Hey guys, so I have a 2010 dsg gti.
After owning the car about 20k (bought at 90k) the car would sometimes bang three times into gear, when changing from neutral, drive or reverse. Another issue i had was periodically if I would creep forward, the car would engage in gear and then drop it, but it wouldn't rev, it would just get move a bit forward then harshly shudder and then it would proceed. After this going on for too long, I decided to do a dsg adaptation thru vcds.
after doing the procedure The transmission felt new and crisp again. shifts were faster, smoother, never hesitated again. The adaptation also cured the car banging into gear. a few days later maybe 100 miles in total, when in d mode. The car started to hang alot in 3rd gear, it did it a couple of times. i disregarded it as i was told this was fine after an adaptation.
this turned into an issue when it stay in third and never shift into fourth as i acceleerated.
when trying to shift into 4th from 3nd in manual mode it would never shift and i heard alot of clicking noise from the tranny with the window down.
i next moved onto the shoulder as my gear selector began blinking. Turned the car on and off and seemed to work fine till about an hour later it would shift fine 1st, 2nd and out of 2nd into third, but if i kept it in third for too long it would eventually just let go, gear selector would start blinking and free rev. after a couple of tries this would end bring up the error on vcds as unexpected mechanical disengagement.
when doing the basic adaptations,
Group 60 always seems to get back to the correct values,(13-0-4-1) but never switches to ON unlike all of the other steps in which do turn ON.
the rest of the procedure works fine.
i have redone the adaptations along with the correct driving procedure, i have also let the car learn by itself.
They both work flawlessly for a couple of miles but it always returns to the same issue.
Clearing all faults will instantly return the error 01087 - Basic Setting Not Performed
in addition to this i have also checked the speed sensors and their values to see if it something wasnt being read right.
i always end up in the same scenario.
i am not getting errors for any solenoids so i dont want to blame the mechatronics unit as the issue.
i am trying to pinpoint the issue here that is causing a fault in the transmission as it drives absolutely great for a few miles.
Friday,17,January,2020,20:05:44:33727
VCDS Version: 19.6.2.0 (x64) HEX-V2 CB: 0.4508.4
Address 02: Auto Trans Labels: 02E-927-770.CLB
Control Module Part Number: 02E 300 053 B HW: 02E 927 770 AL
Component and/or Version: GSG DSG AG6 511 2113
Software Coding: 0000020
Work Shop Code: WSC 01357 011 00200
VCID: 1471BE2E5273B4577DF-8040
19143 - Unexpected / Implausible Mechanical Gear Disengagement
P2711 - 005 - - Intermittent
Fault Status: 00100101
Fault Frequency: 255
Reset counter: 39
Mileage: 209447 km
Date: 2048.14.04
Time: 01:42:32
Reset counter: 60
Mileage: 209466 km
Date: 2048.14.04
Time: 08:07:43
P2711 - 004 -
Reset counter: 40
Mileage: 209466 km
Date: 2048.14.04
Time: 08:08:52
Sunday,19,January,2020,17:32:21:33727
VIN: WVWFD7AJ6AW344266 License Plate:
Mileage: 209460km-130152mi Repair Order:
Chassis Type: AJ-VW36 (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 2E 37 42 44 46 52 56 65 77
VIN: WVWFD7AJ6AW344266 Mileage: 209460km-130152miles
Address 01: Engine (CBF) Labels:. 06J-907-115-CBF.clb
Part No SW: 1K0 907 115 AL HW: 1K0 907 115 AK
Component: 2.0l R4/4V TFSI 0030
Revision: E3H21--- Serial number:
Coding: 040301081C070160
VCID: 70B9D2BE06AB2877397-8024
Readiness: 1110 1101
Part No SW: 02E 300 053 B HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2113
Revision: 51112 Serial number: 00001002231584
