mileage: 159609km-99176miles
    Address 01: Engine (J623-DDAA)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 026 DR    HW: 04L 907 309 M
       Component: R4 2.0l TDI   H22 1935
       Revision: B4H22---
       Coding: 011D0012037405083000
       Shop #: WSC 50842 001 1048576
       ASAM Dataset: EV_ECM20TDI01104L906026DR 004005
       ROD: EV_ECM20TDI01104L906026DQ_004_VW48.rod
       VCID: 7DA7FA8F3D7ED97FA21-8029
    28653 - Reductant System Performance Bank 1
              P204F 00 [096] - Malfunction
    4113 - Camshaft Position Sensor (G40)
              P0341 00 [096] - Implausible Signal
       Part No SW: 0D9 300 041 B    HW: 02E 927 770 AQ
       Component: DQ250-6F MQB  H53 4803
       Revision: 05853104    Serial number: TFK01501070647
       Shop #: WSC 00028 028 00023
       ROD: EV_TCMDQ250021.rod
       VCID: 176BC8273F02132F18D-8043
       Part No SW: 3Q0 907 379 R    HW: 3Q0 907 379 G
       Component: ESC           H42 0711
       Revision: 00000000    Serial number: 60205000002913
       Coding: 0FEC6A8F34210B6C077E060641CC49F0562CD0E0608292F11862F078C209
       VCID: 49CF5E5F3936B5DF5E9-801D
       Part No SW: 3Q0 959 435     HW: 3Q0 959 435
       Component: VWKESSYMQB    023 0522
       Revision: 00023000    Serial number: 0357961925
       Coding: 000F0F0703
       ASAM Dataset: EV_KessyHellaMQBAB 004027
       VCID: 77ABE8A71F42F32FF8D-8023
       Part No SW: 5G0 907 044 AH    HW: 5G0 907 044 AH
       Revision: 00001K10
       Coding: 12020104202100012115500000101802
       VCID: 6D87CACF6D1E49FF121-8039
              P1719 00 [008] - -
              [PTC-Reduzierung durch MSG]
                        Reset counter: 212
                        Mileage: 159102 km
                        Date: 2020.01.17
                        Time: 07:48:04
                        Voltage terminal 30: 13.7 V
                        Auxiliary heater: in stages-Act.val.: 3
       Part No SW: 5Q0 937 086 BD    HW: 5Q0 937 086 BD
       Component: BCM PQ37BOSCH 028 0146
       Revision: --------    Serial number: 86582001150859
       Coding: 00071F46C24102FF4BE44004001C07081880000000000000000000000000
       Shop #: WSC 12345 123 61029
       ROD: EV_BCMBOSCH_014.rod
       Component: WWS    150104  042 0607
       Serial number:         150110132708
       Component: RLHS  037 0059
       Serial number: S5Y15M01D27H10M15S51
       Coding: 00A8DD
       Light switch:
       Serial number: 31 10 2014  00000236
    204546 - Remote key 2
                        Reset counter: 171
                        Mileage: 159067 km
                        Date: 2020.01.15
                        Time: 18:48:37
       Part No SW: 5Q0 919 294 H    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0053
       Revision: --------    Serial number: 39311502001881
       Coding: 0071051111
       Shop #: WSC 34081 001 1048576
       VCID: 40D9437B0A0C7497897-8015
       Part No SW: 3Q0 907 572 A    HW: 3Q0 907 572 A
       Component: ACC BOSCH MQB H04 0126
       Coding: 3260674910FFC428949C804C
       ASAM Dataset: EV_ACCBOSCHVW48X 001007
       ROD: EV_ACCBOSCHVW48X.rod
       VCID: 33331CB74BBADF0F045-8067
       Part No SW: 3Q0 959 655 AF    HW: 3Q0 959 655 AF
       Component: Airbag VW20   012 0195
       Revision: --------    Serial number: 003R2P0E19WR
       Coding: 88CCC000000000005C5400CC000800000065
       Shop #: WSC 00028 028 00005
       ROD: EV_AirbaVW20TS6VW48X.rod
       VCID: 025D89734480A687DF3-8057
