Greetings from a cold but sunny Wales
Hello guys
I'm a new member but have had a HEX-USB+CAN since 2013 when I had an 8P S3. I fooled about with it for a while then sold the car for a Mercedes (big mistake).
Now I've bought a 2015 RSQ3 and have revived the cable, although I'm considering upgrading to a HEX-NET as I'd rather use my iPad than messing about with a Windows laptop (dyed-in-the-wool Mac user here).
Here's the complete scan for anyone that's interested:
**EDIT** Re-scanned after updating the software
Hello guys
Monday,20,January,2020,09:39:51:64646
VCDS Version: 19.6.2.0 (x64)
VIN: WUAZZZ8U8GR900937 License Plate:
Chassis Type: 8U-AU21 (8U0)
Scan: 01 02 03 08 09 10 15 16 17 19 20 22 25 42 44 46 52 55 56 5F
62 6C 6D 72
VIN: WUAZZZ8U8GR900937 Mileage: 84620km-52580miles
Address 01: Engine (------CZGA) Labels:. 07K-907-309-V1.clb
Part No SW: 8U0 907 404 B HW: 07K 907 309 D
Component: 2.5l R5/4V TF H54 0005
Revision: NIH54---
Coding: 32250032252601032600
Shop #: WSC 00049 770 00163
ASAM Dataset: EV_ECM25TFS0118U0907404B 001006
ROD: EV_ECM25TFS011_AU21.rod
VCID: 377B64F48EB102F756-8062
Address 02: Auto Trans (J743) Labels:. 0BH-927-711.clb
Part No SW: 0BH 300 012 S HW: 0BH 927 711 G
Component: DSG DQ500-7A H11 5201
Revision: 00H11V01
VCID: 336350E49AC9EED76A-8066
Address 03: ABS Brakes (J104) Labels: 5N0-614-109-V1.clb
Part No SW: 8U0 614 109 H HW: 8U0 614 109 G
Component: ESC-EBC460iV1 H10 0513
Serial number: A00VNK7
Coding: 21F124A1EB20C36C2080840324CAD7C304344700508B4881
ASAM Dataset: EV_Brake1ESCEPBTRW 006353
ROD: EV_Brake1ESCEPBTRW_006.rod
VCID: 3A7D7DC0BDA31F9FA9-806E
0799 - Databus
Reset counter: 225
Mileage: 84306 km
Additional_Codes: 00 00 00 0A BA 7F 40 0F 0A
DTC: 00 03 1F
Additional2: 00 04 00 05 05 00 32 00 32 00
Part No SW: 8U0 820 043 G HW: 8U0 820 043 G
Component: E87 Klimavoll 0210
Revision: 00H05000 Serial number: 8U0820043G
VCID: 35676EFC5CBDF0E744-8060
Fault Status: 00101010
Fault Frequency: 7
Reset counter: 226
Mileage: 84326 km
Date: 2020.01.18
Time: 10:01:05
Temperature: 2.5∞C
Reset counter: 226
Mileage: 84326 km
Date: 2020.01.18
Time: 10:02:52
Temperature: 2.5∞C
Address 09: Cent. Elect. (J519) Labels:. 8X0-907-063.clb
Part No SW: 8X0 907 063 AK HW: 8X0 907 063 AB
Component: BCM PQ35 M 113 0827
Revision: AC113817
Coding: 0E000A2CA805F1C0201849C80184014C43F327AA006F812BE400878400C1
Shop #: WSC 64951 003 1048576
VCID: 0507DE3C8CDDA06794-8050
Subsystem 1 - Part No SW: 8U2 955 119 HW: 8U2 955 119 Labels: 1KX-955-119.CLB
Component: WWS316 150711 H37 0090
Serial number: 150726015936
Coding: 0047F7
Component: G397_RLFS H06 0004
Serial number: 20330110
Coding: 02006E
Subsystem 3 - Part No: 8X0 951 177 A
Component: Sensor, DWA 0 005 0002
Address 10: Park/Steer Assist (J446) Labels:| 8X0-919-475.clb
Part No SW: 8X0 919 475 AD HW: 4H0 919 475 AG
Component: PARKHILFE 8K H01 0070
Revision: 11001001 Serial number: 61061526100942
Coding: A8C30B
ASAM Dataset: EV_EPHVA18AU21X0000 003008
ROD: EV_EPHVA18AU21X0000_003.rod
VCID: 0819D708B3CFBD0FEF-805C
Address 15: Airbags (J234) Labels:| 8X0-959-655.clb
Part No SW: 8U0 959 655 D HW: 8U0 959 655 D
Component: AirbagVW-AU10 H10 0910
Serial number: 003S0R0CJER1
Coding: 31353232343030303030554A305238553053
Shop #: WSC 00049 770 00117
ASAM Dataset: EV_AirbaAU10SMEAU316 001010
ROD: EV_AirbaAU10SMEAU316_001.rod
VCID: 48991708F34F7D0F2F-801C
Subsystem 1 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3496KSME57616C39ZZZ2
Subsystem 2 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3506KSME772D293AZZZ+
Subsystem 3 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3516KSME53616C39ZZZY
Serial number: 3526KSME2617293AZZZU
Subsystem 5 - Part No SW: 8U0 959 651 HW: 8U0 959 651
Serial number: 3555USME392C5439ZZZ6
Address 16: Steering wheel (J527) Labels:| 8X0-953-569.clb
Part No SW: 8X0 953 521 AF HW: 5K0 953 569 BD
Component: LENKS.MODUL 018 0230
Revision: FF010018 Serial number: 20150922200830
Coding: 1894204000
ROD: EV_SMLSNGVOLWSR8C.rod
VCID: 0009CF289BFF854FA7-8054
Subsystem 1 - Part No SW: 8U0 951 528 H HW: 8U0 951 528 H
Serial number: 26 08 2015 B0067810
Address 17: Instruments (J285) Labels:| 8X0-920-xxx-17.clb-SRI1
Part No SW: 8U0 920 990 J HW: 8U0 920 990 J
Component: KOMBI_COLOUR H01 0370
Coding: 44CF01
ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04399
VCID: 44810338CF67596FC3-8010
Address 19: CAN Gateway (J533) Labels: 8X0-907-468.clb
Part No SW: 8U0 907 468 AQ HW: 8U0 907 468 G
Component: GAT 4CAN 1L M H13 0090
Revision: 1P140041 Serial number: 4141P159050313
Coding: FBCF1060000108610353
VCID: 112FFA6CC895FCC738-8044
Subsystem 1 - Part No SW: 8U0 915 181 A HW: 8U0 915 181 A
Component: J367-BDM H08 0190
Serial number: 52237509032981518209
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Component: J532_DCDCStab H17 0042
Serial number: 15258001978021200181
Address 20: High Beam Assist. (J844) Labels:| 8S0-857-511.clb
Part No SW: 8S0 857 511 G HW: 8S0 857 511 C
Component: FLA H09 0003
Revision: AA001001
Coding: 040401F400000100010000
ASAM Dataset: EV_HighBeamAssisAU316 001004
ROD: EV_HighBeamAssisAU316.rod
VCID: 3D7776DCAC8D28A78C-8068
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0AY 907 554 M HW: 0CQ 525 130
Component: Haldex4Motion H52 7542
Serial number: HA1-00023.04.15
Coding: 0001
VCID: 55A7CE7C34FDD0E7A4-8000
Component: IMMO H01 0370
Coding: 000002
ASAM Dataset: EV_Immo_UDS_VDD_AU10 A04113
ROD: EV_Immo_UDS_VDD_AU10.rod
Address 42: Door Elect, Driver (J386) Labels:. 8X0-959-793.clb
Part No SW: 8X0 959 793 H HW: 8X0 959 793 H
Component: TSG FA H11 0415
Coding: 011806201C01000000
VCID: 52AD35600D13C7DF41-8006
Part No: 5N0 909 144 R
Component: EPS_ZFLS Kl. 302 3501
Revision: 00H22000
Shop #: WSC 00049 770 00151
VCID: 40890F28137F454FE7-8014
Address 52: Door Elect, Pass. (J387) Labels:. 8X0-959-792.clb
Part No SW: 8X0 959 792 H HW: 8X0 959 792 H
Component: TSG BF H11 0415
Coding: 011806201E01000000
VCID: 51AF3A6C0815BCC778-8004
Address 55: Headlight Range (J745) Labels:| 5M0-907-357-V3.clb
Part No SW: 5M0 907 357 G HW: 7P6 907 357 B
Component: AFS-ECU H01 0031
Coding: 08AE00102B230200
ASAM Dataset: EV_HeadlRegulLEDAFSPt 001001
ROD: EV_HeadlRegulLEDAFSPt.rod
VCID: 387967C883AF0D8F5F-806C
Subsystem 1 - Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H09 0003
Coding: E02500
Subsystem 2 - Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H09 0003
Coding: E02500
Subsystem 3 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M Labels: 3D0-941-329.CLB
Component: LeiMo links H01 7050
Coding: E02500
Subsystem 4 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 7050
Coding: E02500
Part No SW: 4G0 035 061 Q HW: 4G0 035 061
Component: Radio U DAB H60 0150
Revision: AB001007 Serial number: 109IQ0F2501152
Coding: 010105020100000002
VCID: 2B5348844AF9B61722-807E
Part No SW: 8U1 035 670 A HW: 8U1 035 670
Component: H-BNT-EU H41 0939
Revision: -------- Serial number: 486I30F7510951
Coding: 21010106030AA0EB0580033600000001000000000000000000
VCID: 346153F897C7E9EF73-8060
Subsystem 1 - Part No: 8R0 060 884 CR
Component: EUR 2015 2102
Subsystem 2 - Part No SW: 8U0 919 604 A HW: 8U0 919 604 A
Component: DU High AU316 H43 0018
Serial number: AUZ8ZDFCR000HE1
Subsystem 3 - Part No: 8R0 060 961 G
Component: CD-Database 6208
Reset counter: 227
Mileage: 84596 km
Date: 2020.01.19
Time: 12:36:23
Bin. Bits: 00000000 10000000
Bin. Bits: 00000000 00000000
Part No SW: 8X0 959 795 C HW: 8X0 959 795 C
Component: TSG HL H08 0415
Coding: 010006200001000000
VCID: 4FAB3C141E21AA376E-801A
Address 6C: Back-up Cam. Labels: 4H0-907-441.clb
Part No SW: 8U0 907 441 HW: 8U0 907 441
Component: SG Rueckfahrkamera 0031
Revision: --H09--- Serial number: 525 PA8JA7H2O8
Coding: 1080015
VCID: 76E5A9F0013BBBFF8D-8022
Address 6D: Trunk Elect. (----) Labels:* Redir Fail!
Part No SW: 8U0 959 107 HW: 8U0 959 107
Component: HDSG-Modul H01 0549
Revision: 15001001 Serial number: 227500053
Coding: 183307C002
ASAM Dataset: EV_HDSGAU316 001001
ROD: EV_HDSGAU316.rod
VCID: 7CF1BBD8F717E1AFFB-8028
0128 - Closing Assistance Closed
B113E F1 [008] - Implausible Signal
Fault Frequency: 27
Reset counter: 40
Mileage: 84306 km
Date: 2019.12.11
Time: 16:00:30
Voltage terminal 30: 12.15 V
Component: TSG HR H08 0415
End-------------------------(Elapsed Time: 04:25)--------------------------