Reset counter: 60
Mileage: 209468 km
Date: 2014.06.11
Time: 03:35:36
Part No SW: 1K0 907 379 AJ HW: 1K0 907 379 AJ
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Coding: 114B600C492600FE880D06EA921F0041310800
VCID: 7AADF0965CD76227873-802E
Part No SW: 3C8 907 336 AJ HW: 3C8 907 336 AJ
Component: Climatic H14 0305
Revision: 00009001
Coding: 0000001002
ROD: EV_ClimaBasis_VW36.rod
VCID: 75B7E3AA75490D5FEA1-8020
Part No SW: 1K0 937 087 G HW: 1K0 937 087 G
Component: BCM PQ35 H+ 103 0576
Revision: 00103 AF
Coding: 6D180A3E90272A0480080081600005C443010086434D8D60648020200000
Shop #: WSC 08061 444 67066
VCID: 353723AA35494D5F2A1-8060
Subsystem 1 - Part No: 1K1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer 25021 21 0512
Coding: 009795
Part No SW: 5K0 959 655 B HW: 5K0 959 655 B
Component: AirbagVW10G 021 0706
Serial number: 003C4D0AP6ZM
Coding: 00003031
ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 392F2F9A19D1A93FCE9-806C
Subsystem 1 - Part No SW: 5K0 959 339 HW: 5K0 959 339
Component: BF-Gewichtss. 007 0002
Serial number: ---0000R--00052G2X00
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME014F4550ZZZR
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME1F772050ZZZV
Serial number: 3512QSME26084B3FZZZ/
Serial number: 3522QSME0A515023ZZZI
Component: F.Sens.Fahr --- ----
Serial number: 35527SME3A183720ZZZA
Component: F.Sens.Beif --- ----
Serial number: 35627SME0A183720ZZZ8
Part No SW: 1K0 953 549 CD HW: 1K0 953 549 CD
Component: J0527 056 0111
Coding: 0001632
VCID: 76B5E4A664CF0647E3B-8022
Subsystem 1 - Part No: 5K0 959 542 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H05 0010
Coding: 00000131
Part No SW: 5K6 920 970 H HW: 5K6 920 970 H
Component: KOMBI H03 0305
Coding: 270C00
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H07 0112
Revision: H07 01 Serial number: 240210F1000748
Coding: ED801F07400612000000
VCID: 698FBFDA2571D9BF7E9-803C
Component: IMMO H03 0305
VCID: 6A8DC0D62CF7D2A7773-803E
Part No SW: 5N0 035 342 B HW: 5N0 035 342 B
Component: SG EXT.PLAYER H13 0090
Revision: A1001003 Serial number: 7667850933
VCID: 2615F4E6F8EF36C793B-8072
Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
Part No SW: 3C0 035 684 C HW: 3C0 035 684 C
Component: RNS-MID H06 1000
Revision: AB001001 Serial number: VWZ6Z7K7061033
Coding: 04000400040000A600
VCID: 2313EDF28BDDC3EFF45-8076
Reset counter: 8
Mileage: 209464 km
Part No SW: 5K0 959 701 B HW: 5K0 959 701 B
Component: Tuer-SG 009 2111
Coding: 0001076
VCID: 313F17BACD21617F769-8064
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 74 3001
Revision: 00H17000
Part No SW: 5K0 959 702 B HW: 5K0 959 702 B
Coding: 0001076
VCID: 323D18B6C8275A670F3-8066
Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
Reset counter: 8
Mileage: 209464 km
Address 65: Tire Pressure (J502) Labels:. 1K0-937-08x-65.clb
Component: RDK 103 0521
Coding: 018704
02214 - Tire Pressure Warning
Mileage: 209468 km
Date: 2014.06.11
Time: 03:16:48
Text: 3451341284
Pressure: 0.00 bar
Pressure: 2.40 bar
Temperature: 52.4°C
Text: 00
Address 77: Telephone (J738) Labels:. 1K8-035-730.clb
Part No SW: 1K8 035 730 D HW: 1K8 035 730 D
Component: Telefon H08 6900
Revision: 00008000 Serial number: 00000330660514
Coding: 412100
VCID: 2A0D00D6ECF712A7B73-807E
End----------(Elapsed Time: 00:59, VBatt start/end: 14.1V/14.2V)-----------
Advanced Identification
Identification: TFK-030
Revision: 51112
Date: 23.02.10
Test stand number: 8501
Manufacturer number: 1584
Flash Status
Programming Attempts: 2
Successful Attempts: 2
Programming Status: 00000000
Required Conditions: 00000000
Flash Tool Code: 00200 011 01357
Flash Date: 00.14.00
Software
0017
Misc.
Hardware number: 02E 927 770 AL
Lot Number: F10
Type Lock: 0003
VCDS Info:
