Results 1 to 7 of 7
Thread: Greetings from a cold but sunny Wales 🏴󠁧󠁢󠁷󠁬󠁳󠁿
    Verified VCDS User Maximum_RnB's Avatar
    Jan 2020
    Wales, UK
    Hello guys
    I'm a new member but have had a HEX-USB+CAN since 2013 when I had an 8P S3. I fooled about with it for a while then sold the car for a Mercedes (big mistake).
    Now I've bought a 2015 RSQ3 and have revived the cable, although I'm considering upgrading to a HEX-NET as I'd rather use my iPad than messing about with a Windows laptop (dyed-in-the-wool Mac user here).
    Here's the complete scan for anyone that's interested:
    **EDIT** Re-scanned after updating the software
    Monday,20,January,2020,09:39:51:64646
    VCDS Version: 19.6.2.0 (x64)
    VIN: WUAZZZ8U8GR900937   License Plate:
    Chassis Type: 8U-AU21 (8U0)
    Scan: 01 02 03 08 09 10 15 16 17 19 20 22 25 42 44 46 52 55 56 5F
              62 6C 6D 72
    VIN: WUAZZZ8U8GR900937   Mileage: 84620km-52580miles
    Address 01: Engine (------CZGA)       Labels:. 07K-907-309-V1.clb
       Part No SW: 8U0 907 404 B    HW: 07K 907 309 D
       Component: 2.5l R5/4V TF H54 0005
       Revision: NIH54---
       Coding: 32250032252601032600
       Shop #: WSC 00049 770 00163
       ASAM Dataset: EV_ECM25TFS0118U0907404B 001006
       ROD: EV_ECM25TFS011_AU21.rod
       VCID: 377B64F48EB102F756-8062
       Part No SW: 0BH 300 012 S    HW: 0BH 927 711 G
       Component: DSG DQ500-7A  H11 5201
       Revision: 00H11V01
       VCID: 336350E49AC9EED76A-8066
    Address 03: ABS Brakes (J104)       Labels: 5N0-614-109-V1.clb
       Part No SW: 8U0 614 109 H    HW: 8U0 614 109 G
       Component: ESC-EBC460iV1 H10 0513
       Serial number: A00VNK7
       Coding: 21F124A1EB20C36C2080840324CAD7C304344700508B4881
       VCID: 3A7D7DC0BDA31F9FA9-806E
    0799 - Databus
                        Fault Frequency: 6
                        Reset counter: 225
                        Mileage: 84306 km
                        Additional_Codes: 00 00 00 0A BA 7F 40 0F 0A
                        DTC: 00 03 1F
                        Additional2: 00 04 00 05 05 00 32 00 32 00
       Part No SW: 8U0 820 043 G    HW: 8U0 820 043 G
       Component: E87  Klimavoll      0210
       Revision: 00H05000    Serial number: 8U0820043G
       VCID: 35676EFC5CBDF0E744-8060
                        Fault Status: 00101010
                        Fault Frequency: 7
                        Reset counter: 226
                        Mileage: 84326 km
                        Date: 2020.01.18
                        Time: 10:01:05
                        Temperature: 2.5∞C
                        Reset counter: 226
                        Mileage: 84326 km
                        Date: 2020.01.18
                        Time: 10:02:52
                        Temperature: 2.5∞C
    Address 09: Cent. Elect. (J519)       Labels:. 8X0-907-063.clb
       Part No SW: 8X0 907 063 AK    HW: 8X0 907 063 AB
       Component: BCM PQ35  M   113 0827
       Revision: AC113817
       Coding: 0E000A2CA805F1C0201849C80184014C43F327AA006F812BE400878400C1
       Shop #: WSC 64951 003 1048576
       VCID: 0507DE3C8CDDA06794-8050
       Subsystem 1 - Part No SW: 8U2 955 119     HW: 8U2 955 119   Labels: 1KX-955-119.CLB
       Component: WWS316 150711  H37 0090
       Serial number:         150726015936
       Coding: 0047F7
       Serial number: 20330110
       Coding: 02006E
       Subsystem 3 - Part No: 8X0 951 177 A
       Component: Sensor, DWA 0  005 0002
    Address 10: Park/Steer Assist (J446)       Labels:| 8X0-919-475.clb
       Part No SW: 8X0 919 475 AD    HW: 4H0 919 475 AG
       Component: PARKHILFE 8K  H01 0070
       Revision: 11001001    Serial number: 61061526100942
       Coding: A8C30B
       ASAM Dataset: EV_EPHVA18AU21X0000 003008
       ROD: EV_EPHVA18AU21X0000_003.rod
       VCID: 0819D708B3CFBD0FEF-805C
    Address 15: Airbags (J234)       Labels:| 8X0-959-655.clb
       Part No SW: 8U0 959 655 D    HW: 8U0 959 655 D