       Subsystem 1 - Part No SW: -----------    HW: 454 001 701 15
       Serial number: 3576U000000DBAA4221I
       Subsystem 2 - Part No SW: -----------    HW: 454 000 801 15
       Serial number: 3586U0000001EB607218
       Subsystem 3 - Part No SW: -----------    HW: 454 801 801 15
       Serial number: 3516R426B98050000001
       Subsystem 4 - Part No SW: -----------    HW: 454 801 001 15
       Serial number: 3526R94B0B5050000002
       Subsystem 5 - Part No SW: -----------    HW: 454 800 112 14
       Serial number: 3556V4CE63F05000000N
       Part No SW: 3Q0 953 521 P    HW: 5Q0 953 569 A
       Revision: FF032032    Serial number: 20150118400537
       Coding: 0410
       ROD: EV_SMLSVALEOMQB.rod
       VCID: 3D273A8F7DFE197FE21-8069
       Part No SW: 3G0 920 751     HW: 3G0 920 751
       Component: KOMBI         308 4311
       Coding: 07A509182F84000800886A001000000000000000
       VCID: 629DA9F3A4C00687BF3-8037
       Revision: --------    Serial number: 20011510800403
       Coding: 0B0300344F087300EF00025A1C0F00010001070000000000000000000000
       ROD: EV_GatewConti_011.rod
       VCID: 72BDD9B374209607CF3-8027
       Component: E221__MFL-DC1  H16 0040
       Serial number: 27150000062210065032
       Coding: 2DFFFF
       Serial number: 2138345403
       Power Converter DC AC:
       Subsystem 4 - Part No SW: 5Q0 907 155 C    HW: 5Q0 907 155 C
       Component: WECHSELRICHTE  H54 0033
       Serial number: 0021927
       Analog clock:
       Subsystem 5 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
       Component: Analoguhr  111 1004
       Serial number: 0901201500010876
       Serial number: 15000000514017
       Coding: 0800000000000000
       ROD: EV_ELVMarquMQBB.rod
       VCID: 71BFD6BF7126AD1F369-8025
       Part No SW: 5Q4 959 593 D    HW: 5Q4 959 593 B
       Component: TSG FS        009 0016
       Serial number: 0000133380092
       Coding: 00350B20D000020000001000
       VCID: 46D5556328285AA7B3B-8013
       Subsystem 1 - Part No SW: 5Q4 959 812 E    HW: 5Q4 959 812 E  Labels: 5QX-959-81X-V1.CLB
       Serial number: 00000000000000686007
       Part No SW: 5Q0 909 143 K    HW: 5Q0 909 143 E
       Component: MQB_PP_APA    203 2033
       Revision: 00000000    Serial number: 0000110887
       Coding: 01000010005000
       ASAM Dataset: EV_SteerAssisVWBSMQBA 008027
       ROD: EV_SteerAssisVWBSMQBA_008_VW41.rod
       VCID: 3B23349763EA174FDC5-806F
       Part No SW: 5Q4 959 592 C    HW: 5Q4 959 592 B
       Component: TSG BFS       009 0015
       Serial number: 0000133416144
       Coding: 00350120DC00020000001000
       VCID: 44D14F6B1E1468B7ADF-8011
       Subsystem 1 - Part No SW: 5Q4 959 811 E    HW: 5Q4 959 811 E  Labels: 5QX-959-81X-V1.CLB
       Serial number: 00000000000000724269
       Coding: 090000
       Coding: 039A00000F200200
       Shop #: WSC 54950 001 1048576
       ROD: EV_HeadlRegulAFSMQBMLB.rod
       VCID: 3FDB408777F20B6FF0D-806B
       Subsystem 1 - Part No SW: 7PP 941 572 A    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
       Component: LED LeiMo li.  H07 0001
       Coding: E02400
       Subsystem 2 - Part No SW: 7PP 941 572 A    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
       Component: LED LeiMo re.  H07 0001
       Coding: E02400
       Subsystem 3 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: 3D0-941-329.CLB
       Component: LeiMo links  H02 0003
       Coding: E02400
       Subsystem 4 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _  Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H02 0003