       Component: AirbagVW-AU10 H10 0910
       Serial number: 003S0R0CJER1
       Coding: 31353232343030303030554A305238553053
       Shop #: WSC 00049 770 00117
       ASAM Dataset: EV_AirbaAU10SMEAU316 001010
       ROD: EV_AirbaAU10SMEAU316_001.rod
       VCID: 48991708F34F7D0F2F-801C
       Subsystem 1 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
       Serial number: 3496KSME57616C39ZZZ2
       Subsystem 2 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
       Serial number: 3506KSME772D293AZZZ+
       Subsystem 3 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
       Serial number: 3516KSME53616C39ZZZY
       Serial number: 3526KSME2617293AZZZU
       Subsystem 5 - Part No SW: 8U0 959 651     HW: 8U0 959 651
       Serial number: 3555USME392C5439ZZZ6
    Address 16: Steering wheel (J527)       Labels:| 8X0-953-569.clb
       Part No SW: 8X0 953 521 AF    HW: 5K0 953 569 BD
       Component: LENKS.MODUL   018 0230
       Revision: FF010018    Serial number: 20150922200830
       Coding: 1894204000
       ASAM Dataset: EV_SMLSNGVOLWSR8C 001001
       ROD: EV_SMLSNGVOLWSR8C.rod
       VCID: 0009CF289BFF854FA7-8054
       Serial number: 26 08 2015  B0067810
    Address 17: Instruments (J285)       Labels:| 8X0-920-xxx-17.clb-SRI1
       Part No SW: 8U0 920 990 J    HW: 8U0 920 990 J
       Component: KOMBI_COLOUR  H01 0370
       Coding: 44CF01
       VCID: 44810338CF67596FC3-8010
    Address 19: CAN Gateway (J533)       Labels: 8X0-907-468.clb
       Part No SW: 8U0 907 468 AQ    HW: 8U0 907 468 G
       Component: GAT 4CAN 1L M H13 0090
       Revision: 1P140041    Serial number: 4141P159050313
       Coding: FBCF1060000108610353
       VCID: 112FFA6CC895FCC738-8044
       Subsystem 1 - Part No SW: 8U0 915 181 A    HW: 8U0 915 181 A
       Component: J367-BDM  H08 0190
       Serial number: 52237509032981518209
       Serial number: 15258001978021200181
    Address 20: High Beam Assist. (J844)       Labels:| 8S0-857-511.clb
       Part No SW: 8S0 857 511 G    HW: 8S0 857 511 C
       Component: FLA           H09 0003
       Revision: AA001001
       Coding: 040401F400000100010000
       ASAM Dataset: EV_HighBeamAssisAU316 001004
       ROD: EV_HighBeamAssisAU316.rod
       VCID: 3D7776DCAC8D28A78C-8068
       Part No SW: 0AY 907 554 M    HW: 0CQ 525 130
       Component: Haldex4Motion H52 7542
       Serial number: HA1-00023.04.15
       Coding: 0001
       VCID: 55A7CE7C34FDD0E7A4-8000
       Component: IMMO          H01 0370
       Coding: 000002
       ROD: EV_Immo_UDS_VDD_AU10.rod
    Address 42: Door Elect, Driver (J386)       Labels:. 8X0-959-793.clb
       Part No SW: 8X0 959 793 H    HW: 8X0 959 793 H
       Component: TSG FA        H11 0415
       Coding: 011806201C01000000
       VCID: 52AD35600D13C7DF41-8006
       Part No: 5N0 909 144 R
       Component: EPS_ZFLS Kl. 302    3501
       Revision: 00H22000
       Shop #: WSC 00049 770 00151
       VCID: 40890F28137F454FE7-8014
    Address 52: Door Elect, Pass. (J387)       Labels:. 8X0-959-792.clb
       Part No SW: 8X0 959 792 H    HW: 8X0 959 792 H
       Component: TSG BF        H11 0415
       Coding: 011806201E01000000
       VCID: 51AF3A6C0815BCC778-8004
    Address 55: Headlight Range (J745)       Labels:| 5M0-907-357-V3.clb
       Part No SW: 5M0 907 357 G    HW: 7P6 907 357 B
       Component: AFS-ECU       H01 0031
       Coding: 08AE00102B230200
       ASAM Dataset: EV_HeadlRegulLEDAFSPt 001001
       ROD: EV_HeadlRegulLEDAFSPt.rod
       VCID: 387967C883AF0D8F5F-806C
       Subsystem 1 - Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
       Component: LED LeiMo li.  H09 0003
       Coding: E02500
       Subsystem 2 - Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
       Component: LED LeiMo re.  H09 0003
       Coding: E02500
       Subsystem 3 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M  Labels: 3D0-941-329.CLB
       Coding: E02500
       Subsystem 4 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M  Labels: 3D0-941-329.CLB
       Coding: E02500
       Part No SW: 4G0 035 061 Q    HW: 4G0 035 061
       Component: Radio U DAB   H60 0150
       Revision: AB001007    Serial number: 109IQ0F2501152
       Coding: 010105020100000002
       VCID: 2B5348844AF9B61722-807E
       Part No SW: 8U1 035 670 A    HW: 8U1 035 670
       Component: H-BNT-EU      H41 0939
       Revision: --------    Serial number: 486I30F7510951
       Coding: 21010106030AA0EB0580033600000001000000000000000000
       VCID: 346153F897C7E9EF73-8060
       Subsystem 1 - Part No: 8R0 060 884 CR
       Component: EUR 2015  2102
       Subsystem 2 - Part No SW: 8U0 919 604 A    HW: 8U0 919 604 A
       Component: DU High AU316  H43 0018
       Serial number: AUZ8ZDFCR000HE1
       Subsystem 3 - Part No: 8R0 060 961 G
       Component: CD-Database  6208
                        Reset counter: 227
                        Mileage: 84596 km
                        Date: 2020.01.19
                        Time: 12:36:23
                        Bin. Bits: 00000000 10000000
                        Bin. Bits: 00000000 00000000
       Part No SW: 8X0 959 795 C    HW: 8X0 959 795 C
       Component: TSG HL        H08 0415
       Coding: 010006200001000000
       VCID: 4FAB3C141E21AA376E-801A
       Part No SW: 8U0 907 441     HW: 8U0 907 441
       Component: SG Rueckfahrkamera  0031
       Revision: --H09---    Serial number: 525 PA8JA7H2O8
       Coding: 1080015
       VCID: 76E5A9F0013BBBFF8D-8022
       Part No SW: 8U0 959 107     HW: 8U0 959 107
       Component: HDSG-Modul    H01 0549
       Revision: 15001001    Serial number: 227500053
       Coding: 183307C002
       ASAM Dataset: EV_HDSGAU316 001001
       ROD: EV_HDSGAU316.rod
       VCID: 7CF1BBD8F717E1AFFB-8028
    0128 - Closing Assistance Closed
              B113E F1 [008] - Implausible Signal
                        Fault Frequency: 27
                        Reset counter: 40
                        Mileage: 84306 km
                        Date: 2019.12.11
                        Time: 16:00:30
                        Voltage terminal 30: 12.15 V
       Component: TSG HR        H08 0415
    End-------------------------(Elapsed Time: 04:25)--------------------------
  2. Likes Uwe liked this post
  3. #2
    With a VCDS version that old on a car that new, all bets are off.
    Please post the scan with VCDS 19.6.2 (the current version) when available.
  4. Likes Maximum_RnB liked this post
  5. #3
    Jan 2020
    Wales, UK
    Thanks Dave, I guessed that. I've already updated the software and I'll rescan it later, once all the frost has melted off the car!
  6. Likes PetrolDave liked this post
  7. #4
    Jan 2020
    Wales, UK
    First post updated with new scan
  8. Likes Uwe liked this post
  9. #5
    Quote Originally Posted by Maximum_RnB View Post
    You can always use Parallels to create a Windows 10 virtual machine on your Mac - that's what I use on my MacBook to run VCDS (but I do also have a Windows 10 tablet as a backup).
    The message that extended fault detail isn't available which you're seeing on the ABS is because the HEX-CAN isn't capable of handling some of the new longer CAN messages that VAG are using on newer cars. Since you're now "back in the fold" seems like upgrading to a HEX-NET might be a good idea (BTW you can use the HEX-NET either via USB or WiFi).
  10. #6
    Jan 2020
    Wales, UK
    There's an economical upgrade path too. Very tempting.
  11. Likes PetrolDave liked this post
  12. #7
    VCDS-Mobile is cool and has its place (particularly if you're on the road without a laptop) but it is not a 100% full-function replacement for the classic VCDS software.
    But don't let that discourage you from upgrading to a HEX-NET; a HEX-NET supports both VCDS-Mobile and the classic VCDS software.
  13. Likes PetrolDave, Maximum_RnB liked this post