       Coding: E02400
       Part No SW: 3Q0 035 864     HW: 3Q0 035 864
       Component: MU-S-N-ER     H10 0138
       Serial number: VWZAZ2R8513399
       Coding: 02840201FF00000011110001000808031F0100C4012001008F
       Shop #: WSC 33167 001 1048576
       ASAM Dataset: EV_MUStd4CTSAT 001018
       ROD: EV_MUStd4CTSAT_VW48.rod
       VCID: 6E85CDC36018B2E72BB-803B
       Component: ABT_Std-2_Nav  H42 1017
       Serial number: VWZ8Z9RD800TYE
       Subsystem 2 - Part No SW: 3G0 919 866 E    HW: -----------
       Component: ECE 2015  --- 0335
    6179 - Display Module 1 for Multimedia System
              B1297 F6 [008] - Cable for Video Signal; Open Circuit
                        Reset counter: 215
                        Mileage: 159331 km
                        Date: 2020.01.17
                        Time: 15:09:28
                        Voltage terminal 30: 11.9 V
    3086 - Antenna for Telephone Mount
              B1564 01 [008] - Electrical Failure
                        Reset counter: 214
                        Mileage: 159208 km
                        Date: 2020.01.17
                        Time: 10:31:44
                        Voltage terminal 30: 14.3 V
                        Status of telephone-Antenna diagnostic: OK
                        Status of telephone-Telephone baseplate diagnostic: not connected
                        Status of telephone-Handset in handset holder (cradle): not selected
                        Status of telephone-Handset holder (cradle): not connected
       Part No SW: 5Q0 907 383 E    HW: 5Q0 907 383 B
       Component: Anhaenger     H14 0137
       Revision: 8C001001    Serial number: 0356539696
       Coding: 0100000202000000
       VCID: 392F2E9F69D6255FCE9-806D
    136203 - Supply Voltage
              P1757 00 [009] - Open Circuit
                        Fault Frequency: 30
                        Reset counter: 177
                        Mileage: 159067 km
                        Date: 2020.01.15
                        Time: 18:45:41
       Part No SW: 3Q0 980 653 C    HW: 3Q0 980 653
       Component: MQB_B_MFK     H08 0061
       Serial number: 14011511P10330
       Coding: 0004080200000401002213458040A100110004200020
       VCID: 363525A358C8CA2723B-8063
    End----------(Elapsed Time: 01:59, VBatt start/end: 12.3V/12.3V)-----------
    00071F46C24102FF4BE44004001C0708188000000000000000000000 0000
    00071B46C24102FF4BE44004001C0708188000000000000000000000 0000
    Interesting, because the stock value of 7 in bits 0~2 of byte 2 does not appear to be a defined configuration, either in the label file or in experimental coding for this module. I'm not sure what to tell you here.
    Nov 2018
    Europe - Hungary
    This is not my own car. This is a client car who want to activate the DLA.
    If I check the autoscan.txt I can see the 09 and A5 WSC code is not default.
    So the guy tried to activate the HBA (I think clone cable) and the high beam didn't work when he came to me.
    In the long code helper there was only 3 possibility 09 ECU byte02.
    - halogen lamp
    - xenon with out HBA
    - xenon with HBA
    I don't know which is a correct value.
    Jun 2017
    You should not use non-experimantal labels anymore here. They are not well maintained for such things.
    Dec 2016
    DE
    I'm a bit confused. What do you want to active - HBA or DLA? These do not feature the same functionality.
